95CW06D3GWRT
95CW06D3GWRT
    GRAYHILLINC.
    SMD
    轻触开关 立贴
95CW06D3GWRT 数据手册
Washable Tactile Switches SERIES 95C 6mm Square, Washable Features • Designed to Allow Submersed Washing After Soldering • Excellent Tactile Feedback • Thru-hole, Gull Wings, Right Angle, and J-Lead Versions DIMENSIONS: Washable Switches CL Front View .027 (0,70) CL Thru-Hole C L Thru-hole T3 T4 4xØ.040 ±.002 (4xØ1,00 ±0,05) .256 ±.020 (6,50 ±0,50) Ø.118 (Ø3,00) T2 .157 ±.004 (4,00 ±0,10) .138 ±.020 (3,50 ±0,50) .311 ±.020 (7,90 ±0,50) .157 (4,00) .256 ±.004 (6,50 ±0,10) C L "H" DIM. See Ordering Information .071 +0.0-.02 (1,80 +0,0-0,5) .236 (6,00) Side View Ø.118 (Ø3,00) .248 (6,30) T1 Used in applications such as consumer electronics, audio equipment, PCs, VCRs, cable boxes, modems, communications equipment, controls, security and alarm equipment, and test and measurement equipment. in inches (and millimeters) Top View .244 (6,20) applications • Surface Mount Versions Compatible with SMT Assembly Including Infrared and Vapor Phase • Ultraminiature and Lightweight Structure Suitable for High Density Mounting CL P.C.B. LAYOUT CL "H" DIM. See Ordering Information Gull Wing .433 (11,00) .267 (6,80) .102 (2,60) .212 (5,40) Gull Wing 0˚ CIRCUITRY J-Lead CL Ø.118 (Ø3,00) Tact Switches 10˚ .177 (4,50) .268 (6,80) 0.297 ±0.02 (7,55 ±0,50) F1 T1 .276 (7,02) T2 Right Angle F2 cIrcuIt DIaGraM CIRCUITRY .028 (0,70) C L "H" DIM. See Ordering Information 0˚ J-Lead .228 (5,80) .004 ±.004 (0,10 ±0,10) 10˚ .339 (8,60) .157 (4,00) P.C.B. LAYOUT "H" DIM. ±0,008 ("H" DIM. ±0,20) See Ordering Information 0.157 ±0.02 (4,00 ±0,50) 0.181 (4,61) .240 (6,10) .102 (2,60) .212 (5,40) .016 (0,40) .228 ±0.004 (5,80 ±0,10) 0.154 (3,90) Ø.118 (Ø3,00) P.C.B. LAYOUT .354 ±0.004 0.031 (9,00 ±0,10) (0,80) 0.136 ±0.012 (3,45 ±0,30) .146 (3,70) 0.098 ±0.004 (2,50 ±0,10) 0.197 ±0.004 .165 (5,00 0.067 (4,20) ±0,10) (1,70) P.C.B. LAYOUT Unless otherwise specified, tolerances are ±.010 (0,25). SPECIFICATIONS: Washable Switches Materials Base: UL94V-0 Nylon thermoplastic Cover: Stainless steel,nickel silver Actuator: Silicone rubber Terminal: Brass with silver-plating Contact: Stainless steel with silver-plating Dielectric Strength: No dielectric breakdown after 250V for one minute Contact Arrangement: single pole, single throw Passed 6 hours (2 hours in each) of three perpendicular planes at a cycle of 10-55-10Hz/ minute. High reliability. Electrical Environmental Operating Temp. Range: -25 to 70°C Storage Temp. Range: -30 to 80°C Mechanical Shock: MIL-STD-202F, Method 213B, Test Condition A. Gravity: 50G’s (peak value), 11 msec. Direction and times: 6 sides and 3 times in each direction. High reliability. Vibration: MIL-STD-202F, Method 201A. Hand Soldering: Use a soldering iron of 30 watts, controlled at 350°C for 5 seconds maximum while applying solder. Reflow Soldering (surface mount versions only): Peak temperature 260°C (500°F). Wave Soldering: 260C° (500°F) maximum for 5 seconds subject to PCB .063 in. (1,60 mm) thickness. Rating: 50mA, 12 Vdc Life: See table, page C-12 Actuator Travel: .018” ± .008” Contact Resistance: 100 mΩ max. Insulation Resistance: 100 MΩ min. at 500Vdc Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Soldering Process 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Washable Tactile Switches ORDERING INFORMATION: Washable Switches Thru-Hole Part