9
EC
E
IM
N
-U
PANEL
PCB SWITCHES
00
2
C-
Unimec™
M
8 contact functions •
2 pole • distinct tactile feel
DISTINCTIVE FEATURES
12.6 x 12.6 mm; h=15.7 mm
2 pole
Momentary, latching or quiet
8 contact functions
Up to 10,000,000 cycle lifetime
ENVIRONMENTAL SPECIFICATIONS
• Sealing : IP54 according to IEC 60529
• Working temperature : -40 °C/+160 °C
• Storage temperature : -65 °C/+160 °C
• Soldering : IEC 68-2-20
ELECTRICAL SPECIFICATIONS
• Recommended load :
- Gold contacts : min. 0.5 µmA - max.250 mA - 120 V - 9 W AC - 6 W DC
- Silver contacts : min. 0.5 mA - max.250 mA - 120 V - 9 W AC - 6 W DC
• Contact resistance : max. 100 mΩ (initially)
• Insulation resistance : >10 MΩ
• Contact bounce : max. 10 ms
• Dielectric strength between adjacent contacts : 1000 V for 2 min
• Insulation resistance between adjacent contacts : 5 X 10 13Ω
• Capacitance between adjacent contacts :0.5 pF
MATERIALS
• Housing : LCP UL94V0
• Actuator : LCP UL94V0
• Switch spring : Stainless steel
MECHANICAL SPECIFICATIONS
• Standard actuation force : 2.5 N
• Max. actuation force : 100 N for 10 sec
• Travel : 1.8 mm
• Lifetime :
momentary : >10,000,000 cycles
latching : 5,000,000 cycles
The company reserves the right to change specifications without notice.
• Key spring : Stainless steel
• Latch pin : Stainless steel
• Fixed contacts :
Silver : SnCu + 2 µNI + 3 µAg
Gold : SnCu + 2 µNI + 3 µAu
• Moving contacts :
Silver : Stainless steel + 3 µAg
Gold : Stainless steel + 3 µAg + 1 µAu
• Terminals : SnCu + 2 µNI + 3 µSn100
All tolerance if not otherwise specified ±0.2mm.
1
3.3
12.6
10.1
5.6
UNIMEC
12.6
12.6
12.6
• TH
• momentary, latching or quiet
• 8 contact functions
All tolerances unless otherwise noted : ±0.2 mm
PCB LAYOUT
PCB MOUNTING HOLE DIMENSIONS
FUNCTIONAL DIAGRAM
5
7
6
8
1
3
2
4
5
7
6
8
Ø = 0.9
3,0
Ø 0,9
With 3 mm LED
16923 and 16924
1
3
2
4
2
4
1
3
5
7
6
8
6
8
5
7
2.54
2
4
2.54
1
3
13,1
2,54
2,54
Ø = 0.9
With round LED
16920 and 16921
With square LED
16922
- up
- - down
CIRCUIT DIAGRAM
1
3
2
4
1
3
2
4
1
3
2
4
5
7
6
8
5
7
6
8
5
7
6
8
With round LED
16920 and 16921
With rect. LED
16922
WIRING
1 make contact
2
1 break contact
1 change
over contact
2 make contact
2 break contact
2 change
over contact
2 make
& 2 break
Select the contact function you require - and design your PC board accordingly
PCB SWITCHES
Unimec™
reverse polarity
BUILD YOUR PART NUMBER
NON-ILLUMINATED
154
SERIES
09
SWITCH FUNCTION
TERMINAL
momentary
1
silver
5
latching
2
gold
quiet*
COLOR OF
THE HOUSING
*quiet function has silver terminals, in case of gold terminals the part number is 15420
ABOUT THIS SERIES
Notice : please note that not all combinations of above numbers are available.
Contact APEM for further information.
Marking on the switch for identification : 15400 A; 15420 H; 15401 E; 15402 F; 15451 I; 15452 J
Accessories : See www.apem.com for cap & bezel options.
3
PANEL
PCB SWITCHES
Unimec™
Support
Vario Support
IMEC switches with bezels unimec
- 16310-16315 and 16324-16326
nimec
Vario Support
Support
unimec
Vario
Support
16.423- (2x5)
16.450
(5x5)
16.432
(3x5)16324-16326
16.441 (4x5)
ezels
16310-16315
and
x4)
16.440
(4x4)
Unimec
Support
ezels - 16310-16315 and 16324-16326
45.7
30.5 61.0
30.5
61.0
15.2
11.4
30.5 61.0
30.5
61.0
61.0
45.7
45.7
45.7
45.7
38.1
38.1
53.3
53.3
38.1
38.1
53.3
53.3
38.1
53.3
53.3 38.1
14.
53.3
53.3
38.1
38.1
68.5
68.5
53.3
53.3
11.4
11.4
45.7
3.0
14.
11
45.7
45.7
38.1
38.1
53.3
53.357.1
53.3
53.3
45.7
45.7
45.7
45.7
45.7
61.0
30.5
45.7
61.0
30.5
1.1
45.7
3.0 45.7
14.8
38.1
38.1
57.1
41.9
57.1
45.7
57.1
57.1
45.7
41.9
41.9
57.1
45.7
160.0
83.8
61.0
61.0
45.7
45.7
45.7 45.7
45.7
30.5
45.7
30.5
11
30.5 61.0
61.0
3.0
1.1
45.7
45.7
8
38.1
38.1
45.7
61.0
30.5
45.7
11
45.7
45.7
83.8
45.7
45.7
53.3
53.3
30.5
45.7
53.3
30.5
38.1
1.1
45.7
45.7
68.5
68.5
68.5
15.24
1.1
53.3
45.7
68.5
30.5
3.0
45.7
30.5
45.7
30.5
45.7
45.7
61.0
30.5
45.7
45.7
61.0
30.5 45.7 45.7 30.5
Min. 15.3 11.4 45.7
45.7
45.7
45.7
45.7
45.7
45.7
45.7
45.7
11.4
160.0
41.9
11.4 45.7
45.7
45.7
68.5
61.0
45.7
30.5
45.7
11.4 68.5
61.0
15.2 61.0
45.7
30.5
45.7
30.5
11.4 45.7
61.0
Min. 15.3
61.0
41.9
53.3
53.3
22.8
22.8
8.6
45.7
61.0
38.1
45.7
83.8
30.5
30.5
68.5
68.5
22.811.4
45.7
45.7
53.3
1.1
7.1
41.9
61.0
45.7
53.3
45.7
53.3
1.5
30.5
53.3
45.7
2.6
1.5
38.1
10.9
3.8 3.0 4.1
61.0
45.7
38.1
38.1
38.1
68.5
38.1
30.5
53.3
68.5
7.1
45.7
53.3
30.5
15.2
61.0
7.1
38.1
38.1
53.3 68.5
30.5
45.7
45.7
45.7
45.7
160.0
11.4
57.1
45.7
15.24
8.6
68.5
61.0 15.2
160.0
45.7
45.7
41.9
53.3
45.7
14.41.1
38.1
22.8
68.5
68.5
61.038.1
45.7
45.7
61.0
61.0
68.5
38.1
7.1
2.6
41.9
53.3
61.0
Min. 15.3
3.0
22.8
30.5
68.5
61.0
53.3
30.5
22.8
1.5
53.3
45.7
30.5
61.0
1.5
10.9
3.8 3.0 4.1
10.9
38.1
10.9
38.1
45.7
38.1
53.3
30.5
38.1
15.2
53.3
38.1
38.1
22.8
unimec
Vario Support Vario Support
unimec
unimec
Vario Support Vario
unimec
Vario Support
Support
unimec
Vario Support
unimec
unimec
unimec
unimec
Vario Support
unimec
Vario
Support
unimec Vario Support
unimec
Vario
Support
unimec
Vario
Support
nimec
Vario
Support
Vario
Support
unimec
Vario Support
Support
nimec
Vario Support
Vario
nimec
Vario
nimec
VarioSupport
Support
unimec
Vario Support
nimec Vario Support
nimec
Vario
nimec
VarioSupport
Support
nimec Vario Support
nimec Vario Support
61.0
68.5
61.0
Min. 15.3
7.1
7.1
45.7
7.1
7.1
45.7
7.1
7.1
11.4
68.5
15.24
53.3
68.5
8.6
53.3
57.1
1.1
2.6
2.6
15.24
45.7
45.7
45.7
61.0
61.0
61.0
61.0
30.5
45.7
45.7 45.7
45.7 45.7
30.5
45.7
45.7
30.5
45.7
45.7
30.5
2.6
2.6
11.4
45.7
61.0
8.6
30.5
30.5
45.7
45.7
2.6
2.6
1.1
14.4
53.3
2.6
61.0
30.5
22.8
45.7
45.7
8.6
53.3
3.0
45.7
53.3
45.7
30.5
45.7
61.0
45.7
11.4 61.061.0
68.5
41.9
41.9
68.5
15.24
1.1
41.9
68.5 68.5
68.5 68.5
68.5
41.9
41.9
68.5
68.5
41.9
41.9 41.9
41.9 41.9 68.5 41.9
57.1
57.1
57.1
57.1
57.1
57.1
68.5 68.5
68.5 68.5
45.7
45.7
45.7
68.5
41.9
41.9
68.5
68.5
41.9 41.9
41.9 41.9
68.5 41.9
68.5 68.5
68.5 68.5
8.6
68.5
41.9
41.9
41.9
57.1
68.5
68.5
53.3 53.3
53.353.3
53.3 41.9
41.9
41.9
41.9
41.9 41.9
41.9
41.9 68.5 41.9
68.5 68.5
68.5 68.5
68.5
41.9
41.9
68.5
68.5
53.3 53.3
53.353.3
53.3
41.941.9
41.9
41.941.9
41.9
41.953.3
41.9
57.1
53.3
53.3 68.5
41.9
41.9
10.9
10.9
10.9
10.910.968.5
10.9
68.5
68.5
68.5
57.1
41.9
57.1
57.1
68.5
68.5
41.9
41.9
68.5
53.3 53.3
53.353.3
53.3
41.9
41.9 41.9
41.9 41.9
41.953.3
53.3
53.3
41.9
41.941.9
68.5
68.5
68.5
68.5
57.1
68.5
53.3
53.3 53.3
53.353.3
53.3
41.9
41.9
57.1
41.9
57.1
57.1
41.9
41.9
41.9
41.9
41.9
41.9
53.3
53.3
3.8 3.0 4.1 3.8 3.0
3.84.1
3.0 4.1 3.8 3.0
3.8 3.0
41.91.1
41.9
41.9
4.1 4.1 3.8 3.0 4.1
41.9 41.9
41.9
15.24
1.1 15.24
41.9
68.5
38.1
38.1
38.1
38.1
38.1
38.1
53.3
53.353.3 1.1 15.24
53.3
41.9
41.941.9
41.9 41.9
41.941.9
41.9
41.953.3
53.3
53.3
41.9
57.1
41.9
41.9 41.9
41.9 41.9
41.9
41.9
41.9
41.9
57.1 53.3 41.9
57.1 41.9
15.24
1.1
38.1
38.1
38.1
38.1
38.157.1
53.3
53.3
53.353.3
53.3
38.1
38.1
8.6
8.653.3 41.9
8.641.9
53.3
53.3
41.9
41.941.9
41.9
41.9 41.9
41.9 41.9
41.9 38.1
57.1
38.1
38.1
38.1
38.1
38.1
38.1
53.3
53.3 53.3 41.9 53.353.3
53.3
38.1
38.1
53.3
53.3
8.6
41.9
41.9 41.9
41.9 41.9
41.9
38.1
38.1
38.1 15.24
38.1
38.1
53.3 53.3
53.353.3
53.3
22.8 41.9 41.9 22.8
22.8 41.9 41.9 22.8
22.8 41.9 38.1
38.1
38.1
1.1 15.24
1.1 15.24
1.1 53.341.9
53.3
53.
