ADTSM31NV
ADTSM31NV
    APEM(埃斐)
    轻触开关 立贴
ADTSM31NV 数据手册
ADTS3 SERIES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. 3.5 x 6mm TACT SWITCH FEATURES Sharp click feel with a positive tactile feedback. Ultraminiature structure suitable for high density mounting. Economic but high reliability. Insert molded contacts with special treatment prevents flux build-up during soldering and permits auto-dipping. MATERIALS COVER: BASE: STEM: DOME CONTACT: TERMINALS: Stainless Steel. UL94V-0 Nylon, High Temperature Thermoplastic. Color: Black UL94V-0 Nylon, High Temperature Thermoplastic. Color: Brown(160gf), Red(260gf), Salmon(320gf),Yellow(520gf) Stainless with silver cladding. Brass with silver plated. GENERAL SPECIFICATIONS ELECTRICALS Electrical life: Rating: Contact resistance: Insulation resistance: Dielectric Strength: Contact Arrangement: 50,000 cycles for 160gf, 320gf. 30,000 cycles for 260gf, 520gf. 50 mA,12 VDC. 100 milliohms max. 100 megohms min. 500 VDC. 250 VAC /1 minute. 1 pole 1 throw. MECHANICALS Actuation Force: 520 + 130gf Yellow 320 + 80gf Salmon 260 + 50gf Red 160 + 50gf Brown Stoke: 0.25 + 0.2 mm - 0.1 mm (Y) (S) (R) (N) Operating Temperature Range: -25ºC to + 70ºC Storage Temperature Range: -30ºC to + 80ºC MIL-STD-202F METHOD 201A. Vibration resistance: Frequency: 10-55-10Hz/1minute. Directions: X,Y,Z, three mutually perpendicular directions. Time: 2 hours each direction. High reliability. Shock resistance: MIL-STD-202F METHOD 213B. CONDITION A. Gravity: 50G (peak value), 11 msec. Direction and times: 6 sides and 3 times in each direction. High reliability. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M SOLDERING PROCESSES HAND SOLDERING: 320ºC max. for 2.5 seconds max. (30 watt iron). REFLOW SOLDERING: 260ºC max. 360ºC max. for 5 seconds max (1.6 mm Board thickness). SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. WAVE SOLDERING: CIRCUIT HOW TO ORDER M ADTS 3 V B = Tube Package R = Tape & Reel = Bag for Thru-hole type V = Lead Free Solerable Color Of Stem For Operating Force: N = Brown, 160gf R = Red, 260gf S = Salmon, 320gf Y = Yellow, 520gf Dimension H: 1 = 4.3mm 2 = 5.0mm Product Size: 3 = 3.5 x 6mm M: Surface Mounting Type ML: Surface Mounting Type : Through Hole Type APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ADTS3 ADTSM3 M ADTSML3 PACKAGING Tube: 135 pcs/tube ADTM-31 - T/R: 1800 pcs/reel ADTM-32 - T/R: 1600 pcs/reel Bulk: 1000 pcs/bag APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com
ADTSM31NV 价格&库存
很抱歉,暂时无法提供与“ADTSM31NV”相匹配的价格&库存,您可以联系我们找货
ADTSM31NV
  • 1+6.179091+0.80326
  • 10+5.3125210+0.69061
  • 25+4.9492525+0.64339
  • 135+4.30864135+0.56011
  • 270+4.06615270+0.52859
  • 540+3.83997540+0.49919
  • 1080+3.631661080+0.47211
  • 2565+3.398292565+0.44177
  • 5130+3.232615130+0.42023
库存:2298
