947706-001
947706-001
    GRAYHILLINC.
    DIP
    KNOB FOR ROTRY DIP SW GRY 0.370"
947706-001 数据手册
Rotary DIP Switches SERIES 94H DIMENSIONS ACTUATOR STYLES In inches (and millimeters) Tolerances are ± .010 inches unless specified otherwise. 3 0 0.100 (2,54) Typ. 2 4 C C 8 1 0.050 (1,27) .140 DIA. ( ∅ 3,56) 4 1 6 2 3 5 0.240 (6,10) 0.250 [6.35] 0.315 [8.00] .140 DIA. ( ∅ 3,56) .100 .005 TYP. (2,54 0,13) 2 1 2 7 0 .190 (4,83) 2 PLACES .146 (3,71) PC board layout as viewed from the top of the switch CORNER CLOSEST TO PIN #1 .380 (9,65) .225 (5,72) 4 C 1 6 4 5 2 C 8 5 3 .390 (9,91) 4 0 1 3 .040 .005 (1,02 0,13) 45 .270 (6,86) OR .170 (4,32) OR .090 (2,29) .200 (5,08) SEE ORDERING INFORMATION 0.385 [9.78] Standard Thru-Hole 23 EXTENDED ACTUATOR TYPES 0 1 2 4 5 0.410 (10,41) CORNER CLOSEST TO PIN #1 .190 (4,83) 2 PLACES "F" style rotor All actuation types are available in octal (8), binary coded decimal (10), or hexadecimal (16) codes; with either standard or complement output. Standard code outputs have natural color rotors; complements in a contrasting color. .025 (0,64) 3 89 Figure 2 "A" style rotor Surface Mount J-Lead .390 (9,91) 67 7 1 2 2 3 45 23 01 .500 (12,7) Hex–16 position Figure 1 0.280 Solder pad layout as viewed from the top of the switch .225 (5,72) EF 1 0.070 TYP 89 01 0 8 67 CD C AB 4 C CD .380 (9,65) 2 AB 0.100 TYP 9 0 1 PIN #1 BCD–10 position EF 4 5 4 5 6 0.560 .190 (4,83) 2 PLACES Octal–8 position 7 8 .390 (9,91) 4 5 3 .020 +.004/-.002 (0,51 + 0,10/0,05) 2 .100 .005 (2,54 0,13) TYP. 0 1 .060 (1,52) TYP. 6 7 Surface Mount Gullwing .270 (6,86) OR .170 (4,32) OR .090 (2,29) .282 (7,16) SEE ORDERING INFORMATION Figure 3 TERMINALS ARE .020 +.004/-.002 (0,51 +0,10/0,05) WIDE BY .012 .002 (0,31 0,05) THICK .038 DIA. HOLE SIZE RECOMMENDED .300 (7,62) TYP. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP 20 DIP Switches FEATURES • Sealed Construction; No Tape Seal Required • Surface Mount or Thru-Hole Style • Tube or Tape and Reel Packaging • Octal, BCD, and Hexadecimal Code • In Standard or Complement • Standard and Right Angle Mount • Flush or Extended Actuators • Gold-Plated Contacts Binary Coded Rotary DIP Switches DIMENSIONS TAPE AND REEL PACKAGING: Series 94H In inches (and millimeters) Right Angle Thru-Hole Meets requirements of EIA 481-2. .430 (10,92) .210 (5,33) .282 (7,16) 2 3 7 2 3 6 4 5 CONDUCTIVE PLASTIC EMBOSSED TAPE 7 1 0 1 0 5 7 2 3 7 4 5 6 .100 ± .005 (2,54 ± 0,13) TYP. 4 5 6 8 C 2 PC board layout as viewed from the top of the switch 6 .156 (3,96) PIN #1 1 C 4 0 4 TERMINALS ARE .020 ±.002 (0,51±0,05) WIDE BY .012 ±.002 (0,31 ±0,05) THICK 1 .145 (3,68) 13 INCH DIAMETER REEL 0 1 2 3 .190 .400 (4,83) (10,16) .100 ± .005 (2,54 ± 0,13) ORDERING INFORMATION: Series 94H 6 7 5 6 7 6 7 5 4 5 2 3 2 3 4 6 7 0 1 1 5 0 4 0 2 3 4 SERIES 94 High Temperature Knobs: For Shaft Extensions 0 1 * 27 Pieces per tube for surface mount and thru-hole, 24 pieces per tube for right angle switches. PIN #1 CHAMFER 2 3 DIP Switches 94HAB10WRT 16mm 1 Series Actuator Style: A = Flush, Figure 1 B = .270, Figure 3 (see page B-21) C = .170, Figure 3 (see page B-21) E = .090, Figure 3 (see page B-21) F = Flush, Figure 2 Code: B = Standard (Natural), C = Complementary (Contrasting Color) RoHS Compliant Packaging: R = Tape and Reel, (Surface Mount Only) Blank = Tube* Terminal Style: RA = Right Angle, Thru-Hole J = J-Lead W = Surface Mount Blank = Thru-Hole Number of Positions: 08 = Octal, 8 Position 10 = BCD, 10 Position 16 = Hex, 16 Position DIRECTION OF FEED 24mm Each reel contains the following number of switches with a 15.35 inch (390 mm) minimum leader and a 6.30 inch (160 mm) minimum trailer. 94HA style 94HB style 94HC style 94HE style 94HF style 750 sw/reel 150 sw/reel 200 sw/reel 300 sw/reel 750 sw/reel .190 (4,83) .370 (9,40) 1 Slotted knobs show switch markings. Contact Grayhill for other knob material/ marking color combinations and geometrics. 