41.9 22.8
41.9 41.9
41.9
41.9
41.9
38.1
38.1
38.1
38.1
38.1
38.1
1.5
1.5 1.5
1.5 1.5
1.5
38.1
38.1
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8 41.9
15.24
1.1
41.9
41.9 41.9
41.9 41.9
41.9
41.9
41.9
41.9
8.6
8.6
8.6
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
41.9
41.9 41.9
41.9 41.9
41.9
41.9
41.9
38.1
38.1
38.1
38.1
38.1
38.1
8.6
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
15.24 41.9 1.1 15.24
1.1 15.24
1.1
41.9
41.9 41.9
41.9 41.9
41.9
41.9
38.1
38.1 22.8
38.1
38.1
38.1
38.1
41.9
41.9
22.8
22.8
22.8
22.8
22.8
41.9
41.9 41.9
41.9 41.9
41.9
15.2
41.9
41.9
38.1
38.122.8
38.1
38.1
38.1
38.1
41.9
41.9 41.9
41.9 41.9
41.9 41.9
8.6
8.6
8.6
41.9
22.8
22.8
22.8
22.8
22.8
41.9
41.9 41.9
41.9 41.9
41.9
41.9
41.9
41.9
41.9 41.9
41.9 41.9
41.941.9
41.9
41.9
41.9
41.9
41.9
41.9 41.9
41.9 41.9
41.9
41.9
41.9 41.9
41.9 41.9
41.941.9
41.9
41.9
41.9
41.9
41.9 41.9
41.9 41.9
41.9
41.9
41.9 41.9
41.9 41.9
41.941.9
41.9
41.9
41.9
15.24
1.1
15.24
1.1
15.24
1.1
41.9
41.9 41.9
41.9 41.9
41.9 41.9
41.9
41.9
41.9
41.9
41.9 41.9
41.9 41.9
41.9
8.6
8.6
8.6
41.9
41.9
15.24
1.1 15.24
1.1 15.24
1.1
41.9
41.9
15.24
1.1
41.98.6
41.98.6
8.6
41.9
41.9
41.9
41.9
41.9
41.9
15.24
1.1 15.24
1.1 15.24
1.1
8.6
41.9
41.9
41.9
41.9
41.9
41.9
41.9
8.6
8.6
8.6
57.1
57.145.757.1
57.1
57.1
45.7 57.1
45.7
41.9
41.9
2.6
2.6 2.6
2.6 2.6
2.6
41.9
41.9
41.9
41.9
41.9
41.941.9 41.9 41.9
41.9
57.1
57.1
57.1
41.9
45.7
41.9
41.9
7.141.9
7.1 7.141.9
7.1 7.1
7.1
41.941.9
41.9
41.9
41.9
41.9
141.9
57.1
41.9
41.9 41.9 41.9 41.9 41.9
41.9
57.1
41.9
41.9
41.9
41.9
41.9
57.1 41.9
57.141.9
57.1
41.9
41.9
41.9
41.9
41.9
57.1
41.9
41.9
41.9
41.9
41.9
41.9 57.1 41.9 45.7 41.9
41.9
57.1
57.1
57.1
57.1
57.1
45.7
45.7
41.9
57.1 41.9
57.141.9
57.1
41.9
41.9
57.1
41.9
41.9
41.9
41.9
41.9
41.9
68.5 68.5
68.568.5
68.5
57.168.5
41.9
57.1
57.1
57.1
45.7
41.9
41.9
41.9
41.9
41.9
41.9
41.9
41.9 41.9
41.9 41.9
41.9
41.9
57.1
41.9
41.9
41.9
41.9
9
57.1 41.9
57.141.9
57.168.5
68.5 68.5
68.568.5
68.5
68.5
68.5
41.9
57.1
41.9
41.9 41.9
41.9 41.9
41.9
41.9
41.9
41.9
41.9
68.5 68.5
68.568.5
68.5
41.9
57.1 41.9
57.141.9
57.168.5
41.9
57.1
68.5 45.7 57.1
68.5 57.145.757.1
57.1
57.1
57.1
45.7
41.9
41.9
68.541.9
68.5
68.568.5
68.5
41.9
57.1 41.9
57.141.9
57.168.5
15.24
15.24
1.1
15.24
1.1 45.7 1
.1 41.9
57.141.9
57.1
68.5
68.5
41.9
57.1
57.1
57.1
53.3
53.3
53.3
53.3
53.3
53.3
15.24
1.1 15.24
1.1 15.24
1.1
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
41.9
57.1 41.9
57.141.9
57.1
41.9
57.1
41.9
57.1
15.24 53.3
1.1 15.24
1.1
53.3
53.3
53.3
53.3
53.3
53.3
53.3 1.1 15.24
68.5
68.541.9
68.5
68.568.5
68.5
10.9
10.9
10.9
10.9
10.9
10.9
68.5
68.5
41.9
57.1 41.9
57.141.9
57.1
8.6
8.6
8.6
57.1
53.3
53.3
53.3
53.3
53.3
53.3
8.6 68.5
8.6
8.615.24
53.3
53.3
68.5
68.5 68.5 41.9 68.58.6
68.5
68.5 8.6
8.6
68.5
41.9
57.1 41.9
57.141.9
57.1
57.1
53.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
3.8
3.8 3.0
3.0 4.1
3.8
3.8 3.0
3.0 4.1
3.8
3.8 3.0
3.0 4.1
4.1
4.1
4.1
68.5
6
57.141.9
57.1
57.1 53.3
57.145.757.1 41.957.1
57.1
45.7 57.1
38.1
38.1
38.1
38.1
38.1
38.1
53.3
53.3
53.3
53.3
53.3 45.7 57.1
53.3
53.3
41.9
57.1 41.9
57.141.9
57.1
38.1
38.1
38.1
38.1
38.1
38.1
53.3
53.3
53.3
53.3
53.3
53.3
41.9
57.1
38.1
38.1
53.3
53.3
41.9
57.1 41.9
57.141.9
57.1
38.1
38.1
38.1
38.1
38.1
38.1
41.9
57.1
53.3
53.3
53.3
53.3
53.3
53.3
38.1
38.1
57.1
57.145.757.1
57.1
57.1
45.7 57.1
45.7
38.1
38.1
38.1
38.1
38.1
38.1
41.9
57.1 41.9
57.141.9
57.1
53.3
53.3
53.3
53.3
53.3
53.3
41.9
57.1
38.1
38.1
41.9
57.1
57.1
57.1
45.7
38.1
38.1
38.1
38.1
38.1
38.1
41.9
57.1 41.9
57.141.9
57.1
1.5
1.5
1.5
1.5
1.5
1.5
41.9
41.9
57.1 41.9
57.141.9
57.141.9
57.157.1
57.1
57.145.7
57.1
57.1
57.1
45.7
45.7
57.1
38.1
38.1
38.1
38.1
38.1
38.1
22.8
22.8
22.8
22.8
22.8
22.8
41.9
57.1
41.9
57.1 41.9
57.141.9
57.141.9
57.1
41.9
57.1
38.1
38.1
38.1
38.1
38.1
38.1 22.8
22.8
22.8
22.8
22.8
22.8
22.8
57.1 41.9
57.141.9
57.1
22.8
41.9
57.1 41.9
57.141.9
57.141.9
57.1
41.9
57.1
38.1
38.1
38.1
38.1
22.8
22.8
22.8
22.8
22.8
22.8
41.9
57.1 41.9
57.141.9
57.141.9
57.1
41.9
57.1
22.8
22.8
22.8
22.8
22.8
22.8
41.9
57.1 41.9
57.141.9
57.1
41.9
57.1
22.8
22.8
22.8
22.8
22.8
22.8
41.9
57.1
22.8
22.8
68.
38.1
7.1
38.1
22.8
22.8
30.5
7.12.6
38.1
68.5
Min. 15.3
30.5
3.0
45.7
45.7
1.5
2.610.
1.5
53.3
3.8
15.2
38.1
10.9
53.3
53.3
3.8 3.0 4.1 3.8 3.0 4.1 3.8 3.0 4.1
38.1
38.1
38.1
38.1
PCB
SWITCHES
2.6
22.8
38.1
38.1
38.1
15.2
1.5
68.5
68.5
53.3
3.87.1
3.0
16.414
(1x5)
16.423
410
(1x1)of UNIMEC
16.500
(10x10)
16.412
(1x3)
16.430
16.421
(2x3)
types
and
16324-16326
16.410 (1x1)switches with bezels - 16310-16315
16.412
(1x3)
16.430 (3x
(3x
16.421
(2x3) - 16310-163
For all types of
UNIMEC
switches
with
bezels
16.420
(2x2)
16.411
(1x2)
16.420
(2x2)
16.411
(1x2)
16.420
(2x2)
16.411
(1x2)
11.4 45.7
45.7
16.431 (3x4)
16.440 (4x4)14.4
16.422 (2x4)Min. 15.3
16.413 (1x4)
83.8
16.431
(3x4)(1x3)
16.440
(4x4)
16.422 (2x4)
16.413 (1x4)
11.4
3.0
16.414
16.423
16.412
16.430
(3x
16.421
(2x3)
16.412 (1x3)
16.430 (3x3) For all types of UNIMEC
16.421 (2x3)
16.500
(10x10)
16.412switches
(1x3)
16.430
(3x
16.421
(2x3)(1x5)
with
bezels
- 16310-163
15.2
16.420
(2x2)
411 (1x2) 16.411
16.417
(1x8)
16.426
(2x8)
16.435
(3
16.424
16.415
(1x6)
16.42
16.419
(1x10)
16.442
(4x6)
16.433
(3x6)
(2x6)
16.415
(1x6)
14.416.424
11.4 45.7
Min. 15.3
16.431
(3x4)
(4x4)
16.422
(2x4)
16.413
(1x4)
16.420
(2x2)
(1x2)
16.417
(1x8) 16.440
16.426
(2x8)
16.43545.7
(3
(1x1)
3.0 16324-16326
pes
of UNIMEC switches with bezels 11.4
- 16310-16315
11.4 16.413 (1x4)
61.0 16.410 (1x1)and
16.431
(3x
16.422
(2x4)
16.412
(1x3)
16.430
(3x
16.421
(2x3)
16.431
16.422
(2x4) - 16310-163
16.413
(1x4)
11.4 45.7
16.500
(10x10)
16.412 (1x3)
16.430
(3x3)
16.421 (2x3)
16.412
(1x3)
16.430
(3x
16.421
(2x3)
1.1
15.24
For all
types of UNIMEC
switches
with
bezels
15.2
16.500 (10x10)
61.0
30.516.415 (1x6)
11.4 45.7
8.6
16.424
16.414 (1x5)
16.423 (2x5)
16.450 (5x5)
16.432 (3x5)
16.441 (4x5)
14.4 16.414 (1x5)
11.4 16.432
45.7 16.413
45.7
45.7
45.7 (4x4)
30.5
3.0
16.431
16.422
16.410
(1x1)
(2x5)
16.450
(5x5)(3x
(3x5)(1x4)
16.441
(4x5)(2x4)
16.431 (3x4) 16.423
16.440
16.422
(2x4)
16.413 (1x4)
8
contact
functions
16.431
(3x
16.420
(2x2)
16.422
(2x4)
16.413
(1x4)
1.1
15.24
412
(1x3)
16.430
(3x3)
16.421
(2x3)
11.4
45.7
30.5
16.420
(2x2)
1 (1x2) 15.2 2 16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
16.420
(2x2)
16.411
(1x2)
pole
distinct
tactile
feel
8.6
160.0
16.424
16.415
(1x6)
Tel.
30.5
1x1) 45.7 30.5
16.414
(1x5)
16.423 (2x5)
16.450 (5x5)
16.432 45.7
(3x5) 45.7
16.441 (4x5)
11.4 45.7 and
For all30.5types
of UNIMEC 14.4
switches
with bezels
-(3x4)
16310-16315
16324-16326
16.431
(3x
16.422
(2x4)
16.413
(1x4)
16.410
(1x1)
16.420
(2x2)
16.500
(10x10)
16.414
(1x5)
16.423
(2x5)
16.432
(3x
16.431
(4x4)
16.422
(2x4)
16.413 (1x4) 3.0 For
16.418
(1x9)
16.427
(2x9)
16.436
(3
16.416
(1x7)
16.425
16.431
16.422
(2x4)
16.413
(1x4)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7) 16.440
16.500
(1
16.425
(2x7)
83.8
16.414
(1x5)
16.423
(2x5)
16.432
(3x
16.418
(1x9)
16.427
(2x9)
16.436
(3
11.4 all types of UNIMEC
switches
with
bezels
16310-16315
and
16324-163
1.1
15.24
16.420
(2x2)
16.411 (1x2)
160.0
8.6
30.5
30.5
30.5
53.3
61.0
45.7
61.0
45.7
11.4
45.7
Min. 15.3
11.4
45.7
30.5
45.7
45.7
14.4
11.4
45.7
30.5
99.045.7
99.0
45.7
61.0
61.0
61.0
30.5
45.7
11.4
45.7
61.0
30.530.5 45.7
45.7
11.445.745.745.7
30.5
Min. 15.3
45.7 45.7
45.745.7
11.445.7
45.7
45.7
Min. 15.3 30.5
11.4
3.0
61.0
83.8
30.5
45.7
61.0
57.1
14.4
30.5
11.4
45.7
45.7
99.0
30.5 45.7
61.0
61.0
14.4
45.7
45.7
45.7
45.7
45.7
61.0
11.4
160.0
61.0
45.7
30.5 45.7
11.4 45.7
45.745.730.5
30.5
45.7 45.7
45.7
11.4 45.7
45.7
45.7
45.7 45.7 61.0
61.0 45.7
11.4
45.7 45.7 45.7
83.8
14.4
30.5
3.0
14.4
11.4
41.9
41.9
38.1
45.7
30.5
Min. 15.3 45.7
11.4
61.0
11.4
61.0 99.0
61.0
1.1
45.7
45.7
45.7
61.0
8
99.0
45.7 45.7 45.730.5
45.7 45.7 45.730.5
45.7
160.0
45.7
45.7
mec a/s Jan. 2002
57.1
57.145.757.1
57.1
57.1
45.7 57.1
45.7
57.1
57.145.757.1
57.1
57.1
45.7 57.1
45.7
57.141.9
57.1
41.9
57.1
57.1 41.9 41.9 57.141.9
57.1 41.9 57.1 57.141.9
57.1
41.9
57.1
41.9
57.1
41.9
57.1 57.141.9
57.1 41.9
57.1
41.9
57.1
41.9
57.1
mec
a/s
Jan.
2002
41.9
57.1
41.9
57.1
41.9
57.1
41.9
41.9
41.9 41.9 41.9 41.9
41.941.9
41.941.9
41.9
41.9
41.9
57.1
41.9
57.1
41.9
57.1
41.9
57.1
41.9
57.1
41.9
41.9 41.9 41.9 41.9
41.941.9 41.941.9
41.9
41.9
41.9
41.9
41.9
41.9
41.9
41.9
57.1
41.9
41.9
41.9 41.9 41.9 41.9
41.9
41.9 a/s
41.9Jan.
41.9
41.9 2002
41.9
41.9
41.9
41.9
41.9
mec
41.9
41.9
41.9 41.9 41.9 41.9
41.941.9
41.941.9
41.9
41.9
41.9
41.9
41.9
41.9
68.5
68.5
68.5
68.5
68.5
68.5
41.9
41.9
41.9 41.9 41.9 41.9
41.941.9
41.941.9
41.9
41.9
41.9
41.9
41.9
41.9
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
41.9
41.9
41.9 41.9 41.9 41.9
41.941.9
41.941.9
41.9
41.9
41.9
68.5
68.5
68.5
68.5
68.5
41.9
57.1 68.5
68.5
68.5
41.9
41.9
57.1
41.9
57.1
57.1
. 2002
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
53.3
53.3
53.3
53.3 41.9
57.1
mec a/s53.3
Jan. 2002 53.3
41.9
41.9
57.1
41.9
57.1
57.1
68.5
68.5
68.5
68.5
68.5
68.5
15.24
15.24
1.1 15.24 1.1 15.24
1.1 15.24
1.1 15.24
1.153.3
1.1
53.3
53.3
53.3
53.3
53.3
53.3
53.3
68.5
68.5
68.5
68.5
68.5
68.5
41.9
41.9
41.9
57.1
41.9
57.1
57.1
53.3
53.3
53.3
53.3
53.3
53.357.1
68.5
68.5
68.5
68.5
68.5
68.5
8.6
8.6
8.6
8.6
8.6
8.6
c
a/s
Jan.
