MJTP SERIES 6MM
THRU-HOLE MTG.
TACT SWITCHES
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE.
MATERIALS
Gold plating available on contacts &
terminals
- consult factory.
FEATURES
Numerous single pole-single throw momentary configurations.
Excellent tactile feed-back (Snap dome).
Ultra-compact size.
Long operating life for high reliability.
Molded-in terminals minimize wicking of flux or solder.
Case:
Thermoplastic, color black. UL94HB Standard.
Actuator:
Thermoplastic, color black unless otherwise specfied.
Cover/Bracket: PET film, tin plated brass or stainless steel.
Terminals:
Silver plated brass.
Shorting Contact: Phosphor bronze or stainless steel with silver plating.
L.E.D. rating:
Forward voltage- 2.1 V (3.0 V Max.). Cont. fwd. current 20mA max.@ 25°C.
GENERAL SPECIFICATIONS
ELECTRICALS
Contact rating:
Insulation resistance:
Dielectric withstanding voltage:
Contact resistance:
Electrical life:
Contact bounce:
50 mA @ 12 VDC
100 megohms min. (100 VDC)
250 VAC for 1 minute
100 milliohms max. @ 5 VDC, 10 mA
100,000 cycles min. (except models MJTP1243 & 1250- 50,000 cycles)
1,000,000 cycles available - consult factory
less than 10 msec.
MECHANICALS, THERMALS, ENVIRONMENTALS
Plunger travel:
.010"+ .008", - .004" (0,25 +0,2, -0,1 mm)
Actuation force:
160 grams ±30 grams
Operating temperature range:
-20°C to +70°C
Storage temperature range:
-30°C to +80°C for 96 hours
Shock resistance:
30G per method 213, MIL-STD-202
Vibration resistance:
passes method 201, MIL-STD-202
M
SOLDERING (note - non-washable except for models indicated 'process compatible' below).
IR reflow soldering:
240°C max. for 20 seconds max.
Wave soldering:
255°C max. for 5 seconds max.
Hand soldering:
320°C max. for 3.5 seconds max. (40 watt iron max.)
MJTP1105T
Right angle,
grounding
Caps available see end of section.
Bulk packaged.
US # MJTP1109
EU # PHAP3350
Process
compatible,
grounding
US Model
No.
Dim.
EU Model
L (In./mm) No.
MJTP1109
.197 (5.0) PHAP3350
MJTP1109A .354 (9.0) PHAP3350A
MJTP1109B .512 (13.0) PHAP3350B
Bulk packaged.
APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com
M3
US # MJTP1117
EU # PHAP3363
Right angle,
grounding
New!
US # MJTP1119
EU # PHAP3351
Process compatible
US Model
Dim.
No.
MJTP1119
L (in./mm) No.
.197 (5.0) PHAP3351
EU Model
MJTP1119A .354 (9.0) PHAP3351A
MJTP1119B .512 (13.0) PHAP3351B
Bulk packaged.
New!
M
US # MJTP1129
EU # PHAP1152
Right angle,
grounding,
process
compatible
US Model
No.
Dim.
EU Model
L (in./mm) No.
MJTP1129 .171 (4.35) PHAP3352
MJTP1129A .329 (8.35) PHAP3352A
MJTP1129B .486 (12.35) PHAP3352B
Bulk packaged.
US # MJTP1141
EU # PHAP3307
Long terminals
US Model
No.
Dim.
EU Model
L (in./mm) No.
MJTP1141 .169 (4.3)
MJTP1141A .197 (5.0)
PHAP3307
PHAP3307A
Packaged on tape. Note: other
models available with this tape
packaging - consult factory.
M4
Bulk packaged.
US # MJTP1193
EU # PHAP3308
With L.E.D.
Note: LED
cathode is
marked
with a dot
US Model
L.E.D.
EU Model
No.
MJTP1193
Color
No L.E.D.
No.
PHAP3308
MJTP11936 Red
MJTP11935 Yellow
PHAP3308R
PHAP3308Y
MJTP11933 Green
PHAP3308G
Caps available with lens see end of section.
Bulk packaged.
New!
US # MJTP1230
EU # PHAP3301
US Model Dim.
No.
L (in./mm)
MJTP1230 .170 (4,3)
MJTP1230A .197 (5,0)
MJTP1230B .374 (9,5)
MJTP1230C .315 (8,0)
MJTP1230D .512 (13,0)
MJTP1230E .287 (7,3)
MJTP1230F .335 (8,5)
MJTP1230G .275 (7,0)
EU Model
No.
