95C05B4GWRT
95C05B4GWRT
    GRAYHILLINC.
    SMD
    轻触开关 立贴
95C05B4GWRT 数据手册
Non-Washable Tactile Switches SERIES 95C 5mm Square Features • Excellent Tactile Feedback • Compatible with SMT Assembly Including Infrared and Vapor Phase • Ultraminiature and Lightweight Structure Suitable for High Density Mounting applications Used in applications such as consumer electronics, audio equipment, PCs, VCRs, cable boxes, modems, communications equipment, controls, security and alarm equipment, and test and measurement equipment. DIMENSIONS in inches (and millimeters) top View Front View .059 (1,49) .205 (5,20) .315 (8,00) .004 (0,10) .002 (0,50) Ø.079 (Ø2,00) .173 (4,40) Side View .205 (5,20) .189 (4,80) .241 (6,12) .102 (2,60) p.c.B. layOut .146 (3,70) Unless otherwise specified, tolerances are ±.010 (0,25) Materials Circuitry Base: UL94V-0 LCP thermoplastic Cover: Nickel silver Actuator: Brass with nickel-plating Terminal: Brass with silver-plating Contact: Stainless steel with silver-plating Dielectric Strength: No dielectric breakdown after 250V for one minute. Contact Arrangement: single pole, single throw Electrical Operating Temp. Range: -25 to 70°C Storage Temp. Range: -30 to 80°C Mechanical Shock: MIL-STD-202F, Method 213B, Test Condition A. Gravity: 50G (peak value), 11 msec. Direction and times: 6 sides and 3 times in each direction. Vibration: MIL-STD-202F, Method 201A. Passed 6 hours (2 hours in each) of three perpendicular planes at a cycle of 10-55-10Hz/minute. Rating: 50mA, 12 Vdc Life: 160g: 1,000,000 cycles; 260g: 200,000 cycles Actuator Travel: .010” + .008”/ - .004” Contact Resistance: 100 mΩ max. Insulation Resistance: 100 MΩ min. at 500Vdc Tact Switches SPECIFICATIONS Environmental T1 T2 T3 T4 Soldering Process Hand Soldering: Use a soldering iron of 30 watts, controlled at 350°C for 5 seconds maximum while applying solder. Reflow Soldering: Peak temperature 260°C (500°F). Packaging ORDERING INFORMATION Tape and Reel: 4000 pcs/reel. Series Size: 05 = 5mm Square Height: B = .059 (1,49) 95C05B3GWRT RoHS compliant Packaging: R = Tape and Reel (see pkg note) Terminal Style: GW = Gull Wing Operating Force: 3 = 160g, 4 = 260g Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
95C05B4GWRT 价格&库存
很抱歉,暂时无法提供与“95C05B4GWRT”相匹配的价格&库存,您可以联系我们找货
95C05B4GWRT
  • 4000+5.122084000+0.66034
