OTJTGLLTNF-106.250000
    TAITIEN(泰艺)
    SMD7050_6P
    有源晶振 106.25MHz 2.5V -40℃~+85℃
OTJTGLLTNF-106.250000 数据手册
Actual Size OT Type 7.0 x 5.0 mm SMD LVPECL/LVDS/ HCSL Crystal Oscillator FEATURE - Conforms to AEC-Q200 - Typical 7.0 x 5.0 x 1.45 mm hermetically sealed ceramic package. - Very low jitter performance: typical 0.15 pS RMS from 12k-20MHz. - Fundamental/3rd overtone crystal design. RoHS Compliant - Output frequency up to 220 MHz. - Operating temperature up to 125。C - Tri-state enable/disable TYPICAL APPLICATION - 10Gbit Ethernet, Fiber Channel, Storage Area Network, SONET - Enterprise Servers, Reference clocks for ADC and DAC - Telecom OT multiplier DIMENSION (mm) SOLDER PAD L AYOUT (mm) [ TOP VIEW ] [ BOTTOM VIEW ] 5.08±0.20 7.00±0.20 #4 #4 #5 #6 5.08 #3 #3 #2 #1 0.1µF 1.40±0.20 1.45±0.15 0.6 Function NC/Tri-State Tri-State/NC GND Output Comp.output VDD Pin# 1 2 3 4 5 6 [ SIDE VIEW ] 4.00 #2 1.10±0.20 5.00±0.20 #1 2.00 #5 3.70±0.20 #6 1.80 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION LVPECL Parameter 3.3V 2.5V Unit Min. Max. Min. Max. VDD-10% VDD+10% VDD-5% VDD+5% V 13.5 220 13.5 220 MHz - 55 - 55 mA Output High 2.215 2.42 1.415 1.64 V Output Low 1.49 1.68 0.69 1.88 V - 0.6 - 0.6 nSec nSec Supply Voltage Variation (VDD) Frequency range Standard frequency 100, 125, 156.25 Power current consumption: MHz Output Level Rise Time Transition Time Fall Time Duty Cycle Start-up Time Tri-State - 0.6 - 0.6 45 55 45 55 % - 10 - 10 mSec Output Enable 0.7 x VDD - 0.7 x VDD - Output Disable - 0.3 x VDD - 0.3 x VDD - 10 - 10 Stand by Current V uA 50Ω, VDD-2V Output Loading Phase Noise @ VDD=3.3V 156.25MHz offset 10kHz Typ.: -143 Typ.: -145 dBc/Hz offset 100kHz Typ.: -151 Typ.: -154 dBc/Hz offset 1MHz Typ.: -155 Typ.: -155 dBc/Hz RMS Phase Jitter Integrated 12KHz to 20MHz @3.3V 13.5MHz ~ 80MHz - 1 - 1 pSec 80MHz ~ 220MHz - 0.3 - 0.3 pSec ±3 ppm Aging (@ 25oC, First Year) Storage Temp. Range ±3 -55 125 -55 125 C o Note: not all combination of options are available. Other specifications may be available upon request. 58 www.taitien.com sales@taitien.com.tw XO-0054 Rev(27) 06/2023
1. 物料型号:OT Type 7.0 x 5.0 mm SMD Differential Output Crystal Oscillator。
2. 器件简介: - 符合AEC-Q200标准。 - 行业标准的7.0 x 5.0 x 1.45mm密封陶瓷封装。 - 超低抖动性能:典型值12kHz至20MHz时为0.15ps RMS。 - 基频/三次谐波晶体设计,输出频率高达220MHz。
3. 引脚分配: - PIN#1:NC/Tri-State。 - PIN#2:Tri-State/NC。 - PIN#3:GND。 - PIN#4:Output。 - PIN#5:Comp.Output。 - PIN#6:VoD。
4. 参数特性: - 供电电压变化:3.3V,频率范围:2.5V。 - 标准频率:100, 125, 156.25 MHz(这些是晶体设计的标准频率,不意味着有库存)。 - 功耗:55 mA。 - 输出电平:高电平2.215V至2.42V,低电平1.49V至1.68V。 - 转换时间:上升时间0.6ns,下降时间0.6ns。 - 占空比:45%至55%。 - 启动时间:10ms。 - 三态使能:0.7xVD0,三态禁用:0.3xVpo。 - 待机电流:10μA。 - 输出负载:50Ω,Vop-2V,频率范围13.5MHz至80MHz和80MHz至220MHz。 - 均方根相位抖动:12kHz至20MHz@3.3V时为1ps至0.3ps。
5. 功能详解: - 为了确保最佳振荡器性能,应在VDD和GND焊盘之间尽可能靠近器件的位置放置一个0.1μF的旁路电容器。
6. 应用信息: - 10Gbit以太网、光纤通道、存储区域网络、SONET。 - 企业服务器、ADC和DAC的参考时钟、电信。
7. 封装信息:7.0 x 5.0 x 1.45mm密封陶瓷封装。
OTJTGLLTNF-106.250000 价格&库存
很抱歉,暂时无法提供与“OTJTGLLTNF-106.250000”相匹配的价格&库存,您可以联系我们找货
