11K5014-JMNB
11K5014-JMNB
    GRAYHILLINC.
    SWITCH ACCESS ROTARY SWITCH BLAK
11K5014-JMNB 数据手册
Control Knob Accessories Control Knobs Ideally Suited for Encoder and Rotary Switches FEATURES • Standard Fit for Grayhill Encoder and Rotary Switches • Custom Materials, Styles, Colors and Markings Available • Standard Black or Gray • Choice of Spring Clip (Press-On) or Metal Insert with Set Screw Versions Contact Grayhill for special design considerations Optical and Mechanical Encoders DIMENSIONS In inches (and millimeters) Top View Style 5013 Top View Style 5014 .620 (15,75) .440 (11,18) DIA. .593 (15,06) DIA. .700 (17,78) DIA. .335 (8,51) .600 (15,24) 1.330 (33,78) DIA. Available in .250 Dia. Shaft only.* Top View Style 5015 .894 (22,71) DIA. Style 5017 .500 (12,7) DIA. Top View .440 (11,2) .662 (16,81) .350 (8,9) DIA. .500 (12,7) Available in .125 and .157 (4mm) dia. shaft in spring clip (press-on) version only.* . *See Ordering Information. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Control Knob Accessories DIMENSIONS In inches (and millimeters) Style 5019 Top View Style 5020 Top View .315 (8,00) .393 (9,98) C OF L .220 (5,59) R. .092 (2,34) TYP. (4 PLACES) .500 (12,7) DIA. 1.575 DIA. (40,01) .660 (16,76) .220 R. (5,59) .550 (13,97) DIA. .215 (5,46) .400 (10,16) Available in ABS, .250 dia. shaft in spring clip (press-on). The locking clip is also available, requires a custom shaft.** Style 5028 Style 5029 Top View Top View 1.090 (27,69) Optical and Mechanical Encoders .710 (18,03) DIA. *See Ordering Information. .500 (12,7) DIA. .730 (18,54) .500 (12,7) SPRING CLIP **Contact Grayhill representative ORDERING INFORMATION Series Style*: 5013, 5014, 5015, 5017, 5019, 5020, 5028, 5029 (see dimension drawings for style options) Shaft Diameter: J = .125 dia. shaft E = .157 (4mm) dia. shaft K = .250 dia. shaft 11K5028-KCNB Knob Color: B = Black G = Gray Material: A = ABS (available on the styles 5017 and 5020 only) N = Nylon Version: C = Spring Clip (press-on) F = Flat Clip (available on the style 5013 only) L = Locking Clip (available on the style 5020 only) M = Metal Insert w/Set Screw(s) Custom materials, styles and colors are available. For prices and discounts, contact a local sales office or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
11K5014-JMNB 价格&库存
很抱歉,暂时无法提供与“11K5014-JMNB”相匹配的价格&库存,您可以联系我们找货
11K5014-JMNB
    • 1+135.14040
    • 200+53.92440
    • 500+52.12080