2002
53.3
53.3
53.3
53.3
53.3
53.3 41.9
57.1
41.9
41.9
57.1
41.9
57.1
57.1
s Jan.mec
2002
a/s Jan.
mec
2002
a/s Jan. 2002
53.3
53.3
53.3
53.3
53.3
53.3
mec a/s Jan. 2002
53.3
53.3
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
53.3
15.24
1.1
45.7
1.5
22.8
38.1
8.6
30.5
45.7
22.8 61.0
22.8
15.24
8.6
61.0
8.6
53.3
53.3
68.5
53.3
3.8 3.0 4.1
68.5
53.3
53.3 53.3
53.3 53.3
53.3
68.5
53.3
53.3
68.5 68.5
68.5
68.5
38.1
38.1 53.3
53.3
53.3
53.3
68.5
53.3
53.3
53.3
53.3
38.138.1
38.1
68.5 53.3
53.3 53.3
53.3 53.338.1
53.3 38.1
68.52.6
53.3
2.6
68.5
38.1
38.1 38.168.5
38.138.1
38.1
22.8
22.8
38.1
38.1 2.6
1.5
1.5
1.5
53.3 68.5
53.3
53.3
68.5
68.5
68.5
38.1
38.1 38.168.5
38.138.1
38.1
68.5 1.5
1.5 22.8
38.1
22.8
22.8
22.8
22.8
22.8
22.8
7.11.5
7.1
7.1 38.1
22.8
68.5 2.6
68.52.6
68.5
38.1
38.1 38.168.5
38.138.1
38.1
2.6
68.5
68.5
38.1
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
68.5
38.1
38.1 38.1
38.1
38.1
38.1
68.5
68.5
68.5
68.5
22.8
22.8
22.8
22.8
22.8
22.8
2.6
68.5
22.8
22.8
7.1
7.1
7.1
38.1
38.1 38.1
38.138.1 68.5 38.1
68.5
68.5
68.5
2.6
2.6
2.6
22.8
22.8
22.8
22.8
22.8
22.8
68.5
68.5
7.1
38.1
38.1
38.138.1
38.1
68.5
68.5
68.5
22.8
22.8
22.8
22.8
22.8
22.838.1
68.57.1
68.5
68.5
7.1
7.1
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.568.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
2.6
2.6
2.6
30.5
3.0
30.5
15.24
30.5
53.3
15.2
45.7
45.7
53.3
45.7
61.0
38.1
38.1
22.8
53.3
22.8
7.1
2.6
38.1
30.5
68.5
30.5
Min. 15.3
11.4
1.1
30.5
61.022.8
10.9
3.0
61.0
22.8
45.7
22.8
14.4
3.8 3.0 4.1
22.8
30.5
8.6
38.1
38.1
2.6
22.8
38.1
22.8
16.450
(5x5)
x5)
(4x5)
For all types16.441
ofVARIO
UNIMEC
switches
with
bezels
- 16310-16315
and
16324-16326
SUPPORT
MOUNTING
For
all
types
of
UNIMEC
switches
with
bezels
- 16310-16315
and
16324-163
16.414
(1x5)
16.423
(2x5)
16.432
(3x
16.420
(2x2)
16.500
(1
16.423
16.450
(5x5)
16.416
(1x7)
16.432
(3x5)
216.414
(1x3)
16.430
(3x3)
16.421
(2x3)
16.425
16.441
16.420
(2x2)
1x2)
16.431
(3x4)
16.440
(4x4)(4x5)
16.422
(2x4)(2x5)
413
(1x4)(1x5)
16.414
(1x5)
16.423
(2x5)and
16.432
(3x
For
all
types
of
UNIMEC
switches
with
bezels
-(5x6)
16310-16315
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
16.460
(6x6) 16324-163
16.415
(1x6)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
16.420
(2x2)
16.411
(1x2)
For
all
types
of
UNIMEC
switches
with
bezels
16310-16315
and
16324-16326
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.415
(1x6)
16.410 (2x3)
(1x1)
16.430
(3x3)
16.421
16.500
(10x10)
For all types
of UNIMEC
switches
with
- 16310-16315
and
16324-16326
For
all types
of bezels
UNIMEC
switches with
bezels
- 16310-16315
and
16324-163
16.410
(1x1)
16.414
(1x5)
16.423
(2x5)
16.432
(3x
16.416
(1x7)16.451
16.425
16.500
(1
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
For
all
types
of
Unimec
switches
with
bezels
16310
16315
and
16324
16326.
16.414
(1x5)
16.423
(2x5)and
16.432
(3x
For
all
types
of
UNIMEC
switches
with
bezels
16310-16315
16324-163
16.442
(4x6)
16.433
(3x6)
(2x6)
(5x6)
16.415with
(1x6) bezels16.424
r all types of UNIMEC switches
- 16310-16315
and 16324-16326
More
options
available
as
custom.
16.410
(1x1)
16.433
(3x
16.424
(2x6)
16.415
(1x6)
16.428
(2x10)
16.419(2x8)
(1x10)
16.437
(3x
16.430
16.421
(2x3)
16.417 (1x8)
16.426
16.435
(3x8)
(4x8)
16.417
(1x8) 16.444
16.426
16.410(3x3)
(1x1)
16.433
(3x
16.424
(2x6)
16.415
(1x6)
16.428
(2x10)
16.419
(1x10)
16.437
(3x
1x3)
16.430 (3x3)
16.421 (2x3)
99.0
11.4
45.7
41.9
15.24
45.7
10.9 53.3
10.9
10.9
3.8 3.0 4.1
3.8 3.0 4.1
3.8 3.0 4.1
61.0
53.3
53.3
38.1
38.1
38.1
38.1
38.1
11.4 45.7
45.7
45.7
30.5
11.4
45.7
30.5
45.7
14.4
11.4 45.7
45.7
45.7
61.0
45.7
30.5
45.7
45.7
45.7
45.7
45.7 38.1
45.7
30.51.1
45.7
15.24
45.7
30.5
1.1
15.24
30.5
11.4
45.7
45.7
45.7
3.0
11.4
45.7
30.5
45.7
61.0
45.7
45.7
45.7
45.7
61.0
3.0
45.7
30.5
22.8
45.7
45.7
22.8
8.6
14.4
11.4 45.7 14.4 45.7
45.7
45.7
30.5
Min. 15.3
8.6
Min. 15.3 160.0
83.8
45.7
30.5
11.4 45.7
45.7
45.7
1.1
15.24
11.4 45.7
45.7
15.2
45.7
45.7
45.7
83.8
3.0
15.2
11.4
14.4
11.4
8.6
Min. 15.3
45.7 45.722.8 45.7
45.7
14.4
15.3
45.7 Min.30.5
38.1
68.5
45.7 Min. 15.3
22.8
45.7
11.4
61.0
45.7 45.7 45.7 45.7
14.4
11.4
45.7
38.1
99.0
99.0
15.2
45.7
30.5
3.0
114.3
45.7
30.5
11.4 160.0 114.3
45.7
30.5
11.4
45.7
45.7
45.7
45.7
45.7
45.7 38.1
11.4 1.1
61.0
45.7
30.5
30.5
45.7
15.24
45.7
45.7
15.24
45.7
30.5
15.2 1.1
45.7
30.5
1.1
15.24
61.0
45.7
45.7 114.3
30.5
45.7
30.5
11.4
45.7
45.7
45.7
3.0
3.0
61.0
8.6
45.7
30.5
30.5
45.7
61.0
45.7
45.7
61.0
160.0
22.8
45.7
8.6
30.5
11.4
45.7
45.7
45.7
45.7
30.5
38.1
30.5
14.4
45.7
30.5
8.6
Min. 15.3
1.1
30.5
11.4
45.7
45.7 61.0
30.5
45.715.24
45.7
45.7
45.7
45.7
61.0
53.3
15.2
15.2
45.7
99.0
99.0
30.511.43.0
11.4 45.7
8.645.7
45.7
30.5
45.7
3
45.7 11.4
45.7
45.7 61.0
30.5
45.7
45.7
3
3.0
22.8
45.7 45.7 61.0
61.0
45.768.5 30.5 45.7
14.41.1
11.4 45.7 45.7
15.24
Min. 15.3
38.1
38.1
11.445.745.7
22.8
45.745.7
53.3
45.7
30.5
45.7
15.2 61.0
14.4
11.4 45.7
45.7
45.7
30.5
45.7
Min. 15.345.7
11.445.7
45.7
45.7
30.5
45.7
30.5
45.7
99.0
99.0
3.0
160.0
8.6
45.7
45.7
15.2
45.7
30.5
114.3
11.4
61.0
11.4 45.7
30.5
45.7 38.1
114.3 1.1
11.4
45.7
30.5
1.1
15.24 30.5
15.24
61.0
45.7
45.7
45.7
30.5
38.1
83.8
30.5
45.7
61.0
3.0
61.0
11.4 45.7
8.6
8.6
45.7
45.7
30.5
45.7
30.5
30.5 160.0
61.0
45.7
45.7
45.7
11.4
61.0
45.7
30.5
45.7
45.7
1.1
15.24
53.3
45.7
61.0
11.4
61.0
53.3
45.7
45.7
1.1
15.24
45.7
30.5
30.5
15.2
61.0
160.0
45.7
3
45.7
61.0
45.7
45.7
45.7
3
8.645.7
3.0
30.5
45.7
11.4
45.7
45.7
45.7
22.8
45.7
61.0
8.6
3.0
22.8
14.4
45.7
11.4 45.7
45.7
45.7
53.3
Min. 15.3
45.7
30.5
45.7
38.1
61.0
14.4
11.4 45.7
45.7
45.7
61.0
45.7 45.7 45.7
61.0
Min.
15.3
45.7
30.5
45.7
11.4
45.7
45.7
61.0
22.8 45.7
45.7
45.7
14.4
11.4 45.7
45.7
45.7
45.7 160.0
Min. 15.3
15.2 30.5
99.0
99.0
11.4
45.7
45.7
61.0
45.7
22.8
45.7
11.4
11.445.7
45.7
15.2
61.0
11.4 45.7
45.7 61.0
30.5
Min. 15.3
45.7
61.0
30.5 14.4
11.4
99.0
99.0 45.745.7 30.5
11.4
38.1 53.3
11.4
1.1
15.24
61.0
1.1
15.24
11.4 45.7
45.7
45.7
61.0
45.7
45.7 11.4
38.1
61.0
45.7
61.0
30.5
30.5
11.4 45.745.7 30.5
45.7
61.0
114.3
114.3
8.6
11.4 45.7
45.7 45.7
11.4
61.0
30.5
61.0 160.0
68.5
8.6 45.7
129.5
45.7
129.5
30.5
45.7
45.7
45.7
53.3
53.3
1.1
15.24
61.0
45.7
61.0
45.730.5 30.5
45.7
45.7
45.7
45.7
61.0
45.7
3
1.1
15.24
45.7
3
3.0
45.7
45.7
45.7
61.0
11.4 45.7 11.4 45.7
8.6
3.0
30.5
45.745.7
45.7
68.5
45.7
30.5
45.7
45.7
45.7
45.7
129.5
45.7
61.0
61.0
22.8
22.8
45.7
8.6
45.7
45.7
53.3
45.7
30.5
45.7
61.0 3.0
14.4
14.4
11.4 11.4
45.7
45.7 45.7 45.7
11.4 45.7
45.7
45.7
Min. 15.3
Min. 30.5
15.3
45.7
30.5
45.7
45.7
45.7
45.7
45.7
45.7
61.0
53.3
45.7 45.7 45.7
22.8
45.7 15.2
45.7
45.711.4 45.7
11.4 3.0
45.7 14.4
15.2
45.7
61.0
45.7
45.745.7 45.730.5
45.7
45.745.7
Min. 15.3
83.8
61.0
45.7
30.5
15.2
30.5
11.4
11.4
45.7
61.0
11.4 45.7
45.7
45.7
61.0
61.0
4
45.7
38.1
61.0
11.4 45.7
45.7
4
45.7
45.730.5
45.7
45.7
38.1
45.7
15.2
45.745.7 11.4
45.7
30.5
45.7
45.7
45.7
11.4 160.0
45.7 61.0 30.5
38.1
30.5
45.7
68.5
61.061.0
45.7
45.7 45.7
30.5
45.7
45.7
11.4
61.0114.3
11.445.745.7
45.7
45.7
45.7
45.7
45.7
45.7
45.7
30.5
68.5
38.1
45.7
45.7
61.0
160.0 114.3129.5
45.7
45.761.0 45.7
11.4 11.4
45.761.061.0
30.5
45.7
53.3
1.1
15.24
30.5
45.7
1.1
15.24
83.8
45.7
45.7
30.5
45.7
30.5
1.1
15.24
68.5
45.7
61.0
8
45.7
45.7
45.7
45.7
8.6
3.0
3.014.4
11.4 45.7
45.7
45.7
Min. 15.3
8.6 15.24
99.0
99.0
30.5
45.7
61.0
61.0
1.1
45.761.0
30.5
45.7
11.4 11.4
45.7
30.545.7 45.7
61.0
22.8 45.7
11.411.445.745.7 30.545.7
8.6
61.0
45.7
45.7
53.3
3.0
14.4
30.545.7
45.7
Min. 15.3
45.7
61.0
45.7
45.7
45.7
45.7
61.0
22.8
11.4
8.6
45.7
53.3
68.5
15.2
15.2
45.7
45.7
45.745.7
45.7 61.0
30.5
45.7 Min. 15.3
30.545.714.4 30.5
11.4 45.7
45.7
45.7
61.0 11.4 45.7
4
45.7
45.7 11.4
45.7 61.0
30.545.7 45.7
45.7
61.0
4
45.7
45.7
61.0
45.7
15.2
45.7
61.0
61.0
38.1
38.1
61.0
11.4 45.7
45.7 45.7
45.7
30.5
45.7
11.4
61.0
61.0
45.7
45.7
30.5
45.7
45.7
45.7
30.5
45.7
61.0
45.7
45.7
30.5
45.7
114.3
114.3
45.7
45.7
45.7
160.0
68.5
68.5
38.1
160.0
45.7 114.3
11.4 61.061.0
30.5
61.0
61.0
11.4 45.7
45.7
45.761.0
30.5
45.7
30.5 61.0
160.0 114.3
11.4 11.4
45.7114.3
30.5
45.7
61.0
83.8
45.7
30.5 30.5
45.7
114.3
45.7
30.5
45.7
11.4
45.7
45.7
1.1
15.24
1.1
15.24
3.0
160.0
8
30.5
11.4
61.0 30.5
45.7
30.5
14.4
11.4 45.7
45.7
45.7
Min.68.5
15.3
30.5
45.7
61.0
45.7
61.0
1.1
15.24
11.4
61.0
3.0
45.7
30.5 30.5
45.7 61.0
30.5
45.7
8.6
68.5
11.4 45.7
45.7 8.6
61.0
45.7129.5
30.5
45.7 129.5
129.5
11.4
45.7 45.7 61.012
53.3
3.0
45.7
30.5
11.4
8.6
53.3 15.2
30.5
61.0
45.7
83.8
45.7
61.0
144.7
144.7
45.7
61.0
.5 53.3
15.2
61.0 45.7
45.7
45.7 61.0
30.5
45.7
45.7
45.7
11.4
61.0
61.0
61.0
1
45.7
30.5
4
45.7
53.3
4
45.7
61.0
45.7
45.7
30.545.7 61.0 61.0
11.4 45.7
45.715.2
61.0
45.7
45.7
38.1
61.0 45.7
11.4 45.7
83.8
144.7
45.7 61.0
30.5
45.7
45.7
45.7
45.7
61.0
45.7
30.5
45.7
45.7
45.7
61.0
45.7
45.7
45.7
61.0
68.5
38.1
45.7
61.0
11.4 45.7 160.0 61.0 45.7
45.7
160.0
30.5
45
45.7 61.0
45.7
45.7
11.4 61.061.0
11.4
61.0
61.0
11.4
45.7
61.0
1.1
15.24
14.4
11.4
45.7
45.7
45.7
45.7
30.5
45.7
Min.
