DLP-2232H
DLP-2232H
    DLPDESIGN
    MODULE USB ADAPTER FOR FT2232H
DLP-2232H 数据手册
DLP2232H LEAD-FREE DUAL-CHANNEL HIGH-SPEED USB ADAPTER The DLP-2232H is DLP Design’s premier USB-to-UART/FIFO interface module based on FTDI’s 5th generation USB 2.0 High Speed (480Mb/s) silicon. The DLP-2232H is manufactured in a lead-free, RoHS-compliant, compact 40-pin, 0.1-inch spaced standard 0.6 inch wide DIP footprint. FEATURES: The DLP-2232H is drop in compatible with the DLP-2232M except for the difference in the VCCIO voltage. The DLP-2232H has a maximum VCCIO of +3.6 Volts, but as inputs it’s IO pins are +5.0 Volt tolerant. The DLP-2232H is shipped from the factory in DLP-2232M compatible mode. Refer to section 2.1 for mode select jumper configuration details. The DLP-2232H has the capability of being configured in a variety of industry standard serial or parallel interfaces supporting these features: • Entire USB protocol handled on the module. No USB specific firmware programming required. • USB 2.0 High Speed (480Mbits/Second) and Full Speed (12Mbits/Second) compatible. • Multi-Protocol Synchronous Serial Engine (MPSSE) to simplify synchronous serial protocol (USB to JTAG, I2C, SPI or bit-bang) design. • RS232/RS422/RS485 UART Transfer Data Rate up to 12Mbaud. (RS232 Data Rate limited by external level shifter). • USB to parallel FIFO transfer data rate up to 8 Mbyte/Sec. • Single channel synchronous FIFO mode for transfers up to 25 Mbyte/Sec. • Enhanced bit bang mode interface option with read and write strobes • USB to Fast Serial Interface mode provides a method of communicating with an external device over USB using 4 wires that can have opto-isolators in their path for galvanic isolation • MCU host bus emulation mode uses both ports to emulate a standard 8048/8051 host bus • CPU-style FIFO interface mode simplifies CPU interface design. • FTDI’s royalty-free Virtual Com Port (VCP) and Direct (D2XX) drivers eliminate the requirement for USB driver development in most cases. Rev. 1.1 (May 2011) 1 © DLP Design, Inc. • Adjustable receive buffer timeout. • Transmit and receive LED drive signals. • FT245B-style FIFO interface option with bidirectional data bus and simple 4 wire handshake interface. • Asynchronous serial UART interface option with full hardware handshaking and modem interface signals. • Fully assisted hardware or X-On / X-Off software handshaking. • UART Interface supports 7/8 bit data, 1/2 stop bits, and Odd/Even/Mark/Space/No Parity. • Auto-transmit enable control for RS485 serial applications using TXDEN pin. • Operational configuration mode and USB Description strings configurable in on-board EEPROM over the USB interface. • Configurable I/O drive strength (4, 8, 12 or 16mA) and slew rate. • Low operating and USB suspend current. • Supports bus powered, self powered and high-power bus powered USB configurations. • UHCI/OHCI/EHCI host controller compatible. • USB Bulk data transfer mode (512 byte packets in High Speed mode). • +3.3V I/O interfacing (+5V Tolerant). • Extended -40°C to 85°C industrial operating temperature range. APPLICATION AREAS: • Upgrading legacy peripherals to USB • Interfacing MCU/PLD/FPGA-based designs to USB • USB to UART (RS232, RS422 or RS485) • USB to FIFO • USB to Fast Serial Interface • USB to JTAG • USB to SPI • USB to I2C • USB to Bit-Bang • USB to CPU target interface (as memory) • USB to MCU (8048/8051 style) host bus emulation • PDA to USB data transfer • USB Smart Card Readers • USB Instrumentation • USB Industrial Control • USB MP3 Player Interface • USB FLASH Card Reader / Writers • Set Top Box PC - USB interface • USB Digital Camera Interface • USB Bar Code Readers • USB audio and low-bandwidth video data transfer • USB hardware modems • USB wireless modems DRIVER SUPPORT: Royalty-Free Virtual COM Port (VCP) Drivers for: • Windows 