10C1015-1
10C1015-1
    GRAYHILLINC.
    10C1015-1
10C1015-1 数据手册
Pushbutton Options and Accessories SEALED TERMINAL AND WIRE LEAD OPTIONS OPTION -E AND -EW FEATURES • 1/4, 1/2, and 1 Amp • Limit, Overtravel, or Panel Seal • Butt or Wiping Contact • Normally Open or Normally Closed • Momentary or Push/Pull • Series 23, 30, 39 and 46 Option -EW, Potted Base & 6" Wire Leads Option -E Epoxy-Sealed Terminals SPECIFICATIONS Rating Criteria Pushbutton Switches Make and Break Current Rating: See page for standard part number Contact Resistance: 25 milliohms maximum on a new switch. Less than 4 milliohms per inch of wire for wire lead option styles. Insulation Resistance: 1,000 megohms minimum between mutually insulated parts Voltage Breakdown: 1,000 Vac minimum between mutually insulated parts Materials and Finishes Potting Sleeve (Series 39): Thermoset Plastic Wire Leads: #26AWG, (.99mm diameter) insulated Teflon, Copper stranded wire, per MlL-W-16878,Type E. Ends are stripped 0.250" (6.35) and solder dipped. For other specifications, see Page References. Standard Part Number Red Button Standard Part Number Black Button 23-1 30-1 30-15 30-17 RED 30-16 RED 30-251 RED 30-252 RED 30-32 RED 30-6 30-601 RED 39-1* –––– 39-12* 39-101 39-351 RED 39-352 RED* 39-601 RED 39-701*** 39-702*** 46-101 RED 46-102 RED 46-110 RED 46-111 RED 46-150 RED 46-151 RED 46-200 RED 46-201 RED 46-270 RED 46-271 RED 23-4 30-3 30-37 30-17 BLK 30-16 BLK 30-251 BLK 30-252 BLK 30-32 BLK 30-2 30-601 BLK 39-3* 39-2 39-24* –––– 39-351 BLK 39-352 BLK* 39-601 BLK –––– –––– 46-101 BLK 46-102 BLK 46-110 BLK 46-111 BLK 46-150 BLK 46-151 BLK 46-200 BLK 46-201 BLK 46-270 BLK 46-271 BLK Choices of Suffix -E -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -EW** -E,- EW -EW** -EW** -EW** -E, -EW -EW* -EW** -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E -E -E -E Length Behind Panel In inches (and millimeters) -EW Style Standard Switch Body & Terminals 0.665 0.592 0.679 0.958 0.958 0.632 0.645 0.867 0.605 0.592 0.315 0.490 0.455 0.650 0.350 0.529 0.315 0.800 0.510 0.890 0.890 0.890 0.890 0.957 0.957 0.921 0.921 0.957 0.957 (16,89) (15,04) (17,25) (24,33) (24,33) (16,05) (16,38) (22,02) (15,37) (15,04) (8,00) (12,45) (11,56) (16,51) (8,89) (13,44) (8,00) (20,32) (12,95) (22,61) (22,61) (22,61) (22,61) (24,31) (24,31) (23,39) (23,39) (24,31) (24,31) –––– 0.645 0.728 1.007 1.007 0.685 0.700 0.896 0.640 0.645 0.440 0.575 0.575 0.775 0.450 0.630 0.440 0.925 0.750 0.957 0.957 0.957 0.957 1.024 1.024 –––– –––– –––– –––– (16,38) (18,49) (25,58) (25,58) (17,40) (17,78) (22,76) (16,26) (16,38) (11,18) (14,61) (14,61) (19,69) (11,43) (16,00) (11,18) (23,50) (19,05) (24,31) (24,31) (24,31) (24,31) (26,01) (26,01) *Epoxy potting sleeve enlarges the diameter of the -EW style to 0.300 (7,62). **Sealed terminal (-E) option is not necessary; terminals have sealed construction. ***Natural Color Button †Adjustable from 1.214 (30,84) to 1.334 (33,88) dependent on button height, see switch pages. Pushbutton 60 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton Options and Accessories ORDERING INFORMATION Use the Selector Charts at the beginning of the section to select a series. Use the pages listed there or referenced here to select a switch. Standard Part Number Choice of Button Color (see switch pages) (see switch pages) –––– –––– –––– –––– 30-01-01-500-XX 30-01-04-500-XX 30-05-01-502-XX 30-05-04-502-XX –––– 46-01-05-500-XX 46-01-07-500-XX 46-01-08-500-XX 46-01-09-500-XX 46-05-05-502-XX 46-05-07-502-XX 46-05-08-502-XX 46-05-09-502-XX –––– –––– –––– –––– 30-001-A-XX 30-002-A-XX 30-015-A-XX 30-017-A-XX 30-1-1-50-XX 30-1-4-50-XX 30-5-1-52-XX 30-5-4-52-XX 30-601-A-XX 46-1-5-50-XX 46-1-7-50-XX 46-1-8-50-XX 46-1-9-50-XX 46-5-5-52-XX 46-5-7-52-XX 46-5-8-52-XX 46-5-9-52-XX 46-102-A-XX 46-111-A-XX 46-200-A-XX 46-201-A-XX To order epoxy sealed terminals, add the suffix E to the selected part number as allowed in the chart. Example: 30-1-E. To order the epoxy-potted version with 6-inch wire leads, use the suffix -EW as allowed in the chart. Example: 39-1-EW Available From Your Local Grayhill Distributors. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Choices of Options -E, -E, -E, -E, -E, -E, -E, -E, -E, -E, -E, -E -E -E, -E, -E -E -E, -E, -E -E -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW Length Behind Panel In inches (and millimeters) Standard Switch & Terminals 1.119 (28,42) 1.132 (28,75) 1.204 (30,58) Adjustable† 1.100 (27,94) 1.257 (31,93) 0.930 (23,62) 1.130 (28,70) 1.119 (28,42) 1.361 (34,57) 1.451 (36,86) 1.381 (35,08) 1.381 (35,08) 1.179 (29,95) 1.465 (37,21) 1.188 (30,18) 1.317 (33,45) 1.417 (35,99) 1.417 (35,99) 1.448 (36,78) 1.448 (36,78) -EW Style Body 1.172 (29,77) 1.167 (29,64) 1.253 (31,83) Adjustable† 1.153 (29,29) 1.310 (33,27) 0.983 (24,97) 1.183 (30,05) 1.172 (29,77) 1.428 (36,27) 1.518 (38,56) –––– –––– 1.246 (31,65) 1.532 (38,91) –––– –––– 1.484 (37,69) 1.484 (37,69) –––– –––– CIRCUITRY: Series 46 N.C. (YELLOW) C1 (RED) N.O. (GREEN) *Epoxy potting sleeve enlarges the diameter of the -EW style to 0.300 (7,62). **Sealed terminal (-E) option is not necessary; terminals have sealed construction. ***Natural Color Button †Adjustable from 1.214 (30,84) to 1.334 (33,88) dependent on button height, see switch pages. SPDT WIPING CONTACTS Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton 61 Pushbutton Switches Standard Part Number Without Options Choice of Button Color Pushbutton Options and Accessories ACCESSORIES For Pushbutton Switches Button Caps Decorative Mounting Nuts Pendant Housing Button Guard DIMENSIONS In Inches (and millimeters) .75 (19,1) ACROSS FLATS Decorative Mounting Nuts .44 (11,2) ACROSS FLATS .50 (12,7) ACROSS FLATS 30C1023-1 Pushbutton Switches .46 (11,7) DIA. .52 (13,2) DIA. Brass, nickel-plated for 1/4" (6,35) bushing. .09 (2,3) 07C1040-1 23C1024-1 .77 (19,6) DIA. Brass, nickel-plated for 5/16" (7,93) bushing. Brass, nickel-plated for 15/32" (11,9) bushing. .12 (3,1) .09 (2,3) Button Caps and Guard .89 (22,6) DIA. 30B1012 07Z1047 Thermosetting plastic (Fasten to button with cyanoacrylate adhesive) black, red or white. .19 (4,8) .09 (2,3) .34 (8,6) For use with all Series 30 and 39 switches except part number 39-101. See switch pages. .25 (6,4) DIA. 07Z4950 07Z5051 .33 (8,4) REF. Flat Cap .89 (22,6) 1.19 1.03 (30,2) (26,16) .27 (6,86) DIA. Brass, zinc trivalent chromate-plated for 15/ 32" (11,9) bushing. .41 (10,4) .59 (15,0) .08 (2,0) Housing 2.45 (62,23) .42 (10,67) Thermoplastic, black or red color. For use with Series 2000 and Series 7 switches. See switch pages. 1.00 (25,4) DIA. Remote Switching Accessories Pendant Housing and Caps 10C1015-1 1.19 (30,2) .08 (2,03) .25 (6,4) .89 (22,6) Recessed Cap 1.04 1.19 (30,2) (26,4) .48 (12,2) .48 (12,2) Application: All grayhill pushbutton switches with 15/32-32 bushings: catalog numbers 2201, 2202, 07-7, 07-8, 07-21, 07-22, 07-26, 4001, 4002, 10-9, 10-10, 10-100, 10-101, 30-16, 30-17 and 30-32. any other switch with 15/32-32 bushing if it fits housing. Material: Thermoplastic Specials: other colors available on special order. ORDERING INFORMATION: Mounting Nuts, Button Caps, and Guards Part Number Color 07C1040-1 23C1024 30C1023-1 07Z1047-1 BLK 07Z1047-2 RED 10C1015-1 30B1012-5 30B1012-8 30B1012-9 Decorative Nut Decorative Nut Decorative Nut Black Button Cap Red Button Cap Button Guard Red Cap White Cap Black Cap Pendant Housing and Caps Part Number 07Z4950 07Z4950 07Z5051 07Z5051 RED BLK RED BLK Description Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Red Flat Cap & Housing Black Flat Cap & Housing Red Rcssd Cap & Housing Black Rcssd Cap & Housing Sold only as sets of one housing and one cap. Pushbutton 62 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
10C1015-1 价格&库存
很抱歉,暂时无法提供与“10C1015-1”相匹配的价格&库存,您可以联系我们找货
