OWJRGLVANF-200.000000
    TAITIEN(泰艺)
    SMD5032_6P
    有源晶振 200MHz 2.5V -40℃~+85℃
OWJRGLVANF-200.000000 数据手册
OW-M Type 5.0 x 3.2 mm SMD LVPECL/LVDS Crystal Oscillator Actual Size FEATURE - Industry Standard 5.0 x 3.2 x 1.25 hermetically sealed ceramic package - Very low phase jitter: 0.6 ps, typ. RMS - Tri-state enable/disable - Fast delivery TYPICAL APPLICATION RoHS Compliant High-Speed Gigabit Ethernet, Fiber Channel, Storage Area Network, SONET Enterprise Server, SAS/SATA Microprocessors/DSP/FPGA Broadband Access Smart Grid DIMENSION (mm) SOLDER PAD L AYOUT (mm) [ TOP VIEW ] [ BOTTOM VIEW ] 2.54 ± 0.15 #1 #2 #3 #6 #2 #1 2.54 0.1µF 0.64 ± 0.15 1.25 ± 0.10 0.55 [ SIDE VIEW ] #3 #5 Pin# 1 2 3 4 5 6 1.20 #4 #4 0.90 ± 0.15 #5 3.20 ± 0.15 #6 2.10 ± 0.15 5.00 ± 0.15 2.10 - Function 0.90 NC/Tri-State Tri-State/NC GND Output To ensure optimal oscillator performance, place a by-pass capacitor of 0.1µF as close to the part as possible between Vdd and GND pads. Comp. Output VDD ELECTRICAL SPECIFICATION 1.2 1.2 1.2 1.2 FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm -10 ~ +60 -20 ~ +70 -40 ~ +85 -40 ~ +105 ±25 ±50 * ○: Available △:Conditional X: Not available * Inclusive of calibration @ 25 °C, operating temperature range, input voltage variation, load variation, aging (1st year), shock, and vibration Note: not all combination of options are available. Other specifications may be available upon request. www.taitien.com sales@taitien.com.tw Rev(14) 11/2022 61
物料型号: - 型号:OW-M
器件简介: - 该器件是一个5.0 x 3.2 x 1.25mm的工业标准尺寸的密封陶瓷封装差分输出晶体振荡器。
引脚分配: - 引脚1:Tri-State/NC - 引脚2:NC/Tri-State - 引脚3:GND - 引脚4:Output - 引脚5:Comp.Output - 引脚6:VoD
参数特性: - 供电电压变化:Vcc±5% - 频率范围:10 MHz至1500 MHz - 标准频率:106.25, 125, 133.33, 150, 155.52, 156.25, 187.5, 212.5, 312.5, 622.08 MHz - 供电电流:10MHz至1500MHz时为50mA - 输出电平:高电平2.275V,低电平1.68V(LVPECL);高电平1.475V,低电平0.88V(LVDS) - 转换时间(上升/下降时间):1.0ns - 启动时间:10ms - 相位抖动:1.2ps(12kHz至20MHz) - 相位噪声:-105dBc/Hz(1kHz偏移),-115dBc/Hz(10kHz偏移) - 老化率:每年+3ppm - 存储温度范围:-55℃至125℃
功能详解: - 该振荡器提供了超低抖动性能,典型值在12kHz至20MHz时为0.6ps RMS。 - 为了确保最佳振荡器性能,应在VDD和GND引脚之间尽可能靠近器件放置一个0.1μF的旁路电容器。
应用信息: - 典型应用包括高速千兆以太网、光纤通道、存储区域网络、SONET、企业级服务器SAS/SATA、微处理器/DSP/FPGA、宽带接入和智能电网。
封装信息: - 封装类型:5.0 x 3.2 x 1.25mm密封陶瓷封装。
OWJRGLVANF-200.000000 价格&库存
很抱歉,暂时无法提供与“OWJRGLVANF-200.000000”相匹配的价格&库存,您可以联系我们找货
