ISP Ribbon Cable - family overview
6-way 0.1" pitch ISP ribbon cable
(200mm)
20-way 0.1" pitch ISP ribbon cable for
ARM microcontrollers (200mm)
Digi-key - 483-1029-ND
Equinox - CAB-ISP6W200
Digi-key - 483-1032-ND
Equinox - CAB-ARM-20W
10-way 0.1" pitch ISP ribbon cable
(200mm)
10-way 0.05" pitch ISP ribbon cable
for ARM microcontrollers - (150mm)
Digi-key - 483-1030-ND
Equinox - CAB-ISP10W200
Digi-key - 483-1033-ND
Equinox - CAB-ARM-10W-150
16-way 0.1" pitch ISP ribbon cable
(200mm)
Typical layout of an ISP cable
connector (10-way)
Digi-key - 483-1031-ND
Equinox - CAB-16W/16W-ISP-RIBBON
6-way In-System Programming (ISP) Cable
(0.1" IDC connectors)
Equinox order code: CAB-ISP6W200
Digi-key order code: 483-1029-ND
The CAB-ISP6W200 is a 6-way In-System Programming (ISP) ribbon cable designed to
connect from any ISP programmer which features a 6-way IDC connector to a 6-way 0.1"
pitch IDC connector on a suitable Target System. The cable features 200mm of flat ribbon
cable with a 6-way IDC 0.1" pitch female connector on each end. The IDC connectors are
fitted with 'cable grips' and are bump polarised to prevent the connector being plugged in
the wrong way around.
The CAB-ISP6W200 cable is suitable for use with any Equinox ISP programmer and also
with any other programmer or 'Starter Kit' which features the 6-way 0.1" pitch IDC
connector. eg. Atmel AVRISP, STK500, STK501 etc.
Specification:
Cable length (connector to connector): 200mm
Cable type: 6-way flat ribbon cable (red stripe denotes pin 1)
Each end of the cable is terminated with a 10-way 0.1" pitch IDC female connector
Connectors are fitted with 'cable grips' for added resilience.
Connectors are bump-polarised to stop the connector being plugged in the wrong
way around
This cable is compatible with the following equipment:
Any Equinox ISP programmer with a 6-way IDC connector eg. EPSILON5, FS2000A,
FS2003, FS2009, FS2009USB, PPM3-MK2, PPM4-MK1, ISPnano etc.
Any ISP programmer, Starter Kit or Development Board which features a 6-way IDC
connector eg. Atmel STK500, STK501, STK502, STK505 etc
Any other programmer or Target PCB which features a 0.1" pitch 6-way IDC male
connector.
10-way In-System Programming (ISP)
Cable (0.1" IDC connectors)
Equinox Code: CAB-ISP10W200
Digikey Code: 483-1030-ND
The CAB-ISP10W200 is a 10-way In-System Programming (ISP) ribbon cable designed to
connect from any ISP programmer which features a 10-way IDC connector to a 10-way
0.1" pitch IDC connector on a suitable Target System. The cable features 200mm of flat
ribbon cable with a 10-way IDC 0.1" pitch female connector on each end. The IDC
connectors are fitted with 'cable grips' and are bump polarised to prevent the connector
being plugged in the wrong way around.
The CAB-ISP10W200 cable is suitable for use with any Equinox ISP programmer and also
with any programmer or 'Starter Kit' which features the 10-way 0.1" pitch IDC connector.
eg. Atmel STK500, STK501 etc.
Specification:
Cable type: 10-way flat ribbon cable (red stripe denotes pin 1)
way around
Any Equinox ISP programmer with a 10-way 0.1" pitch IDC connector eg. Equinox
EPSILON5, EPSILON5-MK4, FS2000A, FS2003, FS2009, FS2009USB, PPM3-MK2,
PPM4-MK4
Any ISP Starter Kit or Development Board which features a 10-way IDC connector
Any other programmer or Target PCB which features a 0.1" pitch 10-way IDC male
connector.
