95CAP-112
95CAP-112
    GRAYHILLINC.
    CAP TACTILE ROUND RED
95CAP-112 数据手册
Non-Washable Tactile Switches SPECIFICATIONS CIRCUITRY Materials Base: UL94V-0 Nylon thermoplastic Cover: Stainless steel, tin-plated Actuator: UL94V-0 Nylon thermoplastic Terminal: Brass with silver-plating Contact: Stainless steel with silver-plating Cap: Thermoplastic ABS Insulation Resistance: 100 M: min. at 500Vdc Dielectric Strength: No dielectric breakdown after 250V for one minute Contact Arrangement: single pole, single throw Environmental Operating Temp. Range: -25 to 70°C Storage Temp. Range: -30 to 80°C Mechanical Shock: MIL-STD-202F, Method, 213B, Test Condition A. Gravity: 50G's (peak value), 11 msec. Direction and times: 6 sides and 3 times in each direction. High reliability. Vibration: MIL-STD-202F, Method 201A. Passed 6 hours (2 hours in each) of three Electrical Rating: 50mA, 12 Vdc Life: 160g: 1,000,000 cycles/ 260g: 500,000 cycles Actuator Travel: .014” ± .004” Contact Resistance: 100 m: max. ORDERING INFORMATION Series Size: 12 = 12mm Square Height (“H”): A = .169 (4,29); B = .335 (8,51); C = Square .287 (7,29) 95C12A3GWRT RoHS compliant Packaging: Blank = Tube or Bulk, R = Tape and Reel (see pkg note) Terminal Style: Blank = Thru-hole, GW = Gull Wing Operating Force (Actuator Color): 3 = 160g (Brown), 4 = 260g (Red) Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local distributor, or Grayhill. T1 T2 T3 T4 perpendicular planes at a cycle of 10-55-10Hz/1 minute. Stop Strength: Place the switch such that vertical, a static load of 3kg shall be applied in the direction of stem operation for a period of 15 seconds. Soldering Process Hand Soldering: Use a soldering iron of 30 watts, controlled at 350°C for 5 seconds maximum while applying solder. Reflow Soldering (surface mount versions only): Peak temperature 260°C (500°F). Wave Soldering: 260C° (500°F) maximum for 5 seconds subject to PCB .063 in. (1,6mm) thickness. Packaging Thru-Hole: Bulk, 500 pcs/bag. Surface Mount: 40 pcs/tube, 700 pcs/reel (.169" height), 500 pcs/reel (.335" and .287” height). DECORATIVE CAPS (for use with “C” style square actuators) Tact Switches .452 DIA. .157 .059 .059 .224 .079 PART NUMBER SWITCH SIZE SHAPE COLOR FIGURE 95CAP-100 12mm SQUARE YELLOW 3 95CAP-101 12mm SQUARE BLUE 3 95CAP-102 12mm SQUARE RED 3 95CAP-103 12mm SQUARE NATURAL 3 95CAP-104 12mm SQUARE BLACK 3 95CAP-105 12mm SQUARE GREEN 3 95CAP-106 12mm SQUARE ORANGE 3 95CAP-110 12mm ROUND YELLOW 4 95CAP-111 12mm ROUND BLUE 4 95CAP-112 12mm ROUND RED 4 95CAP-113 12mm ROUND NATURAL 4 95CAP-114 12mm ROUND BLACK 4 95CAP-115 12mm ROUND GREEN 4 95CAP-116 12mm ROUND ORANGE 4 .472 .512 DIA. 12mm Square figure 3 TACT 8 12mm Round figure 4 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
95CAP-112 价格&库存
很抱歉,暂时无法提供与“95CAP-112”相匹配的价格&库存,您可以联系我们找货
