CCL LLC
88 Black Falcon Ave., Ste. 247,
Boston, MA 02210
USA
Contact: Antea Risso
Digi-Key Corporation
e-mail: antea@arduino.org
701 Brooks Ave.South
PRODUCT CHANGE NOTIFICATION
Thief River Falls, MN 5670
January 25th 2017
USA
Page 1 of 2
______________________________________________________________________________
Kindly note that some items will be soon disabled from our range of products.
Please check below for your reference.
Kindly update your system with the codes that will be discontinued.
CODE
NAME
DATE DISMISSION
B000003
Open Softwear 2nd Edition
March 25th 2017
A000015
USB/serial converter WITHOUT headers
March 25th 2017
X000005
GSM Antenna ANTA7000A0200BD1
March 25th 2017
A000014
March 25th 2017
B000004
Pro Android Open Accessory Programming w/ Arduino
March 25th 2017
K000010
Expansion Pack
March 25th 2017
X000004
GSM Antenna ANTH7100A0200AI1
March 25th 2017
X000010
PoE module 5V
March 25th 2017
A000084
14.5mm Strip 6 ways 2 pcs
March 25th 2017
A000086
14.5mm Strip 10 ways 2 pcs
March 25th 2017
X000002
PoE module 12V
March 25th 2017
A000085
14.5mm Strip 8 ways 2 pcs
March 25th 2017
A000032
Breadboard 830 with Wire Kit
March 25th 2017
T010051
Digital Continuous Rotation (360°) Servo
March 25th 2017
A000028
KIT Workshop - Base level WITHOUT Arduino Board
March 25th 2017
CCL LLC
Legal Address: 88 Black Falcon Ave, Ste. 247, Boston, MA 02210, USA
www.arduino.org
CODE
NAME
DATE DISMISSION
T010050
Analog 180° Micro Servo
March 25th 2017
A000089
Arduino WiFi shield (antenna connector)
March 25th 2017
A000007
Shield - Xbee
March 25th 2017
A000021
Shield - Xbee WITHOUT RF module
March 25th 2017
CODE
NAME
DATE DISMISSION
T070000
TinkerKit IR Remote Control
February 1st 2017
C000014
10 10nF poly
February 1st 2017
C000015
10 100nF poly
February 1st 2017
C000017
10 1n4148
February 1st 2017
C000018
10 1n4007
February 1st 2017
C000041
Arduino Shaped Copper PCB (Double Side)
February 1st 2017
C000048
10 Tinkerkit Male 3pin Connectors
February 1st 2017
C000062
male jack plug 3.5mm - 4 connections
February 1st 2017
C000001
10 Led Rossi 5mm
February 1st 2017
C000002
10 Green Led 5mm
February 1st 2017
C000003
10 Yellow Led 5mm
February 1st 2017
C000027
5 PushButton 6x6
February 1st 2017
C000060
1V5 AA battery pack (4 units)
February 1st 2017
C000052
25 cm Alligator test cable Black
February 1st 2017
C000053
25 cm Alligator test cable Red
February 1st 2017
C000029
3x2 Header Male Strip
February 1st 2017
C000059
paper speaker 8 ohm, min 6cm diameter 5x
February 1st 2017
C000032
10 jumper wires 70mm male - male
February 1st 2017
C000019
10 BC547
February 1st 2017
C000008
10 10k 1/4w resistor
C000011
10 100 ohm 1/4w resistor
February 1st 2017
February 1st 2017
CCL LLC
www.arduino.org
CODE
NAME
C000077
10 680 ohm resistors
C000078
10 470 ohm resistors
C000079
10 1.2 K ohm resistors
C000006
5 RGB LED 5mm
C000023
1 74HC595
E000040
Water pump - USB connector
C000051
1M ohm Resistor 10x
C000024
5 linear potentiometer
C000016
10 100uF elettrolytic
T000061
Tinkerkit 2 Axis Gyroscope Sen.ty 1x BB Version
C000025
5 LDR
T000063
Tinkerkit 2 Axis Gyroscope - sensitivity 4x BB Version
C000004
10 White Led 5mm
C000009
10 220ohm 1/4w resistor
C000031
Rotary Potentiometer
C000061
battery holder for 8 1v5 AA batteries with 9V battery plug
C000043
IR Led 940nm - TSAL5100
E000041
Wire's spools 10 colours 10m
