AS5043 10-BIT PROGRAMMABLE MAGNETIC ROTARY ENCODER
Adapter PCB Operation Manual
AS5043
10 BIT PROGRAMMABLE MAGNETIC ROTARY ENCODER
ADAPTER PCB OPERATION MANUAL
1 The AS5043 adapter PCB:
The AS5043 adapter PCB is a simple circuit allowing customers to test and evaluate the AS5043 rotary encoder
rapidly without having to build their own test fixture or PCB.
The PCB can be used as standalone unit or plugged onto the AS5043 demo board as external encoder.
For Standalone operation, it can be supplied with 3.3V, 5V or 7,5...12V DC supply voltages.
Figure 1: AS5043 Adapter PCB: top and bottom view
Features:
100mil connector for direct connection to AS5043 demo board
Provision for a 600mil DIP socket
Hole in PCB to center a 6mm magnet at the bottom of the IC
LED for MagRng output
On-board 5V linear voltage regulator for 7,5…12V supplies
9V battery connector for standalone operation
Dimensions: 35mm x 37mm (1.38 x 1.46 inch)
Revision A.02, 04. Jul 06
www.austriamicrosystems.com
Page 1 of 12
2 General Description
4 Pin Description
The AS5043 is a system-on-chip, combining
integrated Hall elements, analog front end and
digital signal processing in a single device. It
provides incremental output signals and the
absolute angular position of a magnet that is placed
either above or below the device.
The AS5043 can be configured to specific customer
requirements by programming the integrated OTP
(one time programmable) register. An internal
voltage regulator allows the AS5043 to operate at
either 3.3 V or 5 V supplies.
Pin
Symbol
Type
1
MagRngn
DO_OD
Magnet Field Magnitude RaNGe warning;
active low, indicates that the magnetic
field strength is outside of the
recommended limits.
2
Mode
DI_PD,
ST
Mode input. Select between low noise
(open, low) and high speed (high) mode.
Internal pull-down resistor
3
CSn
DI_PU,
ST
Chip Select, active low; Schmitt-Trigger
input, internal pull-up resistor (~50kΩ)
4
CLK
DI,ST
Clock Input of Synchronous Serial
Interface; Schmitt-Trigger input
5
NC
must be left unconnected
6
DO
DO_T
Data Output of Synchronous Serial
Interface
7
VSS
S
Negative Supply Voltage (GND)
8
Prog_DI
DI_PD
OTP Programming Input and Data Input
for Daisy Chain mode. Internal pull-down
resistor (~74kΩ).
Should be connected to VSS if not used
9
DACref
AI
DAC Reference voltage input for external
reference
10
DACout
AO
DAC output (unbuffered, Ri ~8kΩ)
11
FB
Feedback, OPAMP inverting input
Must be left unconnected
12
Vout
AI
AO
13
NC
14
NC
Figure 2: Typical arrangement AS5043 and magnet
3 Pin Configuration
Description
OPAMP output
15
VDD3V3
S
3V-Regulator Output for internal core,
regulated from VDD5V.Connect to
VDD5V for 3V supply voltage. Do not
load externally.
16
VDD5V
S
Positive Supply Voltage, 3.0 to 5.5 V
AS5043
Table 1: Pin description SSOP16
Figure 3: Pin configuration SSOP16
Page 2 of 12
5 Principle of Operation
3.9 mm
3.9 mm
1
Circle of Hall elements
on chip: 2.2mm diameter
2.433 mm
Defined
center
2.433 mm
Area of allowed magnet
misalignment: 0.5mm diameter
The AS5043 chip consists of a ring of hall
elements, placed at the center of the IC at a
circle diameter of 2.2mm (86.6mil).
The hall elements pick up the field of a magnet,
placed atop this hall array circle. This
information is digitized and fed into a digital
signal processor (DSP), which calculates the
angle of the magnet with a resolution of 0.0879
degrees or 4096 positions per revolution (10bit)
at a sampling rate of 96µs (10kHz; Default) or
384µs (2.6kHz).
The digital angle information is available in
several formats: as serial 10-bit data stream, as
pulse-width modulated (PWM) signal or as
quadrature incremental signal
Figure 4:Tolerances of magnet placement
5.1
Magnet considerations
A magnet, having one north / one south pole in the horizontal axis is placed right above the ring of hall elements
(see Figure 2). The magnet does not necessarily need to be circular, it can be rectangular as well, as long as the
north and south pole are arranged horizontally over the center of the hall array ring.
The magnetic field strength along this ring should be in the range of ±45….75 milliTesla (mT).
5.1.1
Magnet size
The size of the magnet should be at least the size of the hall array ring (2.2mm). Smaller magnets are more critical
in terms of misalignment due to the non-linear magnetic field distribution along the circumference of the magnet.
The recommended magnet diameter is 4….6mm
5.1.2
Magnet distance and material
To achieve the required field strength at a reasonable distance (~0.5…5mm), it is recommended to use rare-earth
magnets, such as Samarium-Cobalt (SmCo) or Neodyne-Iron-Boron (NdFeB) magnets.
5.1.3
Magnet misalignment
In theory, the magnet misalignment is not critical for this type of angular measurement. In practice however,
magnets are not perfectly linear. The magnetic field strength does not increase linearly with the radius. As you get
towards the boundary of the magnet, the magnetic field comes to a maximum and then weakens as you move
further away from the center. Therefore, a magnet should be chosen, that is still in the linear range at a
很抱歉,暂时无法提供与“AS5043AB”相匹配的价格&库存,您可以联系我们找货