15.3
30.5
99.0
99.0
30.5
45.7
45.7
45.7
45.7
30.5
45
3.0
160.0
61.0
45.7
30.5
61.0
11.4 45.7
11.4
61.0 30.5
1.1
15.24
11.4 45.7 83.8 61.0
45.7
45.7
30.5
45.7
8
8.6
45.7
45.7
45.7
11.4 45.7
30.5
14.4
11.4 45.7
45.7
45.7 30.5
Min.61.0
15.3
11.4 61.0
30.5
68.5
30.5
61.0
61.0 45.7
45.7
45.7
1.1
15.24
61.0
45.730.5
11.4 45.7
45.7 11.4
11.4 11.4
45.7 45.7 45.7
8.6
61.0
68.5 15.2
45.7
30.5
11.4 45.7
45.7 30.5
30.5 83.8
45.7
45.7
11.4
61.0
129.5
45.7
61.0
129.5
61.0 45.7
11.4 61.0
45.7
45.7
30.5
11.4
8.6 30.5
53.3
53.3
61.045.7
83.8
45.7
61.0
144.7
45.730.5
11.4 11.4
45.7 45.745.7
61.0
61.0
1
61.0
45.7
53.3
11.4
45.745.7 30.
45.7
30.5
11.4
45.7
45.7
61.0
45.7
61.0
45.7
61.0
61.0 45.7
45.7
30.5
45.7
83.8
45.7
61.0
114.3
45.7
30.5
61.0114.3
45.7 45.7 45.730.5
45.7 45.7
160.0
45.7
30.5
11.4 45.7
45.7
11.4 11.4
45.7 45.7 45.7
45.7 3.0
45.7
61.0
45.7
61.0
45.7
30.5
45
45.7
45.7
61.0
11.4
45.7 45.730.5
61.0
15.24
14.41.1
45.7 61.0
30.5
45.7
11.4 45.7
45.7
.7
61.0
Min. 15.3 30.5
45.7
160.0 45.7
30.5
45
11.4
61.0 45.7
45.7
61.0
30.5
45.7
45.7 45.7 45.730.5
45.7 45.7
45.7
30.5
83.8
11.4
45.7
45.7
45.7
45.7
61.0
3.0
45.7
30.5
45.7
160.0
30.5
8.6
45.7
45.7
45.7 45.7 45.7
45.7
11.4
61.0 30.5
15.2 30.5 45.7
45.7 61.0
30.5
45.7
11.4
45.7 11.4
30.5 45.7 45.7 30.5
61.0
45.7
11.4 45.7
30.5
68.5
30.5
45.7 45.7 45.730.5
45.7 45.7
61.0
68.5
45.7
30.5
45.7
11.4
45.7
45.7
30.5
45.7
45.7
11.4
61.0
45.7
45.7
61.0
3 68.5
45.7
30.5
45.7
45.7
83.8
45.7
45.7
15.2
45.7
30.5
45.7
30.5
45.7
30.5
45.7129.5
30.5
45.7 30.5
83.8
83.8
129.5
11.4
45.7
30.5
45.7
11.4
61.0
11.4
45.7
45.7
30.5
53.3
45.7
45.7
45.7 68.5
61.0
45.7 45.730.5
11.4 11.4
45.7 129.5
45.7
45.7
61.0
129.5
45.7 45.7 45.730.5
45.7
1
61.0
61.0
53.3
45.7
45.7
30.5
11.4 11.4
45.745.7
45.7
45.7
45.7
45.7
30.5
61.01.1
30.5
45.7 45.7 45.7
30.5 45.730.5 45.7
15.2445.7
61.0
160.0
45.7 45.7
30.5
45.7
11.4 45.783.8 30.5
45.7
45.7
45.7
3.0
61.0
11.4
45.7
61.0
30.5 45.7
45.7 45.7 45.730.5 11.445.7
83.8
144.7
99.0
45.7
30.5
45.7
45.7
30.599.0 45
45.7
45.7144.7
8.6
61.0
1.1
15.24
14.4
45.7
30.5
61.0
11.4
45.7
45.7
45.7
Min.
15.3
99.0
99.0
160.0
160.0
45.7
30.5
45.7
5.7
45.7
30.5
45
45.7
45.7
30.5
61.0
45.7
30.5
45.7 15.2 30.5 45.7
30.5
45.7 45.7 45.730.5 11.445.745.7
45.7
61.0 45.7
45.7
30.5
45.7
30.5
45.7
8.6
45.7
45.7
61.0
45.7
30.5
11.4
45.7 45.7
30.5
45.7
45.7
61.0
45.7
30.5
45.7
30.5
11.4
45.7
45.7
30.5
45.7
30.5
45.7
11.4 45.7
30.5
99.0160.0
61.0
3 68.5
45.7
45.7
83.8 45.7
68.5
61.0
45.7
30.5
45.7
11.4
61.0
45.7
45.7 45.7
30.5
11.4
61.0 45.7
61.0
45.7
30.5
45.745.745.7 30.5
45.7
11.4 45.7
30.5 83.8
45.7 68.5
30.5
45.7
45.7
45.7
30.5
61.0
11.4 11.4
45.7 45.7
30.5 11.4
45.7
45.745.7 30.5
61.0
30.5
11.4
45.7
30.5
45.7
30.5
114.3
114.3
45.7
45.7
45.7
45.7
45.7
61.0
45.7
45.7
30.5
11.4
45.7 129.5
45.7
30.5
129.5
11.4 11.4
45.7 160.0
30.5
45.7
61.0
61.0
30.5
45.7
1.1
15.24
61.0 45.7
11.4
61.0
45.730.5 45.7
45.7
11.4 45.7
45.7 45.745.7
45.7
45.7
30.5
45.7
30.5
30.511.4 45.7
61.0
61.0
45.7 30.5
45.7
160.045.7
45.7
30.5
45.7
45.7
45.7
83.8
30.5
11.4 45.7
99.0
99.045.7
45.7
45.7
30.5
3.0
8.6 61.0
61.0
30.5 45.7
30.5
61.0 45.7
11.4
99.0
83.8
99.045.7
45.730.5
11.4 45.7
45.7 45.745.7
144.7
144.7
45.7 61.0
30.5
45.7
30.5
11.4
45.7
45.7
30.5
45.7 45.7
30.511.445.745.7
61.0
45.7
99.0
45.7
160.0
45.7
45.7
30.5
45.7
45.7
45.7
30.5
45.7
30.5
45.7
61.0
11.4 45.7
15.2 30.5 45.7
61.0
144.7
144
45.7 61.0
30.5
45.7
45.7
61.0
45.7
30.5
45.7
45.7
45.7
30.5 45.7 45.730.5
5
99.0
45.7 61.0
30.5
45.7
129.5
45.7
129.5
45.7
45.7
45.7
30.5
61.0
3 68.5
83.8
11.4 45.7
61.0
61.0
11.4 45.7
45.7
30.5
45.7
45.745.7
45.7 61.0
30.5
45.7
61.0
61.0 45.7
11.4
61.0
45.7
30.5
61.0
45.7
30.5
45.7 45.7 45.730.5
45.7
11.4 11.4
45.7160.0
45.7
30.5
45.7
45.7
22.8
68.5
45.7
11.4 45.7 45.730.5
45.715.3
45.7
45.7
30.5
14.4
11.4
45.7
45.7
45.7
Min.
30.5
11.4
45.7
99.0
99.0
11.4
61.0
61.0
11.4
45.7
61.0
45.7
30.5
45.7
30.5
45.7
45.7
45.7
45.7 45.745.7 30.516924
11.4
45.7
61.0
Part
Nos.
16920/16921
16922
16923
45.730.5
45.7 45.7
45.7
1.1
15.24
61.0
61.0
45.7 30.5
45.7 11.4 45.7
45.7
45.7
45.7
45.7
45.7
45.7
45.7
11.4 11.4
45.7 45.7 45.730.5
45.7
30.5
30.5
83.8 30.545.7
45.7
45.7
61.0
45.730.5
99.0
99.0
11.4
45.745.7
61.0
83.8
30.5
45.7
45.7 11.4
11.4 61.045.7
45.7 45.7
45.7 45.7 45.7
45.7
11.4 45.7 45.7 30.5
8.6
61.0
61.0
45.7
99.0
99.045.745.7
83.8
99.0
45.7
144.7 45.7
45.7
45.7
11.4 11.4
45.7 45.7 45.730.5 144.7
45.7
30.511.4 45.7
11.4 144.7
11.445.7 45.7
45.7
45.7
61.0
45.7
61.0
83.8
144.7
11.4 45.7 R 30.5 45.745.7
Color (G=green,
Y=yellow, R=red)
G 11.4 Y45.7
R30.5
G
Y
B
G
Y
W
G
Y
R 45.7 45.7
45.7
30.5 R
61.0
61.0
5
45.7
61.0
45.7 61.0
45.7
30.5
45.7
45.7
45.7 45.730.5
45.7 11.4
11.4 45.799.0
45.7
45.7
45.7
45.7 45.7
45.7
30.5
11.4
45.7
30.5 45.7
45.7
45.7
61.0
61.0
45.7
45.7
30.5
99.0
99.0160.0
160.0
61.0
61.0
11.4 45.7
45.7 45.7 45.
11.4 61.0
45.7
45.7
11.4
45.7 45.7 45.7
45.7
3.0
22.8
11.4
61.0
30.5
45.715.3
45.7
114.3
45.7
30.5
45.7
45.7 114.345.7
Min.
45.7
45.7
61.0
1.0
45.7 45.7
45.7
45.7
160.0
45.7
45.7
45.7
45.7
45.7
45.7 23
45.7
Codes
30.5
02
04
0845.7 45.7 45.7
02
04
08 14.4 00
8011.445.7
45
88
30.5
11.4
45.7
11.4
61.0
61.0
11.4 61.0
45.7
30.5
30.5
45.7
45.7 Color30.5
11.4 45.745.7 30.5 45.7
45.7
30.5
11.4 45.7
30.5
45.7
45.7
15.2 45.7
45.7
11.4
45.7
45.7 45.7 45.7
45.7
11.4
61.0
45.7
45.7
45.7
45.7
45.7
45.7
30.5
45.7
11.4
45.7
45.7
45.7
45.7 45.7
45.7
45.7
45.7
11.4 11.4
45.7 45.7 45.730.5
114.3
45.7
30.5
45.7
30.5
45.7 61.0
30.5
45.7 11.4
45.7
11.4
61.0
61.045.7
83.8 45.745.7 30.5 45.7
45.7
11.4 45.783.8 30.5
30.5 45.7
45.7
45.7
45.7
30.5
45.7
11.4 11.4
45.7 45.7 45.730.5
38.1
45.7 45.7 45.7
45.7
61.0
45.7
45.7
45.745.7
99.0
45.7 45.711.4
45.745.7
11.4
45.7
45.7
5.7
30.5
11.4
45.7
45.7
30.5
45.7
45.7
45.7
11.4
45.7
45.7
45.7
129.5
83.8
129.5
ABSOLUTE
61.0
45.7 MAXIMUM
30.5
45.7RATINGS (Ta=25°C)
11.4
45.7
61.0
45.7
45.799.0
99.0
30.5
11.4
45.7
45.7
11.4
45.7
45.7
45.7
45.7
30.5
45.7
45.7
45.7
45.7
61.0
5
11.4 45.7
45.7
45.7
30.5
45.7
30.5
45.7
45.7
45.7
45.7
11.4
61.0
45.7
45.7
30.5
45.7
1.1
15.24
45.7 45.7 45.730.5 45.7
45.7
11.4 45.7
45.7
61.0
11.4 99.0
45.7
99.0
45.7
61.0
45.7
30.5
45.7
45.7
3.0
45.7
30.5
61.0
45.7
30.5
45.7 11.4
114.3
114.3
45.7
30.5
45.7 99.0160.0
45.7 150
30.511.445.745.7
99.0
160.0
45.7
22.8
8.6 45.7
45.7
45.7
45.7
45.7100
45.7
45.7
45.745.7
114.3
45.7
mW 45.745.7
10045.730.545.7
100
135
13545.7 135 14.4
10545.7
70
6011.4
300
45.7
45.7 130
45.7
Min.
