MJTP1138CTR
MJTP1138CTR
    APEM(埃斐)
    轻触开关 立贴
MJTP1138CTR 数据手册
MJTP SERIES 6MM & 4MM SMD TACT SWITCHES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. MATERIALS Gold plating available on contacts & terminals - consult factory. FEATURES Numerous single pole-single throw momentary configurations. Excellent tactile feed-back (Snap dome). Ultra-compact size. Long operating life for high reliability. Molded-in terminals minimize wicking of flux or solder. Case: High temperature 4/6 nylon. Actuator: High temperature 4/6 nylon. Cover/Bracket: PET film, tin plated brass or stainless steel. Terminals: Silver plated brass. Shorting Contact: Phosphor bronze or stainless steel with silver plating. L.E.D. rating: Forward voltage- 2.1 V (3.0 V Max.). Cont. fwd. current 20mA max.@ 25°C. GENERAL SPECIFICATIONS ELECTRICALS Contact rating: Insulation resistance: Dielectric withstanding voltage: Contact resistance: Electrical life: Contact bounce: 50 mA @ 12 VDC 100 megohms min. (100 VDC) 250 VAC for 1 minute 100 milliohms max. @ 5 VDC, 10 mA 100,000 cycles min. (1,000,000 cycles available - consult factory) less than 10 msec. MECHANICALS, THERMALS, ENVIRONMENTALS Plunger travel: .010"+ .008", - .004" (0,25 +0,2, -0,1 mm) Actuation force: 160 grams ±30 grams Operating temperature range: -20°C to +70°C Storage temperature range: -30°C to +80°C for 96 hours Shock resistance: 30G per method 213, MIL-STD-202 Vibration resistance: passes method 201, MIL-STD-202 M SOLDERING (note - non-washable except for models indicated as 'process compatible'). IR reflow soldering: 240°C max. for 20 seconds max. Wave soldering: 255°C max. for 5 seconds max. Hand soldering: 320°C max. for 3.5 seconds max. (40 watt iron max.) US # MJTP1106S US Model Dim. No. MJTP1106S L (in./mm) .169 (4,3) MJTP1106SA .197 (5,0) Bulk packaged. US # MJTP1106SATR Same as above, except supplied on tape and reel as shown. Tape & reel packaging - quantity 1800 per reel. M8 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com US # MJTP1122 Grounding US # MJTP1122A Grounding Bulk packaged. M US # MJTP1122B EU # PHAP3374 Bulk packaged. US # MJTP1122TR, MJTP1122BTR & MJTP3374TR EU # PHAP3374R Same as above, except supplied on tape & reel as shown. Note MJTP1122A not available on tape & reel. Tape & reel packaging - quantity 1500 per reel. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M9 SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Bulk packaged. US # MJTP1125B SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Bulk packaged. New! US # MJTP1138 EU # PHAP3368 .137 (3.5) US Model Dim. No. L (in./mm) MJTP1138 .170 (4,3) MJTP1138A .197 (5,0) MJTP1138B .374 (9,5) MJTP1138C .315 (8,0) MJTP1138D .512 (13,0) MJTP1138E .287 (7,3) MJTP1138F .335 (8,5) MJTP1138G .275 (7,0) EU Model No. PHAP3368 PHAP3368A PHAP3368B PHAP3368C PHAP3368D PHAP3368E PHAP3368F N/A Bulk packaged. Tubes available for some models consult factory. M M10 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com US # MJTP1138TR & MJTP1138ATR SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Same as above except supplied on tape & reel as shown. Tape & reel packaging - quantity 1200 per reel. US # MJTP1140 EU # PHAP3390 4mm x 4mm Bulk packaged. US # MJTP1140A EU # PHAP3391 M Bulk packaged. US # MJTP1140TR & MJTP1140ATR EU # PHAP3390R & PHAP3391R Same as above, except supplied on tape & reel as shown. Tape & reel packaging - quantity 3400 per reel. US # MJTP1162 EU # PHAP3371 US Model No. MJTP1162 Dim. L (in./mm) .102 (2,6) MJTP1162A .134 (3,4) EU Model No. PHAP3371 PHAP3371A Bulk packaged. M11 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. US # MJTP1162TR & MJTP1162ATR EU # PHAP3371R & PHAP3371AR Same as above except supplied on tape & reel as shown. Tape & reel packaging - quantity 1600 per reel. US # MJTPSJW66N Process compatible .339 (8.60) .102 (2.6) .212 (5.4) .157 (4.00) New! Bulk packaged. M US # MJTPSJW69N Process compatible (3.8) .339 (8.60) .102 (2.6) .212 (5.4) .157 (4.00) New! US # MJTPSMW Process compatible Bulk packaged. US Model No. Dim. L (in./mm) MJTPSMW MJTPSMWA .122 (3,1) .091 (2,3) MJTPSMWB .146 (3,8) Bulk packaged. M12 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com Tape & reel packaging - quantity 'MWTR' & 'MWATR' 2000 per reel, 'MWBTR' 1900 per reel. SCHEMATICS MJTP1122 MJTP1125 MJTP1137 MJTP1138 MJTP1140 MJTP1162 MJTPSJW66N MJTPSJW69N MJTPSMW MJTP1106 PRINTED CIRCUIT BOARD LAYOUTS Layout tolerances; Linear: ± .004" ( ± 0,1MM) Holes: ± .002" ( ± 0,05MM) Pads: ± .008" ( ± 0,2MM) M MJTP1106S MJTP1122 MJTP1122A MJTP1122B MJTP1137 MJTP1137E MJTP1138 MJTP1140 MJTP1140A MJTP1162 MJTPSMW M13 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. US # MJTPSMWTR & MJTPSMWATR, MJTPSMWBTR Same as above except supplied on tape & reel as shown.
MJTP1138CTR 价格&库存
很抱歉,暂时无法提供与“MJTP1138CTR”相匹配的价格&库存,您可以联系我们找货
MJTP1138CTR
  • 1+7.417041+0.96419
  • 10+6.3370310+0.82380
  • 25+5.8986325+0.76681
  • 100+5.26247100+0.68411
  • 250+4.87505250+0.63374
库存:3349
MJTP1138CTR
    • 700+4.48095700+0.58251
    • 1400+4.243421400+0.55163
    • 2100+4.115172100+0.53496
    • 3500+3.964723500+0.51540
    • 4900+3.872354900+0.50340
    • 7000+3.780147000+0.49141
    库存:3349
