VWEUPLJANF-38.400000 数据手册
VW Type
5.0 x 3.2mm SMD Voltage Controlled
Crystal Oscillator
Actual Size
FEATURE
- Typical 5.0 x 3.2 x 1.25 mm 6 pads ceramic SMD package.
- Tight symmetry (45 to 55%) available.
- Operating temperature up to 105。C
- Tri-state enable/disable
TYPICAL APPLICATION
- Set-top Box, HDTV
- WiMAX/WLAN
- xDSL/ VoIP, Cable modem
RoHS Compliant
DIMENSION (mm)
SOLDER PAD LAYOUT (mm)
[ BOTTOM VIEW ]
[ TOP VIEW ]
2.54 ± 0.15
5.00 ± 0.15
#4
#4
#5
#6
#2
#3
#3
#2
#1
0.1µF
1.20
#1
0.90 ± 0.15
2.10 ± 0.15
2.54
0.64 ± 0.15
0.55
1.25 ± 0.10
[ SIDE VIEW ]
Pin#
1
2
3
4
5
6
2.20
#5
3.20 ± 0.15
#6
Function
Vcon
Tri-State
GND
Output
NC
VDD
0.85
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
3.3V
Parameter
Supply Voltage Variation (VDD)
Frequency Range
Standard Frequency
Absolute Pulling Range (APR)
Control Voltage Range
Supply Current 1.5 MHz
Fo < 20 MHz
20 MHz Fo < 50 MHz
Fo 170 MHz
50 MHz
Output Level
Output High (Logic"1")
Output Low (Logic"0")
Transition Time: Rise/Fall Time+
1.5 MHz Fo < 20 MHz
20 MHz Fo < 50 MHz
50 MHz Fo 170 MHz
Start Time
Tri-State (input to Pin 2)
Enable (High voltage or floating)
Disable (Low voltage or GND)
Linearity
Modulation Bandwidth (BW)
1.5 MHz
Fo
170 MHz
Input Impedance
Period Jitter (Pk-Pk)
RMS Phase Jitter (Integrated 12 kHz ~ 20 MHz)
Phase Noise@38.4 MHz
100 Hz
1 kHz
10 kHz
Aging (@ 25°C 1st year)
Storage Temp. Range
Min
Max.
VDD -5%
VDD+5%
1.5
170
19.44, 38.4
±50
0.3
_
3.0
10
_
_
_
V
MHz
ppm
V
mA
_
2.97
_
0.33
_
_
_
_
5
4
3
2
2.31
_
_
_
0.99
10
15
10000
_
_
_
_
40
1
-100
-133
-140
_
Unit
-55
V
nSec
mSec
V
kHz
kΩ
pSec
pSec
dBc/Hz
±3
125
ppm
°C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
+ Transition times are measured between 10% and 90% of VDD, with an output load of 15pF.
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
±25
±50
-10 ~ +60
-20 ~ +70
-40 ~ +85
-40 ~ +105
ż: Available Χ:Conditional X: Not available
* Inclusive of calibration @ 25 °C, operating temperature range, input
voltage variation, load variation, aging (1st year), shock, and vibration
Note: not all combination of options are available. Other specifications may be available upon request.
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(12)11/2019
67
VWEUPLJANF-38.400000 价格&库存
很抱歉,暂时无法提供与“VWEUPLJANF-38.400000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+27.399251+3.27560
- 10+26.0936810+3.11952
- 国内价格 香港价格
- 100+21.61643100+2.58426
