SEN0208
SEN0208
    DFROBOT
    WEATHER-PROOFULTRASONICSENSOR
SEN0208 数据手册
    Weather ‐ proof Ultrasonic Sensor with Separate Probe SKU : SEN0208      Contents      1 Introduction 2 Specification 3 Board Overview 4 Tutorial 4.1 Fundamental Principles 4.2 Requirements 4.3 Connection Diagram 4.4 Sample Code 5 FAQ Introduction Most ultrasonic distance sensors aren't waterproof which can be a problem if you need your project to withstand the elements outdoors. No need to worry any more! We have developed waterproof ultrasonic distance sensors with a waterproof sealed emitter. This sensor is suitable for outdoor applications such as car reversing sensors, security alarms, industrial inspection, etc. What will you make? Specification           Operating Voltage: 5V DC Static Current: 5mA Operating Current: 30mA Operating Range: 25cm ~ 4.5m Resolution: 0.5cm Detecting Angle: < 70° Operating Temperature: -10 ~ 70°C Cable Length: 2.5 M Dimension: 41mm x 28.5mm/1.61*1.12 inches Weight: 54g Board Overview LABEL 1 2 3 4 NAME 5V Trig Echo GND FUNCTION Power Input + Trigger Signal Echo Signal GND Tutorial This tutorial will demonstrate how to use the Weather-proof Ultrasonic Sensor to measuring distance. Fundamental Principles A short ultrasonic pulse is transmitted at the time 0, reflected by an object. The sensor receives this signal and converts it to an electric signal. The next pulse can be transmitted when the echo fades. This time period is called cycle period. The recommend cycle period should be no less than 50ms. If a 10μs width trigger pulse is sent to the signal pin, the ultrasonic module will output eight 40kHz ultrasonic signals and detect the echo back. The measured distance is proportional to the echo pulse width and can be calculated by the formula above. If no obstacle is detected, the output pin will give a 38ms high level signal. Requirements   Hardware Arduino UNO x1 Battery Capacity Indicator x1 Software  Arduino IDE V1.6.9 Click to Download Arduino IDE from Arduino®   Connection Diagram Sample Code 1 #define ECHOPIN 2// Pin to receive echo pulse 2 #define TRIGPIN 3// Pin to send trigger pulse 3 void setup(){ 4 Serial.begin(9600); 5 pinMode(ECHOPIN, INPUT); 6 pinMode(TRIGPIN, OUTPUT); 7 } 8 void loop(){ 9 digitalWrite(TRIGPIN, LOW); // Set the trigger pin to low for 2uS 10 delayMicroseconds(2); 11 digitalWrite(TRIGPIN, HIGH); // Send a 10uS high to trigger ranging 12 delayMicroseconds(10); 13 digitalWrite(TRIGPIN, LOW); // Send pin low again 14 int distance = pulseIn(ECHOPIN, HIGH,26000); // Read in times pulse 15 distance= distance/58; 16 Serial.print(distance); 17 Serial.println(" 18 delay(50);// Wait 50mS before next ranging cm"); 19 } FAQ There are no questions about this product yet. If you have any problems or suggestions, you are welcome to email us or post on the DFRobot forum! For any questions/advice/cool ideas to share, please visit the DFRobot Forum or email techsupport@dfrobot.com Powered By DFRobot © 2008-2017
SEN0208 价格&库存
很抱歉,暂时无法提供与“SEN0208”相匹配的价格&库存,您可以联系我们找货
