TYEAPLSANF-40.000000
    TAITIEN(泰艺)
    SMD-4
    有源晶振 40MHz 2.8V~3.3V SMD-4
TYEAPLSANF-40.000000 数据手册
TY Type 2.5 x 2.0 mm SMD Voltage Controlled Temperature ture Compensated Crystal Oscillator Actual Size FEATURE - Typical 2.5 x 2.0 x 0.7 mm ceramic SMD package. - For automatic assembly. - Compactness and lightweight. - VCTCXO available. - Low thickness TYPICAL APPLICATION - GPS - WiMAX, WLAN - Mobile Phone RoHS Compliant DIMENSION (mm) SOLDER PAD LAYOUT (mm) [ BOTTOM VIEW ] [ TOP VIEW ] 0.1 μF 2.50±0.15 2.00±0.15 #1 #2 #2 #1 0.90 #4 0.60±0.10 #3 1.35±0.15 #4 1.45 1.95±0.15 2.05 0.50±0.10 Pin# [ SIDE VIEW ] 0.70±0.10 0.22±0.04 1 2 3 4 0.80 Function VCON:VC-TCXO GND / NC: TCXO GND Output VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3 / 3.0 / 2.8 V Min. Max. 2.66 3.465 10 52 Parameter Supply Voltage Variation (VDD) Frequency Range Standard Frequency Frequency Tolerance* Frequency stability Vs Supply Voltage (±5%) change Vs Load (±10%) change Vs Aging (@1st year) Supply Current 10 MHz Fo 26 MHz 26 MHz Fo 52 MHz Output Level (Clipped sine wave) Load Control Voltage Range (VCTCXO) Pulling Range (VCTCXO) Vc Input Impedance (VCTCXO) Phase Noise @ 19.2 MHz 100 Hz 1 kHz 10 kHz Start time Storage Temp. Range _ ±2.0 _ _ _ _ _ 2.5 V Min. Max. 2.375 2.625 10 52 16.369, 19.2, 26.0, 38.4 _ ±2.0 _ _ _ _ _ ±0.2 ±0.2 ±1.0 1.5 2.0 _ ±0.2 ±0.2 ±1.0 1.5 2.0 _ 0.8 0.8 10 KΩ // 10pF 10 KΩ // 10pF 0.5 2.5 0.4 2.4 _ _ ±5.0 ±5.0 _ _ 500 500 -115 -115 -135 -135 -148 -148 _ _ 2 2 -55 125 -55 125 Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. * Frequency at 25°C, 1 hour after reflow. 1.8 V Min. 1.71 10 _ _ _ _ _ _ Max. 1.89 52 ±2.0 ±0.2 ±0.2 ±1.0 1.5 2.0 _ 0.8 10 KΩ // 10pF 0.3 1.5 _ ±5.0 _ 500 -115 -135 -148 _ 2 -55 125 Unit V MHz ppm ppm ppm mA Vp-p V ppm kΩ dBc/Hz mSec °C FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm ±0.5 ±1.0 ±1.5 ±2.0 ±2.5 -20 ~ +70 -30 ~ +85 -40 ~ +85 * ż: Available Χ:Conditional X: Not available Note: not all combination of options are available. Other specifications may be available upon request. 6SHFL¿FDWLRQVVXEMHFWWRFKDQJHZLWKRXWQRWLFH www.taitien.com sales@taitien.com.tw Rev(11)11/2019 85
物料型号:TY型 器件简介:2.5 x 2.0 x 0.7 mm的典型尺寸,适用于自动装配,具有紧凑性和轻量级特点,符合RoHS标准。 引脚分配: - 1号引脚:VCON:VC-TCXO - 2号引脚:GND - 3号引脚:输出 - 4号引脚:VDD
参数特性: - 供电电压变化范围:2.66V至3.465V - 频率范围:10MHz至52MHz - 标准频率:16.369MHz, 19.2MHz, 26.0MHz, 38.4MHz - 频率容差:+2.0ppm - 电源电流:10MHz时为1.5mA,26MHz时为2.0mA - 输出电平:0.8Vp-p - 控制电压范围:0.5V至2.5V(VCTCXO) - 拉频范围:±5.0ppm(VCTCXO)
功能详解:为确保最佳振荡器性能,应在Vdd和GND焊盘之间尽可能靠近器件放置0.1μF的旁路电容。
应用信息:适用于GPS、WiMAX、WLAN和移动电话。
封装信息:2.5 x 2.0 mm的SMD封装,具有0.7mm的低厚度。
TYEAPLSANF-40.000000 价格&库存
很抱歉,暂时无法提供与“TYEAPLSANF-40.000000”相匹配的价格&库存,您可以联系我们找货
  • 1+27.247221+3.51708
  • 10+23.6741710+3.05587
  • 25+22.3895825+2.89006
  • 50+21.4623050+2.77036
  • 100+20.57492100+2.65582
  • 250+19.45869250+2.51174
库存:498
  • 500+18.65486500+2.40798
  • 1000+17.885101000+2.30862
  • 1500+17.449991500+2.25245
  • 2500+16.917182500+2.18368
  • 3500+16.575383500+2.13956
  • 5000+16.220745000+2.09378
库存:498
