OTJRGLVANF-312.500000
    TAITIEN(泰艺)
    SMD-6
    有源晶振 2.5V 312.5MHz SMD-6
OTJRGLVANF-312.500000 数据手册
OT Type 7.0 x 5.0 mm SMD LVPECL/LVDS/ HCSL Crystal Oscillator Actual Size FEATURE - Typical 7.0 x 5.0 x 1.45 mm hermetically sealed ceramic package. - Very low jitter performance: typical 0.3 pS RMS from 12k-20MHz. - Fundamental/3rd overtone crystal design. - Output frequency up to 320 MHz. - Operating temperature up to 125。C - Tri-state enable/disable RoHS Compliant TYPICAL APPLICATION - 10Gbit Ethernet, Fiber Channel, Storage Area Network, SONET - Enterprise Servers, Reference clocks for ADC and DAC - Telecom OT multiplier SOLDER PAD L AYOUT (mm) DIMENSION (mm) [ TOP VIEW ] [ BOTTOM VIEW ] 5.08±0.20 #4 #4 #5 #6 5.08 #2 #3 #3 #2 1.10±0.20 5.00±0.20 #1 #1 0.1µF 1.40±0.20 0.6 1.45±0.15 [ SIDE VIEW ] Pin# 1 2 3 4 5 6 4.00 #5 3.70±0.20 #6 2.00 7.00±0.20 Function NC/Tri-State Tri-State/NC GND Output Comp.output VDD 1.80 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION Parameter Supply Voltage Variation (VDD) Frequency Range Standard Frequency Supply Current 10 MHz Fo < 160 MHz 160 MHz Fo < 250 MHz 250 MHz Fo 320 MHz Output High Output Level Output Low Transition Time: Rise/Fall Time+ Start Time Tri-State(Input to Pin 2 or Pin 1) Enable (High voltage or floating) Disable (Low voltage or GND) RMS Phase Jitter (Integrated 12 KHz ~ 20 MHz) Fo < 80 MHz 80 MHz Fo
1. 物料型号:OT Type 7.0 x 5.0 mm SMD Differential Output Crystal Oscillator。
2. 器件简介: - 符合AEC-Q200标准。 - 行业标准的7.0 x 5.0 x 1.45mm密封陶瓷封装。 - 超低抖动性能:典型值12kHz至20MHz时为0.15ps RMS。 - 基频/三次谐波晶体设计,输出频率高达220MHz。
3. 引脚分配: - PIN#1:NC/Tri-State。 - PIN#2:Tri-State/NC。 - PIN#3:GND。 - PIN#4:Output。 - PIN#5:Comp.Output。 - PIN#6:VoD。
4. 参数特性: - 供电电压变化:3.3V,频率范围:2.5V。 - 标准频率:100, 125, 156.25 MHz(这些是晶体设计的标准频率,不意味着有库存)。 - 功耗:55 mA。 - 输出电平:高电平2.215V至2.42V,低电平1.49V至1.68V。 - 转换时间:上升时间0.6ns,下降时间0.6ns。 - 占空比:45%至55%。 - 启动时间:10ms。 - 三态使能:0.7xVD0,三态禁用:0.3xVpo。 - 待机电流:10μA。 - 输出负载:50Ω,Vop-2V,频率范围13.5MHz至80MHz和80MHz至220MHz。 - 均方根相位抖动:12kHz至20MHz@3.3V时为1ps至0.3ps。
5. 功能详解: - 为了确保最佳振荡器性能,应在VDD和GND焊盘之间尽可能靠近器件的位置放置一个0.1μF的旁路电容器。
6. 应用信息: - 10Gbit以太网、光纤通道、存储区域网络、SONET。 - 企业服务器、ADC和DAC的参考时钟、电信。
7. 封装信息:7.0 x 5.0 x 1.45mm密封陶瓷封装。
OTJRGLVANF-312.500000 价格&库存
很抱歉,暂时无法提供与“OTJRGLVANF-312.500000”相匹配的价格&库存,您可以联系我们找货