15.3
61.0120
11.4 45.760
45.7
61.0
61.0Power
45.7
45.7
45.7114.345.7
45.7
30.5
11
45.7
30.5
15.2
45.7
30.5
45.7
45.7
45.7
45.7
45.7
30.5
45.7
45.7
45.7
30.5 114.3
11.4 45.7
30.5
11.4 45.7
45.7
45.7
45.7
11.4
45.7
61.0
83.8
144.7
144.7
45.7
61.0
45.7
45.7
30.5
45.7
45.745.7 38.1
45.7
45.7
45.7
61.0
45.7
11.4 45.7
30.5
11.4 11.4
45.7 45.7 30.5
45.7
30.5
45.730.5
45.7 45.7 45.7
45.7
83.8 30.5
45.7
45.7
45.7
30.5 40 45.7
30.5
11.4 45.7 20
11.4 45.720
45.7
45.7
45.7 45.7
30.5 45.7
Current61.0
forward
mA
30
30
30
30
30
3011.4 11.4
30
20 114.3 25
40
90 45.7
45.7
11.4
45.7
45.7
61.0
45.7
45.7
83.8
45.7
30.5
45.7
114.3
61.0
99.0
99.0
11.4 45.7 45.7 30.511.4 61.0
30.5
45.7 45.7 45.7
45.745.7
160.0
45.7
45.7
45.7
30.5
45.7
45.7
45.7 45.7 45.7
30.5
30.5
45.7
30.5
1.1
15.24
45.7
61.011.4 45.7
11.4 45.7
45.7
45.7
45.7
61.0
11.4
61.0
45.7
45.7
99.0
99.045.7
11.4 61.0
45.7
30.5
11.4
45.7
45.7
45.7
99.0
**45.7
45.7 61.0
30.545.7 45.730.5
144.7
3.0
144.7
8.6 45.7
mA 45.7
50
50
90 45.7
90
20045.7
6045.7
60
100 45.799.06045.7
500
1000
114.3
114.3
45.7 90
30.5
45.750 30.5
114.3
99.0
99.0
160.0500
61.011.4
11.4 45.7
160.0
45.7
61.0 Forward peak current 30.5
45.7
45.7
45.7
61.0
11.4 99.0
45.7
11
61.0
114.3
61.0
45.7
61.0
45.7
30.5
99.0
45.7 45.730.5 30.545.7
45.7 45.730.5
160.0
45.7
11.4 11.4
45.7 160.0
45.7
45.7
53.3
45.7
30.5
15.2
11.4
45.7
45.7
45.7
83.8
45.7
30.5
45.7
30.5
11.4 45.7
45.7
61.0
45.7
45.7
45.7
45.7
114.3
61.0
11.4 45.7
61.0 61.0
45.745.7 30.5
45.7 61.0
30.5
45.7
11.4
45.7 45.730.5
45.7
61.0
11.4
45.7
45.7
45.7
114.3
45.7
30.5
45.7
30.5
45.7
30.5
38.1
Voltage
reverse
V
545.7
5
5 45.7
545.7
5
5
5 11.4 45.7 3 30.5 114.3
3 129.5
5
3
12
12
5 11.4
61.0 11.4 45.7
11.4
45.745.7
160
160.0
45.7
30.5
45.7
45.7
61.0
129.5
45.7
11.4
61.0
61.0
45.7
45.7
30.5
160.0
45.7
61.0
45.7
99.0
99.0 45.7 45.7 45.730.5 45.7
61.0 11.4 45.7 45.7 30.511.4 61.0
11.4
45.7 45.7 45.7
45.7
30.5
45.7
45.7
45.7
30.5 45.745.7 11.4
11.4 45.7
45.7
45.7
45.7
61.0
45.7 11.4 45.761.011.4
1.1
15.24
45.7 129.5 45.7
45.7
61.0
45.7 45.7
61.0
45.7 45.7 61.0
45.7
11.4
45.7
45.7
45.7
Operating
45.7 45.730.5
45.7
30.5
45.7
30.5 45.7
45.7
11.4
45.7
99.0 45.7 -25 /
61.0
11.4 45.799.0
45.7 99.0
11.4 45.7 99.0 45.7 114.3
45.7
61.0
45.7
45.7
8.6 45.711.4 30.5
°C 45.7
-25 / +100
-55
+100
+85
-55 / +100
45.7 61.0 30.5
45.7
45.7
45.7
61.0
11.4
45.7
61.0
11.4 99.0
45.7
45.7
45.7
45.7
61.0
45.7
61.0
83.8
144.7
144.7
99.0
30.5
11.4
45.7114.3
45.7 45.730.5
temperature
45.7
45.7
11
53.3
45.7
30.5
45.7
61.0
45.7
61.0
45.7
45.7
11.4
45.7
11.4
45.7
11.4
45.7
45.7
45.7
45.7
45.7
45.7
30.5
45.7
45.7
61.0
11.4 45.7
45.7
45.7
45.7
61.0
45.7
61.0
83.8
30.5
11.4
45.7
45.7
61.0
45.7
61.0
30.5
45.7
45.7
45.7
45.7
114.3
45.7 11.4 45.7 11.4 61.0
11.4 45.7114.3 30.5
45.7
45.7
30.5
45.7
45.7
61.0
45.7
45.7
61.0129.5
11.4 45.7
45.7
30.5
45.7
114.3
114.3
45.7
45.7
129.5
45.7 / +100
45.745.7 -55
45.7
45.7
11.4
45.7
45.7
61.0
Storage
temperature
°C
-25
+100
-30
+100
-55
+100
45.7
61.0
129.5
45.7
61.0
45.7
45.7
11.4
45.7
30.5
45.7
11.4
61.0
45.7
30.5
45.7
30.5
45.7 45.7 45.7
45.7
61.0
45.7
160.0
45.7
61.0
45.7
45.7
45.7
45.7
45.7
61.0
11.4 45.7 11.4
30.5
45.7
61.0
45.745.7
45.7
45.761.0
11.4 45.7
45.7
45.7
61.0
129.5 45.7
45.7
45.7 45.745.7
45.7
45.7
30.5
99.0
160.0
160.0 61.0
45.7
61.0 45.7
61.0
45.799.0
45.7
30.5
45.7 11.4
30.5
45.7
45.7
45.7 11.4 11.4
45.7
45.7
11.4 11.4
45.7 45.7 45.7
45.7
45.7 45.7 45.730.5 99.0
45.7
45.7
45.7
45.7 30.5 45.7 °C
45.7
45.7 for max.
61.0
45.7 +300
45.745.7
45.7
11.4 45.7
11.4 45.799.0
45.7for max. 5 sec
61.0 Soldering
+245
3 sec
+300 for max. 3 sec
+260
for max.
311.4
sec45.7
45.7
61.0
7
45.7 45.7
83.8
45.7temperature
30.5
68.5
61.0
61.0
45.7
61.0
45.7
30.5
45.7
99.0
99.0
129.5 11.4 45.7
30.5
11.4 45.7
45.7
61.0
11.4
129.5
11.4
45.7 45.7 45.730.5
45.7
45.7
53.3
61.0
11.4
45.7 45.7
30.5 45.745.7
45.7
45.7
45.7
45.7
61.0
11.4
45.7
45.7
45.7
45.7 45.7
30.5
45.7
45.7
45.7
45.7 45.7
11.4 45.7
30.5
61.0
11.4
61.0
45.7
61.0
45.7
30.5
45.7
45.7
30.5
11.4 45.7
45.7
61.0
114.3
114.3
11.4
45.7
45.7 45.7
30.5
61.0
11.4
114.3
114.3
45.7 45.7 45.7
45.7
61.0
45.7
45.7
45.7
30.5 45.745.7
114.3
45.7 114.3
45.7
ELECTRICAL-OPTICAL
CHARACTERISTICS
(Ta=25°C)
45.7
129.5 11.4
45.7
45.7
129.5
45.761.0 45.7
114.3
129.5
114.3 45.7
11.4
30.5
45.7 45.7
61.0
45.7
30.5
45.7
45.7
45.7
61.0
11.4 45.7114.3 30.5
45.7
45.7 45.745.7
45.730.530.5
45.7
45.7
114.3
11.4 45.7
45.7
45.7 45.7 45.730.5
45.7
45.745.7
61.0
45.7
45.7
61.0
11.4
45.7
45.7
45.7
99.0
45.7
99.0
45.7
45.7
45.7
129.5 45.7
45.7
61.0
45.7
61.0 45.7 45.7 45.730.5 45.7
45.7
61.0
45.7
30.5
45.7 11.4
11.4 45.7 45.7 30.5
45.7
11.4 45.711.4 30.5
45.7 45.745.7
30.5 30.5 45.7
45.7
45.7
45.7
61.0
Voltage45.7
forward
Typ. V
2.045.7
2.0
2.0
2.1
2.2
2.3
2.1
2.1 45.7 129.5
2.1
3.8 45.7129.5
2.030.511.445.745.7
2.1*
2.3***
2.4*** 45.7
11.4
45.7
7
45.7
129
45.7 45.7
45.7129.5
30.5
45.7
45.7
68.5
11.4
45.7
45.7
61.0
61.0
144.7
144.7
45.7
30.5
45.7 45.7
11.4 45.783.8 30.5
45.7
30.5
45.7
45.7
45.7
30.5
45.7
45.7
30.511.4 11.4
45.7
61.0
45.7
61.0
45.7
30.5
45.7 45.7 45.7 45.7
11.4
45.7
45.745.7
61.0
61.0
11.4 45.7
45.7
45.7
45.7
61.0
11.4
45.7
45.7
61.0
45.7
30.5
45.7
30.5
45.7
45.7
45.7 3.8***
11.461.0
45.7
30.5
11.4 3.0
45.7
45.745.7 3.0
30.5
144.7
30.5
45.7
45.7 3.0
45.7
61.0
45.7
30.53.0 45.7
114.3
114.3
45.7
45.7
Max.
V
3.0
3.0
3.0
3.0
2.8
3.0
4.3
2.5*
2.5***
61.0
11.4 45.7
114.3
45.7
114.3
45.7 45.7 45.7
114.3
45.7
61.0
61.0
11.4 45.7
30.5
45.7 45.7
45.7
30.5
45.7 45.7
61.0
61.0129.5 45.7
11.4 11.4
45.7 45.7 114.3
45.745.745.7 30.5
61.0 45.7
45.7
45.7
11.4 61.0
45.7
30.5
45.7
11.4160.0
45.7
30.5
99.0
114.3 30.5
114.3
45.7
30.5
45.7
45.7
160.0
11.4 99.0
45.7
45.7
45.7
45.7
45.7
45.7
11.4
45.7
61.0
11.4 45.7
45.7 61.0
30.5
45.7160.0
160.061.0
45.7
61.0
45.7
61.0
45.7
45.7
45.7
11.4 45.7
45.7
30.5
45.7
30.5
45.7
99.0
45.7
45.7 45.7
61.0
45.7
61.0
45.7
30.5
11.4 10
45.7
30.5
45.7
Current
reverse45.7 61.0
µA
100
100
100
100
100 45.7 11.4 2 45.799.0 45.7
10
10
50 45.745.7129.5
10
1030.5
129.5
129.5 45.710
45.7
45.7
30.530.511.4 45.7
11.4
129
45.7
45.7 100
30.5
45.7
45.7
61.0
11.4 45.7
30.5
45.7
7
45.7
129.5
45.7
61.0
45.7 61.0 61.0
144.7
144.7
129.5
11.4
45.7
68.5
45.7
61.0
144.7
45.7
30.5
45.7
45.7
45.7
11.4 45.745.7 30.530.511.4 11.4
45.7
45.7
61.045.7
45.7
45.7 61.0
30.5
45.7 45.7
45.7
30.5
45.7
45.7
61.0
11.461.0 45.7
30.5
45.7
61.0
45.7
61.0
45.7 11.4 45.7
30.5
45.7
11.4 45.7
61.0
45.7length61.045.7
144.7
30.5
45.7
45.7 56530.5 45.7 45.7
Wave
nm
560
590
660
585
635
460
563
585
NA
650
570
587
635
45.7
45.7
114.3
114.3
45.7
30.5
45.7
45.7
45.7
61.0
61.045.7
45.7
30.5
45.7
114.3
114.3
45.7
45.7
45.7
61.0
61.0
11.4 11.4
45.7 45.7
45.7
61.0
45.7
61.0
114.3
114.3
11.4 11.4
45.7 45.7
30.5
45.7
61.0
11.4
45.7 99.0
61.0
11.4 45.7
45.7
30.5
45.7
45.7
30.5 45.7 45.7 30.5
61.045.7
99.0
45.7
45.7
11.4 45.7114.3 30.5
45.7
45.7
45.7
30.5
114.3
45.7
30.5
45.7
45.7 61.0 45.7
45.7
83.8
11.4 45.7
45.7
61.0
45.7
11.4 11.4
45.7
45.7
144.7 11.4 45.7
144.7
61.0
45.7
61.0
45.7
11.4
30.5
45.7 45.7 45.7
45.7
30.5
45.7
45.740
61.0 40
45.7
45.7
61.0
Ønm
10
10
10
10
10
40
NA 45.7
40
25
45
45.745
45.7
11.4 45.7
45.7
11.4
45.7
30.5
45.7 Spread
30.5
30.510 45.7
45.7 61.0 45.7
45.7 45.7
11.4 45.7 11.4 45.7
45.7129.5
30.5
45.7 129.5
129.5 45.7
129.5
30.5
45.7 61.0 45.7
129
45.7 45.7
61.0
45.7
30.5
45.7
129.5
45.7 45.7 45.7
11.4
45.7
45.7
30.5
45.7
45.7
61.0
129.5 45.7
144.7
45.7
61.0
144.7
144.7
129.5
30.5
45.7
45.7 11.4 45.7
11.4
45.7 61.0 45.7
45.7
45.7
30.5
45.7
11.4 45.7 129.5
45.7 61.0
11.4
61.0
11.445.7 45.7
30.5
45.7
45.7
129.5
45.745.7
45.7
61.0
11.4 45.7
45.7
45.7 45
30.5
45.7
45.7
45.7 angle
61.0
Spread
degree
20 45.7 20
2045.7 45.7
4530.5
45 45.7
20 30.5 114.3
45
45
25
45 114.3
25
45
45
45.7
61.0
45.7
30.561.0
144.7
45.7
45.7
45.7
45.7
45.7 45.7
45.7
11.4 45.711.4 45.7
45.7
45.7
11.4 45.7
45.7
45.7
45.7
61.0
45.745.7
45.7
45.7 45.745.7 61.0
61.0
11.4
45.7
61.0
144.7 11.4
45.7 45.7 30.5 45.7
144.7
45.7
30.5
45.7
45.7
61.0
61.0
61.0
11.4
45.7 45.730.511.445.745.7
11.4 45.7
45.7
45.7
61.0
11.4 45.7
45.7
30.5
45.7
160.0
99.0
45.7
45.7
45.7
45.7
30.5
45.7
83.8160.0
11.4 45.799.0
45.7
45.7 61.0
45.7
45.7
61.0
45.7
30.5
45.7
45.7
45.7
45.7
45.7 45.7
45.745.7
61.0
11.4
45.7
30.5
45.7 Min. mcd
61.0
45.7 45.7
61.0 2.5
45.730.511.4630
11.4
45.7
Luminous Intensity
1
1
0.8 45.7 1.5
2.5
5.6
5.6
71****
100****
45.7 11.4 45.7
11.4 45.771****
30.5
45.7
30.5
45.7
45.7
45.7
45.7
30.5
45.7
45.7
45.7
45.7
45.7
11.4
45.7
30.5 45.7
45.7 11.4 45.7
45.745.7
45.745.7 45.761.0
61.0
45.7 30.5
45.7
30.5
45.7
160.0
45.7
45.7
45.7
45.7
61.0
45.7
11.4 45.7
30.5
45.7 11.4 45.7
129.5 45.7
61.0
129.5
129.5 45.7
129.5
30.5
61.0
11.4 45.7
45.7 45.7 45.730.5
45.745.7
11.4 45.7
30.5
45.7
30.5
45.7
45.7
45.7
45.7
45.7
61.0
11.4 114.3
45.7
30.5 45.7
45.7
45.7
11.4
45.7
11.4 45.7 129.5 144.7
45.7
45.7
114.3
61.0
45.7
45.7
45.7
129.5
45.7
45.7
45.7
61.0
11.4 45.7
45.7
61.0
11.4 45.7 45.7 30.5
45.7
61.0
Typ.
1.6
2.5
3.0
5.0
25 30.5
25 129.5 16 11.4 1000
112****
160****
129.5
45.7
30.5 16 45.7 112****
45.7 45.7 345.730.5
45.7
45.7
45.7
30.5
45.7
45.7 mcd
30.5 45.7 2 45.7
45.7
45.7
11.4 114.3
45.7
45.7
61.0
45.7 45.7
45.7
114.3
45.7
45.7
45.7
45.7
61.0
11.4
61.0
45.7
45.7
45.7
30.5 45.7
45.7
144.7
11.4 45.745.7
45.745.7
45.7
11.4 45.7
144.7
30.5
11.445.7
45.7
45.7
61.0
45.7
30.5
45.7
61.0
45.7
45.7
45.7
30.5
45.7
45.7
30.5
45.7
61.0
45.7 11.4
45.7
160.0
144.7
144.7
160.0 45.7
45.7
30.511.4 45.7
45.7
30.5
45.7
45.7
45.7
30.5
45.7
45.7
45.7
45.7
160.0
45.7 is the
30.5 anode,
45.7
11.4 45.745.7
45.745.7
45.7the cathode.
