25436NLDH
25436NLDH
    APEM(埃斐)
    插件
    滑动开关 插件 单刀双掷 直插
25436NLDH 数据手册
SW PANEL PCB SWITCHES 0N 00 5 -2 3 80 -1 25000N series Professional slide switches DISTINCTIVE FEATURES Professional grade slide switches for PC boards Approved according to UL 1054 Wave solderable Available with flush, high and side actuator Various actuator lengths ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contacts (A) : 1 A 30 VDC - gold plated brass contacts (LD) : 100 mA 30 VDC • Minimum load : - silver contacts (A) : 100 mA 10 V - gold plated brass contacts (LD) : 10 µA 5 VDC - 10 mA 50 mV • Initial contact resistance : - silver contacts (A) : 10 mΩ max. - gold plated brass contacts (LD) : 50 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 1,000 Vrms 50 Hz min. between terminals 2,000 Vrms 50 Hz min. between poles 2,000 Vrms 50 Hz min. between terminals and frame • Electrical life : 10,000 cycles at full load • Low level or mechanical life : 20,000 cycles GENERAL SPECIFICATIONS • Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F) • Overall length : 14 mm (.551) • Actuator height (outside case) : - high : 2.80 mm (.110) - extra high : 6 mm (.236) - side : 2.30 mm (.090) - long side : 6 mm (.236) • Travel : 4 mm (.157) The company reserves the right to change specifications without notice. 1 Professional slide switches MATERIALS POSITIONS AND CONNECTIONS • Case : PBT • Actuator : polyamide, glass filled 2 • Cover : polyamide, glass filled • Contacts A : silver LD : brass, gold plated • Terminal seal : epoxy APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. AGENCY APPROVAL 2 A 250 VAC 4 A 125 VAC Availability : consult factory for details of approved models. Marking : to order switches marked UL, complete the “Options and Approvals” box of ordering format. ELECTRICAL FUNCTIONS PCB MOUNTING 7.50 (.295) 2 B 7.50 (.295) 6.00 (.236) 2.30 (.090) 14.10 (.555) 10.80 (.425) B HH H6 1 2 1 2 1 Function 6 : ON ON Function 9 : ON OFF ON 8.10 (.318) PCB SWITCHES 25000N series H6 - 66 Professional slide switches BUILD YOUR PART NUMBER BASIC PART NUMBER 25 N SERIES ACTUATOR AND TERMINALS 1 Flush or high actuator, terminal spacing 2.54 (.100) 4 Flush or high actuator, terminal spacing 5.08 (.200) 3 Side actuator, terminal spacing 2.54 (.100) 5 Side actuator, terminal spacing 5.08 (.200) NUMBER OF POLES ELECTRICAL FUNCTIONS 3 Single pole 6 ON - ON 4 Double pole 9 ON OFF ON VERSION N For all models OPTIONS CONTACT MATERIALS A LD ACTUATOR Silver B Flush Gold plated brass H High H6 Blank -6 Extra high Side Long side OPTIONS AND APPROVALS X601 Special contact : lower rating X603 Flame retardant plastic material X693UL UL approved and marked Model with tape & reel packaging : see last page. ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. 