30B1012-9
30B1012-9
    GRAYHILLINC.
    CAP PUSHBUTTON ROUND BLACK
30B1012-9 数据手册
Pushbutton Options and Accessories ACCESSORIES For Pushbutton Switches Button Caps Decorative Mounting Nuts Pendant Housing Button Guard DIMENSIONS In Inches (and millimeters) .75 (19,1) ACROSS FLATS Decorative Mounting Nuts .44 (11,2) ACROSS FLATS .50 (12,7) ACROSS FLATS 30C1023-1 .52 (13,2) DIA. Brass, nickel-plated for 1/4" (6,35) bushing. .09 (2,3) .77 (19,6) DIA. Brass, nickel-plated for 5/16" (7,93) bushing. Brass, nickel-plated for 15/32" (11,9) bushing. .12 (3,1) .09 (2,3) Button Caps and Guard .89 (22,6) DIA. 30B1012 07Z1047 Thermosetting plastic (Fasten to button with adhesive, Eastman 910 or equivalent) black, red or white. .19 (4,8) .09 (2,3) .25 (6,4) DIA. .34 (8,6) For use with all Series 30 and 39 switches except part number 39-101. See switch pages. .33 (8,4) REF. 1.19 1.03 (30,2) (26,16) .27 (6,86) DIA. Brass, cadmium-plated for 15/32" (11,9) bushing. .41 (10,4) .59 (15,0) .08 (2,0) Flat Cap .89 (22,6) .42 (10,67) Thermoplastic, black or red color. Housing 2.45 (62,23) 10C1015-1 For use with Series 2000 and Series 7 switches. See switch pages. 1.00 (25,4) DIA. Remote Switching Accessories Pendant Housing and Caps 07Z4950 07Z5051 Pushbutton Switches .46 (11,7) DIA. 07C1040-1 23C1024-1 1.19 (30,2) .08 (2,03) .25 (6,4) .89 (22,6) Recessed Cap 1.04 1.19 (30,2) (26,4) .48 (12,2) .48 (12,2) Application: All grayhill pushbutton switches with 15/32-32 bushings: catalog numbers 2201, 2202, 07-7, 07-8, 07-21, 07-22, 07-26, 4001, 4002, 10-9, 10-10, 10-100, 10-101, 30-16, 30-17 and 30-32. any other switch with 15/32-32 bushing if it fits housing. Material: Thermoplastic Specials: other colors available on special order. ORDERING INFORMATION: Mounting Nuts, Button Caps, and Guards Part Number Color 07C1040-1 23C1024 30C1023-1 07Z1047-1 BLK 07Z1047-2 RED 10C1015-1 30B1012-5 30B1012-8 30B1012-9 Decorative Nut Decorative Nut Decorative Nut Black Button Cap Red Button Cap Button Guard Red Cap White Cap Black Cap Pendant Housing and Caps Part Number 07Z4950 RED 07Z4950 BLK 07Z5051 RED 07Z5051 BLK Description Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Red Flat Cap & Housing Black Flat Cap & Housing Red Rcssd Cap & Housing Black Rcssd Cap & Housing Sold only as sets of one housing and one cap. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com D-34
30B1012-9
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为Anode、Cathode、Gate、Collector、Emitter、Base。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特性。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装。
30B1012-9 价格&库存
很抱歉,暂时无法提供与“30B1012-9”相匹配的价格&库存,您可以联系我们找货
30B1012-9
  • 1+27.694111+3.57477
  • 10+25.0448810+3.23280
  • 25+24.0742425+3.10751
  • 50+23.3669250+3.01621
  • 100+22.68063100+2.92762
  • 250+21.80270250+2.81430
  • 500+21.16133500+2.73151
  • 1000+20.538551000+2.65112
  • 5000+19.161535000+2.47338
库存:182
30B1012-9
库存:8
30B1012-9
    • 1+7.36560
    • 200+2.93760
    • 500+2.84040
    • 1000+2.79720
