Series 48A: Slide
Switches
SERIES 48A
Slide Switches
MODELS
DIP Switches
FEATURES
• Save Space and Weight
• SPDT and DPDT Circuitry
• Choice of Actuators and
Terminations
In inches (and millimeters)
TRAVEL
.085
(2.16)
SPDT
SWITCH POSITION
MODEL
NO.
SSP1
SSP2
SSP3
ON
ON
ON
2-1
TERM. COMM.
NONE
NONE
OFF
OPEN
ON
(ON)
ON
2-3
.770
(19.56)
.240
(6.10)
TRAVEL
.085
(2.16)
TERM. COMM.
SWITCH POSITION
ON
NONE
ON
OFF
OPEN 2-3,5-6
ON
ON
2-1,5-4
.770
(19.56)
()=MOMENTARY
02COMM.
.152
(3.86)
.155
(3.94)
.250
(6.35)
3 4
Std
6
.080
(2.03)
.200
(5.08)
.450
(11.43)
.030
(0.76)
.200
(5.08)
.185
(4.70)
.152
(3.86)
.250
(6.35)
6
3
5
2
4
1
.500
(12.70)
.080
(2.03)
.155
(3.94)
.190
(4.83)
SCHEMATIC
S3
S2
.152 SQ.
(3.86)
EPOXY SEAL
.690
(17.53)
.240
(6.10)
05COMM.
ACTUATOR OPTIONS
S1
.500
(12.70)
2
Slide Switches
1
3
3
1
DPDT
SDP1
SDP3
.260
(6.60)
1
02COMM.
MODEL
NO.
.030
(0.76)
.185
(4.70)
.200
(5.08)
.690
(17.53)
()=MOMENTARY
SCHEMATIC
EPOXY SEAL
.152 SQ.
(3.86)
.285
(7.24)
S4
.152 SQ.
(3.86)
.370
(9.40)
.152 SQ.
(3.86)
.140
(3.56)
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
H-4
Series 48A: Slide Switches
ACTUATOR OPTIONS
S5
For DPDT Only
S6
S7
.152 SQ.
(3.86)
.152 SQ.
(3.86)
T1
For DPDT Only
.152 SQ.
(3.86)
.152
(3.86)
.325
(8.26)
.040
(1.02)
.485
(12.32)
TERMINATION OPTIONS
M1
M2
M3
.189
(4.80)
.250
PC mount
(6.36)
terminals
.080
(2.03) supplied
without
.050
mounting tabs
THK. .030 (0.76)
(1.27)
standard.
THK. .030 (0.76)
.186
(4.72)
.152
.125
(3.18) (3.86)
.185
(4.70)
.046
(1.17)
SPDT
.260
(6.60)
2
.106
(2.69)
3
.520
(13.21)
.375
(9.53)
Slide Switches
.030
(0.76)
4
5
6
1
2
3
.106
(2.69)
.500
(9.53)
.150
(3.81)
.185
(4.70)
DPDT
M7
4
.050
(1.27)
EPOXY
SEAL
.186
(4.72)
Right Angle
P.C. Mount,
Vertical
Actuation
.050
(1.27)
SPDT
H-5
1
2
Ø.073
(Ø1.85)
.500
(12.70)
.520
(13.21)
.014
(0.36)
.260
(6.60)
.520
(13.21)
Ø.073
(Ø1.85)
2
.500
(12.70)
.400
(10.16)
.046
(1.17)
.030
(0.76)
.150
(3.81)
1
3
.014
(0.36)
.400
(10.16)
.150
(3.81)
3
.106
2.69
.152
(3.86)
.520
(13.21)
.185
(4.70)
.450
(11.43)
1
.185
(4.70)
Ø.073
(Ø1.85)
.014
(0.36)
.500
(12.70)
EPOXY
SEAL
.046
(1.17)
.062
(1.57)
.030 (0.76) THK.
.375
(9.53)
.050
(1.27)
.186
(4.72)
.152
(3.86)
.125
(3.18)
.250
(6.35)
.500
(12.70)
1
.030
(0.76)
P.C. Mount, Quick Connect
EPOXY SEAL
.189
(4.80)
M6
Right Angle
P.C. Mount,
Horizontal
Actuation
P.C. Mount (Std)
.156
(3.96)
.078
(1.98)
.047
(1.19)
.200
(5.08)
Solder Lug
Solder lug
terminals
supplied with
mounting tabs
standard.
.310
(7.88)
.150
(3.81)
.175
(4.45)
.175
(4.45)
TERMINATION OPTIONS
EPOXY
SEAL
.186
(4.72)
DPDT
.190
(4.83)
.450
(6.60)
.106
(2.69)
2
.150
(3.81)
Ø.073
(Ø1.85)
3
.500
(12.70)
1
.150
(4.83)
V2
5
4
.014
(0.36)
.500
(12.70)
.030
(0.76)
.152
(3.86)
1
.186
(4.72)
2
3
.014
(0.36)
.181
(4.60)
.125
(3.18)
.175
(4.45)
.125
(3.18)
.350
(8.90)
SPDT
.106
.175 (2.69)
(4.45)
.150
(3.81)
.314
(8.00)
.046
(1.17)
.500
(12.70)
.046
(1.17)
Vertical Bracket P.C. Mount
.152
(3.86)
6
.185
(4.70)
.620
(15.75)
.030
(0.76)
.185
(4.70)
DIP Switches
.152
(3.86)
Ø.073
(Ø1.85)
.620
(15.75)
.152
(3.86)
.152
(3.86)
.492
(12.50)
.125
(3.18)
.314
(8.00)
.400
(10.16)
4
5
.186
(4.72)
.046
(1.17)
.125
(3.18)
SPECIFICATIONS
Ø.073
(Ø1.85)
.190
(4.83)
.620
(15.75)
Contact Resistance: 10 milliohms max. initial
@ 2-4 VDC, 100 mA
Insulation Resistance: 1,000 megaohms
minimum
Dielectic Strength: 1,000 V RMS @ sea
level
Operating Temperature: -30°C to 85°C
MATERIALS
Case: Diallyl phthalate (DAP) (UL94V-0)
Housing: Stainless steel
Slide Handle: Nylon
Terminal Seal: Epoxy
Slide Switches
RATINGS
Contact Rating: Q option - 5A with resistive
load @ 125 VAC or 28 VDC; 2A with resistive
load @ 250 VAC. R option - 0.4 VA max @ 20
Vmax (AC or DC)
Electrical Life: 30,000 cycles at full load
.030
(0.76)
.185
(4.70)
.184
(4.67)
.620
(15.75)
6
.014
(0.36)
DPDT
.185
(4.70)
ORDERING INFORMATION
SERIES
MODEL NO.
ACTUATOR
TERMINATION
CONTACT
SEAL
48A
SSP1
S2
M6
R
E
48A =
Slide
Switches
Options: SSP1, SSP2,
SSP3, SDP1, SDP3
(see models for
switching positions)
Options:
S1, S2, S3, S4,
S5, S6, S7, T1
(see actuator
options)
Options: M1,
M2, M3, M6,
M7, V2 (see
termination
options)
Example Part Number: 48ASSP1S2M6RE
R = Copper
alloy, gold plate
over nickel plate.
E = Epoxy
seal
Q = Copper
alloy, silver
plated.
Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local
Distributor or Grayhill.
H-6
很抱歉,暂时无法提供与“48ASSP1S1M6RBT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+70.10280
- 200+27.97200
- 500+27.04320
- 1000+26.57880