2000, Server 2003, Server 2008 • Windows XP and XP 64-bit Rev. 1.1 (May 2011) 2 © DLP Design, Inc. • Windows Vista and Vista 64-bit • Windows 7 • Windows CE 4.2, 5.0, and 5.2 based OS • Mac OS-X • Linux 2.6.31 or later Royalty-Free D2XX Direct Drivers (USB Drivers + DLL S/W Interface) for: • Windows 2000, Server 2003, Server 2008 • Windows XP and XP 64-bit • Windows Vista and Vista 64-bit • Windows 7 • Windows CE 4.2, 5.0, and 5.2 based OS • Linux 2.6.31 or later The drivers listed above are all available for free download from the DLP Design website www.dlpdesign.com and FTDI website www.ftdichip.com. Various third-party drivers are also available for other operating systems; see the FTDI website www.ftdichip.com for details. ABSOLUTE MAXIMUM RATINGS • Storage Temperature • Ambient Temperature (Power Applied) • VCC Supply Voltage • DC Input Voltage: Inputs • DC Input Voltage: High-Impedance Bidirectionals • DC Output Current: Outputs -65°C to +150°C -40 to +85°C -0.5V to +6.00V -0.5V to VCC + 0.5V -0.5V to VCC + 0.5V 16mA D.C. CHARACTERISTICS (AMBIENT TEMPERATURE: -40 TO 85°C) • VCC Operating-Supply Voltage • VCCIO Digital IO Voltage • Operating Supply Current • Operating Supply Current 4.0 - 5.5V 3.3V 75mA (Normal Operation) 500uA USB Suspend 1.0 GENERAL DESCRIPTION The DLP-2232H USB 2.0 High Speed (480Mb/s) to UART/FIFO uses FTDI’s 5th generation USB silicon. It has the capability of being configured in a variety of industry standard serial or parallel interfaces. The DLP-2232H can be configured for UART, FIFO, Fast serial interface, JTAG, SPI, I2C or bit-bang mode. In addition to these, the DLP-2232H supports a CPU interface FIFO mode and MCU host bus emulation mode. Refer to the FT2232H datasheet for additional detail on how to set up and use these modes. Rev. 1.1 (May 2011) 3 © DLP Design, Inc. 2.0 PIN DESCRIPTIONS This section describes the operation of the DLP-2232H pins. The function of the I/O pins is determined by the configuration that is stored in the EEPROM connected to the FT2232H IC. The following table details the function of each pin for the specified mode. Note that the convention used throughout this document for active low signals is the signal name followed by a #. Pins marked ** default to tri-stated inputs with an internal 75K Ohm (approx) pull up resistor to VCCIO (3.3V). Pins marked *** may require mode select jumper configuration. This is explained in section 2.1. Table 1: DLP-2232H Pin Definitions DLP-2232H Pin Functions For Each Supported Mode Pin Pin Pin # Name 40 ADBUS0 39 ASYNC Fast CPU Host 245 FIFO 245 ASYNC SYNC SYNC FIFO Bit-bang Bit-bang TXD D0 D0 D0 D0 TCK/SK Uses D0 AD0 ADBUS1 RXD D1 D1 D1 D1 TDI/DO Chan D1 AD1 38 ADBUS2 RTS# D2 D2 D2 D2 TDO/DI B D2 AD2 37 ADBUS3 CTS# D3 D3 D3 D3 TMS/CS D3 AD3 36 ADBUS4 DTR# D4 D4 D4 D4 GPIOL0 D4 AD4 35 ADBUS5 DSR# D5 D5 D5 D5 GPIOL1 D5 AD5 34 ADBUS6 DCD# D6 D6 D6 D6 GPIOL2 D6 AD6 33 ADBUS7 RI# D7 D7 D7 D7 GPIOL3 D7 AD7 32 ACBUS0 TXDEN RXF# RXF# ** ** GPIOH0 CS# A8 31 ACBUS1 ** TXE# TXE# WRSTB# WRSTB# GPIOH1 A0 A9 30 ACBUS2 ** RD# RD# RDSTB# RDSTB# GPIOH2 RD# A10 29 ACBUS3 TXLED# WR# WR# ** ** GPIOH3 WR# A11 28 ACBUS4 RXLED# SIWUA SIWUA SIWUA SIWUA GPIOH4 SIWUA A12 27 ACBUS5 ** CLKOUT ** ** ** GPIOH5 ** A13 26 ACBUS6 ** OE# ** ** ** GPIOH6 ** A14 25 ACBUS7 ** ** ** ** ** GPIOH7 ** A15 Serial (RS232) MPSSE Serial I/F Target Emulation Channel A Channel B 13 BDBUS0 TXD Uses D0 D0 D0 TCK/SK FSDI D0 CS# 12 BDBUS1 RXD Chan A D1 D1 D1 TDI/DI FSCLK D1 ALE 11 BDBUS2 RTS# D2 D2 D2 TDO/DO FSDO D2 RD# 10 BDBUS3 CTS# D3 D3 D3 TMS/CS FSCTS D3 WR Rev. 1.1 (May 2011) 4 © DLP Design, Inc. 9 BDBUS4 DTR# D4 D4 D4 GPIOL0 D4 IORDY CLK BDBUS5 8 DSR# D5 D5 D5 GPIOL1 D5 OUT 7 BDBUS6 DCD# D6 D6 D6 GPIOL2 D6 I/O0 6 BDBUS7 RI# D7 D7 D7 GPIOL3 D7 1/01 5 BCBUS0 TXDEN RXF# ** ** GPIOH0 ** 4 BCBUS1 ** TXE# GPIOH1 ** 3 BCBUS2 ** RD# GPIOH2 ** 2 BCBUS3 RXLED# WR GPIOH3 ** 1 BCBUS4 TXLED# SIWUB GPIOH4 ** BCBUS5 ** ** ** ** GPIOH5 ** ** BCBUS6 ** ** ** ** GPIOH6 ** ** 24 17 1 18 2 ** PWR BCBUS7 GPIOH7 SAV# Support Pins Function Pin 14 GND GROUND 15 GND GROUND VCCSW - Use for powering external devices at +3.3V. This voltage is derived from the USB input +5.0V. It is switched off by the FT2232H PWREN# pin when the device is not enumerated. 