61.0
11.445.745.783.8 30.5
45.7
61.0
30.5
Orientation
pin
the shorter
is
45.7
45.7 45.7 45.7
45.7
45.7144.745.7
45.7
45.7
30.5
45.7The longer
144.7
45.7
30.5
45.7
45.7
30.5
45.7
45.7
45.7
45.7
45.7
11.4
45.7
30.5
45.7
11.4
45.7
30.5
45.7
45.7
45.7
45.7
45.7
45.7
30.5 45.7
45.7
160.0
129.5
45.7
61.0
129.5
45.7
45.7
45.7 30.530.5
45.7
30.5
45.7
45.7
45.7
45.7
61.0
11.4
45.7
45.7
11.4
45.7
30.5
45.7
45.7
45.7
30.5
45.7
45.7
30.5
45.7
129.5 45.7
129.5
11.4 45.7
30.5
45.7
11.4 114.3
45.7
30.5
45.7
45.7
45.7
30.5 45.7
45.7
114.3
45.7
45.7
45.7
45.7
45.7
45.7
61.0
11.4 45.7 129.5 45.7
45.7
45.7
129.5 45.7
45.7
45.7
30.5
45.7
45.7
129.5
30.5
99.0
99.0160.0 11.4 45.7
61.0
11.4 45.7
61.0
11.4 45.7
160.0
129.5
45.7
30.5
45.7
45.7
45.7
11.4
45.7
45.7
45.7
45.7 45.7
45.7
30.5 45.7 45.7
61.0
45.7 45.7
30.5
45.7
45.7
30.5
45.7
45.7
45.7
11.4 45.7
45.7
45.7
45.7
45.7
45.7
30.5
61.0
11.4
45.7144.7 45.7
144.7
45.7
61.0
30.5
11.445.7
45.7
45.7
11.4 45.7
45.7 30.5 144.7
144.7
45.7
11.4
45.7
45.7
30.5
45.7
45.7
45.7
160.0
144.7
160.0
144.7
160.0
45.7
30.5
45.7
45.7
30.5
45.7
45.7
11.4 45.7
30.5
45.7
45.7 45.7 30.5
45.7
45.7
45.7
45.7
61.0
30.5
11.445.745.7
144.7
45.7
61.0
144.7
144.7
144.7
45.7
30.5
45.7
11.4 45.7
30.5 45.745.7
45.7
45.7
45.7
11.4
45.7
30.5
45.7
45.7
30.5
45.7
45.7
30.5
45.7
129.5
129.530.5
45.7
45.7
45.7
45.7
45.7 45.7 45.7 30.5 45.7
160.0
61.0
11.4 45.711.4 45.7
45.7
61.0
11.4
45.7
45.7
61.0
45.7
30.5
45.7
45.7
30.5
160.0
45.7
160.0
45.7
11.4
45.7
45.7
45.7
11.4 45.7
45.7
45.7
11.4 45.7
30.5
45.7
30.5
45.7
30.5
45.7
11.4 114.3
45.7
30.5
45.799.0
114.3
45.7
45.7
45.7
45.7
45.7
45.7
99.0
61.0
11.4 45.7
45.7
45.7
30.5
45.761.0
45.7
30.5
129.5
11.4 45.7
30.5
45.7
129.5
45.7
11.4
45.7
45.7
45.7
30.5
45.7
45.7 45.7 30.5 45.7 45.7
45.7
45.7
11.4 45.7
45.7
45.7
11.4 45.7
45.7
11.4 45.7
45.7
45.7
45.7
61.0
45.7
30.5
45.7
61.0
30.5
45.715.3
Min.
15.2
68.5
53.3
11.4
45.7
45.7
41.9 57.1
41.9
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
mec a/s Jan. 2002
7.1
.953.3
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
68.5
38.1
38.1
38.1 38.1
68.5
68.5
22.8
22.8
38.138.1
68.5
22.8
22.8
38.1 38.1
68.5
38.1
38.1
68.5
38.138.1
68.5
38.1 38.1
68.5
8.1
8.5
53.3
68.5
53.3
53.3
53.3
53.3 53.3
68.5
68.5
53.3
68.5
53.3
mec a/s Jan. 2002
mec a/s Jan. 2002
7.1
7.1
7.1
2.6
7.1
7.1
53.3
53.3
68.5
53.3
53.3
68.5
53.3
53.3 53.3
53.3
68.5
68.5
68.5
68.5
53.3
68.5
53.3
53.3
53.3
53.3 53.3
68.5
68.5
41.9
41.9
9
68.5
41.9 68.5
2.6
7.1
53.3
2.6
2.6
10.9
7.1
10.9
10.9
10.9 2.6
10.9 2.6
3.8 3.0 4.1
3.8 3.0 4.1 7.1
7.1
3.8 3.0 4.1
53.3 3.8 3.0 4.17.1
2.6
7.1
10.9
3.8 3.0 4.1
2.6
2.6
41.9
7.1
41.9
41.9
7.1
41.9
7.1
41.9
41.9
53.3
53.3
53.3
41.9
53.3
53.3
53.3
41.9
53.3
53.3
53.3
53.3
41.9
53.3
53.3
53.3
53.3
41.9
53.3
53.3
53.3
41.9
53.3
41.9
41.9
53.3
53.3
41.9
53.3 41.9
53.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
7.1
1.5
53.3
1.5
41.9
1.5
53.3
1.5
7.1
10.9
3.8 3.0 4.1
2.6
22.8
38.1
53.3
53.3
.8
3
53.3
53.3
38.1
38.1 38.1
38.1 38.1
53.3
53.3
53.3
53.3
38.1
53.3
22.8 22.8
22.822.8
22.8
22.8
53.3
53.3
53.3
53.3
53.3
53.3
38.1
38.1 38.1
38.1 38.1
53.3
53.3
53.3
38.1
22.8 22.8
22.822.8
22.8
22.8
53.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
38.1
38.1 38.1
38.1 38.1
53.3
53.3
53.3
38.1
22.8 22.8
22.822.8
22.8
22.8
53.3
53.3
53.3
53.3
53.3
53.3
38.1
38.1
38.1
53.3
.1
53.3
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
22.8
53.3
53.3
53.3
53.3
53.3
53.3
53.3
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
53.3
53.3
53.3
53.3
3.8 3.0
3.8 3.0 4.138.1 3.8 3.0 4.1
4.1
38.1
53.3
38.1
38.1
53.3
10.9
10.9 53.3
10.938.1
38.1 38.1
38.1 38.1
38.1
38.1
22.8
22.8
38.1
53.3 53.3
53.3
38.1
38.1
38.1
53.3
38.1
38.1
38.1
22.8 3.8 3.0 4.1
3.8 3.0
4.138.1 22.8
4.1
53.3
53.3
53.3 53.3 38.1
38.1 3.8 3.038.1
38.1
38.1
22.8 22.8
22.822.8
22.8
22.8
22.8
1.5
1.5
1.5
38.1 53.3 38.1
38.1
10.9
10.9
10.9
22.8
22.8 22.8
22.822.8
22.8
38.1 38.1
38.1
53.3 53.3
53.3
53.3
53.353.3
38.1
38.1
38.1
22.8
22.8 22.8
22.822.8
22.8
53.3
53.3
3.8 3.0 4.1
3.8 3.0 4.1
3.8 3.0 4.1
53.3
53.3
53.3 53.3
53.3
53.3
1.5
1.5
1.5
53.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
10.9
10.9
53.3
53.3
53.3
53.3
1.5
1.5
1.5
53.3
53.3
3.8
3.0
3.8
3.0 4.1
4.1
10.9 53.3
10.9 53.3
10.9 53.3
53.3
53.3
53.3
53.3
3.8 3.0 4.1
3.8 3.0 4.1
3.8 3.0 4.1
53.353.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
53.3
41.9
53.341.9
53.3
53.3
53.3
53.31.5
1.5
53.3
53.3 41.9
53.3
53.3
41.9
53.3
53.3
53.3
53.3
53.3
1.5
1.5
1.5
41.9 53.3
41.9 53.3 53.3
2.6
2.6
2.6
53.3
41.9
41.9
41.9
41.9
41.9
53.3
53.3
10.9
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
10.9
53.3
10.9
38.1
38.1
38.138.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
68.5
38.1
38.1
38.1
68.5
53.3
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
68.5
38.1
68.5
38.1
38.1
38.1
68.5
38.1
68.5
38.1
22.8
22.8 22.8
22.8
38.1
38.1
68.5
38.1
mec
38.1
38.1
68.5
38.1
68.5
53.3
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
68.5
38.1
38.1
38.1
38.1
38.1
68.5
38.1
68.5
38.1
38.1
22.8
38.1
22.8
68.538.1
22.8
38.1
22.8
38.1
22.8 22.8
22.8 22.8
22.8
22.8
22.8
22.8
68.5
38.1 38.1
38.1
38.1
38.1
38.1 38.1
38.1
38.1
38.1
38.1
38.1
68.5
68.5
68.5
38.138.1
38.1
38.1
68.5
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
38.1
22.8
22.8
22.8
38.1
22.8
22.8
38.1
38.1
38.1
22.8
22.8
38.1
22.8
22.8
22.8 22.8
38.1
38.1
22.8
22.8
38.1
22.8
22.8
22.8 22.8
38.1
38.1
2.8
8.1
38.1 38.1
38.1
38.138.1
38.1
68.5
38.1
22.8
22.8
22.8
22.8
22.8
53.3
38.1
38.1
38.1
1.5
38.1
38.1
38.1
38.1
3.8
3.0 4.1
22.8
38.1
22.8
22.8
38.1
38.1
22.8
38.1
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
22.8
53.3
38.1
68.5
38.1
22.8
38.1
22.8
38.1
10.9
38.1
22.8
22.8
(1x1)
For16.410
all types
switches
with
bezels
- 16310-16315
and 16324-163
16.431
(3x4) of UNIMEC
16.440
(4x4)
(2x4)
3 (1x4)
16.420 (2x2)
16.411
(1x2)16.422
16.431 (3x3)
(3x4)
16.440 (4x4)
16.422 (5x5)
(2x4)
(1x4)
414
(1x5)
16.423
16.450
16.432
(3x5) 16.432
16.441
(4x5) 16.441
16.412
(1x3)
16.430
16.421
(2x3)
16.410
(1x1)
r all
types
of
switches
with
-16.413
16310-16315
and
16324-16326
16.414
(1x5) (2x5)
16.423
(2x5)
16.450
(5x5)
(3x5)
(4x5)
For
allUNIMEC
types
of UNIMEC
switches
with
bezels
and
16324-16326
16.500
(10x10)
16.420
(2x2) - 16310-16315
16.411
(1x2) bezels
16.433
(3x
16.424
(2x6)
16.415
(1x6)
16.417
(1x8)
16.426
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
16.415
(1x6)
16.410
(1x1)
16.410(3x3)
(1x1)
16.430
16.421
(2x3)
16.433
(3x
16.424
(2x6)
16.415
(1x6)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
16.500
(10x10)
(1x1)
16.420 (2x2)16.410
16.411
(1x2)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
16.410
(1x1)
16.420 (2x2)
16.411 (1x2)
mec·· Industriparken
Industriparken
rl types
all types
of
switches
with
bezels
- 16310-16315
and
16324-16326
For
allUNIMEC
types switches
of UNIMEC
switches
bezels
16310-16315
and 16324-16326mec
16.500
(10x10)
16.420
(2x2) - (4x4)
16.411
(1x2)
of
UNIMEC
with
bezels
-with
16310-16315
and
16324-16326
16.431
(3x4)
16.440
16.422
(2x4)
For
all
types
of
UNIMEC
switches
with
bezels
16310-16315
and
16324-16326
Tel.:
+45
44
97
33
66
·· Fax:
+45
16.442
(4x6)
x6)
16.451
(5x6)
16.460
(6x6)
(3x
16.424
(2x6)
16.415
(1x6)
16.417
(1x8)
16.426
16.410
(1x1)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
16.415
(1x6)
16.420
(2x2)
Tel.:
+45
44
97
33
6616.433
Fax:
+45
16.411
(1x2)
16.433
(3x
16.424
(2x6)
16.415
(1x6)
16.500
(10x10)
16.431
(3x4)
16.440
(4x4)(2x7)
16.422 (2x4)16.421 (2x3)16.416 (1x7)
1x4)16.412 (1x3)
16.452
(5x7)
16.434 (3x7)
16.443 (4x7)
16.425
16.430 (3x3)
3)
16.410
(1x1)
416.425
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432(3x7)
(3x5)
16.441
(4x5)
16.42016.434
(2x2)16.412
16.411
(1x2)
16.420
(2x2)
16.411
(1x2)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.461
16.452
(5x7)
16.443
(4x7)
(2x7)
16.410
(1x1)
16.434
(3x
16.416
(1x7)
16.425
(2x7)(1x9) 16.441
(1x3)
16.430
(3x3)
16.421
(2x3)
16.414
(1x5)
16.423
(2x5)
16.432
(3x5)
(4x5)
16.418
(1x9)
16.445
(4x9)
(2x9)
16.436
(3x9)
16.418
16.427
16.434
(3x
16.416
(1x7)
16.425
For
alltypes
types
of(2x2)
UNIMEC
switches
bezels
16310-16315
and16324-16326
16324-16326
l types
of
UNIMEC
switches
with
bezels with
-with
16310-16315
and 16.427
16324-16326
16.500
(10x10)
16.420
(2x2) --16310-16315
16.500(2x7)
(10x10)
16.411
(1x2)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.420
16.411
(1x2)
For
all
of
UNIMEC
switches
bezels
and
16.442
(4x6) 16.442
16.433
(3x6) (3x3)
16.424
(2x6) (2x3)
16.451
(5x6) 16.451
16.460
(6x6) (10x10)
41516.412
(1x6) (1x3)
16.500
16.430
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
(4x6)
16.433
(3x6)
16.424
(2x6)
(5x6)
16.460 (6x6)
16.415
(1x6)16.421
3)
16.410
(1x1)
16.410 (1x1)
16.434
(3x
16.416
(1x7)
16.425
(2x7)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
16.420
(2x2)
16.411
(1x2)
16.414
(1x5)
16.423
(2x5)
16.432
(3x5)
16.441
(4x5)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.418
(1x9)
16.416
(1x7)
16.427
16.425
(2x7)
10
(1x1)
(10x10)
16.434
(3x
16.416
(1x7)(5x8) 16.500
16.425
(2x7)
16.417
(1x8)
16.426
(2x8)
16.453
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
types
of
UNIMEC
switches
with
bezels
16310-16315
and
16324-16326
16.410
(1x1)
l types
of
UNIMEC
switches
with
bezels
- 16310-16315
and
16324-16326
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
16.420
(2x2)
16.411
(1x2)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
For
all
types
of
UNIMEC
switches
with
bezels
16310-16315
and
16324-16326
16.420
(2x2)
16.411
(1x2)
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
1x5)
16.423 (2x5)16.421 (2x3)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.412 (1x3)
16.430 (3x3)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
3)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
product
updates
and/or
changes
of specifications
please
see
www.mec.dk
16.410
(1x1)
10For(1x1)
16.434
(3x
16.416
(1x7) 16.452
16.425
(2x7)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
16.500
(10x10)
16.414
(1x5)
16.423
(2x5)
16.432
(3x5)
16.441
(4x5)
16.418
(1x9)
16.427
53
16.461
(6x7)
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
types
of
UNIMEC
switches
with
bezels
16310-16315
and
16324-16326
16.425
(2x7)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
16.434
(3x
16.416
(1x7)
16.425
(2x7)
16.410 (1x1)
16.500
(10x10)
16.417 (1x8)
16.426 (2x8)
16.453
(5x8)
16.435 (3x8)
16.444
(4x8)
16.420
(2x2)
16.411
(1x2)
16.420
(2x2)
16.411
(1x2)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
511(1x6)
16.420
(2x2)
(1x2)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.431 (3x4)16.422
16.440
(2x4)
16.413 (1x4)
16.417
(1x8)
16.426
(2x8)
16.435
(3x
(4x6)
16.433
(3x6)
16.424
(2x6)
16.415
(1x6)
16.428
(2x10)
16.446
(4x10
16.419
