04-Serie G-A_04-Serie G-A 06/11/14 13:56 Page8
G series
Slide switches - telecom grade
Distinctive features and specifications
UG1410A
❑ Panel and PC mount models
❑ 6 actuator lengths
❑ Wide variety of contact materials
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- silver contacts (codes 1 or 2) : 3A 30VDC
- gold plated brass contacts (code 0) : 0,4VA 20VAC or DC max.
• Initial contact resistance : 10 mΩ
• Insulation resistance : 1.000 MΩ min.
• Dielectric strength : 1.000 Vrms 50 Hz min.
• Electrical life with resistive load :
- silver contacts (codes 1 or 2) : 2 positions : 40.000 cycles
3 positions : 20.000 cycles
- gold plated brass contacts (code 0) : 60.000 cycles (0,4VA max.)
MATERIALS
E
GENERAL SPECIFICATIONS
• Case : PES
• Actuator : polyamide, glass
filled
• Cover : stainless steel
• Contacts
0 : brass, gold plated
1 : silver
2 : silver, gold plated
5 : special contact, lower
rating, minimum quantity :
consult factory
• Terminal seal : epoxy
• Travel : 2,20 mm (.086), except actuator N on SP model : 2,60 mm (.102)
• Operating temperature : -30°C to +85°C
• Recommended soldering : 300°C 5 sec. max.
The company reserves the right to change specifications without notice.
E-8
www.apem.com
APEM
04-Serie G-A_04-Serie G-A 06/11/14 13:56 Page9
G series
Overview
G
Actuators
SERIES
C
H
L
B
E
N
3,50 mm (.137)
5,10 mm (.200)
Standard
6,40 mm (.251)
7,65 mm (.301)
9,10 mm (.358)
9,50 mm (.374)
Number
of poles
3
4
Terminals
Electrical functions
Single pole
Double pole
6
9
ON
ON
OFF
ON
ON
S0
P0
W0
WW
Y0
Y4
Types L, B and E for
single pole models only.
Contact and terminal
materials
2
5
Brass, gold plated
Silver
Silver, gold plated
Special contact, lower
rating
Special options 2
Special options 1
00
10
11
12
Standard model
Switch without ground
plate
10,35 mm (.407)
PC terminals
Same as 11, without
ground plate
Solder lugs
Straight PC
Right angle, horizontal
Right angle, vertical
Straight PC with short
bracket
Straight PC with tall
bracket
00
01
10
11
No epoxy seal
Epoxy sealed
terminals
Extended terminals
Same as 10, with
epoxy seal
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches
- options in the same order as in above chart
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
Packaging unit : 100 pieces for SP solder lug (S0) and straight terminal (P0) models.
50 pieces for other models.
APEM
www.apem.com
E-9
E
04-Serie G-A_04-Serie G-A 06/11/14 13:56 Page10
G series
1.10
(.043)
1.80
(.070)
4.00
(.157)
3
5.90
(.232)
2
4.20
(.165)
1
1.90
(.074)
• Solder lug, straight PC or right angle terminals
• Single and double pole configurations
1.10
(.043)
MODEL
STRUCTURE
Shown with standard actuator (type H)
19.50
(.767)
0.50
(.019)
OFF
ON
ON
7.60
(.299)
4.40
(.173)
9.50
(.374)
4.70
(.185)
4.75
(.187)
9.53
(.375)
www.apem.com
4.70
(.185)
3.85
(.151)
13.60
(.535)
3.30
(.129)
4.30
(.169)
Ø1.60
(.062 DIA)
4.70
(.185)
3.85
(.151)
4.70
(.185)
3.85
(.151)
1.30
(.051)
9.53
(.375)
0.80
(.031)
13.20
(.519)
E-10
5.10
(.200)
8.25
(.324)
1.17
(.046)
13.60
(.535)
0.50
(.019)
4.70
(.185)
4.70
(.185)
1.10
(.043)
0.50
(.019)
0.80
(.031)
12.70
(.500)
Single pole Double pole
GH36W0 GH46W0 ON
GH39W0 GH49W0 ON
0.80
(.031)
3.85
(.151)
Ø1.60
(.062 DIA)
4.70
(.185)
3.85
(.151)
3.85
(.151)
11.40
(.448)
Ø1.60
(.062 DIA)
4.70
(.185)
Right angle terminals - horizontal
1.10
(.043)
4.70
(.185)
4.70
(.185)
12.70
(.500)
12.70
(.500)
0.80
(.031)
10.55
(.415)
12.70
(.500)
3.81
(.150)
ON
ON
4.00
(.157)
OFF
3.85
(.151)
5.10
(.200)
GH36P0
GH46P0
ON
GH39P0
GH49P0
ON
6.65
(.261)
0.50
(.019)
4.00
(.157)
12.70
(.500)
0.80
(.031)
5.10
(.200)
Order with epoxy sealed terminals (option 01).
