48ASSP3S1M2RBT
48ASSP3S1M2RBT
    GRAYHILLINC.
    插件,12.7x6.6mm
    滑动开关 插件,12.7x6.6mm 单刀双掷 直插
48ASSP3S1M2RBT 数据手册
Series 48A: Slide Switches SERIES 48A Slide Switches MODELS DIP Switches FEATURES • Save Space and Weight • SPDT and DPDT Circuitry • Choice of Actuators and Terminations In inches (and millimeters) TRAVEL .085 (2.16) SPDT SWITCH POSITION MODEL NO. SSP1 SSP2 SSP3 ON ON ON 2-1 TERM. COMM. NONE NONE OFF OPEN ON (ON) ON 2-3 .770 (19.56) .240 (6.10) TRAVEL .085 (2.16) TERM. COMM. SWITCH POSITION ON NONE ON OFF OPEN 2-3,5-6 ON ON 2-1,5-4 .770 (19.56) ()=MOMENTARY 02COMM. .152 (3.86) .155 (3.94) .250 (6.35) 3 4 Std 6 .080 (2.03) .200 (5.08) .450 (11.43) .030 (0.76) .200 (5.08) .185 (4.70) .152 (3.86) .250 (6.35) 6 3 5 2 4 1 .500 (12.70) .080 (2.03) .155 (3.94) .190 (4.83) SCHEMATIC In inches (and millimeters) S3 S2 .152 SQ. (3.86) EPOXY SEAL .690 (17.53) .240 (6.10) 05COMM. ACTUATOR OPTIONS S1 .500 (12.70) 2 Slide Switches 1 3 3 1 DPDT SDP1 SDP3 .260 (6.60) 1 02COMM. MODEL NO. .030 (0.76) .185 (4.70) .200 (5.08) .690 (17.53) ()=MOMENTARY SCHEMATIC EPOXY SEAL .152 SQ. (3.86) .285 (7.24) S4 .152 SQ. (3.86) .370 (9.40) .152 SQ. (3.86) .140 (3.56) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com H-4 Series 48A: Slide Switches ACTUATOR OPTIONS S5 In inches (and millimeters) For DPDT Only S6 S7 .152 SQ. (3.86) .152 SQ. (3.86) T1 For DPDT Only .152 SQ. (3.86) .152 (3.86) .325 (8.26) .040 (1.02) .485 (12.32) TERMINATION OPTIONS M1 M2 M3 .189 (4.80) .250 PC mount (6.36) terminals .080 (2.03) supplied without .050 mounting tabs THK. .030 (0.76) (1.27) standard. THK. .030 (0.76) .186 (4.72) .152 .125 (3.18) (3.86) .185 (4.70) .046 (1.17) SPDT .260 (6.60) 2 .106 (2.69) 3 .520 (13.21) .375 (9.53) Slide Switches .030 (0.76) 4 5 6 1 2 3 .106 (2.69) .500 (9.53) .150 (3.81) .185 (4.70) DPDT M7 4 .050 (1.27) EPOXY SEAL .186 (4.72) Right Angle P.C. Mount, Vertical Actuation .050 (1.27) SPDT H-5 1 2 Ø.073 (Ø1.85) .500 (12.70) .520 (13.21) .014 (0.36) .260 (6.60) .520 (13.21) Ø.073 (Ø1.85) 2 .500 (12.70) .400 (10.16) .046 (1.17) .030 (0.76) .150 (3.81) 1 3 .014 (0.36) .400 (10.16) .150 (3.81) 3 .106 2.69 .152 (3.86) .520 (13.21) .185 (4.70) .450 (11.43) 1 .185 (4.70) Ø.073 (Ø1.85) .014 (0.36) .500 (12.70) EPOXY SEAL .046 (1.17) .062 (1.57) .030 (0.76) THK. .375 (9.53) .050 (1.27) .186 (4.72) .152 (3.86) .125 (3.18) .250 (6.35) .500 (12.70) 1 .030 (0.76) P.C. Mount, Quick Connect EPOXY SEAL .189 (4.80) M6 Right Angle P.C. Mount, Horizontal Actuation P.C. Mount (Std) .156 (3.96) .078 (1.98) .047 (1.19) .200 (5.08) In inches (and millimeters) Solder Lug Solder lug terminals supplied with mounting tabs standard. .310 (7.88) .150 (3.81) .175 (4.45) .175 (4.45) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 48A: Slide Switches TERMINATION OPTIONS In inches (and millimeters) EPOXY SEAL .186 (4.72) DPDT .190 (4.83) .450 (6.60) .106 (2.69) 2 .150 (3.81) Ø.073 (Ø1.85) 3 .500 (12.70) 1 .150 (4.83) V2 5 4 .014 (0.36) .500 (12.70) .030 (0.76) .152 (3.86) 1 .186 (4.72) 2 3 .014 (0.36) .181 (4.60) .125 (3.18) .175 (4.45) .125 (3.18) .350 (8.90) SPDT .106 .175 (2.69) (4.45) .150 (3.81) .314 (8.00) .046 (1.17) .500 (12.70) .046 (1.17) Vertical Bracket P.C. Mount .152 (3.86) 6 .185 (4.70) .620 (15.75) .030 (0.76) .185 (4.70) DIP Switches .152 (3.86) Ø.073 (Ø1.85) .620 (15.75) .152 (3.86) .152 (3.86) .492 (12.50) .125 (3.18) .314 (8.00) .400 (10.16) 4 5 .186 (4.72) .046 (1.17) .125 (3.18) SPECIFICATIONS Ø.073 (Ø1.85) .190 (4.83) .620 (15.75) Contact Resistance: 10 milliohms max. initial @ 2-4 VDC, 100 mA Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,000 V RMS @ sea level Operating Temperature: -30°C to 85°C MATERIALS Case: Diallyl phthalate (DAP) (UL94V-0) Housing: Stainless steel Slide Handle: Nylon Terminal Seal: Epoxy Slide Switches RATINGS Contact Rating: Q option - 5A with resistive load @ 125 VAC or 28 VDC; 2A with resistive load @ 250 VAC. R option - 0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 30,000 cycles at full load .030 (0.76) .185 (4.70) .184 (4.67) .620 (15.75) 6 .014 (0.36) DPDT .185 (4.70) ORDERING INFORMATION SERIES MODEL NO. ACTUATOR TERMINATION CONTACT SEAL 48A SSP1 S2 M6 R E 48A = Slide Switches Options: SSP1, SSP2, SSP3, SDP1, SDP3 (see models for switching positions) Options: S1, S2, S3, S4, S5, S6, S7, T1 (see actuator options) Options: M1, M2, M3, M6, M7, V2 (see termination options) Example Part Number: 48ASSP1S2M6RE R = Copper alloy, gold plate over nickel plate. E = Epoxy seal Q = Copper alloy, silver plated. Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com H-6
48ASSP3S1M2RBT 价格&库存
很抱歉,暂时无法提供与“48ASSP3S1M2RBT”相匹配的价格&库存,您可以联系我们找货
48ASSP3S1M2RBT
  • 1+57.082041+7.38444
