T000180
T000180
    ARDUINO
    Module
    Button Human Interface TinkerKit Platform Evaluation Expansion Board
T000180 数据手册
CCL LLC 88 Black Falcon Ave., Ste. 247, Boston, MA 02210 USA Contact: Antea Risso Digi-Key Corporation e-mail: antea@arduino.org 701 Brooks Ave.South PRODUCT CHANGE NOTIFICATION Thief River Falls, MN 5670 January 25th 2017 USA Page 1 of 2 ______________________________________________________________________________ Kindly note that some items will be soon disabled from our range of products. Please check below for your reference. Kindly update your system with the codes that will be discontinued. CODE NAME DATE DISMISSION B000003 Open Softwear 2nd Edition March 25th 2017 A000015 USB/serial converter WITHOUT headers March 25th 2017 X000005 GSM Antenna ANTA7000A0200BD1 March 25th 2017 A000014 USB/serial converter March 25th 2017 B000004 Pro Android Open Accessory Programming w/ Arduino March 25th 2017 K000010 Expansion Pack March 25th 2017 X000004 GSM Antenna ANTH7100A0200AI1 March 25th 2017 X000010 PoE module 5V March 25th 2017 A000084 14.5mm Strip 6 ways 2 pcs March 25th 2017 A000086 14.5mm Strip 10 ways 2 pcs March 25th 2017 X000002 PoE module 12V March 25th 2017 A000085 14.5mm Strip 8 ways 2 pcs March 25th 2017 A000032 Breadboard 830 with Wire Kit March 25th 2017 T010051 Digital Continuous Rotation (360°) Servo March 25th 2017 A000028 KIT Workshop - Base level WITHOUT Arduino Board March 25th 2017 CCL LLC Legal Address: 88 Black Falcon Ave, Ste. 247, Boston, MA 02210, USA www.arduino.org CODE NAME DATE DISMISSION T010050 Analog 180° Micro Servo March 25th 2017 A000089 Arduino WiFi shield (antenna connector) March 25th 2017 A000007 Shield - Xbee March 25th 2017 A000021 Shield - Xbee WITHOUT RF module March 25th 2017 CODE NAME DATE DISMISSION T070000 TinkerKit IR Remote Control February 1st 2017 C000014 10 10nF poly February 1st 2017 C000015 10 100nF poly February 1st 2017 C000017 10 1n4148 February 1st 2017 C000018 10 1n4007 February 1st 2017 C000041 Arduino Shaped Copper PCB (Double Side) February 1st 2017 C000048 10 Tinkerkit Male 3pin Connectors February 1st 2017 C000062 male jack plug 3.5mm - 4 connections February 1st 2017 C000001 10 Led Rossi 5mm February 1st 2017 C000002 10 Green Led 5mm February 1st 2017 C000003 10 Yellow Led 5mm February 1st 2017 C000027 5 PushButton 6x6 February 1st 2017 C000060 1V5 AA battery pack (4 units) February 1st 2017 C000052 25 cm Alligator test cable Black February 1st 2017 C000053 25 cm Alligator test cable Red February 1st 2017 C000029 3x2 Header Male Strip February 1st 2017 C000059 paper speaker 8 ohm, min 6cm diameter 5x February 1st 2017 C000032 10 jumper wires 70mm male - male February 1st 2017 C000019 10 BC547 February 1st 2017 C000008 10 10k 1/4w resistor C000011 10 100 ohm 1/4w resistor February 1st 2017 February 1st 2017 CCL LLC Legal Address: 88 Black Falcon Ave, Ste. 247, Boston, MA 02210, USA www.arduino.org CODE NAME C000077 10 680 ohm resistors C000078 10 470 ohm resistors C000079 10 1.2 K ohm resistors C000006 5 RGB LED 5mm C000023 1 74HC595 E000040 Water pump - USB connector C000051 1M ohm Resistor 10x C000024 5 linear potentiometer C000016 10 100uF elettrolytic T000061 Tinkerkit 2 Axis Gyroscope Sen.ty 1x BB Version C000025 5 LDR T000063 Tinkerkit 2 Axis Gyroscope - sensitivity 4x BB Version C000004 10 White Led 5mm C000009 10 220ohm 1/4w resistor C000031 Rotary Potentiometer C000061 battery holder for 8 1v5 AA batteries with 9V battery plug C000043 IR Led 940nm - TSAL5100 E000041 Wire's spools 10 colours 10m X000011 Micro SD card 4GB with SD adapter C000012 IR Receiver Tsop2238 - 38 KHZ C000030 2 4N35 Optocoupler C000021 1 IRF520 C000020 10 BC557 C000005 10 Blues Led 5mm C000057 12mm push buttons 10x DATE DISMISSION February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 CCL