NI-100M-2900
NI-100M-2900
    TAITIEN(泰艺)
    DIP-5
    有源晶振 12V 100MHz DIP-5
NI-100M-2900 数据手册
Our Performance Your Reputation Oven Controlled Crystal Oscillator NI-100 MHz-2900 series 2900 Series in 36.3x27.2mm DIP package NI-100M-2900 series is a 100.000 MHz high performance (VC)OCXO offering Low Phase Noise, low G sensitivity(LGS) and tight frequency stability down to ±50ppb(-30ºC to +70ºC). The part comes in a small hermetically sealed through hole package which makes it suitable for humid environmental conditions. FEATURES RoHS Compliant Standard APPLICATIONS Low Phase Noise & Low G-Sensitivity Instrument Reference Hermetically Sealed Package Microwave / Satellite Communication Tight Frequency Stability Clock Reference for Microwave Signal Source Low Power Consumption Test & Measurement Fast Warm-up Time Telecom Systems Electrical Frequency Tuning Input Radar Systems Reference Voltage Output Medical (MRT) RoHS-Compliant (lead-free) ELECTRICAL SPECIFICATIONS 1. OUTPUT (PIN = “R.F. OUTPUT”) Parameter 1.1. Min. Frequency Typ. Max. 100.000 Unit Test Condition MHz @ +25 ±1°C 1.2. Initial Accuracy -0.2 +0.2 ppm after turn on power 30 ±5 minutes ≤ 90 days following date code VCO Input at +4 ±0.001V 1.3. Waveform 1.4. Level 1.5. Load 1.6. 1.7. Sine wave +7 +9 +11 dBm Harmonics -30 dBc Spurious -70 dBc 50 Ω http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Rev(4)07/2018 Page 1of 4 Our Performance Your Reputation 2. FREQUENCY STABILITY Parameter 2.1. Min. Typ. Max. Unit Test Condition Ambient -50 +50 ppb -30°C ~ +70°C Aging -3 +3 ppb per day, at time of shipment after 30 days Daily -3 +3 ppb Yearly -0.3 +0.3 ppm 10 Years 2.2. referenced to 25°C -1.2 +1.2 ppm 2.3. Voltage -20 +20 ppb ±5% change 2.4. Load -50 +50 ppb ±5% change 2.5. Warm-up -0.1 +0.1 ppm in 10 minutes @ +25 ±1°C Option A 2.6. 2.7. 3. Phase Noise -90 dBc/Hz @ 10Hz -120 dBc/Hz @ 100Hz -150 G-Sensitivity (each axis) @ 1KHz dBc/Hz @ 10KHz -160 dBc/Hz @ 100KHz ppb/g 10 ~ 700Hz. 0.5 Tuning Range Min. 1.5 Typ. Refer to Table 1 : Ordering Information Max. Unit -1.5 ppm VCO @ 0V ppm VCO @ 8V +1.5 3.2. Control Voltage 3.3. Slope 3.4. Center Voltage 3.5. Linearity -10 3.6. Input Impedance 25 4. dBc/Hz -155 ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”) Parameter 3.1. -85 -115 -145 0 +8 Test Condition Positive +4 V +10 Note 1 % kΩ INPUT POWER (PIN = “+VDC”) Min. Typ. Max. 4.1. Voltage +11.4 +12 +12.6 V 4.2. Current 350 mA @ turn on 4.3. Steady State 1.5 W @ +25°C 1 Unit Min. Typ. Max. Units 5.1. Voltage +7.6 +8.0 +8.4 V 5.2. Load 6. Test Condition REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE") Parameter 5.3. Referenced to frequency at nominal Center Voltage V Parameter 5. referenced to 1 hour Refer to Table 1 : Ordering Information Option B Temperature stability 9 -0.02 kΩ +0.02 Test Condition Over temperature range in 2.1. V ENVIRONMENTAL Parameter 6.1. Operating Temperature 6.2. Storage Temperature Reference Std. -40°C to +85°C Test Condition Note 2 -55°C to +105°C 6.3. Humidity MIL-STD-202, Method 103 Test Condition A 6.4. Vibration (non-operating) MIL-STD-202, Method 201 95% RH @ +40°C,non-condensing,240 hours 0.06” Total p-p, 10 to 55 Hz MIL-STD-202, Method 213, 6.5. Shock (non-operating) 30g, 11ms, half-sine Test Condition J Note 1. When not connected, VCO INPUT is internally held at this voltage. Note 2. Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the temperature range in 2.1. Rev(4)07/2018 http://www.taitien.com E-Mail: sales@taitien.com.tw Page 2of 4 Specifications subject to change without notice Our Performance Your Reputation Table 1 : ORDERING INFORMATION Phase Noise Option A Option B TAITIEN P/N NI-100M-2900 NI-100M-2901 Phase Noise Test Data G-Sensitivity Test Data http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Rev(4)07/2018 Page 3of 4 Our Performance Your Reputation OUTLINE DRAWING http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Rev(4)07/2018 Page 4of 4
NI-100M-2900 价格&库存
很抱歉,暂时无法提供与“NI-100M-2900”相匹配的价格&库存,您可以联系我们找货
