NK236W
NK236W
    APEM(埃斐)
    插件,10x7.5mm
    滑动开关 插件,10x7.5mm 单刀双掷 2千次 直插
NK236W 数据手册
PANEL PCB SWITCHES -N NK series Subminiature slide switches DISTINCTIVE FEATURES The smallest changeover Flush and raised actuators Straight PC and right angle terminals ENVIRONMENTAL SPECIFICATIONS • Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F) • Moisture test : 21 days at 95 % RH (IEC 68-2-3) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 0.5 A 12 V • Minimum load : 1 mA 10 mV • Initial contact resistance : 20 mΩ max. • Insulation resistance : 10,000 MΩ min. at 500 VDC • Dielectric strength : 250 Vrms. 50 Hz min. between terminals 2,000 Vrms 50 Hz min. between adjacent poles of switches placed side by side • Electrical life with nominal load : 2,000 cycles • Capacitance : < 1.5 pF GENERAL SPECIFICATIONS • Hand soldering with lead-free alloy type SAC 305 (flux amount 2,2%): temperature 337-381°C. Standard application time is 3s. • End stackable, 2.54 (.100) terminal to terminal pitch - 4 switches max., hole dia. 1 mm (.039) • Travel : 1.6 mm (.062) EXAMPLES OF LAYOUT Ø1.00 (.039DIA) MATERIALS 2.54 (.100) 2.54 (.100) SW 08 23 K- • Case : PA6/6, glass filled, UL94-V0 • Actuator : PA6/6, glass filled, UL94-V0 • Contacts : gold over nickel APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. Ø0.80 - Ø1.00 (.031DIA - .039DIA) CNKLAY-A The company reserves the right to change specifications without notice. 1 Subminiature slide switches STRAIGHT PC TERMINALS I 1-3 II 1-2 II 2.60 (.102) I I ON - ON ON - ON 5.00 (.196) 3 1 2 2.54 (.100) 2.54 (.100) 2 1 3 Ø1.00 (.039 DIA) Ø0.60 (.023 DIA) 10.00 (.393) Raised actuator NK236H 0.50 (.019) 6.50 (.256) NK236 2 3 Flush actuator II 7.90 (.311) 1 RIGHT ANGLE TERMINALS II 1 2.60 (.102) I 3.70 (.146) - ON 10.00 (.393) Raised actuator NK236WH 2 2.54 (.100) ON - ON Ø0.60 (.023 DIA) 3 1 2 ON 0.50 (.019) NK236W II 2.54 (.100) 2 3 Flush actuator I 7.90 (.311) II 1-2 0.70 (.027) I 1-3 6.50 (.256) PCB SWITCHES NK series 2 1 3 Ø1.00 (.039 DIA)
NK236W 价格&库存
很抱歉,暂时无法提供与“NK236W”相匹配的价格&库存,您可以联系我们找货
NK236W
  • 5+45.76257
  • 50+43.93598
  • 125+42.10523
  • 250+41.31586
库存:70
