ADTSMW64NVTR
ADTSMW64NVTR
    APEM(埃斐)
    轻触开关 立贴
ADTSMW64NVTR 数据手册
WASHABLE TACT SWITCH SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. FEATURES O O O O Sharp click feel with a positive tactile feedback. Ultraminiature structure suitable for high density mounting. Economic but high reliability. Insert molded contacts with special treatment prevents flux build-up during soldering and permits auto-dipping. Allows submersed washing after soldering. MATERIALS COVER: Stainless Steel. TERMINALS: Brass with silver plating. BASE: UL94V-0 Nylon, High Temperature Thermoplastic. Color:Black ITEM NO. ADTSHW66N ADTSMW66N ADTSJW66N ADTSHW68S ADTSMW68S ADTSJW68S High-Temp. None Thermoplastic STEM Nylon UL 94V-0 Color: Brown(N), 160gf TEFLON (Standard) ADHESIVE TAPE TEFLON KAPTON (V-option) Brass with Brass with METAL STEM Nickel plating Nickel plating FILLER None CONTACT Phosphor bronze with silver cladding (Standard) Stainless steel (V-option) ITEM NO. ADTS(H)MW69,65N (R)T ADTS(H)MW67N(R)T ADTSJW69,65N (R)T ADTSJW67N(R)T STEM Silicone Rubber Silicone Rubber ADHESIVE TAPE None None METAL STEM None None FILLER None Nylon CONTACT Phosphor bronze with silver cladding(Standard) Stainless Steel Stainless steel(V-option) None GENERAL SPECIFICATIONS ELECTRICAL Electrical life: Rating: Contact resistance: Insulation resistance: Dielectric Strength: Contact Arrangement: 500,000 cycles for ADTS W 69, 67N(R)T, 65N(R)T, 64N(R) 100,000 cycles for ADTS W 66N,68S 50 mA,12 VDC. 100 milliohms max. 100 megohms min. 500 VDC. 250 VAC /1 minute. 1 pole 1 throw. MECHANICAL Stop Strength: Stroke: 3kgf max, continuous vertical static load. + 0.2 mm 66N, 68S 0.25 - 0.1 mm 0.6 + 0.2 mm, 69, 67T 0.45 + 0.2 mm, 69, 67, 65N(R), 65T, 64, J=64N(R) Operation Temperature Range: -25ºC to +70ºC Storage Temperature: -30ºC to +80ºC Shock Resistance: 50G per method 213B, MIL - STD - 202F Vibration Resistance: Passes method 201A, MIL - STD - 202F APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M SOLDERING PROCESSES HAND SOLDERING: 350ºC max. for 5 seconds max. (30 watt iron max). WAVE SOLDERING: 260ºC max. for 5 seconds max. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. REFLOW SOLDERING: 255ºC max.(see profile) CIRCUIT HOW TO ORDER M ADTS W V B = Tube Package T/R = Tape & Reel = Bulk ( J Type only) V = Lead Free Solderable Color Of Stem For Operating Force: N = Brown, 160gf ( 66N ) 180gf ( 69N. 67N, 65N, 64) S = Silver, 160gf R = Red, 260gf T = Transparent, 360gf (69T, 67T, 65T ) Dimension H: 64 = 4.5mm ( N, R ) 65 = 3.5mm ( N, R, T ) 66 = 3.1mm ( N ) 67 = 5.2mm ( N, R, T ) 68 = 2.3mm ( S ) 69 = 3.8mm ( N, R, T ) H: Through Hole Terminals J: Surface Mounting Type M: Surface Mounting Type APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ADTSHW66 ADTSHW68 M ADTSHW69 ADTSHW67 ADTSHW65 ADTSHW64 ADTSJW66 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com ADTSJW69 ADTSJW67 ADTSJW65 M ADTSMW66 ADTSMW68 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ADTSJW68 SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ADTSMW69 ADTSMW67 ADTSMW65 ADTSMW64 PACKAGING Tube: 75 pcs/tube ADTSMW64 -T/R: 900 pcs/reel ADTSMW65 -T/R: 1900 pcs/reel ADTSMW66 -T/R: 2000 pcs/reel ADTSMW67 -T/R: 900 pcs/reel ADTSMW68 -T/R: 2000 pcs/reel ADTSMW69 -T/R: 1900 pcs/reel Tube: 75 pcs/tube -T/R: 900 pcs/reel ADTSJW64 ADTSJW65 -T/R: 1800 pcs/reel ADTSJW66 -T/R: 1900 pcs/reel ADTSJW67 -T/R: 900 pcs/reel ADTSJW68 -T/R: 2700 pcs/reel ADTSJW69 -T/R: 1800 pcs/reel APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M
ADTSMW64NVTR 价格&库存
很抱歉,暂时无法提供与“ADTSMW64NVTR”相匹配的价格&库存,您可以联系我们找货
ADTSMW64NVTR
    • 900+4.37453900+0.56354
    • 1800+4.146241800+0.53413
    • 2700+4.023332700+0.51830
    • 4500+3.879544500+0.49978
    • 6300+3.791456300+0.48843
    • 9000+3.703629000+0.47711
    库存:10968
    ADTSMW64NVTR
    • 1+7.386741+0.95158
    • 10+6.3111410+0.81302
    • 25+5.8749625+0.75683
    • 100+5.24129100+0.67520
    • 250+4.85544250+0.62550
    库存:10968
