30B1012-5
30B1012-5
    GRAYHILLINC.
    CAP PUSHBUTTON ROUND RED
30B1012-5 数据手册
Butt Contact Pushbutton Switches SERIES 39 SPST, 150 mA to 1/2 Amp FEATURES • Requires an Absolute Minimum of Space • Molded-In Terminals in SPST–N.O. • Solder Lug Terminals DIMENSIONS in inches (and millimeters) Economy Version Normally Open–SPST Economy and Standard Version 39-1 39-3 39-601* At 5 Vdc At 20 Vdc 1,000,000 150 mA 20 mA .110 ± .005 (2,79 ± 0,13) DIA. H .036 ±.005 (0,91 ± 0,13) H = HEX MTG NUT .063 ± .010 (1,59 ± 0,25) THICK .219 ± .010 (5,56 ± 0,25) ACROSS FLATS .068 ±.005 (1,73 ± 0,13) B E.I.A. DATE CODE LABEL* Momentary .615 (15,62) REF. C 39-601 RED 39-601 BLK Red Black Actuating Mtg. Total Force (oz.) Hole Travel .035 ± .015 +4 11/64" 4 -2 (0,89 ± 0,38) (4,37) DIA. Action A Button Color Standard D Operations at Rated Load Electrical Ratings .250 + .010/ –.005 (6,35 + 0,25/ – 0,13) DIAMETER A = .175 + .025/ –.020 (4,45 + 0,64/ – 0,51) *Label increases B = .125 ± . 010 (3,18 ± 0,25) nominal diameter C = .215 ± .015 (5,46 ± 0,38) to .255 (6,48) D = .100 ± .020 (2,54 ± 0,51) Complete Part Number At 115 Vac At 220 Vac 1,000,000 1 /2 Amp Res. 1/4 Amp Res. Action Momentary Button Color 39-1 Red 39-3 Black Actuating Total Force (oz.) Travel +4 .035 ± .015 4 –2 (0,89 ± 0,38) Mtg. Hole 11/64" (4,37) DIA. Normally Open–SPST with Sealed Bushing and Button 39-351* .110– .005 DIA. (2,79 – 0,13) A = .175 +.025/ .020 (4,45 +0,64/ 0,51) B = .125 – .010 (3,18 – 0,25) C = .250 –.015 (6,35 – 0,38) D = .100 – .020 (1,54 – 0,51) E.I.A. DATE CODE #8-40 UNS-2A THREAD C HEX MTG. NUT .0625 (1,59) TYP. THICK AND .218 (5,54) TYP. ACROSS FLATS O B .650 (16,51) REF. E.I.A. DATE CODE LABEL* Rating at 115 Vac Resistive A H B C .755 (19,18) REF. D .250 + .010/ – .005 (6,35 + 0,25/ – 0,13) DIAMETER A = .175 + .025/ –.020 (4,45 + 0,64/ – 0,51) *Label increases B = .125 .010 (3,18 0,25) nominal diameter C = .355 .015 (9,02 0,38) to .255 (6,48) D = .100 .020 (2,54 0,51) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 39-351 RED 39-351 BLK Red Black Actuating Force (oz.) .035 ± .015 16 ± 8 (0,89 ± 0,38) .110 .005 (2,79 0,13) DIA. 8-40 UNS-2A THREAD .068 .005 (1,73 0,13) Button Color Total Travel Action Momentary *Complete Part Number .072 – .005 (1,83 – 0,13) Normally Open–SPST with Overtravel .036 .005 (0,91 0,13) Operations at Rated Load .036 – .005 (0,91 – 0,13) Button is O-Ring sealed internally. H = HEX MTG NUT .063 .010 (1,60 0,25) THICK .219 .010 (5,56 0,25) ACROSS FLATS Rating at 220 Vac Resistive /2 Amp 1/4 Amp 250,000 .068 – .005 (1,73 – 0,13) D 39-12 39-24 1 O = O RING XXXX .312 –.005 (7,92 –0,13) ACROSS FLATS .072 .005 (1.83 0,13) Rating at 115 Vac Resistive A 1 Rating at 220 Vac Resistive Operations at Rated Load /2 Amp 1/4 Amp 100,000 Action Total Travel Over Travel Complete Part Number Button Color Red Black 39-12 39-24 Actuating Force (oz.) Mtg. Hole 11/64" .130 ± .025 .015 (0,38) Momentary 5 ± 3 (4,37) (3,30 ± 0,64) Min. DIA. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton Switches 8-40 UNS-2A THREAD .072 ±.005 (1.83± 0,13) Operations *Complete at Rated Part Load Number Electrical Ratings Butt Contact Pushbutton Switches DIMENSIONS in inches (and millimeters) Normally Closed–SPST 39-2 .105 – .005 (2,67 – 0,13) DIA. 8-40 UNS-2A THREAD H = HEX MTG NUT .063 – .010 (1,60 – 0,25) THICK .219 – .010 (5,56 – 0,25) ACROSS FLATS .100 ±.010 (2,54 ± 0,25) .060 ± .010 (1,52 ± 0,25) Rating at 115 Vac Resistive A H B E.I.A. DATE CODE LABEL* .780 (19,81) REF. 1 Rating at 220 Vac Resistive Operations at Rated Load /4 Amp 1/8 Amp 250,000 C Total Travel Action D .250 +.010/ .005 (6,35 +0,25/ 0,13) DIAMETER A = .175 – .025 (4,45 –0,64) *Label increases B = .125 – . 