500mA is the maximum current available to the USB adapter and target electronics if the USB device is configured for high power. EXTVCC - Use for applying main power (+4.5 to +5.25 V) to the module. Connect to PORTVCC if the module is to be powered by the USB port (typical configuration). PORTVCC - Power from the USB port (typically +5.0 V). Connect to EXTVCC if the module is to be powered by the USB port (typical configuration). 500mA is the maximum current available to the USB adapter and target electronics if the USB device is configured for high power. VCCUSB – Filtered power from the USB port (typically +5.0 V). 500mA is the maximum current available to the USB adapter and target electronics if the USB device is configured for high power. VCCSW 16 19 EXTVCC PORTVCC 20 21 VCCUSB 22 GND GROUND 23 GND GROUND Notes: 1. Pin 17 is configured via jumper JP2. Refer to section 2.1 for more details. 2. Pin 18 is configured via jumper JP3. Refer to section 2.1 for more details. Rev. 1.1 (May 2011) 5 © DLP Design, Inc. 2.1 JUMPER CONFIGURATION The DLP-2232H module was design so that it can be used as a drop in replacement for the DLP-2232M module. The DLP-2232H provides a high speed USB interface compared to the DLP-2232M module’s full speed USB interface. The mode select jumpers (JP1 – JP3) are identified above and on the silkscreen. They are located in the center and top of the DLP-2232H module. These three jumpers control the usage of the DLP-2232H module’s pins 17 and 18 as follows: JP1 (supports option for VCCIO +3.3V to be supplied internally): 1. Shunt installed on pins 1 and 2: VCCIO provided internally. Insure that either JP2 shunt is in position 1, or no external voltage is applied to pin 17. 2. Shunt not installed on pins 1 and 2: VCCIO applied externally (compatible with DLP-2232M). VCCIO must not exceed +3.6V or module can be damaged.   JP2 (controls pin 17): 1. Shunt installed on pins 1 and 2: BCBUS6 signal available on pin 17. 2. Shunt installed on pins 2 and 3: VCCIO input available on pin 17 (compatible with DLP-2232M). VCCIO must not exceed +3.6V or module can be damaged. JP3 (controls pin 18): 1. Shunt installed on pins 1 and 2: BCBUS7 signal available on pin 18. 2. No shunt installed: Pin 18 unconnected (compatible with DLP-2232M). Rev. 1.1 (May 2011) 6 © DLP Design, Inc. 2.2 TIMING DIAGRAMS - 245 FIFO MODE The following diagram details the FT2232H operation in 245 FIFO asynchronous mode. For detailed timing on the remaining modes refer to the FT2232H datasheet from FTDI. T6 T5 RXF# T1 T2 RD# T3 T4 D D[7..0] Description Min Max Unit TIME T1 T2 T3 T4 T5 T6 Valid data DESCRIPTION RD# Active Pulse Width RD# to RD# Pre-Charge RD# Active to Valid Data* Valid Data Hold Time from RD# Inactive* RD# Inactive to RXF# output active RXF# Inactive After RD Cycle *Load = 30pF MIN 50 T5 + T6 20 0 0 33 MAX 50 25 67 UNIT nS nS nS nS nS nS MAX 25 84 UNIT nS nS nS nS nS nS T12 T11 TXE# T7 T8 WR T 10 T9 D[7 ..0] TIME T7 T8 T9 T10 T11 T12 Valid data DESCRIPTION WR Active Pulse Width WR to WR Pre-Charge Time Valid Data Setup to WR Falling Edge* Valid Data Hold Time from WR Inactive* WR Inactive to TXE# TXE# Inactive After WR Cycle MIN 10 50 20 10 10 49 *Load = 30pF Rev. 1.1 (May 2011) 7 © DLP Design, Inc. 3.0 APPLICATION NOTES USB devices transfer data in packets. If data is to be sent from the PC, a packet is built up by the application program and is sent via the device driver to the USB scheduler. This