EK-H5
EK-H5
    SENSIRION(盛思锐)
    EVALUATION KIT EK-H5 FOR HUMIDIT
EK-H5 数据手册
Datasheet Evaluation Kit EK-H5 For SHT2x and SHT7x Humidity and Temperature Sensors     Very simple Evaluation Kit Applicable to SHT2x and SHT7x series Viewer Software for download USB Interface Product Summary The evaluation kit EK-H5 is made for running Sensirion’s humidity and temperature sensors and display measured values. It is held very simple: A USB dongle with USB to I2C translator capabilities connects with a sensor cable and sensor. With viewer software it is able to communicate with SHT1x, SHT7x as well as the new generation SHT2x and display measured values. The viewer software can be downloaded from the Sensirion web page and owns some simple data-logger features. Set Up of EK-H5 Viewer Software The main purpose of the evaluation kit is demonstrating the unique performance of Sensirion’s humidity and temperature sensors without any own hard or software design work. The viewer software displays relative humidity and temperature data on two different windows. It allows for addressing all available resolutions, absolute or relative timing, free choice of measurement intervals (1 … 1440s), and choice for displaying °C or °F. The data may be logged, stored and exported to Excel format. Figure 1 Schematic of Evaluation Kit EK-H5. USB Dongle with I2C to USB converter. Sensor cable is connected via plug to this USB dongle. Either SHT7x or SHT21 on PCB may be plugged to the cable. Viewer software must be downloaded from the Sensirion web page. Pin assignment of SHT21 on PCB top view from left to right: SCL, VDD, VSS, SDA (same as SHT7x). Material Contents    1 EK-H5 USB Stick: Contains USB to I2C translator capabilities. 1 Sensor cable of 1m length with plug for connecting sensors with USB dongle. 1 SHT21 sensor: SMD type, DFN 3-0 packaged sensors with version 4C sensor chip mounted to small PCB with connector. Please refer to datasheet SHT21 for more details. Device Certification The Evaluation Kit EK-H5 is RoHS and WEEE compliant. www.sensirion.com Viewer Software must be downloaded from the Sensirion web page. Please find it on www.sensirion.com/ek-h5. Please note that the USB stick, sensor cable and sensor must be connected to the computer before starting the software. No further software driver or any other hardware is required for running EK-H5. When starting the viewer software, the right sensor must be selected in a first window (more sensors are given for choice). The settings must be chosen and then the measurement may be started. Version 2.0 – August 2012 1/2 Revision History Date January 2010 August 2012 Version 1.0 2.0 Page(s) 1–2 1 Changes Initial release Changed hyperlink Important Notices Warning, Personal Injury Do not use this product as safety or emergency stop devices or in any other application where failure of the product could result in personal injury. Do not use this product for applications other than its intended and authorized use. Before installing, handling, using or servicing this product, please consult the data sheet and application notes. Failure to comply with these instructions could result in death or serious injury. If the Buyer shall purchase or use SENSIRION products for any unintended or unauthorized application, Buyer shall defend, indemnify and hold harmless SENSIRION and its officers, employees, subsidiaries, affiliates and distributors against all claims, costs, damages and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if SENSIRION shall be allegedly negligent with respect to the design or the manufacture of the product. ESD Precautions The inherent design of this component causes it to be sensitive to electrostatic discharge (ESD). To prevent ESD-induced damage and/or degradation, take customary and statutory ESD precautions when handling this product. See application note “ESD, Latchup and EMC” for more information. Warranty SENSIRION warrants solely to the original purchaser of this product for a period of 12 months (one year) from the date of delivery that this product shall be of the quality, material and workmanship defined in SENSIRION’s published specifications of the product. Within such period, if proven to be defective, SENSIRION shall repair and/or replace this product, in SENSIRION’s discretion, free of charge to the Buyer, provided that:  notice in writing describing the defects shall be given to SENSIRION within fourteen (14) days after their appearance;  such defects shall be found, to SENSIRION’s reasonable satisfaction, to have arisen from SENSIRION’s faulty design, material, or workmanship;  the defective product shall be returned to SENSIRION’s factory at the Buyer’s expense; and  the warranty period for any repaired or replaced product shall be limited to the unexpired portion of the original period. This warranty does not apply to any equipment which has not been installed and used within the specifications recommended by SENSIRION for the intended and proper use of the equipment. EXCEPT FOR THE WARRANTIES EXPRESSLY SET FORTH HEREIN, SENSIRION MAKES NO WARRANTIES, EITHER EXPRESS OR IMPLIED, WITH RESPECT TO THE PRODUCT. ANY AND ALL WARRANTIES, INCLUDING WITHOUT LIMITATION, WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, ARE EXPRESSLY EXCLUDED AND DECLINED. SENSIRION is only liable for defects of this product arising under the conditions of operation provided for in the data sheet and proper use of the goods. SENSIRION explicitly disclaims all warranties, express or implied, for any period during which the goods are operated or stored not in accordance with the technical specifications. SENSIRION does not assume any liability arising out of any application or use of any product or circuit and specifically disclaims any and all liability, including without limitation consequential or incidental damages. All operating parameters, including without limitation recommended parameters, must be validated for each customer’s applications by customer’s technical experts. Recommended parameters can and do vary in different applications. SENSIRION reserves the right, without further notice, (i) to change the product specifications and/or the information in this document and (ii) to improve reliability, functions and design of this product. © Copyright 2010 by SENSIRION. CMOSens® is a trademark of SENSIRION All rights reserved Headquarter and Sales Offices Headquarter SENSIRION AG Laubisruetistr. 50 CH-8712 Staefa ZH Switzerland Sales Office USA: SENSIRION Inc. 2801 Townsgate Rd., Suite 204 Westlake Village, CA 91361 USA Sales Office Japan: SENSIRION JAPAN Co. Ltd. Postal Code: 108-0074 Shinagawa Station Bldg. 7F, 4-23-5, Takanawa, Minato-ku Tokyo, Japan Sales Office Korea: SENSIRION KOREA Co. Ltd. www.sensirion.com Phone: +41 44 306 40 00 Fax: +41 44 306 40 30 info@sensirion.com http://www.sensirion.com/ Phone: +1 805 409 4900 Fax: +1 805 435 0467 michael.karst@sensirion.com http://www.sensirion.com/ Phone: +81 3 3444 4940 Fax: +81 3 3444 4939 info@sensirion.co.jp http://www.sensirion.co.jp Phone: #1414, Anyang Construction Tower B/D, 1112-1, Bisan-dong, Anyang-city Gyeonggi-Province South Korea Sales Office China: Sensirion China Co. Ltd. Room 2411, Main Tower Jin Zhong Huan Business Building, Futian District, Shenzhen, Postal Code 518048 PR China Fax: +82 31 440 9927 info@sensirion.co.kr http://www.sensirion.co.kr phone: +86 755 8252 1501 fax: +86 755 8252 1580 info@sensirion.com.cn www.sensirion.com.cn Find your local representative at: http://www.sensirion.com/reps +82 31 440 9925~27 Version 2.0 – August 2012 2/2
EK-H5 价格&库存
很抱歉,暂时无法提供与“EK-H5”相匹配的价格&库存,您可以联系我们找货