010 (3,18 – 0,25) nominal diameter C = .390 – .010 (9,91 – 0,25) to .255 (6,48) D = .100 (2,54) MAX. Momentary Part Number Cap Color 39-2 Black Actuating Force (oz.) +4 .042 ± .010 4 – 2 (1,07 ± 0,25) Mtg. Hole .172 (4,37) DIA. Normally Closed–SPST with Sealed Bushing and Button Pushbutton Switches 39-352* .110– .005 DIA. (2,79 – 0,13) #8-40 UNS-2A THREAD A A = .165 +.035/ .015 (4,19 +0,89/ 0,38) B = .125 – .007 (3,18 – 0,18) C = .429 –.015 (10,90 – 0,38) D = .100 (2,54) MAX. E = 10 TO 40 APPROX. H B C O-RING .819 (20,80) REF. E.I.A. DATE CODE LABEL* H = HEX MTG. NUT .0625 (1,59) TYP. THICK AND .218 (5,56) TYP. ACROSS FLATS D Rating at 115 Vac Resistive 1 .100 (2,54) MAX. CIRCUITRY SPSt n.O. SPSt n.C. SPECIFICATIONS Rating Criteria Contact Resistance: 25 milliohms maximum on a new switch Voltage Breakdown: 1,000 Vac between mutually insulated parts Insulation Resistance: 1,000 megohms minimum Operating Temperature: -40°C to +85°C Mounting Torque: 2 inch-pounds Momentary Button Color 39-352 RED 39-352 BLK Red Black Actuating Total Force (oz.) Travel .042 ± .010 8 ± 4 (0,17 ± 0,25) .060 – .010 (1,52 – 0,25) *Label increases nominal diameter to .255 (6,48) Materials and Finishes SPST–N.O. WITH OVERTRAVEL Action *Complete Part Number .100 – .010 (2,54 – 0,25) .250 +.010/ .005 (6,35 + 0,25/ 0,13) Button is o-ring sealed internally. Operations at Rated Load /4 Amp 1/8 Amp 100,000 E .312 –.005 (7,92 –0,13) ACROSS FLATS Rating at 220 Vac Resistive Mounting Nut: Brass, tin zinc Housing: Aluminum, clear anodized for 39-351 and 39-352; Brass, zinc trivalent chromate-plated for others Button: Thermoset plastic Base: Thermoset plastic Shorting Bar: Fine silver for 39-2 and 39-352; brass, gold-plated over nickel plate for 39-601; fine silver, gold-plated for others Terminals: Fine silver for 39-2 and 39-352; commercial bronze with gold-plated fine silver contact surface for others Spring: Tinned music wire O-Rings: (39-351 and 39-352) Internal ring is silicone; external ring is buna ‘N’ Accessory Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Button Cap Part No. 30B1012 For use with part numbers 39-351 and 39-352. (Fasten to button with Cyanoacrylate Adhesive) ORDERING INFORMATION Part Number Description 39-1 N.O., Red Button 39-2 N.C., Black Button 39-3 N.O., Black Button 39-12 N.O., Overtravel Red Button 39-24 N.O., Overtravel Black Button 39-351 RED N.O., Sealed, Red Button 39-351 BLK N.O., Sealed, Black Button 39-352 RED N.C., Sealed, Red Button 39-352 BLK N.C., Sealed, Black Button 39-601 RED N.O., Economy, Red Button 39-601 BLK N.O., Economy, Black Button Accessory cap may be used with all switches shown except 39-2. Accessory Part Number Description 30B1012-5 Red Button Cap 30B1012-9 Black Button Cap 30B1012-8 White Button Cap 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
30B1012-5 价格&库存
很抱歉,暂时无法提供与“30B1012-5”相匹配的价格&库存,您可以联系我们找货
30B1012-5
  • 1+24.708081+3.19665
  • 10+22.3550310+2.89222
  • 25+21.4943225+2.78087
  • 50+20.8629150+2.69918
  • 100+20.24992100+2.61987
  • 250+19.46701250+2.51858
  • 500+18.89406500+2.44445
  • 1000+18.338141000+2.37253
  • 5000+17.108755000+2.21348
库存:547
