ADTSM62NVTR
ADTSM62NVTR
    APEM(埃斐)
    轻触开关 立贴
ADTSM62NVTR 数据手册
ADTS6, ADTSM & AKTSC6 SERIES (SQUARE STEM WITH CAP OPTIONS) SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. MECHANICAL CONTACT STYLE FEATURES Positive tactile feedback. Ultraminiature structure suitable for high density mounting. Economic but high reliability. Insert molded terminals prevent flux build-up during soldering. MATERIALS COVER: BASE: STEM: CONTACT DISC: TERMINAL: CAP: Stainless steel. UL94V-0 Nylon Thermoplastic. Color: Black UL94V-0 Nylon Thermoplastic. Color: Black(100gf), Brown(160gf), Red(260gf), Salmon(320gf),Yellow(520gf) Silicone rubber Color: Red(300gf) Phosphor bronze with silver cladding. Brass with silver plating. Termoplastic ABS. GENERAL SPECIFICATIONS ELECTRICALS Electrical life: Rating: Contact resistance: Insulation resistance: Dielectric Strength: Contact Arrangement: 100,000 cycles for 320gf, 520gf. 100,000 cycles for 260gf. 200,000 cycles for 100gf, 160gf. 50 mA,12 VDC. 100 milliohms max. 100 megohms min. 500 VDC. 250 VAC /1 minute. 1 pole 1 throw. MECHANICALS Operational Force: 520 + 130gf Brown 320 + 80gf Brown 260 + 50gf Red 160 + 50gf Brown 100 + 50gf Black Stop Strength: Max 3kgf vertical static load continuously for 15 seconds. Stoke: (12x12) 0.35 + 0.1mm (6x6) 0.25 + 0.2 mm - 0.1 mm (Y) (S) (R) (N) (K) Operating Temperature Range: Storage Temperature Range: Vibration resistance: -25ºC to + 70ºC -30ºC to + 80ºC MIL-STD-202F METHOD 201A. Frequency: 10-55-10Hz/1minute. Directions: X,Y,Z, three mutually perpendicular directions. Time: 2 hours each direction. High reliability. Shock resistance: MIL-STD-202F METHOD 213B. Frequency: 10-55-10Hz/1minute. Directions: X,Y,Z, three mutually perpendicular directions. Time: 2 hours each direction. High reliability. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M SOLDERING PROCESSES WAVE SOLDERING: Recommended solder temperature at 500ºF (260ºC) max. 5 seconds subject to PCB 1.6mm thickness. (For through hole type) HAND SOLDERING: Use a soldering iron of 30 watts, controlled at 350ºC approximately 5 seconds while applying solder. HOW TO ORDER V ADTS Package Style: = Bulk Pack * B = Tube * Except ADTS-63, 644, 648, 65, 66 Soldering: V = Lead Free M Color Of Stem For Operating Force: K= Black, 100gf N = Brown, 160gf R = Red, 260gf S = Salmon, 320gf Y = Yellow, 520gf N/K = Black, 160gf < 12 x 12, K, Y Unavailable> Dimension H: 6 x 6mm: 12 x 12mm: 1 = 4.3mm 1 = 4.3mm 2 = 5.0mm 4 = 7.3mm (SQ.) x 3.8mm 3 = 7.0mm 5 = 8.5mm 44= 7.3mm (SQ.) x 2.4mm 48= 7.3mm (SQ.) x 2.8mm 5 = 9.5mm 6 = 13mm Prod. Size 6 = 6.6mm 2 = 12 x 12mm = None Post M = Surface Mount APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. CIRCUIT SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ADTS6**V ADTS64**V PRODUCT NO. LOC. MM. INCH ADTS644*V A B 2.4 1.6 [.095] [.063] ADTS648* V A B 2.8 2.0 [.110] [.079] M ADTS2**V ADTS24*V APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com PART NUMBER. DIM. I ADTSM62~66* .024 MAX. ADTSM61* .020 MAX. ADTSM64**V PART NUMBER. DIM. A DIM. B ADTSM644*V* ADTSM648*V* .094 [2.4] .100 [2.8] .063 [1.6] .079 [2.0] M ADTSM2**V ADTSM24*V APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ADTSM6**V SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. AKTSC CAPS CAP PART NO. AKTSC Cap Type: 1 = Square 2 = Round Prod. Size: ( Tactile Switch ) 6 = 6 x 6mm 2 = 12 x 12mm AKTSC61 AKTSC21 Cap Color: Y= Yellow B = Blue R = Red I = Ivory K = Black G = Green S = Salmon AKTSC62 AKTSC22 PACKAGING ADTS-6 Series: 1000 pcs/bag ADTS(P)-2 series: 500 pcs/bag or 40pcs/tube APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M
ADTSM62NVTR 价格&库存
很抱歉,暂时无法提供与“ADTSM62NVTR”相匹配的价格&库存,您可以联系我们找货
ADTSM62NVTR
  • 900+3.35170900+0.43178
  • 1800+3.174001800+0.40889
  • 2700+3.078082700+0.39653
  • 4500+2.965584500+0.38204
  • 6300+2.896536300+0.37314
  • 9000+2.827559000+0.36426
库存:891
ADTSM62NVTR
  • 1+5.718081+0.73662
  • 10+4.8784410+0.62846
  • 25+4.5459825+0.58563
  • 100+4.05994100+0.52302
  • 250+3.76059250+0.48445
库存:891
