26PN
26PN
    APEM(埃斐)
    SECURITY CAP
26PN 数据手册
03-Security caps-A_03-Security caps-A 22/11/12 12:15 Page4 Security caps For switch series 12000 - 3500 - 600H - 6000 With standard bushing Security caps prevent any inadvertent lever operation. When the cap is raised, the lever can be operated freely. When the cap is fully depressed, the lever is reset/locked in a stable position. They are designed for use on switches with Ø 11,9 (.468) or Ø 12 (.472) threaded bushing and lever length 17,5 (.688) outside bushing. MATERIALS • Support plate : matt black steel • Cap : thermoset or thermoplastic (20PN, 200PN, 300PN) Note : For correct switch operation, the security cap should be adjusted properly by means of 2 nuts. MODEL STRUCTURE Series 20 - for 2-position switches 14.00 (.551) 49.00 (1.929) Colour 22 23 24 25 26 27 28 29 25/28 Grey White Orange Black Red Green Yellow Blue Black/yellow striped 16.40 (.645) Model No 39.40 (1.551) • Lever returned then locked in down position (OFF) 17.00 (.669) Series 20PN - for 2-position switches 22.00 (.866) 14.00 (.551) 22PN 23PN 24PN 25PN 26PN 27PN 28PN 29PN Grey White Orange Black Red Green Yellow Blue 21.00 (.826) Colour 44.00 (1.732) Model No 33.50 (1.318) • Lever returned then locked in down position (OFF) 28.00 (1.102) 17.00 (.669) On this model, holes for wiring a seal are standard. Series 30 - for 3-position switches 14.00 (.551) 49.00 (1.929) I-4 Colour 32 33 34 35 36 37 38 39 35/38 Grey White Orange Black Red Green Yellow Blue Black/yellow striped www.apem.com 16.40 (.645) I Model No 39.40 (1.551) • Lever returned then locked in upper position 17.00 (.669) 22.00 (.866) APEM 03-Security caps-A_03-Security caps-A 22/11/12 12:15 Page5 Security caps For switch series 12000 - 3500 - 600H - 6000 With standard bushing Series 40 - for 2-position switches 14.00 (.551) 49.00 (1.929) Colour Grey White Orange Black Red Green Yellow Blue Black/yellow striped 16.40 (.645) Model No 42 43 44 45 46 47 48 49 45/48 39.40 (1.551) • Lever returned then locked in upper position 17.00 (.669) Model 140 (with smaller aperture) recommended for the 12000 series. Series 80 - for 3-position switches 22.00 (.866) 14.00 (.551) 49.00 (1.929) Colour 82 83 84 85 86 87 88 89 Grey White Orange Black Red Green Yellow Blue 16.40 (.645) Model No 39.40 (1.551) • Lever returned then locked in center position 17.00 (.669) Series 200 - for 2-position switches 22.00 (.866) 14.00 (.551) 49.00 (1.929) Colour 202 203 204 205 206 207 208 209 Grey White Orange Black Red Green Yellow Blue 16.40 (.645) Model No 39.40 (1.551) • Lever returned then locked either in lower or in upper position 17.00 (.669) Series 200PN - for 2 or 3-position switches - action preventer 22.00 (.866) 14.00 (.551) APEM 202PN 203PN 204PN 205PN 206PN 207PN 208PN 209PN Grey White Orange Black Red Green Yellow Blue I 21.00 (.826) Colour 44.00 (1.732) Model No 33.50 (1.318) • Lever not locked, but protected in the position where left by the user 17.00 (.669) www.apem.com 28.00 (1.102) I-5 03-Security caps-A_03-Security caps-A 22/11/12 12:15 Page6 Security caps For switch series 12000 - 3500 - 600H - 6000 With flatted bushing Series 50 - for 2-position switches 14.00 (.551) 49.00 (1.929) Colour 52 53 54 55 56 57 58 59 55/58 Grey White Orange Black Red Green Yellow Blue