TXETDDSANF-12.800000
    TAITIEN(泰艺)
    SMD-4
    有源晶振 12.8MHz 2.8V~3.3V SMD-4
TXETDDSANF-12.800000 数据手册
TX Type 3.2 x 2.5 mm SMD Voltage Controlled Temperature ature Compensated Crystal Oscillator Actual Size FEATURE - Typical 3.2 x 2.5 x 0.9 mm SMD. - For automatic assembly. - Compactness and lightweight. - Low power consumption. - VCTCXO available. - Low thickness TYPICAL APPLICATION - GPS - WiMAX, WLAN - Mobile Phone RoHS Compliant DIMENSION (mm) SOLDER PAD LAYOUT (mm) [ BOTTOM VIEW ] [ TOP VIEW ] 0.1μF 2.30±0.15 3.20±0.15 1.70±0.15 2.50±0.15 #2 #2 #1 #1 1.80 #4 #3 0.90 #3 0.60±0.10 #4 Pin# 1 0.90±0.10 [ SIDE VIEW ] 0.25±0.04 0.70±0.10 2.40 Function Vcon:VC-TCXO GND / NC:TCXO GND Output VDD 2 3 4 1.00 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3 / 3.0 / 2.8 V Parameter Supply Voltage Variation (VDD) Frequency Range Standard Frequency Frequency Tolerance* Frequency stability Vs Supply Voltage (±5%) change Vs Load (±10%) change Vs Aging (@1st year) Supply Current 10 MHz Fo 26 MHz 26 MHz Fo 52 MHz Output Level (Clipped sine wave) Load Control Voltage Range (VCTCXO) Pulling Range (VCTCXO) Vc Input Impedance (VCTCXO) Phase Noise @ 19.2 MHz 1.8 V 2.5 V Min. Max. Min. Max. Min. Max. 2.66 3.465 2.375 2.625 1.71 1.89 10 52 10 52 10 52 10, 12.8, 13, 16.367667, 16.368, 16.369, 19.2, 19.44, 20, 25, 26, 27, 30 30.72, 32, 38.4 _ ±2.0 _ ±2.0 _ ±2.0 _ _ _ _ _ ±0.2 ±0.2 ±1.0 1.5 2.0 _ _ _ _ _ ±0.2 ±0.2 ±1.0 1.5 2.0 _ _ _ _ _ ±0.2 ±0.2 ±1.0 1.5 2.0 _ 100 Hz 1 kHz 10 kHz _ 0.8 10KΩ//10pF 0.5 2.5 _ ±5.0 _ 500 0.8 10KΩ//10pF 0.4 2.4 _ ±5.0 _ 500 0.8 10KΩ//10pF 0.3 1.5 _ ±5.0 _ 500 -115 -135 -148 -115 -135 -148 -115 -135 -148 _ Start time Storage Temp. Range _ _ 2 85 -40 -40 2 85 _ -40 Unit V MHz ppm ppm ppm mA Vp-p V ppm kΩ dBc/Hz 2 85 mSec °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. * Frequency at 25°C, 1 hour after reflow. FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm ±0.5 ±1.0 ±1.5 ±2.0 ±2.5 -20 ~ +70 -30 ~ +85 -40 ~ +85 * ○: Available Χ:Conditional X: Not available Note: not all combination of options are available. Other specifications may be available upon request. 6SHFL¿FDWLRQVVXEMHFWWRFKDQJHZLWKRXWQRWLFH www.taitien.com sales@taitien.com.tw Rev(14)01/2020 87
1. 物料型号: - 型号:3.2 x2.5 mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator(电压控制温度补偿晶体振荡器)。
2. 器件简介: - 符合AEC-Q20标准,3.2 x2.5 x0.9 mm SMD封装,适用于自动组装,具有紧凑和轻量的特点,低功耗。 - 可用VCTCXO(电压控制温度补偿晶体振荡器)。 - 典型应用包括GPS、WiMAX、WLAN和移动电话。
3. 引脚分配: - 1号引脚:Voon/VC-TCXO GND/NC:TCXO - 2号引脚:GND(地) - 3号引脚:Output(输出) - 4号引脚:VDD(电源)
4. 参数特性: - 供电电压变化范围:2.66V至3.465V。 - 频率范围:10MHz至52MHz。 - 标准频率:10, 12.8, 13, 16.367667, 16.368, 16.369, 19.2, 19.44, 20, 25, 26, 27, 30, 30.72, 32, 38.4 MHz。 - 频率容差:±2.0 ppm。 - 供电电压变化(5%)时的频率稳定性:±0.2 ppm。 - 负载变化(±10%)时的频率稳定性:±0.2 ppm。 - 老化(第一年)时的频率稳定性:±1.0 ppm。 - 供电电流:在10 MHz至26 MHz时为1 mA,在26 MHz至52 MHz时为1.5 mA。 - 输出电平(剪切正弦波):0.8 Vp-p。 - 控制电压范围(VCTCXO):0.5V至2.5V。 - 拉差范围(VCTCXO):±5.0 ppm。 - Vc输入阻抗(VCTCXO):500 kΩ。 - 100Hz相位噪声@19.2 MHz:1kHz处-115 dBc/Hz,10kHz处-135 dBc/Hz。
5. 功能详解: - 晶体设计用于特定频率,不意味着有库存位置。 - 频率稳定性与温度范围的关系:在-20至+70°C范围内为±0.5 ppm,在-30至+85°C范围内为±1.0 ppm,在-40至+85°C范围内为±1.5 ppm至±2.5 ppm。
6. 应用信息: - 适用于GPS、WiMAX、WLAN和移动电话等应用。
7. 封装信息: - 封装尺寸为3.2 x2.5 x0.9 mm,SMD封装,符合RoHS标准。
TXETDDSANF-12.800000 价格&库存
很抱歉,暂时无法提供与“TXETDDSANF-12.800000”相匹配的价格&库存,您可以联系我们找货
  • 500+15.41433500+1.98969