Number 95CW06A1T 95CW06B1T 95CW06C2T 95CW06C3T 95CW06C5T 95CW06D2T 95CW06D3T 95CW06D4T 95CW06D5T 95CW06E2T 95CW06E3T 95CW06E4T 95CW06E5T Height (“H”) in (mm) Force (Grams) Actuator Color .091 (2,3) 160 Silver .122 (3,1) 160 Brown .138 (3,5) 180 Brown .138 (3,5) 260 Red .138 (3,5) 360 Clear .150 (3,8) 180 Brown .150 (3,8) 260 Red .150 (3,8) 520 Yellow .150 (3,8) 360 Clear .205 (5,2) 180 Brown .205 (5,2) 260 Red .205 (5,2) 520 Yellow .205 (5,2) 360 Clear Gull Wing Height (“H”) in (mm) .091 (2,29) .122 (3,10) .138 (3,51) .138 (3,51) .138 (3,51) .150 (3,81) .150 (3,81) .150 (3,81) .150 (3,81) .205 (5,21) .205 (5,21) .205 (5,21) .205 (5,21) Force Actuator Electrical Tube Tape & Reel * (Grams) Color Life (Cycles) Packaging Packaging 160 Silver 100,000 75PCS/Tube 2000PCS/Reel 160 Brown 100,000 75PCS/Tube 2000PCS/Reel 180 Brown 500,000 75PCS/Tube 1900PCS/Reel 260 Red 500,000 75PCS/Tube 1900PCS/Reel 360 Clear 500,000 75PCS/Tube 1900PCS/Reel 180 Brown 500,000 75PCS/Tube 1900PCS/Reel 260 Red 500,000 75PCS/Tube 1900PCS/Reel 520 Yellow 50,000 75PCS/Tube 1900PCS/Reel 360 Clear 500,000 75PCS/Tube 1900PCS/Reel 180 Brown 500,000 77PCS/Tube 900PCS/Reel 260 Red 500,000 77PCS/Tube 900PCS/Reel 520 Yellow 50,000 77PCS/Tube 900PCS/Reel 360 Clear 500,000 77PCS/Tube 900PCS/Reel Height (“H”) in (mm) .091 (2,29) .122 (3,10) .138 (3,51) .138 (3,51) .138 (3,51) .150 (3,81) .150 (3,81) .150 (3,81) .150 (3,81) .205 (5,21) .205 (5,21) .205 (5,21) .205 (5,21) Force Actuator Electrical Tube Tape & Reel * (Grams) Color Life (Cycles) Packaging Packaging 160 Silver 100,000 75PCS/Tube 2000PCS/Reel 160 Brown 100,000 75PCS/Tube 1900PCS/Reel 180 Brown 500,000 75PCS/Tube 1800PCS/Reel 260 Red 500,000 75PCS/Tube 1800PCS/Reel 360 Clear 500,000 75PCS/Tube 1800PCS/Reel 180 Brown 500,000 75PCS/Tube 1800PCS/Reel 260 Red 500,000 75PCS/Tube 1800PCS/Reel 520 Yellow 50,000 75PCS/Tube 1800PCS/Reel 360 Clear 500,000 75PCS/Tube 1800PCS/Reel 180 Brown 500,000 77PCS/Tube 900PCS/Reel 260 Red 500,000 77PCS/Tube 900PCS/Reel 520 Yellow 50,000 77PCS/Tube 900PCS/Reel 360 Clear 500,000 77PCS/Tube 900PCS/Reel J-Lead Part Number 95CW06A1JT 95CW06B1JT 95CW06C2JT 95CW06C3JT 95CW06C5JT 95CW06D2JT 95CW06D3JT 95CW06D4JT 95CW06D5JT 95CW06E2JT 95CW06E3JT 95CW06E4JT 95CW06E5JT Right Angle Part Number Height in (“H”) (mm) Force (Grams) Actuator Color 95CW06A3RART .031 (0,79) 260 Red 95CW06B3RART .039 (0,99) 260 Red 95CW06C3RART .091 (2,31) 260 Red Electrical Life (Cycles) Tape & Reel Packaging 500,0000 700PCS/Reel 500,0000 700PCS/Reel 500,0000 700PCS/Reel Available from your local Grayhill Component Distributor. *Insert “R” before “T” for tape and reel packaging. For prices and discounts, contact a local Sales Office, an authorized local distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Tact Switches Part Number 95CW06A1GWT 95CW06B1GWT 95CW06C2GWT 95CW06C3GWT 95CW06C5GWT 95CW06D2GWT 95CW06D3GWT 95CW06D4GWT 95CW06D5GWT 95CW06E2GWT 95CW06E3GWT 95CW06E4GWT 95CW06E5GWT Electrical Life (Cycles) Tube Packaging 100,000 75PCS/Tube 100,000 75PCS/Tube 500,000 75PCS/Tube 500,000 75PCS/Tube 500,000 75PCS/Tube 500,000 75PCS/Tube 500,000 75PCS/Tube 50,000 75PCS/Tube 500,000 75PCS/Tube 500,000 77PCS/Tube 500,000 77PCS/Tube 50,000 77PCS/Tube 500,000 77PCS/Tube
95CW06D3GWRT 价格&库存
很抱歉,暂时无法提供与“95CW06D3GWRT”相匹配的价格&库存,您可以联系我们找货
95CW06D3GWRT
    • 1+15.24960
    • 200+6.09120
    • 500+5.88600
    • 1000+5.77800