PHAP3301
PHAP3301A
PHAP3301B
PHAP3301C
PHAP3301D
PHAP3301E
PHAP3301F
N/A
Bulk packaged.
US # MJTP1232
EU # PHAP3302
Grounding
US Model Dim.
No.
L (in./mm)
MJTP1232 .170 (4,3)
MJTP1232A .197 (5,0)
MJTP1232B .374 (9,5)
MJTP1232C .315 (8,0)
MJTP1232D .512 (13,0)
MJTP1232E .287 (7,3)
MJTP1232F .335 (8,5)
MJTP1232G .275 (7,0)
M
EU Model
No.
PHAP3302
PHAP3302A
PHAP3302B
PHAP3302C
PHAP3302D
PHAP3302E
PHAP3302F
PHAP3302G
Bulk packaged.
US # MJTP1234
EU # PHAP3303
US Model
No.
Dim.
L (in./mm)
MJTP1234 .094 (2,4)
MJTP1234A .110 (2,8)
EU Model
No.
PHAP3303
PHAP3303A
Bulk packaged.
M5
US Model Dim.
EU Model
No.
L (in./mm) No.
MJTP1236 .124 (3,1) PHAP3305
MJTP1236A .152 (3,9) PHAP3305A
MJTP1236B .329 (8,4) PHAP3305B
MJTP1236C .270 (6,9) PHAP3305C
MJTP1236D .466 (11,9) PHAP3305D
MJTP1236E .244 (6,2)
PHAP3305E
MJTP1236F .289 (7,3)
N/A
MJTP1236G.230 (5,8)
N/A
Bulk packaged.
US # MJTP1243 &
MJTP1250
US # Model Dim.
Dim.
No.
L1(in./mm) L (in./mm)
MJTP1243
MJTP1250
.169 (4,3)
.197 (5,0)
.307 (7,8)
.335 (8,5)
Bulk packaged.
M
US # MJTP2205
EU # PHAP3306
2 switch vertical
gang assembly,
black actuators
1
4
2
3
US Model Dim.
EU Model
No.
L (in./mm) No.
MJTP2205 .124 (3,15) PHAP3306
MJTP2205A .152 (3,85) PHAP3306A
MJTP2205B .329 (8,35) PHAP3306B
MJTP2205C .270 (6,85) PHAP3306C
MJTP2205D .466 (11,85)PHAP3306D
MJTP2205E .242 (6,15) PHAP3306E
Bulk packaged.
M6
US # MJTP1236
EU # PHAP3305
Right angle,
grounding
US # MJTPSHW
Process
compatible
US # Model
No.
Dim.
L (in./mm)
MJTPSHW
MJTPSHWA
.122 (3,1)
.091 (2,3)
MJTPSHWB
.146 (3,8)
Bulk packaged.
CAPS
(for MJTP1105T and MJTP1234 only)
MJ61 Square cap
MJ62 Round cap
CAPS
(for MJTP1193 only)
New!
CAP COLORS
MJ3 Square cap (w/clear lens in center for LED illumination)
Note - add digit from table to
cap part number for color.
Example - MJ612 indicates
square black cap.
No.
1
2
3
5
6
7
Color
blue
black
green
yellow
red
ivory
SCHEMATICS
MJTP1109
MJTP1119
MJTP1193
MJTP1230
MJTP1232
MJTP1234
MJTP2205
MJTP4102
MJTP5302
MJTPSHW
MJTP1105
MJTP1117
MJTP1129
MJTP1141
MJTP1144
MJTP1145
Note: LED is for
MJTP1193 only.
MJTP1236
MJTP1243
MJTP1250
MJTP2205
MJTP4102
MJTP5302
M
PRINTED CIRCUIT BOARD LAYOUTS
Layout tolerances; Linear: ± .004" ( ± 0,1MM) Holes: ± .002" ( ± 0,05MM)
MJTP1105T
MJTP1141, 44 & 45
MJTP1109
MJTP1117
MJTP1119
MJTP1129
MJTP1193
MJTP1230
MJTP1232
MJTP1234
MJTP1243
MJTP1250
MJTPSHW
4
MJTP1236
MJTP4102
MJTP5302
3
2
1
MJTP2205
M7