LLC Legal Address: 88 Black Falcon Ave, Ste. 247, Boston, MA 02210, USA www.arduino.org CODE NAME C000055 piezo 5x T010117 TinkerKit Yellow Led [10mm] module C000028 18x2 Header Male Strip T010111 TinkerKit Blue Led [5mm] module C000056 LED vari colori 10mm 20x C000022 1 L293D T020170 Tinkerkit 4 pin Wires 55cm C000010 10 1k 1/4w resistor C000007 Resistor Kit A000026 Strip 40x1 C000033 10 jumper wires 70mm female - female C000065 Wire Male/Female 10 pcs C000013 10 10K potentiometers E000011 32X8 Red LED Dot Matrix Unit Board - P7.62 T020160 Tinkerkit 4 pin Wires 25cm T010112 TinkerKit Green Led [5mm] module T010113 TinkerKit Yellow Led [5mm] module E000022 mini breadboard - mixed colours C000055 piezo 5x T010117 TinkerKit Yellow Led [10mm] module C000028 18x2 Header Male Strip T010111 TinkerKit Blue Led [5mm] module C000056 LED vari colori 10mm 20x C000022 1 L293D T020170 Tinkerkit 4 pin Wires 55cm C000010 10 1k 1/4w resistor DATE DISMISSION February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 CCL LLC Legal Address: 88 Black Falcon Ave, Ste. 247, Boston, MA 02210, USA www.arduino.org CODE NAME C000007 Resistor Kit A000026 Strip 40x1 C000033 10 jumper wires 70mm female - female C000065 Wire Male/Female 10 pcs C000013 10 10K potentiometers E000011 32X8 Red LED Dot Matrix Unit Board - P7.62 T020160 Tinkerkit 4 pin Wires 25cm T010112 TinkerKit Green Led [5mm] module T010113 TinkerKit Yellow Led [5mm] module E000022 mini breadboard - mixed colours T010118 TinkerKit Red Led [10mm] module C000050 Power Supply 9V. C000064 2 wheels for Robot T010114 TinkerKit Red Led [5mm] module T010115 TinkerKit Blue Led [10mm] module T010116 TinkerKit Green Led [10mm] module T020180 Tinkerkit 4 pin Wires 105cm C000054 Battery wire 9V - DC plug E000021 Micro USB Male to USB A Female Adapter C000039 10 jumper wires 200mm female - female T000030 TinkerKit Joystick module T000200 TinkerKit Thermistor module C000036 10 jumper wires 150mm male T020080 TinkerKit Wires [100cm] T030080 Full Breadboard PCB Module K000006 ADK Kit C000080 Stepper motor Nema 17 DATE DISMISSION February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 CCL LLC Legal Address: 88 Black Falcon Ave, Ste. 247, Boston, MA 02210, USA www.arduino.org CODE NAME C000037 10 jumper wires 150mm female C000035 10 jumper wires 100mm female - female T000150 TinkerKit Linear Potentiometer module T000060 TinkerKit Gyroscope 2 Axis sensitivity 1X T000220 TinkerKit Touch Sensor module X000006 Antenna WiFi E000020 Non-invasive AC current sensor (30A max) C000034 10 jumper wires 100mm male - male T000062 TinkerKit Gyroscope 2 Axis sensitivity 4X T000090 TinkerKit LDR Sensor module T000190 TinkerKit Tilt Sensor module M000011 USB Micro cable type CANON 1.8 m T000180 TinkerKit PushButton module T030081 Half Breadboard PCB Module T020040 Shield - TinkerKit Mega Sensor Shield A000102 Arduino Due with Headers bottom side T000140 TinkerKit Vertical Rotary Pot E000019 Non-invasive AC current sensor (100A max) T010160 Small DC motor T020070 TinkerKit Wires [50cm] T000070 TinkerKit Hall Sensor module C000038 10 jumper wires 200mm male - male T020060 TinkerKit Wires [20cm] module M000006 USB cable type A/B E000039 70 Wires Kit M/M mixed colours C000063 Robot 2 wheels set DATE DISMISSION February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 CCL LLC Legal Address: 88 Black Falcon Ave, Ste. 247, Boston, MA 02210, USA www.arduino.org CODE NAME T010020 TinkerKit Mosfet module T000020 TinkerKit 2/3 Axis Accelerometer module T020010 Shield - TinkerKit Sensor Shield V.2 module T010010 TinkerKit Relay module DATE DISMISSION February 1st 2017 February 1st 2017 February 1st 2017 February 1st 2017 CCL LLC Legal Address: 88 Black Falcon Ave, Ste. 247, Boston, MA 02210, USA www.arduino.org
T000180 价格&库存
很抱歉,暂时无法提供与“T000180”相匹配的价格&库存,您可以联系我们找货