3 PANEL PCB SWITCHES 25000N series Professional slide switches Shown with 2.54 mm terminal spacing 25139N B 25439N B 0.60 (.023) Double pole 25146N B 25446N B 25149N B 25449N B 0.50 (.019) 3.00 (.118) 25446N H 25149N H 25449N H 0.60 (.023) 5.08 (.200) Ø1.10 (.043DIA) 0.60 (.023) EPOXY 5.08 (.200) 5.08 (.200) 5.08 (.200) 25439N H6 Double pole 25146N H6 25446N H6 25149N H6 25449N H6 0.60 (.023) 5.08 (.200) 6.00 (.236) 3.00 (.118) 3.80 (.149) 25139N H6 12.50 (.465) 3.00 (.118) Single pole 25436N H6 14.10 (.555) 0.50 (.019) Ø1.10 (.043DIA) 5.08 (.200) Terminal spacing 5.08 (.200) 0.60 (.023) EPOXY 5.08 (.200) 5.08 (.200) 5.08 (.200) Shown with 2.54 mm terminal spacing Terminal spacing 5.08 (.200) 7.50 (.295) 14.10 (.555) 12.50 (.465) 2.30 (.090) 2.54 (.100) SIDE ACTUATOR : 25000N 4 0.50 (.019) 7.50 (.295) 25136N H6 3.00 (.118) Single pole 25339N 25539N Double pole 25346N 25546N 25349N 25549N 0.60 (.023) 0.50 (.019) 2.54 (.100) EPOXY Ø1.10 (.043DIA) 0.60 (.023) 5.08 (.200) 2.54 (.100) 25536N 6.00 (.236) 25336N Double pole 3.00 (.118) Shown with 5.08 mm terminal spacing EXTRA HIGH ACTUATOR : 25000NH6 Single pole 12.50 (.465) 5.08 (.200) Double pole 25146N H Terminal spacing 2.54 (.100) 5.08 (.200) 8.10 (.318) 25439N H Double pole 14.10 (.555) 3.80 (.149) 25139N H Single pole 7.50 (.295) Single pole 25436N H Terminal spacing 2.54 (.100) 5.08 (.200) 2.80 (.110) Terminal spacing 5.08 (.200) 25136N H Double pole 0.60 (.023) Shown with 5.08 mm terminal spacing 3.80 (.149) Single pole EPOXY 2.54 (.100) HIGH ACTUATOR : 25000NH Terminal spacing 2.54 (.100) Ø1.10 (.043DIA) 8.10 (.318) Double pole 12.50 (.465) 2.54 (.100) 25436N B 14.10 (.555) 8.10 (.318) Single pole 25136N B 7.50 (.295) 8.10 (.318) Single pole Terminal spacing 5.08 (.200) 3.80 (.149) Terminal spacing 2.54 (.100) 2.54 (.100) FLUSH ACTUATOR : 25000NB 1.30 (.051) PCB SWITCHES 25000N series 5.08 (.200) Professional slide switches Shown with 2.54 mm terminal spacing Double pole 25346N -6 25546N -6 25349N -6 25549N -6 0.60 (.023) Ø1.10 (.043DIA) 0.50 (.019) 2.54 (.100) EPOXY 0.60 (.023) 5.08 (.200) 2.54 (.100) 25539N -6 6.00 (.236) 4.30 (.169) 25339N -6 12.50 (.465) 8.10 (.318) 25536N -6 14.10 (.555) 3.00 (.118) Single pole 25336N -6 Double pole 7.50 (.295) 3.80 (.149) Single pole Terminal spacing 5.08 (.200) 3.00 (.118) Terminal spacing 2.54 (.100) 2.54 (.100) LONG SIDE ACTUATOR : 25000N-6 5.08 (.200) CONTACT MATERIALS BASIC P/N A LD Silver Brass, gold plated ACTUATORS BASIC P/N Already included in the above part numbers. B H H6 Blank -6 Flush actuator High actuator Extra high Side Long side OPTIONS AND APPROVALS BASIC P/N X601 Silver plated brass contacts - Lower rating 3 VA 30 VDC. Min. quantity : 5,000 pieces per model and shipment. X693 Flame retardant plastic materials X693UL Switches approved and marked UL (silver contacts only) MODEL WITH TAPE AND REEL PACKAGING 25436NLDH X693-02 R On request. 5 PANEL PCB SWITCHES 25000N series
25436NLDH 价格&库存
很抱歉,暂时无法提供与“25436NLDH”相匹配的价格&库存,您可以联系我们找货
25436NLDH
  • 500+25.69188500+3.33350
