76P06
76P06
    GRAYHILLINC.
    DIP
    COVER FOR 6POS DIP SWITCH CLEAR
76P06 数据手册
DIP Switch Options and Accessories OPTIONS Other Switch Markings For Series 76RSB, 76RSC, 76RSD, & 90B A line can be added to the recessed rocker or Series 90 slide actuator to provide positive identification of the actuator position. To order, add L as a final suffix to the part number. For example, 76RSB08 becomes 76RSB08L; and, 90B08S becomes 90B08SL. Available from a local Grayhill Distributor. For Series 76, 78, & 90 We can mark your part number or other wording on the switch, often at no charge. For some markings there will be a nominal charge for tooling plus a set-up charge. In addition, there is a marking charge per side per switch. Add it to the unit price and discount it accordingly. To order, contact Grayhill. DIP Switches Position Identification Line Option ACCESSORIES Protective Cover Accessory For Series 76, & 78 Rigid, clear plastic cover fits all but toggle actuated switches. It provides a top cover for less strenuous cleaning, serves as a dust cover in dirty environments, and provides protection against accidental actuation. Material: 76,78, only-Polycarbonate. Purchase as a separate item. Check length of the desired DIP Switch, and then select from the ordering information on this page. Available from a local Grayhill Distributor. .130 .152 (3,86) (3,30) TYP. TYP. .422 (10,72) REF. .217 (1,20) REF. SEE NOTE Note: For length, add .042 "(1,07 MM) to length of DIP switch. DIPSTICK Accessory For all series Pen-sized plastic DIPSTICK has a tapered end for actuating DIP Switches. Part Number ........................ 90-DIPSTICK Available from a local Grayhill Distributor ORDERING INFORMATION Length Inches Protective Cover Part Number 0.280 0.380 0.480 0.580 0.680 0.780 0.880 0.980 1.080 1.180 1.780 76P02 76P03 76P04 76P05 76P06 76P07 76P08 76P09 76P10 79P10 79P16 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP 22
76P06 价格&库存
很抱歉,暂时无法提供与“76P06”相匹配的价格&库存,您可以联系我们找货
76P06
    库存:834
    76P06
    • 162+6.02005
    • 1000+4.07276
    库存:834
    76P06
    库存:834
    76P06
      • 97+8.2715897+1.07350
      • 485+7.48796485+0.97180
      库存:834