scheduler adds a request to the list of tasks that the USB host controller will perform. This will typically take at least 1 millisecond to execute because it will not pick up the new request until the next USB frame (the frame period is 1 millisecond). There is, therefore, sizeable overhead (depending upon your required throughput) associated with moving data from the application to the USB device. If data is sent one byte at a time by an application, this will severely limit the overall throughput of the system. It must be stressed that in order to achieve maximum throughput, application programs should send or receive data using buffers and not individual characters. 4.0 DRIVER SOFTWARE FTDI's VCP (Virtual COM Port) USB driver files are provided royalty free on the condition that they are only used with designs incorporating an FTDI device (i.e. the FT2232H and DLP2232H). The latest version of the drivers can be downloaded from either www.dlpdesign.com or www.ftdichip.com. The CDM driver download file is a combined set of drivers for the Windows operating system and contains both the VCP and D2XX driver versions. To download, simply unzip the file to a folder on your PC. (The drivers can coexist on the same floppy disk or folder since the INF files determine which set of drivers to load for each operating-system version.) Once loaded, the VCP drivers will allow your application software—running on the host PC—to communicate with the DLP-2232H as though it were connected to a COM (RS-232) port. In addition to VCP drivers, FTDI's D2XX direct drivers for Windows offer an alternative solution to the VCP drivers that allow application software to interface with the FT2232H device using a DLL instead of a Virtual COM Port. The architecture of the D2XX drivers consists of a Windows WDM driver that communicates with the FT2232H device via the Windows USB stack and a DLL that interfaces with the application software (written in VC++, C++ Builder, Delphi, VB, etc.) to the WDM driver. The D2XX direct drivers add support for simultaneous access and control of multiple DLP2232H devices. The extended open function (FT_OpenEx) allows the device to be opened either by its product description or serial number, both of which can be programmed to be unique. The list devices function (FT_ListDevices) allows the application software to determine which devices are currently available for use, again by either product description or serial number. Download FTDI Application Notes AN_103, AN_104, and AN_119 for detailed instructions on how to install the drivers on Windows XP, Vista, and 7 platforms. Rev. 1.1 (May 2011) 8 © DLP Design, Inc. 5.0 EEPROM WRITE UTILITY The DLP-2232H has the option to accept manufacturer-specific information that is written into EEPROM memory. Parameters that can be programmed include the VID and the PID identifiers, the manufacturer's product string and a serial number. MPROG is the EEPROM programming utility for the FT2232H device. You must install the latest release of the CDM drivers in order to run this application. If you have CDM drivers installed on the PC that is to perform the EEPROM write process, you can run MPROG and update the EEPROM contents with either mode (VCP or D2XX) active. 6.0 QUICK START GUIDE This guide requires the use of a Windows XP/Vista/7 PC that is equipped with a USB port. 1. Configure mode select jumpers using the shunts provided. Refer to section 2.1 on page 5. 2. Download the latest CDM device drivers from either www.dlpdesign.com or www.ftdichip.com. Unzip the drivers into a folder on the hard drive. 