(1x10) (4x4)16.430
16.437
(3x10)
16.428
16.419
(1x10) 16.442
16.431
(3x4)
(4x4)
(2x4)
16.413
(1x4)
16.420
(2x2)
16.411
(1x2) 16.422
16.417
(1x8) 16.440
16.426
(2x8)
16.435
(3x
4)(1x1)
16.440
(4x4)
16.412
(1x3)
16.421
16.431 (3x3)
(3x4)
16.440 (4x4)
16.422 (2x3)
(2x4) and 16324-16326
16.413
(1x4)
pes
of
UNIMEC
switches
with
bezels
16310-16315
10
(1x1)
16.500
(10x10)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
16.500
(10x10)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
types
of
UNIMEC
switches
with
bezels
16310-16315
and
16324-16326
16.443
(4x7)
416
(1x7)
16.425
(2x7)
16.410
(1x1)
16.500
(10x10)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
16.431
(3x4)
16.440 (4x4)
16.422
(2x4)
16.413 (1x4)
16.461
16.452
(5x7)
x7)
16.443
(4x7)
16.461
(6x7)
16.452 (5x7)
16.434
(3x7)
16.443
(4x7) (6x7)
16.416
(1x7)
16.425 (2x2)
(2x7)
16.500
(10x10)
16.420
16.411
(1x2)
16.420
(2x2) (2x8)
11
(1x2) (1x8)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.417
(1x8)
16.426
(2x8)
16.435
(3x
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.415
(1x6)(4x8)
16.417
16.426
16.453
(5x8)
16.435
(3x8)
16.444
16.428
16.462
(6x8)
16.419
(1x10)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.420
(2x2)
16.411
(1x2)
16.417
(1x8)
16.426
(2x8)
16.435
(3x
4)
16.440
(4x4)
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.454
(5x9)
16.463
(6x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(1x1)
pes
of
UNIMEC
switches
with
bezels
16310-16315
and
16324-16326
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.454
(5x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
(10x10)
16.500
(10x10)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
mec
· Industriparken
23 16.500
·16.500
P.o. Box(10x10)
26 · DK-2750
16.442(3x3)
(4x6)
16.433
(3x6)(3x3) 16.430
16.424
(2x6)
16.451 (5x6)
16.460
(6x6)
1x6)
12
(1x3) 16.412
16.430
16.421
(2x3) 16.421
16.420
(2x2)
(1x2)
(1x3)
(2x3)
16.420
(2x2) 16.432
11
(1x2) (2x5)
16.423
16.450
(5x5)
(3x5)
16.441
(4x5)
16.417
(1x8)
16.426
(2x8)
16.435
(3x
Tel.:
+45
44
97
33
66
Fax:
+45
44
68
15
14
E-mail:
danm
Tel.:
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.415
(1x6)
16.428
16.419
(1x10)
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.431
(3x4)
16.440
(4x4)
16.441
(4x5)
16.422
(2x4)
16.413
(1x4)
16.420
(2x2)
16.411
(1x2)
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
16.417
16.426
16.435
(3x
4)
x1)
16.440
(4x4)with
16.414
16.423
(5x5)
16.432
(3x5)
(4x5)
16.454
(5x9)
16.418(1x5)
(1x9)
16.445
(4x9)(2x8) 16.450
16.427(2x5)
(2x9)
16.436
(3x9)(1x8) 16.441
pes
of (1x4)
UNIMEC
switches
bezels
16310-16315
and
16324-16326
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
6(1x1)
(1x7)
16.425
(2x7)
16.500
(10x10)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.418
(1x9)
16.427
(2x9)
16.436
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
16.500
(10x10)
16.412
(1x3)
16.430 (3x3)
(3x3)
16.421
(2x3)
12
(1x3) (1x5)
16.430
(3x3) (3x5)
16.421
(2x3) (2x5)
16.418
(1x9)
16.427 (2x9)
16.436 (3x
(3x
16.414
16.423
16.450
(5x5)
16.432
16.441 (4x5)
16.420
(2x2)
(1x2)
16.500 (10x10)
16.412
(1x3)
16.430
16.421
(2x3)
Tel.:
x1) 16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.414
(1x5)
16.423
(2x5)
16.441
(4x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
16.450
(5x5)
5) (1x4)16.413
16.441
16.417
(1x8) (4x5)16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.500
(10x10)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
(1x4)
16.418
(1x9)
16.427
(2x9)
16.436
(3x
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
(1x3)
16.430
(3x3)
16.421
(2x3)
16.441
(4x5)
16.454
(5x9)
16.463
(6x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.420
(2x2)
x2)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
13
(1x4)
16.418
(1x9)
16.427
(2x9)
16.436
(3x
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
16.415
(1x6)
16.464
(6x10)
16.428
(2x10)
16.446
(4x10)
16.419
(1x10)
16.455
(5x10)
16.437
(3x10)
12
(1x3)
16.430
(3x3)
16.421
(2x3)
16.431 (3x3)
(3x4)
16.440 (4x4)
16.422 (2x3)
(2x4)
16.413
(1x4)
16.442
(4x6)
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
16.420
(2x2) 16.433
(1x2)
16.412
(1x3)
16.430
16.421
or
all
types
of
UNIMEC
switches
with
bezels
16310-16315
and
16324-16326
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.415
(1x6)
16.428
(2x10)
16.446
(4x10)
16.419
(1x10)
16.455
(5x10)
16.437
(3x10)
Tel.:
x1)
16.414
(1x5)
16.423
(2x5)
16.450 (5x5)
16.432
(3x5)
16.441
(4x5)
16.450
(5x5)
5)
16.441
16.461
(6x7)
16.452
(5x7)
(3x7)
16.443
(4x7)
1x7)
16.425
(2x7) (4x5)16.434
16.500
(10x10)
16.500
(10x10)
LED COMPONENT
SPECIFICATIONS
16.414
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
(1x3)
16.430
(3x3)
16.421
(2x3)
16.441
(4x5)
16.420
(2x2)
x2)
16.453
(5x8)
x8)
16.444
(4x8)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.431
(3x4)
16.462
(6x8)
16.440
(4x4)
16.422
(2x4)
13
(1x4)(1x5)
16.418
(1x9)
16.427
(2x9)
16.436
(3x
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
16.442
(4x6)
16.414
(1x5)
16.433
(3x6)
16.423
(2x5)
16.424
(2x6)
16.450
(5x5)
16.451
(5x6)
16.432
(3x5)
16.460
(6x6)
16.415
(1x6)
16.441
(4x5)
16.454
(5x9)
(6x9)
16.418(1x4)
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.418
16.427
16.436
(3x
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.415
(1x6)
16.428
(2x10) (4x6)
16.442
16.446
(4x10)(2x9) 16.463
16.433
(3x6)
16.424
(2x6)
16.419
(1x10)
16.455
(5x10)
16.451
(5x6)
16.437
(3x10)(1x9)
16.460
or
all
types
of
UNIMEC
switches
with
bezels
16310-16315
and
16324-16326
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.415
(1x6)
7
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
16.454
(5x9)
16.463
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.428
(2x10)
16.419
(1x10)
16.437
(3x1
16.417
(1x8)
16.426
(2x8)
16.435
(3x8)
16.444
(4x8)
16.428
(2x10)
16.419
(1x10)
16.437 (3x1
16.500
16.450
(5x5)
5)
16.441
(4x5)
16.442
(4x6) Ballerup
16.433
(3x6)23
mec(3x3)
· Industriparken
· P.o. Box
26 · DK-2750
· Denmark
16.424
(2x6)
16.451
(5x6) (10x10)
16.460
(6x6)
16.415 (1x6)
x3)
16.430
16.421
(2x3)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
(1x4)
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
(1x3)
16.430
(3x3)
16.421
(2x3)
16.441
(4x5)
16.420
(2x2)
x2)
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.431
(3x4)
16.440
(4x4)
16.441
(4x5)
16.422
(2x4)
13
(1x4)
mec
Industriparken
23
P.o.
Box
26
DK-2750
Ballerup
Denmark
Tel.:
+45
44
97
33
66
Fax:
+45
44
68
15
14
E-mail:
danmec@mec.dk
www.mec.dk
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
16.415
(1x6)
16.442
(4x6)
14
(1x5)
16.423
(2x5)
16.433
(3x6)
16.424
(2x6)
16.450
(5x5)
16.451
(5x6)
16.432
(3x5)
16.415
(1x6)
16.441
(4x5)
16.454
(5x9)
16.463
(6x9)
418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.431
(3x4)
16.410 (1x1)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.454
(5x9)
16.463
(6x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
Tel.:
+45
44
97
33
66
Fax:
+45
44
68
15
14
E-mail:
danmec@mec.dk
www.mec.dk
or
all
types
of
UNIMEC
switches
with
bezels
16310-16315
and
16324-16326
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.415
(1x6)
16.428
(2x10)
16.419
(1x10)
16.437
(3x1
16.417
(1x8)
16.426
(2x8)
16.442
(4x6)
16.435
(3x8)
16.433
(3x6)
16.424
(2x6)
16.444
(4x8)
16.451
(5x6)
16.460
(6x6)
16.415
(1x6)
16.464
(6x10)
16.428
(2x10)
16.446
(4x10)
16.419
(1x10)
16.455(1x10)
(5x10)
16.437
(3x10)
16.428
(2x10)
16.419
16.437
(3x1
16.461
(6x7) · Denmark
(5x7)
16.434
(3x7)
16.443
16.416
(1x7)
16.425
(2x7)
16.500
(10x10)
x3)
16.430
(3x3)
16.421
(2x3)
mec(4x7)
· Industriparken16.452
23 · P.o.
Box 26
· DK-2750
Ballerup
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
(1x4)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
14
(1x5)
16.423
(2x5)
16.450
(5x5)
16.441
(4x5)
16.432
(3x5)
16.441
(4x5)
16.410 (1x1)
Tel.:
+45
44 97 33
6616.433
· Fax:
+45
44 68 1516.450
1416.442
· E-mail:
danmec@mec.dk
· www.mec.dk
mec
·· Industriparken
(4x6)
(3x6)
16.424
(2x6)
(5x6) 22
16.415
(1x6)
1x8)
16.414
16.426(1x5)
(2x8)
16.423
(2x5)
(5x5)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.432
(3x5)
16.441
(4x5)
16.462
(6x8)
mec16.451
Industriparken
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
16.415
(1x6)
Tel.:
+45
44
97
33
66
Fax:
+45
4
16.442
(4x6)
6)
16.451
(5x6)
16.460
(6x6)
16.428
(2x10)
16.419
(1x10)
16.437
(3x1
16.417
(1x8)
16.426
(2x8)
16.435
(3x8)
16.444
(4x8)
16.461
(6x7)
16.452
(5x7)
16.434 (3x7)
16.443 (4x7)
16.416(1x2)
(1x7)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.425(2x2)
(2x7)
16.451
(5x6)
16.460
(6x6)
16.415
(1x6)
16.420
Tel.:
+45
44
97 16.452
33 6616.437
· Fax:
+45
4
16.411
16.464
(6x10)
16.428
(2x10)
16.446
(4x10)
16.419(2x3)
(1x10)
16.455
(5x10)
16.437
(3x10)
16.428
(2x10)
16.419
(1x10)
(3x1
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
x4)
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
x3)
16.430
(3x3)
16.421
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
(1x4)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.454
(5x9)
16.463
(6x9)
8
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.461
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.425
(2x7)
mec
Industriparken
14
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
mec
· Industriparken
23
· P.o. Box
26
· DK-2750
Ballerup
· Denmark
16.410
mec· Industriparken 22
16.414 (1x5)16.425 (2x7)
16.423
(2x5)16.434 (3x7)
16.450 (5x5)
16.432
(3x5)
16.441
(4x5)
16.461
(6x7)
16.452 (5x7)
16.443
(4x7)
16.416(1x1)
(1x7)
16.500
(10x10)
Tel.:
+45
44
97
33
·· Fax:
+45
16.442
(4x6)
6)
16.451
(5x6)
16.460
(6x6)
Tel.:
+45
44
97
33
66
Fax:
+45
44
68
15
14
E-mail:
danmec@mec.dk
www.mec.dk
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
16.415
(1x6)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
16.415
(1x6)
16.420
(2x2)
Tel.:
+45 44
97 16.452
33 66
66(6x6)
Fax:
+45 4
4
16.411
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
x4)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
16.416
(1x7)
(5x7)
16.434
(3x7)
16.443
(4x7)
16.425
(2x7)
16.416
(1x7)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.425
(2x7)
16.451
(5x6)
16.460
(6x6)
15
(1x6)
16.464
(6x10)
16.428
(2x10)
16.446
(4x10) (4x7)
419
(1x10)(1x2)
16.455
(5x10)
16.437
(3x10)
16.454
(5x9)
16.442
(4x6)
16.463
(6x9)
16.433
(3x6)
16.424
(2x6)
16.445
(4x9)
16.451
(5x6)
16.460
(6x6)
x9)
16.415
(1x6)
16.464
(6x10)
16.428
(2x10)
16.446
(4x10)
16.419
(1x10)
16.455
(5x10)
16.437
(3x10)
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
16.461
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.425
(2x7)
16.418
(1x9)
16.445
(4x9)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
(2x9)
16.436
(3x9)
mec
2
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8) ·· Industriparken
mec
· (3x3)
Industriparken
23
· P.o.