16-way In-System Programming (ISP)
Equinox Code: CAB-16W/16W-ISP-RIBBON
Digikey Code: 483-1031-ND
The CAB-16W/16W-ISP-RIBBON cable is a 16-way In-System Programming (ISP) ribbon
cable designed to connect from any ISP programmer which features a 16-way IDC
connector to a 16-way 0.1" pitch IDC connector on a suitable Target System. The cable
features 200mm of flat ribbon cable with a 16-way IDC 0.1" pitch female connector on each
end. The IDC connectors are fitted with 'cable grips' and are bump polarised to prevent the
connector being plugged in the wrong way around.
The CAB-16W/16W-ISP-RIBBON cable is suitable for use with all Equinox ISPnano
programmers and also with any other programmer or 'Starter Kit' which features the 16-way
Specification:
Cable type: 16-way flat ribbon cable (red stripe denotes pin 1)
way around
Equinox ISPnano programmer family - ISPnano Series 3, Series IV, ISPnano-MUX
Equinox CONMOD connector module
Infineon OCDS (JTAG) target boards feature a 16-way 0.1" IDC connector
Any other programmer or 'Starter Kit' which features the 16-way 0.1" pitch IDC
connector.
20-way In-System Programming (ISP)
Cable for ARM microcontrollers (0.1" IDC)
Equinox Code: CAB-ARM-20W
Digikey Code: 483-1032-ND
The CAB-ARM-20W cable is a 20-way In-System Programming (ISP) ribbon cable
designed to connect from any ISP programmer which features a 20-way IDC connector to
a 20-way 0.1" pitch IDC connector on a suitable ARM microcontroller Target System. The
cable features 200mm of flat ribbon cable with a 20-way 0.1" pitch female IDC connector on
each end. The IDC connectors are fitted with 'cable grips' and are bump polarised to
prevent the connector being plugged in the wrong way around.
The CAB-ARM-20W cable is suitable for use with the Equinox ISPnano programmer family
which support the 20-way ARM connector interface. This cable is also compatible with any
other programmer or 'Starter Kit' which features the 20-way 0.1" pitch IDC connector.
Specification:
Cable type: 20-way flat ribbon cable (red stripe denotes pin 1)
Each end of the cable is terminated with a 20-way 0.1" pitch IDC female connector
way around
Any other ARM microcontroller programmer, ARM 'Starter Kit' or ARM 'evaluation
board' which features the standard ARM 20-way 0.1" pitch IDC connector.
10-way In-System Programming (ISP) Cable
for ARM Cortex microcontrollers (0.05" pitch)
Equinox Code: CAB-ARM-10W-150
Digikey Code: 483-1033-ND
The CAB-ARM-10W-150 is an In-System Programming (ISP) ribbon cable designed to
connect from any ISP programmer which features a 10-way 0.05" pitch connector to a 10way 0.05" pitch connector on a suitable ARM microcontroller Target System. The cable
features 150 mm of flat ribbon cable with a 10-way 0.05" (1.27mm) pitch female connector
on each end.
This cable can be used with any ARM device programmer which features the standard
ARM Cortex 10-way 0.05" pitch connector. It is suitable for programming any ARM device
via either the JTAG or Serial Wire Debug (SWD) interface. It can also be used with any
compatible ARM programmer or debugger including the Equinox range of ISP
programmers.
Specification:
Cable length (connector to connector): 150 mm
Each end of the cable is terminated with a 10-way 0.05" (1.27mm) pitch female
connector
way around
Any compatible ARM programmer or debugger or ARM Target System (PCB) which
features the 0.05" (1.27mm) pitch 10-way connector.
EPSILON5-MK4(ARM) programmer - fitted with ASSY-ARM-10W connector module
FS2009USB(ARM) programmer - fitted with ASSY-ARM-10W connector module
ISPnano Series 4 programmer - fitted with IOMOD8 connector module
ISPnano-MUX programmer - fitted with IOMOD8 connector module
很抱歉,暂时无法提供与“CAB-ARM-10W-150”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+173.566661+22.56311