3. Connect the DLP-2232H module to the PC via a USB ‘A’ to mini-B cable. This action initiates the loading of the USB drivers. When prompted, select the folder where the device drivers were stored in Step 1. Windows will then complete the installation of the device drivers for the DLP-2232H module. The next time the DLP-2232H module is attached, the host PC will immediately load the correct drivers without any prompting. Reboot the PC if prompted to do so. At this point, the DLP-2232H is ready for use. Note that if the DLP-2232H is configured for 245 FIFO mode that it will appear non-responsive if data sent from the host PC is not read by an attached microcontroller, microprocessor, DSP, FPGA, ASIC, etc. 7.0 PIN LOCATIONS Pin 1 Pin 40 USB Pin 21 Pin 20 Top View (Interface Headers on bottom of PCB) Rev. 1.1 (May 2011) 9 © DLP Design, Inc. 8.0 PIN USAGE EXAMPLES The following tables highlight two possible configurations for the DLP-2232H module. There are numerous additional combinations available. For the complete DLP-2232H pin list refer to the pin descriptions in section 2.0. CASE 1: Port A: 245 FIFO Synchronous, Port B 245 FIFO Asynchronous PIN # 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 19 20 PORT A PARALLEL SYNC, PORT B PARALLEL ASYNC SIGNAL USAGE DESCRIPTION SIWUB –The Port B Send Immediate / WakeUp signal combines two functions on a single pin. If USB is in suspend mode (PWREN# = 1) and remote wakeup is enabled in the EEPROM, strobing this pin low will cause the device to request a resume on the USB Bus. Normally, this can be used to wake up the Host PC. During normal operation (PWREN# = 0), if this pin is strobed low any data in the device TX buffer will be sent out over USB on the next Bulk-IN request from the drivers regardless of the pending packet size. This can be used to optimize USB transfer speed for some applications. Tie this pin to VCCIO if not used. PORT B WR# - When taken from a high to a low state, WR reads the 8 data lines and writes the byte into the FIFO’s transmit buffer. Data written to the transmit buffer is sent to the host PC within the TX buffer timeout value (default 16mS) and placed in the buffer that was created when the USB port was opened. PORT B RD# - When pulled low, RD# takes the 8 data lines from a high-impedance state to the current byte in the FIFO’s buffer. Taking RD# high returns the data pins to a high- impedance state and prepares the next byte (if available) in the FIFO to be read. PORT B TXE# - Transmit Buffer Empty: When high, do not write data into the FIFO. When low, data can be written into the FIFO by toggling WR. During reset this signal pin is tri-state. Data is latched into the FIFO on the falling edge of the WR pin. PORT B RXF# - Receive Buffer Full : When low, at least 1 byte is present in the FIFO’s receive buffer and is ready to be read with RD#. RXF# goes high when the receive buffer is empty. During reset this signal pin is tri-state. If the Remote Wakeup option is enabled in the internal EEPROM, during USB Suspend Mode (PWREN#=1) RXF# becomes an input. This can be used to wake up the USB host from Suspend Mode by strobing this pin low for a minimum of 20ms which will cause the device to request a resume on the USB bus. PORT B DB7 – Port B FIFO Data Bus Bit 7 PORT B DB6 – Port B FIFO Data Bus Bit 6 PORT B DB5 – Port B FIFO Data Bus Bit 5 PORT B DB4 – Port B FIFO Data Bus Bit 4 PORT B DB3 – Port B FIFO Data Bus Bit 3 PORT B DB2 – Port B FIFO Data Bus Bit 2 PORT B DB1 – Port B FIFO Data Bus Bit 1 PORT B DB0 – Port B FIFO Data Bus Bit 0 GROUND GROUND EXTVCC - Use for applying main power (4.5 to 5.25 volts) to the module. Connect to PORTVCC if the module is to be powered by the USB port (typical configuration). PORTVCC - Power from the USB port. Connect to EXTVCC if the module is to be powered by the USB port (typical configuration). 