Box
26 · 16.427
DK-2750
Ballerup
· Denmark
mec
Industriparken
2
16.500
(10x10)
16.464
16.428
(2x10)
16.446
(4x10)
16.455
(5x10)
16.437
16.412 (1x3)
16.430
16.421
(2x3) 16.417(3x10)
Tel.:
+45
44
97
33
66
Fax:
+45
4
16.442
(4x6)
6)
16.451
(5x6)
16.460
(6x6)
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
Tel.:
+45
44
97
33
66
Fax:
+45
44
68
15
14
E-mail:
danmec@mec.dk
www.mec.dk
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
16.415
(1x6)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.420
(2x2)
Tel.:
+45
44
97
33
66
Fax:
+45
4
16.460
(6x6)
15
(1x6)
16.411
(1x2)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
x4)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
x5)
16.423
(2x5)
16.450
16.432
16.441
16.442
(4x6)
16.454(5x5)
(5x9)
16.433
(3x6)
16.424
(2x6)
16.451
16.463 (5x6)
(6x9)
16.460 (6x6)
1x9)
16.445(4x5)
(4x9)
16.415
16.427(1x6)
(2x9)
16.436(3x5)
(3x9)
(1x5)
16.423
(2x5)
16.450
(5x5)(2x9)
16.43216.434
(3x5) see(3x7)
16.441
(4x5)
16.461
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.425
(2x7)
16.461
(6x7)
16.452
(5x7)
16.443
(4x7)
16.416
(1x7)
For16.417
product
updates
and/or
changes
of
specifications
please
www.mec.dk
16.425
(2x7)
16.418
(1x9)
16.445
16.427
16.436
(3x9)
53 (4x9)
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.462
(6x8)
16.416
(1x7)
16.425
(2x7)
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
· Industriparken
·(3x3)
P.o. Box 26 · 23
DK-2750
Ballerup
· DenmarkBallerup · Denmark16.500 (10x10)
16.412 (1x3)
16.430
16.421mec
(2x3)
mec23· Industriparken
· P.o. Box
26
· DK-2750
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
(1x6)
16.464
(6x10)
16.428
(2x10)
16.446
(4x10)
915
(1x10)
16.455
(5x10)
16.437
(3x10)
Tel.: +45
44 9716.432
33Tel.:
6616.433
· +45
Fax:
+45
15
1416.442
· +45
E-mail:
danmec@mec.dk
· www.mec.dk
(4x6)
(3x6)
16.424
(2x6)
16.451
(5x6)
16.428
(2x10) (5x8)
16.460
(6x6)
(1x6) (1x8)
16.446
16.419
(1x10)
16.437
(3x10) (6x8)
x5)16.417
16.423
(2x5)
16.450
(5x5)
(3x5)
16.441
(4x5)
44
9744
3368
66
· Fax:
4416.444
68
15 14
· E-mail:
danmec@mec.dk
· www.mec.dk
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)16.462
16.460
(6x6) (4x10)
16.415
(1x6)
16.426
(2x8)
16.453
16.435
(3x8)
(4x8)
For
product
updates
and/or
changes
of
specifications
please
see
www.mec.dk
16.461
16.452
(5x7)
16.434
(3x7)
16.443
16.416
16.425
(2x7)
53
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.462
(6x8)
16.444
(4x8)
16.461
(6x7)(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)(4x7)
16
(1x7)(1x7)
16.425
(2x7)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
(1x4)
16.461
(6x7)
16.452
(5x7)
7)
16.443
(4x7)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.425
(2x7)
16.412
(1x3)
16.430
(3x3)
16.421
(2x3)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
(1x6)
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
(2x10)
(4x10)
16.419
(1x10)
16.437
(3x10)
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
16.444
(4x8)
16.462
(6x8)
· Industriparken
23(3x8)
· P.o.
Box
2616.445
· DK-2750
Ballerup
·(5x9)
Denmark
x5)16.418
16.423 (2x5)
16.45016.428
(5x5)
16.432 (3x5)
16.454
16.441
(4x5)
16.463
(6x9) 16.446
(1x9)
(4x9)
16.427
(2x9)
16.436
(3x9)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
For
product
updates
and/or
changes
of
specifications
please
see
www.mec.dk
16.454
(5x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
53
mec
··Industriparken
23 · 68
P.o.
Box
26
· DK-2750
· Denmark
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)Ballerup
16.425
(2x7)
16
(1x7) +45
16.425
(2x7)
16.431
(3x4)
16.440
(4x4)
16.422
16.413
(1x4)
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
mec
· ·Industriparken
23 · P.o.
Box
26
· DK-2750
Tel.:
44
97
33
66(2x4)
Fax:
+45
44
15
14
· E-mail:
danmec@mec.dk
www.mec.dk
16.461
(6x7)
16.452
(5x7)
7)
16.443
(4x7)
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
x6)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.464
(6x10)
16.428
(2x10)
16.425
(2x7)
16.446
(4x10)
1x10)
16.455
(5x10)
16.437
(3x10)
Tel.:16.426
+45
44(4x10)
97
33 6616.433
· Fax: +45
44
68
15 1416.442
· E-mail:
danmec@mec.dk
· www.mec.dk
(4x6)
(3x6)
(2x6)
16.451
(5x6)
16.460
(6x6)
(1x6) (1x8) 16.424
16.417
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
16.464
(6x10)
Tel.:
+45
44
97
33
66
Fax:
+45
44
68
15
14
E-mail:
danme
16.446
16.455
(5x10)
10)
16.428
(2x10)
16.446
(4x10)
16.419
(1x10)
16.437
(3x10)
16.45416.453
(5x9)
16.417 (1x8)16.42716.435
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.463 (6x9)
16.418 (2x8)
(1x9)
16.445 (4x8)
(4x9)
(2x9)
16.436 (3x9)
16.462
(6x8)
16.454
(5x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.426
(5x8)
(3x8)
16.444
16.462
16.454
(5x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
(1x7)
16.425
(2x7)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7) (4x5)
16
(1x7) (1x4)
16.425
(2x7)
mec
· Industriparken
23 · (6x9)
P.o.
Box 26
· DK-2750
16.442
(4x6)
16.433
(3x6)
16.424
(2x6)
16.451
(5x6)
16.460
(6x6)
x6)
16.431
(3x4)
16.440
(4x4)
16.422
(2x4)
16.413
16.461
(6x7)
16.452
(5x7)
7)
16.443
(4x7)
16.461
(6x7)
16.452
(5x7)16.463
16.434
(3x7)
16.443
(4x7)
16.416
(1x7)
16.414
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.425
(2x7)
16.441
16.454
(5x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
Tel.:
+45 44
97 16.453
33 66 · Fax:
+45 44
68 15
14 · E-mail:
danme
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
16.417
(1x8)
16.426
(2x8)
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
16.454
(5x9)
16.463
(1x9)
16.445
(4x9)
16.427
(2x9)
16.454
(5x9)
17 16.418
(1x8) (2x8)
16.436
(3x9)
16.426
(2x8)· Industriparken
16.453
(5x8) 16.453
16.435
(3x8)
16.444
(4x8)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.462
(6x8) (6x9)
16.426
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
16.417
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
mec
23
P.o.
Box
26
DK-2750
Ballerup
Denmark
(6x7)
(5x7)
(3x7)
(4x7)
(1x7) (1x9) 16.42516.427
(2x7) (2x9) 16.434
16.41816.436
(1x9) (3x9) 16.443
16.445
(4x9) (6x9) 16.454 (5x9)
16.427
(2x9) (4x9) 16.452
16.436
(3x9) (5x9) 16.461
16.454
16.463
16.418
16.445
mec
· Industriparken
23 · (6x10)
P.o. Box 26 · DK-2750
Tel.: +45
44
97 33 (2x5)
66
· Fax: +45
44
68 15 14
· E-mail:(4x6)
danmec@mec.dk
· www.mec.dk
16.442
16.433
(3x6)
16.424
(2x6)
16.464
16.451
(5x6)
16.428
(2x10)
16.460
(6x6)
x6)
16.446(4x5)
(4x10)
16.419(1x5)
(1x10)
16.455
(5x10)
16.437
(3x10)
16.414
16.423
16.450
(5x5)
16.432
(3x5)
16.441
16.428
(2x10)
16.446
(4x10)
16.419
(1x10)
16.455
(5x10)
16.437
(3x10)
Tel.:
+45
44
97
33
66
Fax:
+45
44
68
15
14 · E-mail:
danme
16.417
(1x8) (2x8) 16.434
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
17 (1x8) 16.417
16.426
16.453
(5x8) 16.461
16.435
(3x8) 16.443
16.462
(6x8)
16.444
(4x8) 16.452
16.462
(6x8) 16.462
16.454
(5x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
(6x7)
(5x7)
(3x7)
(4x7)
x7)
16.425
(2x7)
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
(6x8)
23
P.o.
Box
26
DK-2750
Ballerup
Denmark
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
(1x7)
16.425
(2x7)(4x8)
16.454
(5x9)
16.463
(6x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
16.453
(5x8)
8)16.414
16.444
16.462
(6x8)
16.464
(6x10)
16.428
(2x10)
16.454
(5x9)
16.446
(4x10)
16.419
(1x10)
16.463
(6x9)
16.455
(5x10)
16.418
(1x9)
16.445
(4x9)
16.437
(3x10)
16.427
16.436
(3x9)
16.428
(2x10)
16.446
(4x10)
16.419(2x9)
(1x10)
16.455
(5x10)
16.437
(3x10)
(1x5)
16.423
(2x5)
16.450
(5x5)
16.432
(3x5)
16.441
(4x5)
*/F=20mA,
**Pulse
width
1ms
Duty
cycle
1:5,
***/F=50mA,
****Luminous
Flux
mlm
44
68
15
14
E-mail:
danmec@mec.dk
www.mec.dk
16.428
(2x10)
16.446
(4x10)
16.419
(1x10)
16.455
(5x10)
16.437
(3x10)
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
16.454
(5x9)
16.463
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
17
(1x8)
16.426
(2x8)
16.453
(5x8)
16.435
(3x8)
16.444
(4x8)
16.462
(6x8)
16.461
(6x7)
16.452
(5x7)
16.434
(3x7)
16.443
(4x7)
x7)
16.425
(2x7)
16.417 (1x8)
16.426
16.453 (5x8)
16.435
16.444
(4x8)
16.462 (6x8)
16.442
(4x6)
16.433
mec·(2x8)
Industriparken
23 · P.o.(3x8)
Box
26 · DK-2750
Ballerup
· Denmark
16.424
16.451
(5x6)
16.460
16.415
16.464 (6x6)
(6x10)
16.428 (2x6)
(2x10)
16.446
(4x10)
16.419 (1x6)
(1x10)
16.455
(5x10)
16.437 (3x6)
(3x10)
16.453
(5x8)
8)
16.444
(4x8)
16.462
16.454
16.463
(6x9)
16.418
16.445
(4x9)
16.427
(2x9)
16.436
16.454
(5x9)
16.463
(6x9)
16.418
(1x9)
16.445
(4x9)
16.427
16.436
mec
·(4x10)
Industriparken
23·(6x8)
· (5x9)
P.o.(5x10)
Box
26
· DK-2750
· Denmark
4
Tel.:
+45
44
97
33(2x9)
66
·(3x9)
Fax:(3x9)
+45
4416.428
6816.445
15(3x9)
14(2x10)
· (4x9)
E-mail:
danmec@mec.dk
www.mec.dk
16.464
(6x10)
16.428
(2x10)
16.446
(1x10)
16.455
16.437
(3x10)
16.454
(5x9)
16.446
(4x10)
16.419
(1x10)
16.463
(6x9)Ballerup
1816.419
(1x9)(1x9)
16.455
(5x10)
16.437
(3x10)
16.427
(2x9)
16.436
16.454
(5x9)
16.463
(6x9)
16.418
(1x9)
16.445
(4x9)
16.427
(2x9)
16.436
(3x9)
(1x8)
16.42616.428
(2x8) (2x10)
(5x8)
16.435(3x9)
(3x8)
16.444
(4x8)
(6x8)
Tel.:16.445
+45
44 97 33
6616.453
· Fax: +45
44 68 15
14 16.462
· E-mail:
danmec@mec.dk
www.mec.dk
16.428
(2x10)
16.446
(4x10)
16.419
(1x10)
16.455
(5x10)
16.437
(3x10)
16.454
(5x9)
16.463
(4x9)
16.427
(2x9)
16.436
16.464 (6x10)
8 contact functions •
2 pole • distinct tactile feel
USAGE GUIDELINES
HOW TO GET THE BEST RESULTS WITH
MEC SWITCHES ?
spray the switch during cleaning. The switch must
be protected at all times to prevent contamination by
flux or cleaning liquids.
These guidelines are offered to users of MEC Switches as
an aid to ensure successful and reliable switch operation.
Please see the technical specifications for details on operating and storage temperatures and soldering guidelines to
make sure you select the best switch for your application.
When wave soldering is taking place, MEC strongly recommend that the temperature profile is analyzed and compared with the temperature rating of the switch. It is also
important to monitor the accumulated heat buildup from
both the pre-heat zones and the solder zone.
For unimec™ latching versions we recommend to
leave the actuator in the released upper position during soldering. This makes the switch more resistant
to overheating.
All standard accessories for unimec™ switches are made
from ABS plastic with a maximum operating temperature
of 65°C. It is strongly recommended that accessories are
mounted after soldering of the switch.
Wave soldering: Heat built up in the switch during
pre-heating and soldering must not exceed the
maximum operating temperature of the switch. Peak
temperature must not exceed 260°C, and soldering
time is max 10 sec. (IEC-68-2-20)
LEDs have their own temperature specifications. When
fitted in a switch the LED will determine the max. operating
temperature, i.e. 16923 has an upper temperature limit of
85°C!
MOUNTING AND DISMOUNTING
If switches are to be mounted in rows it is essential that
the recommendations regarding spacing are followed. PC
board thickness should be 1.4±0.2 mm and terminal hole
diameter should be 0.9 mm.
All unimec™ caps and bezels are easily snapped onto the
switch modules and can be changed at a later time with
the exception of the unimec 16.700 cap. Once this cap is
installed it is not designed to be removed. To do so may
cause damage to the switch and the PC board if not done
very carefully.
If the 16.300 or 16.700 cap must be removed from a
unimec™ latching switch, make sure that the switch actuator is in the released, upper position before attempting to
remove the cap. This will prevent possible damage to the
internal latching pin.
SOLDERING - THROUGH HOLE
VERSIONS
Hand soldering: Max. 350°C for max. 3 sec.
ROHS COMPLIANCE
As of 1 July 2006 MEC has completed the conversion
to RoHS compliance. For more info please see our
homepage www.apem.com
TEMPERATURE LIMITS:
Switch
LEDs
Accessories
160 °C
85/100 °C
65 °C
PACKAGING
Unimec™ switches are packed in rigid tubes of 50
pieces each.
A box contains 1.000 pcs.
SOLDERING AND CLEANING
UNIMEC™ SERIES
Most assembly and field problems experienced by users of
unsealed switches are caused by the contamination of the
contacts during soldering and cleaning.
Contact contamination may be recognized by an increase
in contact resistance and possible intermittent operation of
the switch, especially in low power applications. Care must
be taken not to submerge the switch in cleaning agents or
5
PANEL
PCB SWITCHES
Unimec™
很抱歉,暂时无法提供与“1630008”相匹配的价格&库存,您可以联系我们找货