3.85
(.151)
6.10
(.240)
11.40
(.448)
12.70
(.500)
Straight PC terminals
0.30
(.011)
5.80
(.228)
3.85
(.151)
3.85
(.151)
6.35
(.250)
0.50
(.019)
4.20
(.165)
5.10
(.200)
ON
ON
4.70
(.185)
3.85
(.151)
3.85
(.151)
0.80
(.031)
E
6.10
(.240)
4.70
(.185)
OFF
17.53
(.690)
2.40
(.094)
6.65
(.261)
17.53
(.690)
0.30
(.011)
GH36S0
GH46S0
ON
GH39S0
GH49S0
ON
19.50
(.767)
2.40
(.094)
Solder lug terminals
5.70
(.224)
0.50
(.019)
13.20
(.519)
3.10
(.122)
Ø1.60
(.062 DIA)
4.70
(.185)
APEM
04-Serie G-A_04-Serie G-A 06/11/14 13:56 Page11
G series
3.18
(.125)
4.70
(.185)
0.50
(.019)
4.70
(.185)
0.80
(.031)
0.50
(.019)
4.70
(.185)
7.50
(.295)
15.75
(.620)
Ø1.60
(.062 DIA)
11.40
(.448)
3.85
(.151)
E
3.85
(.151)
4.70
(.185)
0.80
(.031)
0.50
(.019)
15.75
(.620)
Ø1.60
(.062 DIA)
4.75
(.187)
15.75
(.620)
10.46
(.411)
0.40
(.015)
4.70
(.185)
4.75
(.187)
3.18
(.125)
4.75
(.187)
3.85
(.151)
13.65
(.537)
0.40
(.015)
15.75
(.620)
3.85
(.151)
4.70
(.185)
0.80
(.031)
ON
ON
11.40
(.448)
3.85
(.151)
Ø1.60
(.062 DIA)
4.70
(.185)
OFF
3.18
(.125)
GH36Y4
GH46Y4
ON
GH39Y4
GH49Y4
ON
3.81
(.150)
15.75
(.620)
7.50
(.295)
3.85
(.151)
12.70
(.500)
Ø1.60
(.062 DIA)
15.75
(.620)
Straight PC terminals - tall bracket : Y4
4.75
(.187)
4.70
(.185)
0.40
(.015)
15.75
(.620)
6.35
(.250)
14.90
(.586)
4.70
(.185)
0.50
(.019)
2.80
(.110)
9.20
(.362)
3.85
(.151)
3.85
(.151)
0.40
(.015)
7.50
(.295)
4.70
(.185)
15.75
(.620)
4.70
(.185)
10.16
(.400)
11.40
(.448)
3.18
(.125)
Ø1.60
(.062 DIA)
3.85
(.151)
Ø1.60
(.062 DIA)
3.18
(.125)
3.81
(.150)
7.50
(.295)
0.80
(.031)
ON
ON
1.10
(.043)
6.35
(.250)
3.85
(.151)
12.70
(.500)
4.70
(.185)
2.80
(.110)
3.18
(.125)
OFF
3.85
(.151)
4.70
(.185)
ON
ON
Straight PC terminals - short bracket : Y0
GH36Y0
GH46Y0
ON
GH39Y0
GH49Y0
ON
3.85
(.151)
10.16
(.400)
OFF
4.45
(.175)
GH36WW GH46WW ON
GH39WW GH49WW ON
12.70
(.500)
6.65
(.261)
4.70
(.185)
12.70
(.500)
Right angle terminals - vertical
Solder lug
model
17.53
(.690)
Ø2.40
(.094 DIA)
4.20
(.165)
PANEL CUT-OUT
6.50
(.255)
APEM
www.apem.com
14.90
(.586)
13.65
(.537)
10.46
(.411)
9.20
(.362)
6.35
(.250)
5.70
(.224)
12.70
(.500)
11.40
(.448)
3.30
(.129)
9.50
(.374)
8.25
(.324)
6.65
(.261)
PCB MOUNTING
E-11
04-Serie G-A_04-Serie G-A 06/11/14 13:56 Page12
G series
ACTUATORS
Replace second digit (H) of basic model number with
one of the codes below.
G H . . . .
5.10
(.200)
3.50
(.137)
L
Standard
For single pole only
9.10
(.358)
9.50
(.374)
H
7.65
(.301)
C
6.40
(.251)
Dimensions below are for solder lug (S0) and straight terminals (P0) models.
For other models (WO - WW - Y0 - Y4), height is less 0,4 mm (.015).
B
E
N
E
CONTACT AND TERMINAL MATERIALS
2
5
E-12
Brass, gold plated
Silver
Silver, gold plated
Special contact, lower rating, minimum quantity : consult factory
www.apem.com
APEM
04-Serie G-A_04-Serie G-A 06/11/14 13:56 Page13
G series
SPECIAL OPTIONS
1
00
Standard switch as presented under "Model Structure"
10
Switch without ground plate
For right angle only (W0 and WW models)
11
10.35
(.407)
10
10,35 mm (.407) long PC terminals
12
10,35 mm (.407) long PC terminals without ground plate
10.35
(.407)
11
12
SPECIAL OPTIONS
2
No epoxy seal
01
Epoxy sealed terminals
(compulsory on solder lug models)
10
Extended terminals
For vertical right angle (WW models)
11
Extended terminals as above, with epoxy seal
E
21.60
(.850)
00
APEM
10
EPOXY
11
www.apem.com
E-13
很抱歉,暂时无法提供与“GH36W010001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+80.9134050+10.42350
- 国内价格
- 17+53.05532
- 51+50.47994