500mA is the maximum current available to the USB adapter and target electronics if the USB device is configured for high power. Rev. 1.1 (May 2011) 10 © DLP Design, Inc. 22 23 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 GROUND GROUND PORT A OE# - Output enable: when low drive data onto D0-7. This should be driven low at least 1 clock period before driving RD# low to allow for data buffer turn around. PORT A CLKOUT – 60 MHz Clock driven from the FTDI chip. All signals should be synchronized to this clock. SIWUA –The Port A Send Immediate / WakeUp signal combines two functions on a single pin. If USB is in suspend mode (PWREN# = 1) and remote wakeup is enabled in the EEPROM, strobing this pin low will cause the device to request a resume on the USB Bus. Normally, this can be used to wake up the Host PC. During normal operation (PWREN# = 0), if this pin is strobed low any data in the device TX buffer will be sent out over USB on the next Bulk-IN request from the drivers regardless of the pending packet size. This can be used to optimize USB transfer speed for some applications. Tie this pin to VCCIO if not used. PORT A WR# - When taken from a high to a low state, WR reads the 8 data lines and writes the byte into the FIFO’s transmit buffer. Data written to the transmit buffer is sent to the host PC within the TX buffer timeout value (default 16mS) and placed in the buffer that was created when the USB port was opened. PORT A RD# - When pulled low, RD# takes the 8 data lines from a high-impedance state to the current byte in the FIFO’s buffer. Taking RD# high returns the data pins to a high- impedance state and prepares the next byte (if available) in the FIFO to be read. PORT A TXE# - Transmit Buffer Empty: When high, do not write data into the FIFO. When low, data can be written into the FIFO by strobing WR high, then low. During reset this signal pin is tri-state. Data is latched into the FIFO on the falling edge of the WR pin. PORT A RXF# - Receive Buffer Full : When low, at least 1 byte is present in the FIFO’s receive buffer and is ready to be read with RD#. RXF# goes high when the receive buffer is empty. During reset this signal pin is tri-state. If the Remote Wakeup option is enabled in the internal EEPROM, during USB Suspend Mode (PWREN#=1) RXF# becomes an input. This can be used to wake up the USB host from Suspend Mode by strobing this pin low for a minimum of 20ms which will cause the device to request a resume on the USB bus. PORT A DB7 – Port A FIFO Data Bus Bit 7 PORT A DB6 – Port A FIFO Data Bus Bit 6 PORT A DB5 – Port A FIFO Data Bus Bit 5 PORT A DB4 – Port A FIFO Data Bus Bit 4 PORT A DB3 – Port A FIFO Data Bus Bit 3 PORT A DB2 – Port A FIFO Data Bus Bit 2 PORT A DB1 – Port A FIFO Data Bus Bit 1 PORT A DB0 – Port A FIFO Data Bus Bit 0 Rev. 1.1 (May 2011) 11 © DLP Design, Inc. CASE 2: Port A: 232 Serial Asynchronous, Port B Fast Serial Interface 22 23 28 PORT A 232 SERIAL SIGNAL USAGE DESCRIPTION SIWUB –The Port B Send Immediate / WakeUp signal combines two functions on a single pin. If USB is in suspend mode (PWREN# = 1) and remote wakeup is enabled in the EEPROM, strobing this pin low will cause the device to request a resume on the USB Bus. Normally, this can be used to wake up the Host PC. During normal operation (PWREN# = 0), if this pin is strobed low any data in the device TX buffer will be sent out over USB on the next Bulk-IN request from the drivers regardless of the pending packet size. This can be used to optimize USB transfer speed for some applications. Tie this pin to VCCIO if not used. FSCTS – Fast serial Clear To Send output. Driven low to indicate that the FTDI chip is ready to send data. FSDO – Fast serial data output FSCLK – Fast serial clock input. Clock input to FTDI chip to clock data in or out. FSDI – Fast serial data input GROUND GROUND EXTVCC - Use for applying main power (4.5 to 5.25 volts) to the module. Connect to PORTVCC if the module is to be powered by the USB port (typical configuration). PORTVCC - Power from the USB port. Connect to EXTVCC if the module is to be powered by the USB port (typical configuration). 