VTEUPLJANF-40.960000
    TAITIEN(泰艺)
    SMD-6
    有源晶振 40.96MHz 3.3V SMD-6
VTEUPLJANF-40.960000 数据手册
VT Type 7.0 x 5.0 mm SMD Voltage Controlled Crystal Oscillator Actual Size FEATURE - Typical 7.0 x 5.0 x 1.75 mm 6 pads ceramic SMD package. - Tight symmetry (45 to 55%) available. - Tri-state enable/disable TYPICAL APPLICATION - Set-top Box, HDTV - WiMAX/WLAN - xDSL/ VoIP, Cable modem RoHS Compliant VT SOLDER Type PAD L AYOUT (mm) DIMENSION (mm) [ TOP VIEW ] [ BOTTOM VIEW ] 5.08±0.20 #4 #1 #2 #3 #4 5.08 #6 #3 #2 1.27±0.20 3.81±0.20 #5 #1 0.1µF 1.40±0.20 Pin# Function 1 Vcon 2 Tri-State 3 GND 4 Outpout 5 NC 6 VDD 0.65 1.75±0.15 [ SIDE VIEW ] 4.00 #5 5.00±0.20 #6 2.00 7.00±0.20 1.80 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3 V Parameter Supply Voltage Variation (VDD ) Frequency Range Standard Frequency Absolute Pulling Range (APR) Control Voltage Range Supply Current 1.5 MHz Fo < 20 MHz 20 MHz Fo < 50 MHz 80 MHz 50 MHz Fo 80 MHz < Fo < 160 MHz 170 MHz 160 MHz Fo Output Level (CMOS) Output High (Logic “1”) Output Low (Logic “0”) Transition Time: Rise/Fall Time+ 1.5 MHz Fo < 20 MHz 20 MHz Fo < 50 MHz 80 MHz 50 MHz Fo 80 MHz < Fo 170 MHz Start Time Tri-State(Input to Pin 2) Enable (High voltage or floating) Disable (Low voltage or GND) Period Jitter (Pk-Pk) RMS Phase Jitter (Integrated 12kHz~20MHz) Linearity Modulation Bandwidth (BW) 1.5 MHz Fo 170 MHz Input Impedance 1.5 MHz Fo 170 MHz 100 Hz Phase Noise@30.72MHz 1 kHz 10 kHz Min. VDD-5% 1.5 Max. VDD+5% 170 Unit V MHz 10,20,25,27,32.768,35.328,38.88,61.44,122.88, 153.6 _ ±50 0.3 3.0 10 20 30 40 50 _ _ _ _ _ _ 5 4 3 2 5 2.31 _ _ _ _ _ 0.99 40 1 10 15 _ 10000 _ _ V 0.33 _ _ _ _ _ -55 mA _ 2.97 Aging (@ 25°C 1st year) Storage Temp. Range ppm V -115 -135 -150 nSec mSec V pSec pSec % kHz kΩ dBc/Hz ±3 125 ppm °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. + Transition times are measured between 10% and 90% of VDD, with an output load of 15pF. FREQ. STABILIT Y vs. TEMP. RANGE Temp. (°C) ppm ±25 ±50 -10 ~ +60 -20 ~ +70 -40 ~ +85 * ○: Available △:Conditional X: Not available * Inclusive of calibration @ 25 °C, operating temperature range, input voltage variation, load variation, aging (1st year), shock, and vibration Note: not all combination of options are available. Other specifications may be available upon request. 68 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(20)09/2019
物料型号:VT Type 器件简介:7.0 x 5.0 x 1.75 mm的6个焊盘的陶瓷SMD封装,具有紧对称性(45%到55%)和三态使能/禁用功能。 引脚分配: - 1:Vcon(电压控制) - 2:三态(Tri-State) - 3:GND(地) - 4:输出(Output) - 5:NC(无连接) - 6:VDD(电源电压)
参数特性: - 供电电压变化:VDD-5%至VDD+5% - 频率范围:170MHz - 标准频率:10, 20, 25, 27, 32.768, 35.328, 38.88, 61.44, 122.88, 153.6MHz - 绝对拉频范围:±50ppm - 控制电压范围:0.3V至3.0V - 供电电流:1.5MHz至20MHz时为1mA至10mA,20MHz至50MHz时为20mA,50MHz至80MHz时为30mA,80MHz至160MHz时为40mA,160MHz至170MHz时为50mA - 输出电平(CMOS):高电平2.97V,低电平0.33V - 上升/下降时间:1.5MHz至20MHz为5ns,20MHz至50MHz为4ns,50MHz至80MHz为1ns,80MHz至170MHz为325ps
功能详解: - 为了确保最佳振荡器性能,应在VDD和GND焊盘之间尽可能靠近器件放置0.1μF的旁路电容器。 - 三态使能/禁用:使能电压2.31V,禁用电压0.99V。 - 周期抖动(Pk-Pk):40ps - 均方根相位抖动(12kHz至20MHz):未提供具体数值。 - 线性调制带宽:1kHz至10kHz为1kHz,1.5MHz至170MHz为15kHz。 - 输入阻抗:1.5MHz至170MHz为10kΩ。 - 相位噪声:在30.72MHz时,100Hz处为-115dBc/Hz,1kHz处为-135dBc/Hz,10kHz处为-150dBc/Hz。 - 老化(25°C第一年):±3ppm。 - 存储温度范围:-55°C至125°C。
应用信息:适用于机顶盒、高清电视、WiMAX/WLAN、xDSL/VoIP、有线电视调制解调器等。 封装信息:符合RoHS标准的7.0 x 5.0 mm SMD封装。
VTEUPLJANF-40.960000 价格&库存
很抱歉,暂时无法提供与“VTEUPLJANF-40.960000”相匹配的价格&库存,您可以联系我们找货
  • 150+13.58789150+1.62466
库存:853
  • 1+17.259801+2.06370
  • 10+16.4892410+1.97157
库存:853