Black/yellow striped 16.40 (.645) Model No 39.40 (1.551) • Lever returned then locked in down position (OFF) 17.00 (.669) Series 60 - for 3-position switches 22.00 (.866) 14.00 (.551) 49.00 (1.929) Colour 62 63 64 65 66 67 68 69 65/68 Grey White Orange Black Red Green Yellow Blue Black/yellow striped 16.40 (.645) Model No 39.40 (1.551) • Lever returned then locked in upper position 17.00 (.669) Series 70 - for 2-position switches 22.00 (.866) 14.00 (.551) 49.00 (1.929) Colour Grey White Orange Black Red Green Yellow Blue Black/yellow striped 16.40 (.645) Model No 72 73 74 75 76 77 78 79 75/78 39.40 (1.551) • Lever returned then locked in upper position 17.00 (.669) Model 170 (with smaller aperture) recommended for the 12000 series. Series 100 - for 3-position switches 22.00 (.866) 14.00 (.551) 49.00 (1.929) I-6 Colour 102 103 104 105 106 107 108 109 Grey White Orange Black Red Green Yellow Blue www.apem.com 16.40 (.645) I Model No 39.40 (1.551) • Lever returned then locked in center position 17.00 (.669) 22.00 (.866) APEM 03-Security caps-A_03-Security caps-A 22/11/12 12:15 Page7 Security caps For switch series 12000 - 3500 - 600H - 6000 With flatted bushing Series 300PN - for 2 or 3-position switches 14.00 (.551) 302PN 303PN 304PN 305PN 306PN 307PN 308PN 309PN Grey White Orange Black Red Green Yellow Blue 21.00 (.826) Colour 44.00 (1.732) Model No 33.50 (1.318) • Lever not locked, but protected in the position where left by the user. 28.00 (1.102) 17.00 (.669) Series 500 - for 2-position switches 49.00 (1.929) 14.00 (.551) Colour 502 503 504 505 506 507 508 509 Grey White Orange Black Red Green Yellow Blue 16.40 (.645) Model No 39.40 (1.551) • Lever returned then locked either in lower or in upper position 17.00 (.669) 22.00 (.866) OPTIONS P Holes for wiring a seal Ø1.50 (.059DIA) Cap engraving available : consult factory. I APEM www.apem.com I-7 03-Security caps-A_03-Security caps-A 22/11/12 12:15 Page8 Security caps For switch series 3500 - 600H - 6000 With standard or flatted bushing Series 90 27.00 (1.062) • Lever locked in center position 12.00 (.472) 22.00 (.866) 13.00 (.512) 18.00 (.708) Ø0.80 (.031DIA) Plate features holes for wiring a seal. To build a part number, select desired option from each category here below. BUSHING SHAPES 90 For standard products A B C D F G H For other products E SECURITY CAP SHAPE 90 I 1 2 3 4 5 Locks in center position Prevents down position Prevents up position Locks in down position Locks in up position I-8 www.apem.com APEM 03-Security caps-A_03-Security caps-A 22/11/12 12:15 Page9 Security caps For switch series 3500 - 600H - 6000 (continued) - For pushbutton series 13000 SECURITY CAP COLOURS 90 1 2 3 4 5 6 7/1 9 0 Blue Black Green Grey Yellow Red White Orange Striped (see below) COLOUR OF STRIPES 90 A B C D Stripe ➀ Stripe ➁ Red Yellow Red White Black Black White Black 2 1 Series 90AX2328 for pushbutton series 13000 with Ø 11,9 (15/32) bushing • Spring-loaded cover returning automatically in lower position. The user has to keep the cover raised while actuating the switch. Model No 35.00 (1.377) 12.00 (.472) Colour 32.00 (1.260) 90AX2328-27 Black with white stripe 90AX2328-67 Red with white stripe 3.50 MAX (.138 MAX) 9.00 (.354) 18.00 (.708) I APEM www.apem.com I-9
很抱歉,暂时无法提供与“26PN”相匹配的价格&库存,您可以联系我们找货
