95C04A3GWT
95C04A3GWT
    GRAYHILLINC.
    SMD
    SWITCH TACTILE SPST-NO 0.05A 12V
95C04A3GWT 数据手册
Non-Washable Tactile Switches SERIES 95C 6mm x 3.5mm applications Features • Excellent Tactile Feedback • Thru-hole and Gull Wing Versions • Surface Mount Versions Compatible with SMT Assembly Including Infrared and Vapor Phase • Ultraminiature and Lightweight Structure Suitable for High Density Mounting Used in applications such as consumer electronics, audio equipment, PCs, VCRs, cable boxes, modems, communications equipment, controls, security and alarm equipment, and test and measurement equipment. Gull Wing, 320g, Orange Actuator Thru-Hole, 160g, Brown Actuator DIMENSIONS in inches (and millimeters) Thru-Hole Top View .236 (6,00) C L .118 (3,00) .138 (3,50) Front View C L "H" DIM. ± .008 ("H" DIM. ± 0,20) Side View .020 (0,50) MAX. C L .059 (1,50) .256 ± .004 (6,50 ± 0,10) .138 (3,50) P.C.B. LAYOUT .010 (0,25) .071 +0.0-0.20 (1,80 +0,0-0,50) .256 ±0.20 (6,50 ±0,50) .311 ± 0.20 (7,90 ± 0,50) Gull Wing .236 (6,00) CL CL .002 (0,05) MAX. 2xØ.051 ±.002 (2xØ1,30 ±0,05) .020 (0,51) .039 (1,00) .059 (1,50) CL .138 (3,50) .283 (7,20) .035 (0,90) .002 (0,05) MAX. .291 (7,40) .063 (1,60) .039 (1,00) .134 (3,40) P.C.B. LAYOUT Unless otherwise specified, dimension tolerances are ±0.010. SPECIFICATIONS Materials Circuitry Base: UL94V-0 Nylon thermoplastic Cover: Stainless steel Actuator: UL94V-0 Nylon thermoplastic Terminal: Brass with silver-plating Contact: Stainless steel with silver-plating Dielectric Strength: No dielectric breakdown after 250V after one minute Contact Arrangement: single pole, single throw T1 Electrical Environmental T2 Operating Temperature Range: -25 to 70°C Storage Temperature Range: -30 to 80°C Mechanical Shock: MIL-STD-202F, Method 213B, Test Condition A. Gravity: 50G (peak value), 11 msec. Direction and times: 6 sides and 3 times in each direction. High reliability. Rating: 50mA, 12 Vdc Life: 50,000 cycles Actuator Travel: .010” + .008”/ - .004” Contact Resistance: 100 mΩ max. Insulation Resistance: 100 MΩ min at 500Vdc ORDERING INFORMATION Series Size: 04 = 3.5mm x 6mm Height (“H”): A = .169 (4,30), B = .197 (5,00) 95C04A3GWRT RoHS compliant Packaging: Blank = Tube, R = Tape and Reel (see pkg note)  Terminal Style: Blank = Thru-Hole, GW = Gull Wing Operating Force: 3 = 160g (brown), 5 = 320g (orange) Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Vibration: MIL-STD-202F, Method 201A. Passed 6 hours (2 hours in each) of three perpendicular planes at a cycle of 10-55-10Hz/minute. Soldering Process Hand Soldering: Use a soldering iron of 30 watts, controlled at 350°C for 5 seconds maximum while applying solder. Reflow Soldering (surface mount versions only): Peak temperature 260°C (500°F). Wave Soldering: 260°C (500°F) max. for 5 seconds. Subject to P.C.B. .063 in. (1,6mm) thickness. Packaging Thru-Hole: 135 pcs/tube. Surface Mount: 135 pcs/tube, 1800 pcs/reel (.169” height), 1600 pcs/reel (.197” height). 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Tact Switches .118 .138 (3,00) (3,50) "H" DIM. ± .008 30˚ ("H" DIM. ± 0,20) See Ordering Information .138 ±0.20 (3,50 ±0,50)
95C04A3GWT 价格&库存
很抱歉,暂时无法提供与“95C04A3GWT”相匹配的价格&库存,您可以联系我们找货
95C04A3GWT
  • 135+5.24450135+0.67852