500mA is the maximum current available to the USB adapter and target electronics if the USB device is configured for high power. GROUND GROUND RXLED - Receive signaling output. Pulses low when receiving data via USB. This should be 29 TXLED# - Transmit signaling output. Pulses low when transmitting data via USB. This should be 32 33 TXDEN - (TTL level). For use with RS485 level converters. RI# - Ring Indicator Control Input. When remote wake-up is enabled in the internal EEPROM taking RI# low (20ms active low pulse), this can be used to resume the PC USB host controller from Suspend. DCD# - Data Carrier Detect Control Input DSR# - Data Set Ready Control Input/Handshake Signal DTR# - Data Terminal Ready Control Output/Handshake Signal CTS# - Clear To Send Control Input/Handshake Signal RTS# - Request to Send Control Output/Handshake Signal RXD - Receiving Asynchronous Data Input TXD - Transmit Asynchronous Data Output PIN # 1 10 11 12 13 14 15 19 20 connected to an LED through a current limiting resistor. connected to an LED through a current limiting resistor. 34 35 36 37 38 39 40 Rev. 1.1 (May 2011) 12 © DLP Design, Inc. 9.0 DEVICE CONFIGURATION EXAMPLES USB Bus-Powered and Self-Powered Configurations Figure 1. VCCIO(3.6V max) driven internally or externally depending on JP1 & JP3 (refer to section 2.1) VCCIO 17 18 19 20 Bus-Powered 5V System The figure above illustrates a typical USB bus-powered configuration. A USB bus-powered device gets its power from the USB bus. Figure 2. VCCIO(3.6V max) driven internally or externally depending on JP1 & JP3 (refer to section 2.1) VCCIO 17 5.0V 18 19 20 Self-Powered 5V System Figure 2 illustrates a typical USB self-powered configuration. A USB self-powered device gets its power from its own power supply and does not draw current from the USB bus. 3.3 - 5V Microcontroller 8 Data Lines Figure 3. VCCIO(3.6V max) driven internally or externally depending on JP1 & JP3 (refer to section 2.1) VCCIO 17 18 19 20 RXF# RD# TXE# WR Bus-Powered 5V System with 3.3V Logic Interface Figure 3 shows how to configure the DLP-2232H to interface with a microcontroller via the parallel 245 FIFO interface mode. In this example, the target electronics can operate at from 3.3 - 5 volts since the DLP-2232H interface I/O pins are 5 volt tolerant. Rev. 1.1 (May 2011) 13 © DLP Design, Inc. 3.3V TXD Figure 4. VCCIO(3.6V max) driven internally or externally depending on JP1 & JP3 (refer to section 2.1) RXD VCCIO 17 18 19 20 Bus-Powered 5V System with 3.3 Volt Logic Interface Figure 4 shows how to configure the DLP-2232H to interface with a 3.3V logic device via the ASYNC serial mode. In this example, the target electronics provide the 3.3 volts to power the microcontroller. 10.0 BUS-POWERED CIRCUIT WITH POWER CONTROL USB bus-powered circuits need to be able to power down in USB Suspend Mode in order to meet the Suspend current requirement (including external logic). The DLP-2232H module provides a switched power output to accomplish this with no external components required: VCCSW (+5.0V) Microcontroller VCC VCCIO(3.6V max) driven internally or externally depending on JP1 & JP3 (refer to section 2.1) 16 VCCIO17 18 19 20 Figure 4. VCCSW controlled internally by PWREN# Figure 4 shows how to connect the switched +5.0V power to external logic circuits. The internal “soft-start” circuit on the DLP-2232H accommodates designs that draw more than 100mA at power up. Rev. 1.1 (May 2011) 14 © DLP Design, Inc. 11.0 MECHANICAL DRAWINGS (PRELIMINARY) INCHES (MILLIMETERS) UNLESS OTHERWISE NOTED 0.50 typ (12.6 typ) 0.18 typ (4.55 typ) Side View 0.38 typ (9.8 typ) 0.50 typ (12.7 typ) 0.62 typ (15.8 typ) 0.10 typ (2.5 typ) 0.08 typ (2.2 typ) 0.925 typ (23.5 typ) 0.018 typ (0.48 typ) (square post) 2.28 typ (57.8 typ) 0.60 typ (15.2 typ) 11.0 