2 3 .040 (1,02) .370 (9,40) A ORDERING INFORMATION: 4 .210 (5,33) 5 .040 (1,02) B * Use only with Actuator Type B or C Series 94 High Temperature Knobs* Knob Style and Height Knob Color Arrow Color Part Number 1A 5A 1B 1B 2B 3B 4B 1B 4B 5B Gray Gray Black Gray Gray Gray Gray Natural Black Gray N/A Black N/A N/A White Black Black N/A White Black 947706-001 947706-005 947705-001 947705-012 947705-004 947705-017 947705-018 947705-009 947705-010 947705-019 *Ordered as a separate item. B = Standard (Natural), C = Complementary (Conrasting Color). DIP 21 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Thru-Hole DIP Switches SERIES 94R Economical, Binary Coded FEATURES • 10,000 Cycles of Operation • Gold-Plated Contacts • Sealed Contact System • Right Angle Mount • Octal, BCD & Hexadecimal Codes • Standard or Complement • RoHS Compliant DIMENSIONS CODE & TRUTH TABLES: Series 94H and 94R In inches (and millimeters) .094 (2,93) Standard Output .162 (4,11) .213 (5,41) .480 .443 (12,19) (11,25) .210 (5,33) DIP Switches .433 (11,00) .200 (5,08) .689 (17,50) 1.123 (28,52) .044 (1,12) DIA. 1 C 4 SWITCH POSITION .286 (7,26) 8 C 2 Pin #1 .179 (4,55) PC board layout as viewed from the top of the switch .059 (1,50) .058 (1,47) DIA. .199 (5,05) .235 (5,97) Unless otherwise indicated, tolerances are ± .010 (0,25) SPECIFICATIONS: Series 94H and 94R Electrical Ratings Make-and-break Current Rating: 30 mA at 30 Vdc for 10,000 cycles of operation. Carrying Current Rating: 100 mA at 50 Vdc Contact Resistance: 50 mohms maximum initially (measured at 10 mA, 50 mVdc). 150 mohms maximum after life. Insulation Resistance:(measured at 100 Vdc across open switch contacts) Initial: 5000 Mohms minimum. After Life: 1000 Mohms minimum. Dielectric Strength: (measured across open switch contacts) Initial: 500 Vac RMS minimum. After Life: 250 Vac RMS Moisture Resistance: 240 hours with temperature cycling and polarization. Passes insulation resistance and dielectric strength per MIL-STD-202F, Method 106 following exposure. Materials and Finishes Rotor and Switch Body: Plastic (UL94V-O) Contact Material: Copper alloy plated. 30 microinches minimum gold over 50 microinches minimum nickel. Shorting Member: Copper alloy plated. 30 microinches minimum gold over 50 microinches minimum nickel. Terminals: Copper alloy, matte tin plated over nickel barrier. Mechanical Ratings Mechanical Life: 10,000 cycles of operation. One cycle is a rotation through all positions and a complete return through all positions. Mechanical Shock: 1000g's, 0.5 mS, half sine per MIL-STD-202F, Method 213, Test Condition E. Vibration Resistance: 10-2000 Hz at 15G or 0.060" double amplitude per MIL-STD-202F, Method 204, Test Condition B. Operational Torque: 2 to 6 inch-ounces initially and 1.2 inch-ounces minimum after life. CODE OUTPUT CODE OUTPUT 1 2 4 8 1 2 4 8 Complement Output 0 1 2 3 4 5 6 7 8 9 A B C D E F Dot indicates terminal to common connection. All switches are continuous rotation. Octal and Octal Complement outputs are 0 thru 7 positions. BCD and BCD Complement outputs are 0 thru 9 positions. Hexadecimal and Hexadecimal Complement outputs are 0 thru F positions. Standard codes have natural color rotors; complements have rotors in a contrasting color. Internal O-ring: Rubber BUNA-N Soldering Information Soldering Temperature: 260° C maximum. Cleaning: Acceptable solutions include 1-1-1 Trichlorenthane, Freon (TF, TE, or TMS), Isopropyl Alcohol and detergent (140°F maximum). Solutions which are not recommended include Acetone, Methylene Chloride, and Freon TMC. ORDERING INFORMATION: Series 94R Continuous Rotation Versions Code No. of Positions Standard Code Part Number Complement Part Number 8 10 16 94RB08CT 94RB10CT 94RB16CT 94RC08CT 94RC10CT 94RC16CT No. of Positions Standard Code Part Number Complement Part Number 16 94RB16FT 94RC16FT Octal BCD Hexadecimal Rotational Stop Versions* Environmental Ratings Code Operating Temperature Range: -40° to +85°C. Storage Temperature Range: -40° to +85°C. Hexadecimal * Consult Grayhill for 8 or 10 position DIP 21 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
947706-001 价格&库存
很抱歉,暂时无法提供与“947706-001”相匹配的价格&库存,您可以联系我们找货
