MK11/M5-KIT
MK11/M5-KIT
    STANDEX-MEDER(斯丹麦德)
    DIP20_300MIL
    REED SENSOR/MAGNET EVAL KIT
MK11/M5-KIT 数据手册
A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – MK11(S) Reed Sensors MK11(S) Reed Sensors  Features: Cylindrical Reed Sensor, Choice of Cable Termination & Lengths available, Various Case Sizes  Applications: Door & Window Contacts, Safety Control, Position Sensing  Markets: Appliance, Industrial, Security & Others MK 11/M0-0X00X-000X Part Description: Thread Contact QTY Contact Form Switch Model Magnetic Sensitivity Cable Length M5, M8 1 A, B, C 66, 85, 90 C, D, E 200, 300, 500, 1,000, 1,500, 2,000, 3,000, 5,000 Termination (mm) W Customer Options Contact Data 66 85 90 Rated Power (max.) 10 100 10 W 200 1000 175 V 0.5 1 0.5 A 1.0 2.5 1.0 A 150 150 150 mOhm 0.25 1.5 0.2 kVDC 0.7 1.1 0.7 ms 0.05 0.05 1.5 ms 1010 1010 109 Ohm 0.3 0.5 1.5 pF Switch Model Any DC combination of V&A not to exceed their individual max.’s Switching Voltage (max.) DC or peak AC Switching Current (max.) DC or peak AC Carry Current (max.) DC or peak AC Contact Resistance (max.) @ 0.5V & 50mA Breakdown Voltage (min.) According to EN60255-5 Operating Time (max.) Incl. Bounce; Measured with w/ Nominal Voltage Release Time (max.) Measured with no Coil Excitation Insulation Resistance (typ.) Rh 5m cable length 1/2 sine wave duration 11ms Vibration Resistance (max.) Operating Temperature Cable not moved Operating Temperature Cable moved Storage Temperature Glossary Contact Form Form A NO = Normally Open Contacts SPST = Single Pole Single Throw Form B NC = Normally Closed Contacts SPST = Single Pole Single Throw Form C Changeover SPDT = Single Pole Double Throw Life Test Data Glossary Magnetic Sensitivity Sens. AT *Load increase reduces life expectancy of Reed Switches A B C D E F G 05-10 10-15 15-20 20-25 25-30 30-35 35-40 USA: Europe: Asia: +1.866.782.6339 +49.7731.8399.0 +86.21.37820625 │ salesusa@standexmeder.com │ info@standexmeder.com │ salesasia@standexmeder.com Modifications in the sense of technical progress are reserved. Version 01 27.01.2015
MK11/M5-KIT 价格&库存
很抱歉,暂时无法提供与“MK11/M5-KIT”相匹配的价格&库存,您可以联系我们找货
