25000N series
Professional slide switches
Distinctive features and specifications
❑ Professional grade slide switches for PC boards
❑ Approved according to UL 1054
❑ Wave solderable
Not washable in aqueous process
❑ Available with flush, high and side actuator
❑ Various actuator lengths
ELECTRICAL SPECIFICATIONS
MATERIALS
• Max. current/voltage rating with resistive load :
- silver contacts (A) : 2A 250VAC - 4A 125VAC - 1A 30VDC
- gold plated brass contacts (LD) : 100mA 30VDC
• Minimum load :
- silver contacts (A) : 100mA 10V
- gold plated brass contacts (LD) : 10µA 5VDC - 10mA 50mV
• Initial contact resistance :
- silver contacts (A) : 10mΩ max.
- gold plated brass contacts (LD) : 50mΩ max.
• Insulation resistance : 1.000 MΩ min. at 500VDC
• Dielectric strength :
1.000 Vrms 50 Hz min. between terminals
2.000 Vrms 50 Hz min. between poles
2.000 Vrms 50 Hz min. between terminals and frame
• Electrical life : 10.000 cycles at full load
• Low level or mechanical life : 20.000 cycles
APPROVALS
E
GENERAL SPECIFICATIONS
Availability : consult factory for details of approved models.
Marking : To order switches marked UL, complete the “Options and
Approvals” box of ordering format.
APEM
• Case : PBT
• Actuator : polyamide, glass
filled
• Cover : polyamide, glass filled
• Contacts
A : silver
LD : brass, gold plated
• Terminal seal : epoxy
www.apem.com
• Operating temperature :
-40°C to +85°C
• Overall length : 14 mm (.551)
• Actuator height (outside case) :
- high : 2,80 mm (.110)
- extra high : 6 mm (.236)
- side : 2,3 mm (.090)
- long side : 6 mm (.236)
• Travel : 4 mm (.157)
E-15
25000N series
Overview
N
25
Actuator and terminals
SERIES
1
4
3
5
Flush or high actuator,
terminal spacing
2,54 (.100)
terminal spacing
5,08 (.200)
Side actuator, terminal
spacing 2,54 (.100)
spacing 5,08 (.200)
Number of poles
3
4
Single pole
Double pole
Contact materials
E
Electrical functions
6
9
ON
ON
OFF
Version
N
For all models
ON
ON
Options and approvals
Actuator
A Silver
LD Gold plated brass
B
H
H6
Blank
6
Flush
High
Extra high
Side
Long side
X601
F
Special contact :
lower rating
Tin dipped terminals
Other : see following pages.
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches (including actuator options)
- contact options
Dimensions : first dimensions are in mm while inches are shown as bracketted numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
Packaging unit : single pole : 100 pieces - double pole : 50 pieces
E-16
www.apem.com
APEM
25000N series
• Epoxy sealed terminals standard
• 1 and 2 pole configurations
• UL approved models : see next page.
MODEL
STRUCTURE
Flush actuator : 25000NB
2.54
(.100)
Terminal spacing
5,08 (.200)
Single pole
25436N B
25439N B
Double pole
25146N B
25149N B
Double pole
25446N B
25449N B
0.60
(.023)
12.50
(.465)
8.10
(.318)
Single pole
25136N B
25139N B
14.10
(.555)
3.80
(.149)
7.50
(.295)
0.50
(.019)
EPOXY
Ø1.10
(.043DIA)
2.54
(.100)
Terminal spacing
2,54 (.100)
0.60
(.023)
2.54
(.100)
5.08
(.200)
5.08
(.200)
E
Single pole
25436N H
25439N H
Double pole
25146N H
25149N H
Double pole
25446N H
25449N H
3.00
(.118)
0.60
(.023)
0.50
(.019)
5.08
(.200)
Single pole
25136N H
25139N H
3.00
(.118)
12.50
(.465)
2.80
(.110)
Terminal spacing
5,08 (.200)
14.10
(.555)
8.10
(.318)
3.80
(.149)
Terminal spacing
2,54 (.100)
7.50
(.295)
EPOXY
Ø1.10
(.043DIA)
5.08
(.200)
High actuator : 25000NH
0.60
(.023)
5.08
(.200)
5.08
(.200)
5.08
(.200)
Double pole
25146N H6
25149N H6
Double pole
25446N H6
25449N H6
3.00
(.118)
3.00
(.118)
0.60
(.023)
12.50
(.465)
0.50
(.019)
5.08
(.200)
5.08
(.200)
Single pole
25436N H6
25439N H6
14.10
(.555)
6.00
(.236)
Single pole
25136N H6
25139N H6
7.50
(.295)
EPOXY
Ø1.10
(.043DIA)
5.08
(.200)
Terminal spacing
5,08 (.200)
8.10
(.318)
Terminal spacing
2,54 (.100)
3.80
(.149)
Extra high actuator : 25000NH6
0.60
(.023)
5.08
(.200)
5.08
(.200)
APEM
www.apem.com
E-17
25000N series
Side actuator : 25000N
2.54
(.100)
Double pole
25546N
25549N
2.30
(.090)
3.00
(.118)
0.60
(.023)
0.50
(.019)
EPOXY
Ø1.10
(.043DIA)
0.60
(.023)
2.54
(.100)
2.54
(.100)
Double pole
25346N
25349N
12.50
(.465)
6.00
(.236)
Single pole
25536N
25539N
14.10
(.555)
8.10
(.318)
Single pole
25336N
25339N
7.50
(.295)
3.80
(.149)
Terminal spacing
5,08 (.200)
1.30
(.051)
Terminal spacing
2,54 (.100)
5.08
(.200)
5.08
(.200)
Long side actuator : 25000N6
2.54
(.100)
Double pole
25546N 6
25549N 6
3.00
(.118)
0.60
(.023)
0.50
(.019)
EPOXY
Ø1.10
(.043DIA)
0.60
(.023)
2.54
(.100)
2.54
(.100)
Double pole
25346N 6
25349N 6
6.00
(.236)
12.50
(.465)
4.30
(.169)
Single pole
25536N 6
25539N 6
14.10
(.555)
8.10
(.318)
Single pole
25336N 6
25339N 6
7.50
(.295)
3.80
(.149)
Terminal spacing
5,08 (.200)
3.00
(.118)
Terminal spacing
2,54 (.100)
5.08
(.200)
5.08
(.200)
E
PCB MOUNTING
POSITIONS AND CONNECTIONS
7.50
(.295)
2
1
14.10
(.555)
10.80
(.425)
H
1
6.00
(.236)
2.30
(.090)
8.10
(.318)
B
2
7.50
(.295)
H6
6
Function 6
Function 9
ON
ON
OFF
ON
ON
CONTACT MATERIALS
A
LD
Silver
Brass, gold plated
OPTIONS AND APPROVALS
F
X601
X693
X693UL
E-18
Tin dipped terminals (for models with gold plated contacts only).
Silver plated brass contacts - Lower rating 3VA 30VDC. Min quantity : 5.000 pieces per model and shipment.
Flame retardant plastic materials
Switches approved and marked UL (silver contacts only)
www.apem.com
APEM
很抱歉,暂时无法提供与“25136NLDH6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+34.91150500+4.49740
- 国内价格
- 1+46.66680
- 10+40.44600
- 30+36.65520