X000011
Micro SD card 4GB with SD adapter
C000012
IR Receiver Tsop2238 - 38 KHZ
C000030
2 4N35 Optocoupler
C000021
1 IRF520
C000020
10 BC557
C000005
10 Blues Led 5mm
C000057
12mm push buttons 10x
DATE DISMISSION
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
CCL LLC
www.arduino.org
CODE
NAME
C000055
piezo 5x
T010117
TinkerKit Yellow Led [10mm] module
C000028
18x2 Header Male Strip
T010111
TinkerKit Blue Led [5mm] module
C000056
LED vari colori 10mm 20x
C000022
1 L293D
T020170
Tinkerkit 4 pin Wires 55cm
C000010
10 1k 1/4w resistor
C000007
Resistor Kit
A000026
Strip 40x1
C000033
10 jumper wires 70mm female - female
C000065
Wire Male/Female 10 pcs
C000013
10 10K potentiometers
E000011
32X8 Red LED Dot Matrix Unit Board - P7.62
T020160
Tinkerkit 4 pin Wires 25cm
T010112
TinkerKit Green Led [5mm] module
T010113
TinkerKit Yellow Led [5mm] module
E000022
mini breadboard - mixed colours
C000055
piezo 5x
T010117
C000028
T010111
C000056
C000022
1 L293D
T020170
C000010
10 1k 1/4w resistor
DATE DISMISSION
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
CCL LLC
www.arduino.org
CODE
NAME
C000007
Resistor Kit
A000026
Strip 40x1
C000033
C000065
C000013
E000011
T020160
T010112
T010113
E000022
T010118
TinkerKit Red Led [10mm] module
C000050
Power Supply 9V.
C000064
2 wheels for Robot
T010114
TinkerKit Red Led [5mm] module
T010115
TinkerKit Blue Led [10mm] module
T010116
TinkerKit Green Led [10mm] module
T020180
Tinkerkit 4 pin Wires 105cm
C000054
Battery wire 9V - DC plug
E000021
Micro USB Male to USB A Female Adapter
C000039
10 jumper wires 200mm female - female
T000030
TinkerKit Joystick module
T000200
TinkerKit Thermistor module
C000036
10 jumper wires 150mm male
T020080
TinkerKit Wires [100cm]
T030080
Full Breadboard PCB Module
K000006
ADK Kit
C000080
Stepper motor Nema 17
DATE DISMISSION
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
CCL LLC
www.arduino.org
CODE
NAME
C000037
10 jumper wires 150mm female
C000035
10 jumper wires 100mm female - female
T000150
TinkerKit Linear Potentiometer module
T000060
TinkerKit Gyroscope 2 Axis sensitivity 1X
T000220
TinkerKit Touch Sensor module
X000006
Antenna WiFi
E000020
Non-invasive AC current sensor (30A max)
C000034
10 jumper wires 100mm male - male
T000062
TinkerKit Gyroscope 2 Axis sensitivity 4X
T000090
TinkerKit LDR Sensor module
T000190
TinkerKit Tilt Sensor module
M000011
USB Micro cable type CANON 1.8 m
T000180
TinkerKit PushButton module
T030081
Half Breadboard PCB Module
T020040
Shield - TinkerKit Mega Sensor Shield
A000102
Arduino Due with Headers bottom side
T000140
TinkerKit Vertical Rotary Pot
E000019
Non-invasive AC current sensor (100A max)
T010160
Small DC motor
T020070
TinkerKit Wires [50cm]
T000070
TinkerKit Hall Sensor module
C000038
10 jumper wires 200mm male - male
T020060
TinkerKit Wires [20cm] module
M000006
USB cable type A/B
E000039
70 Wires Kit M/M mixed colours
C000063
Robot 2 wheels set
DATE DISMISSION
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
CCL LLC
www.arduino.org
CODE
NAME
T010020
TinkerKit Mosfet module
T000020
TinkerKit 2/3 Axis Accelerometer module
T020010
Shield - TinkerKit Sensor Shield V.2 module
T010010
TinkerKit Relay module
DATE DISMISSION
February 1st 2017
February 1st 2017
February 1st 2017
February 1st 2017
CCL LLC
www.arduino.org
很抱歉,暂时无法提供与“T010116”相匹配的价格&库存,您可以联系我们找货