DISCLAIMER © DLP Design, Inc., 2010 Neither the whole nor any part of the information contained herein nor the product described in this manual may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. This product and its documentation are supplied on an as-is basis, and no warranty as to their suitability for any particular purpose is either made or implied. DLP Design, Inc. will not accept any claim for damages whatsoever arising as a result of the use or failure of this product. Your statutory rights are not affected. This product or any variant of it is not intended for use in any Rev. 1.1 (May 2011) 15 © DLP Design, Inc. medical appliance, device or system in which the failure of the product might reasonably be expected to result in personal injury. This document provides preliminary information that may be subject to change without notice. 12.0 CONTACT INFORMATION DLP Design, Inc. 1605 Roma Lane Allen, TX 75013 Phone: 469-964-8027 Fax: 415-901-4859 Email Sales: sales@dlpdesign.com Email Support: support@dlpdesign.com Website URL: http://www.dlpdesign.com Rev. 1.1 (May 2011) 16 © DLP Design, Inc. D 5 1 2 GND VIN SOT223 VOUT U2 TC1262-33VDB 1 2 3 4 U3 VCC CS NC SK NC/ORG DIN GND DOUT 3 C12 4 C11 4.7uF .1uF C13 C24 .1uF R5 10K R4 12K R3 1K C8 .1uF P3V3 4.7uF Ceramic P3V3 C22 .1uF C3 VCCUSB 2 .1uF FB1 240-1018-1 1 C7 4.7uF P3V3 R6 10K Y1 12MHz C5 27pF C4 27pF Ceramic EECS EESK EEDATA C2 .01 1 2 3 4 R2 2K2 JP3 BC7_OPT VPLL VPHY TEST 3 VCCIO P3V3 JP1 ADBUS0/TXD/D0/TCK SK ADBUS1/RXD/D1/TDI DO ADBUS2/RTS#/D2/TDO DI ADBUS3/CTS#/D3/TMS CS ADBUS4/DTR#/D4/GPIOL0 ADBUS5/DSR#/D5/GPIOL1 ADBUS6/DCD#/D6/GPIOL2 ADBUS7/RI#/D7/GPIOL3 ACBUS0/TXDEN/RXF#/GPIOH0 ACBUS1/WRSTB#/TXE#/GPIOH1 ACBUS2/RDSTB#/RD#/GPIOH2 ACBUS3/TXLED#/WR#/GPIOH3 ACBUS4/RXLED#/SIWUA/GPIOH4 ACBUS5/-/CLKOUT/GPIOH5 ACBUS6/-/OE#/GPIOH6 ACBUS7/-/-/GPIOH7 BDBUS0/TXD/DO/TCK SK BDBUS1/RXD/D1/TDI DO BDBUS2/RTS#/D2/TDO DI BDBUS3/CTS#/D3/TMS CS BDBUS4/DTR#/D4/GPIOL0 BDBUS5/DSR#/D5/GPIOL1 BDBUS6/DCD#/D6/GPIOL3 BDBUS7/RI#/D7/GPIOL4 PWREN# SUSPEND# BCBUS0/TXDEN/RXF#/GPIOH0 OSCI BCBUS1/WRSTB#/TXE#/GPIOH1 BCBUS2/RDSTB#/RD#/GPIOH2 BCBUS3/TXLED#/WR#/GPIOH3 BCBUS4/RXLED#/SIWUB/GPIOH4 OSCO BCBUS5/-/-/GPIOH5 BCBUS6/-/-/GPIOH6 BCBUS7/PWRSAV#/PWRSAV#/GPIOH7 EECS EECLK EEDATA DM DP RESET# REF VREGOUT VREGIN U1 FT2232HL 50 49 14 6 7 8 63 62 61 2 3 13 20 31 42 56 VCCUSB C6 1.0uF/0603 EXTVCC PORTVCC R7 0 8 7 6 5 SOIC 10K JP2 VCCIO VCCIO VCCIO VCCIO GND GND GND GND GND GND GND GND 3 FT2232H pin definitions: PIN NAME/232/245/MPSSE VCCIO_BC6 12 37 64 1 5 11 15 25 35 47 51 93LC46 R1 BC7 BC6 VCCIO VCORE VCORE VCORE AGND CN1 CN-USB P3V3 C25 .1uF v1.1 4 4 9 VPHY VPLL 10 C B A DLP-2232H 5 1 5 C15 .1uF C16 .1uF C17 2 C14 .1uF 2.2K P3V3 1 FB2 240-1018-1 2 1 C18 C20 2 4.7uF Ceramic FB3 240-1018-1 1 AD0 4.7uF AD1 Ceramic AD2 GND AD3 AD4 AD5 J1 AD6 CONN PCB 20x2 AD7 1 1 SI/WUB 40 40 2 2 AC0 BC3 39 39 3 3 AC1 BC2 38 38 4 4 AC2 BC1 37 37 5 5 AC3 BC0 36 36 6 6 SI/WUA BD7 35 35 7 7 AC5 BD6 34 34 8 8 AC6 BD5 33 33 9 9 AC7 BD4 32 32 10 10 BD3 31 31 11 11 BD0 BD2 30 30 12 12 BD1 BD1 29 29 13 13 BD2 BD0 28 28 14 14 BD3 GND 27 27 15 15 BD4 GND 26 26 16 16 BD5 VCCSW 25 25 17 17 BD6 VCCIO_BC6 24 24 18 18 BD7 BC7_OPT 23 23 19 19 EXTVCC 22 22 20 20 BC0 PORTVCC 21 21 BC1 BC2 BC3 VCCUSB USB SI/WUB Q1 BC5 IRLML6402 BC6 C1 C9 BC7 R8 .1uF .1uF .1uF 16 17 18 19 21 22 23 24 26 27 28 29 30 32 33 34 38 39 40 41 43 44 45 46 48 52 53 54 55 57 58 59 60 36 NOTES: C19 .1uF C21 .1uF VPHY VPLL AD0 AD1 AD2 AD3 AD4 AD5 AD6 AD7 AC0 AC1 AC2 AC3 SI/WUA AC5 AC6 AC7 BC5 GND GND VCCUSB VCCSW Ceramic C10 4.7uF 1. VCCIO must not exceed +3.6 Volts. As inputs these port pins are +5 Volt tolerant. 2. VCCIO can be provided on module using JP1. 3. BC6 port can be routed to J1 pin 17 using JP2. 1 4. BC7 port can be routed to J1 pin 18 using JP3. 2 D C B A
DLP-2232H 价格&库存
很抱歉,暂时无法提供与“DLP-2232H”相匹配的价格&库存,您可以联系我们找货
