32LED-GRN
32LED-GRN
    GRAYHILLINC.
    ACCY PB SWITCH HOLD GRN LED PC
32LED-GRN 数据手册
Butt Contact Pushbutton Switches SERIES 32 SPST and SPDT, Stackable with LED FEATURES • Stackable, Provides Custom Switch Arrangements • .200" Centers When Stacked • SPST–N.O., SPST–N.C. Circuitry in the Same Package • Process Compatible, Internally Sealed Plunger • Status/Reset or Press-to-Test Functions with Companion LED (In inches and millimeters) GRAYHILL GRAYHILL XXXX GRAYHILL GRAYHILL GRAYHILL Pushbutton Switches SWITCH DIMENSIONS E.I.A. DATE CODE Rating at 28 Vdc Resistive Operations at Rated Load Part Number 150 mA 100,000 32-01 Action Total Travel Momentary .200 (5,08) TYP. .120 (3,05) .220 (5,59) .100 (2,54) .100 (2,54) .050 (1,27) Approx. .084 (2,13) DIA. .180 (4,57) .272 (6,91) .110 (2,79) .090 (2,29) .050 (1,27) .070 (1,78) .100 ± .004 (2,54 ± 0,10) TYP. BTWN. PINS OF STACKED SWITCHES .030 ± .002 (0,76 ± 0,05) DIA. 4 PLS. .050 (1,27) .100 ± .004 (2,54 ± 0,10) .100 ± .004 (2,54 ± 0,10) TYP. BTWN. PINS OF SAME SWITCH .100 ± .004 (2,54 ± 0,10) .200 (5,08) REF. .190 (4,83) .400 (10,16) Unless otherwise stated, linear dimension tolerances are ± .010 (0,25); diameters are ± .005 (0,13) LED DIMENSIONS SWITCH CIRCUITRY (In inches and millimeters) 2 Circuits Per Switch N.C. Actuator N.C. SPST N.C. .220 (5,59) .200 (5,08) REF. .100 (2,54) .118 (3,0) DIA. GRAYHILL .050 (1,27) .100 (2,54) SPST N.O. .100 (2,54) .230 (5,84) .110 (2,79) .272 (6,91) Alternate Wiring C Actuator N.C. SPDT BREAK BEFORE C MAKE .180 .010 (4,57) (0,25) CATHODE N.O. N.O. .190 (4,83) .020 (0,51) SQ. 2 PLS. CONNECT PINS ON PC BOARD N.O. Unless otherwise stated, linear dimension tolerances are ± .010 (0,25); diameters are ± .005 (0,13) E-9 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Butt Contact Pushbutton Switches SPECIFICATIONS ORDERING INFORMATION: Individual Units Rating Criteria Part Number Description 32-01 32-02 32LED-RED 32LED-GRN 32LED-YEL Switch, 10 microinches, gold plating, black button, red body Switch, 30 microinches, gold plating, black button, red body Red LED and holder, red body Green LED and holder, red body Yellow LED and holder, red body Contact Resistance: 25 milliohms maximum on a new switch Voltage Breakdown: 1,000 Vac between mutually insulated parts Insulation Resistance: 1,000 megohms minimum Switch and LED Operating Temperature: -40°C to +85°C Grayhill or your local Distributor will assemble stacks of switches, LEDs or combinations. Materials and Finishes Assemblies of Switches or Switches and LED Combinations Switch Base, LED Base, Button and Cover: Polyester Shorting Bar: Phosphor bronze, gold-plated over nickel Switch Terminals: Brass, gold-plated over nickel LED Terminals: Steel, tin-plated Spring: Tinned Music Wire Example Part Number Basic switch part number (see Ordering Information) Number of ganged elements (2 thru 6) 32-01-6-AARGYA Color Min. MCD* Max. Viewing Angle Red Green Yellow 0.8 0.8 0.8 5.0 3.2 3.2 60° 60° 60° *MCD = Millicandellas at 2 mA Pushbutton Switches Arrangement definition (left to right, front view) A = Switch R = Red LED G = Green LED Y = Yellow LED LED Information Example part number describes a stack of 6 elements consisting of two switches, a red LED, a green LED, a switch and a yellow LED. Shorter stacks will have fewer letters in the arrangement definition. Contact Grayhill for stacks of more than six elements. Recommended Current: 2mA Current limiting resistor is not supplied. Assemblies of LEDs Only Example Part Number Basic identification for LEDs Number of ganged elements (2 thru 6) 32LED-3-RYG Arrangement definition (left to right, front view) R = Red LED G = Green LED Y = Yellow LED Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Example part number describes a stack of 3 LEDs, arranged red, yellow and green from left to right. Maximum number of stacked LEDs in this part numbering scheme is six. Contact Grayhill for stacks of more than six elements. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com E-10
32LED-GRN 价格&库存
很抱歉,暂时无法提供与“32LED-GRN”相匹配的价格&库存,您可以联系我们找货
32LED-GRN
  • 20+36.6346320+4.74547
库存:20
