OTETDLLTNF-156.253906 数据手册
OT Type
7.0 x 5.0 mm SMD LVPECL/LVDS/
HCSL Crystal Oscillator
Actual Size
FEATURE
- Typical 7.0 x 5.0 x 1.45 mm hermetically sealed ceramic package.
- Very low jitter performance: typical 0.3 pS RMS from 12k-20MHz.
- Fundamental/3rd overtone crystal design.
- Output frequency up to 320 MHz.
- Operating temperature up to 125。C
- Tri-state enable/disable
RoHS Compliant
TYPICAL APPLICATION
- 10Gbit Ethernet, Fiber Channel, Storage Area Network, SONET
- Enterprise Servers, Reference clocks for ADC and DAC
- Telecom
OT multiplier
SOLDER PAD L AYOUT (mm)
DIMENSION (mm)
[ TOP VIEW ]
[ BOTTOM VIEW ]
5.08±0.20
#4
#4
#5
#6
5.08
#2
#3
#3
#2
1.10±0.20
5.00±0.20
#1
#1
0.1µF
1.40±0.20
0.6
1.45±0.15
[ SIDE VIEW ]
Pin#
1
2
3
4
5
6
4.00
#5
3.70±0.20
#6
2.00
7.00±0.20
Function
NC/Tri-State
Tri-State/NC
GND
Output
Comp.output
VDD
1.80
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
Parameter
Supply Voltage Variation (VDD)
Frequency Range
Standard Frequency
Supply Current
10 MHz Fo < 160 MHz
160 MHz Fo < 250 MHz
250 MHz Fo 320 MHz
Output High
Output Level
Output Low
Transition Time: Rise/Fall Time+
Start Time
Tri-State(Input to Pin 2 or Pin 1)
Enable (High voltage or floating)
Disable (Low voltage or GND)
RMS Phase Jitter (Integrated 12 KHz ~ 20 MHz)
Fo < 80 MHz
80 MHz Fo
OTETDLLTNF-156.253906 价格&库存
很抱歉,暂时无法提供与“OTETDLLTNF-156.253906”相匹配的价格&库存,您可以联系我们找货
