95C06E5T
95C06E5T
    GRAYHILLINC.
    插件
    轻触开关 直插
95C06E5T 数据手册
Non-Washable Tactile Switches SERIES 95C 6mm Square, Non-washable applications Features • Excellent Tactile Feedback • Thru-hole, Gull Wings, and Right Angle Versions • Ultraminiature and Lightweight Structure Suitable for High Density Mounting • Surface Mount Versions Compatible with SMT Assembly Including Infrared and Vapor Phase Used in applications such as consumer electronics, audio equipment, PCs, VCRs, cable boxes, modems, communications equipment, controls, security and alarm equipment, and test and measurement equipment. DIMENSIONS: Non-Washable Switches in inches (and millimeters) Thru-hole Top View Front View .020 (0,50) MAX. .244 (6,20) C L Side View Ø.138 (Ø3,50) C L .256 ±.004 (6,50 ± 0,10) .177 ±.004 (4,50 ± 0,10) C L .177 (4,50) "H" DIM. .138 See Ordering (3,50) Information C L .012 (0,30) .071 +0-0.02 (1,80 +0,0-0,5) Thru-Hole Tact Switches T1 T2 T3 T4 4xØ .040 ±.002 (4xØ 1,00 ±0,05) .256 ±.020 (6,50 ±0,50) .311 ±.020 (7,90 ±0,50) .138 ±.020 (3,50 ±0,50) P.C.B. LAYOUT .028 (0,70) .138 DIA. CL .067 .020 MAX. .287 .138 .138±.020 .012 +.000 .071 -.020 .256 ±.020 Actuactor Style "F" for use with decorative caps. See page C-7 .311 ±.020 T2 "H" DIM. See Ordering Information 10˚ 0˚ .374 (9,50) .252 (6,40) C L C L Gull Wing T1 .170 .177 (4,50) .051 (1,30) T3 T4 .354 (9,00) .008 ±.004 (0,20 ±0,10) Front View Gull Wing P.C.B. LAYOUT .138 DIA. CL .067 .020 MAX. .287 .138 0˚ Actuactor Style "F" for use with decorative caps. See page C-7 10˚ .354 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .170 .008±.004 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Non-Washable Tactile Switches DIMENSIONS: Non-Washable Switches in inches (and millimeters) Top View Right Angle .012 (0,30) MAX. .291 (7,40) C L .276 ±.020 (7,00 ± 0,50) F1 .157 (4,00) .283 (7,20) .028 (0,70) .335 ±.016 (8,50 ±0,40) .276 ±.004 (7,00 ±0,10) Ø.138 (Ø3,50) 4x.039 ±.002 (4xØ1,0 ±0,05) .098 ±.004 (2,50 ±0,10) .01 (0,40 6 ) .177 (4,50) Right Angle Side View .258 (6,55) CL 0.071 +0.00-.020 .138 (1.800 ±.020 +0,00-0,50) (3,50 ±0,50) .177 ±.004 (4,50 ±0,10) .012 (0,30) .100 (2,55) .028 (0,70) P.C.B. LAYOUT .098 (2,50) "H" DIM. See Ordering Information F2 .258 T1 T2 Ground Terminal .095 .063 .067 .012 .100 .124 Actuactor Style "F" for use with caps. See page .028 .098 .242 MAX 260° 255° 230° 150° Room Temperature 120-150 sec. 5-10 sec. 60 sec. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Tact Switches REFLOW TEMPERATURE PROFILE: Non-Washable Tactile Switches ORDERING INFORMATION: Non-Washable Switches Thru-Hole and Gull Wing Series Size: 06 = 6mm Square Height (“H”): A = .169 (4,29), B = .197 (5,00), C = .276 (7,01), D = .374 (9,50), E = .512 (13,00) 95C06A2GWRT F = .287 (7,29) for use with decorative caps RoHS compliant Packaging: Blank = Tube or bulk, R = Tape and Reel (see pkg note) Terminal Style: Blank = Thru-hole, GW = Gull Wing Operating Force (Actuator Color): 2 = 100g (Black), 3 = 160g (Brown), 4 = 260g (Red), 5 = 320g (Orange), 6 = 520g (Yellow) Right Angle Series Size: 06 = 6mm Square Height (“H”): A = .124 (3,14), B = .152 (3,86), C = .230 (5,84), D = .329 (8,36), E = .467 (11,86) F = .242 (6,15) for use with decorative caps RoHS compliant Terminal Style: RA = Right Angle Operating Force (Actuator Color): 2 = 100g (Black), 3 = 160g (Brown), 4 = 260g (Red) 95C06A2RAT Packaging Thru-Hole: Bulk,1000 pcs/bag. Surface Mount: 77 pcs/tube, 1000 pcs/reel (.169” height), 900 pcs/reel (.197” height), 500 pcs/reel (.276” and .287” height), 380 pcs/reel (.374” height). Right Angle: Bulk, 1000 pcs/bag. SPECIFICATIONS: Non-Washable Switches Materials Base: UL94V-0 Nylon thermoplastic Cover: Stainless steel, tin-plated steel Actuator: UL94V-0 Nylon thermoplastic Terminal: Brass with silver-plating Contact: Stainless steel with silver-plating Cap: Thermoplastic ABS Electrical Tact Switches Rating: 50mA, 12 Vdc Life: 100g, 160g: 1,000,000 cycles; 260g: 500,000 cycles 320g, 520g, 300,000 cycles Actuator Travel: .010” + .008”/ - .004” Contact Resistance: 100 mΩ max. Insulation Resistance: 100 MΩ min. at 500Vdc Soldering Process Dielectric Strength: No dielectric breakdown after 250V for one minute Contact Arrangement: single pole, single throw Environmental Operating Temp. Range: -25 to 70°C Storage Temp. Range: -30 to 80°C Mechanical Shock: MIL-STD-202F, Method 213B, Test Condition A. Gravity: 50G’s (peak value), 11 msec. Direction and times: 6 sides and 3 times in each direction. High reliability. Vibration: MIL-STD-202F, Method 201A. Passed 6 hours (2 hours in each) of three perpendicular planes at a cycle of 10-55-10Hz/ minute. High reliability. Hand Soldering: Use a soldering iron of 30 watts, controlled at 350°C for 5 seconds maximum while applying solder. Reflow Soldering (surface mount versions only): Peak temperature 260°C (500°F). Wave Soldering: 260C° (500°F) maximum for 5 seconds subject to PCB .063 in. (1,6mm) thickness. Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local distributor, or Grayhill. Decorative CAps (for use with “F” style square actuators) B' "B" .217 "B" .217 B SEC "B-B" SEC B-B' .157 "A" "A" A' A , .177 DIA. .110 6mm SQUARE .110 SEC "A-A" 6mm ROUND figure 1 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois figure 2 SEC A-A' PART NUMBER SWITCH SIZE SHAPE COLOR FIGURE 95CAP-000 6mm SQUARE YELLOW 1 95CAP-001 6mm SQUARE BLUE 1 95CAP-002 6mm SQUARE RED 1 95CAP-003 6mm SQUARE NATURAL 1 95CAP-004 6mm SQUARE BLACK 1 95CAP-005 6mm SQUARE GREEN 1 95CAP-006 6mm SQUARE ORANGE 1 95CAP-010 6mm ROUND YELLOW 2 95CAP-011 6mm ROUND BLUE 2 95CAP-012 6mm ROUND RED 2 95CAP-013 6mm ROUND NATURAL 2 95CAP-014 6mm ROUND BLACK 2 95CAP-015 6mm ROUND GREEN 2 95CAP-016 6mm ROUND ORANGE 2 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
95C06E5T 价格&库存
很抱歉,暂时无法提供与“95C06E5T”相匹配的价格&库存,您可以联系我们找货
95C06E5T
    • 1+5.18400
    • 200+2.07360
    • 500+2.00880
    • 1000+1.96560
