ADTS6, ADTSM &
AKTSC6 SERIES
(SQUARE STEM WITH CAP OPTIONS)
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE.
MECHANICAL CONTACT STYLE
FEATURES
Positive tactile feedback.
Ultraminiature structure suitable for high density mounting. Economic but high reliability.
Insert molded terminals prevent flux build-up during soldering.
MATERIALS
COVER:
BASE:
STEM:
CONTACT DISC:
TERMINAL:
CAP:
Stainless steel.
UL94V-0 Nylon Thermoplastic.
Color: Black
Color: Black(100gf), Brown(160gf), Red(260gf), Salmon(320gf),Yellow(520gf)
Silicone rubber Color: Red(300gf)
Phosphor bronze with silver cladding.
Brass with silver plating.
Termoplastic ABS.
GENERAL SPECIFICATIONS
ELECTRICALS
Electrical life:
Rating:
Contact resistance:
Insulation resistance:
Dielectric Strength:
Contact Arrangement:
100,000 cycles for 320gf, 520gf.
100,000 cycles for 260gf.
200,000 cycles for 100gf, 160gf.
50 mA,12 VDC.
100 milliohms max.
100 megohms min. 500 VDC.
250 VAC /1 minute.
1 pole 1 throw.
MECHANICALS
Operational Force:
520 + 130gf Brown
320 + 80gf Brown
260 + 50gf Red
160 + 50gf Brown
100 + 50gf Black
Stop Strength:
Max 3kgf vertical static load continuously for 15 seconds.
Stoke:
(12x12) 0.35 + 0.1mm
(6x6) 0.25 + 0.2 mm
- 0.1 mm
(Y)
(S)
(R)
(N)
(K)
Operating Temperature Range:
Storage Temperature Range:
Vibration resistance:
-25ºC to + 70ºC
-30ºC to + 80ºC
MIL-STD-202F METHOD 201A.
Frequency: 10-55-10Hz/1minute.
Directions: X,Y,Z, three mutually perpendicular directions.
Time: 2 hours each direction.
High reliability.
Shock resistance:
MIL-STD-202F METHOD 213B.
High reliability.
APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com
M
SOLDERING PROCESSES
WAVE SOLDERING: Recommended solder temperature at 500ºF (260ºC) max. 5 seconds subject to PCB 1.6mm
thickness. (For through hole type)
HAND SOLDERING: Use a soldering iron of 30 watts, controlled at 350ºC approximately 5 seconds while applying
solder.
HOW TO ORDER
V
ADTS
Package Style:
= Bulk Pack
* B = Tube
* Except ADTS-63, 644, 648, 65, 66
Soldering:
V = Lead Free
M
Color Of Stem For Operating Force:
K= Black, 100gf
N = Brown, 160gf
R = Red, 260gf
S = Salmon, 320gf
Y = Yellow, 520gf
N/K = Black, 160gf
< 12 x 12, K, Y Unavailable>
Dimension H:
6 x 6mm:
12 x 12mm:
1 = 4.3mm
1 = 4.3mm
2 = 5.0mm
4 = 7.3mm (SQ.) x 3.8mm
3 = 7.0mm
5 = 8.5mm
44= 7.3mm (SQ.) x 2.4mm
48= 7.3mm (SQ.) x 2.8mm
5 = 9.5mm
6 = 13mm
Prod. Size
6 = 6.6mm
2 = 12 x 12mm
= None Post
M = Surface Mount
APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com
CIRCUIT
ADTS6**V
ADTS64**V
PRODUCT NO.
LOC. MM.
INCH
ADTS644*V
A
B
2.4
1.6
[.095]
[.063]
ADTS648* V
A
B
2.8
2.0
[.110]
[.079]
M
ADTS2**V
ADTS24*V
PART NUMBER.
DIM. I
ADTSM62~66*
.024 MAX.
ADTSM61*
.020 MAX.
ADTSM64**V
PART NUMBER.
DIM. A
DIM. B
ADTSM644*V*
ADTSM648*V*
.094 [2.4]
.100 [2.8]
.063 [1.6]
.079 [2.0]
M
ADTSM2**V
ADTSM24*V
ADTSM6**V
AKTSC CAPS
CAP PART NO.
AKTSC
Cap Type:
1 = Square
2 = Round
Prod. Size: ( Tactile Switch )
6 = 6 x 6mm
2 = 12 x 12mm
AKTSC61
AKTSC21
Cap Color:
Y= Yellow
B = Blue
R = Red
I = Ivory
K = Black
G = Green
S = Salmon
AKTSC62
AKTSC22
PACKAGING
ADTS-6 Series: 1000 pcs/bag
ADTS(P)-2 series: 500 pcs/bag or 40pcs/tube
M
很抱歉,暂时无法提供与“ADTSM65NVTR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.973161+0.76948
- 10+5.0888810+0.65557
- 25+4.7394225+0.61055
- 100+4.23042100+0.54498
- 国内价格 香港价格
- 380+3.78441380+0.48752
- 760+3.57590760+0.46066
- 1140+3.462051140+0.44600
- 1900+3.327401900+0.42865
- 2660+3.244092660+0.41792
- 3800+3.160453800+0.40714
- 国内价格
- 1140+1.92247
- 1520+1.77738
