300002
300002
    APEM(埃斐)
    BULB REMOVER
300002 数据手册
A01 SERIES INDUSTRIAL CONTROLS INSTALLATION & TOOLS Round & square operators Rectangular operators Max. panel thickness: .156" (4mm) PANEL MOUNTING ASSEMBLY Drill or punch hole per panel cut-outs above. ● Assemble front operator through hole and assemble fixing nut finger tight. ● Wire switch block as required and slide onto operator until latch engages. ● Assemble bulb, if required, using tool number 30-0002. ● Snap the screen onto the reflector assembly with legend in between, if required. Then snap onto front of operator, taking care to line up the locating slot with the polarizing dot to prevent damaging the seal. ● TO REMOVE BULB Remove reflector/screen assembly by inserting tool number 30-0006 between the bezel finger guard and the screen to ingage the slot and pulling. Use the bulb extractor to remove the bulb. TO ASSEMBLE SWITCH BLOCK Carefully line up switch block with operator then slide onto front of operator. Insure the latch is fully engaged correctly onto the switch block. TO REMOVE SWITCH BLOCK Depress the latch and slide the switch block off the operator. FIXING NUT KEY 30-0001 K K10 BULB REMOVER 30-0002 SCREEN REMOVER 30-0006 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. PANEL CUT-OUTS MODULAR CONSTRUCTION
300002 价格&库存
很抱歉,暂时无法提供与“300002”相匹配的价格&库存,您可以联系我们找货
    库存:23
