TSEABCSANF-25.000000
    TAITIEN(泰艺)
    SMD-10
    有源晶振 25MHz 2.8V~3.3V SMD-10
TSEABCSANF-25.000000 数据手册
TS Type High Precision 7.0 x 5.0 mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator Actual Size FEATURE - Typical 7.0 x 5.0 x 1.9 mm ceramic SMD package. - High Precision for -40ºC~+85ºC, ±0.28ppm - CMOS and Clipped Sine wave (without DC-cut capacitor) output optional. TYPICAL APPLICATION - Femtocell, Base Stations - WLAN / WiMAX / WiFi, Wireless Communications - Mobile Phone RoHS Compliant SOLDER PAD L AYOUT (mm) #2 #3 #10 #4 #3 [ SIDE VIEW ] #2 #1 10 0.7±0.12 1.90±0.20 0.90±0.15 0.60±0.15 6.00 4.30 Function NC NC NC GND Output NC NC Tri-State/NC VDD Vcon:VC-TCXO GND/NC:TCXO 1.00 0.1µF 1.40 0.06 0.80±0.15 #4 #1 #9 1 2 3 4 5 6 7 8 9 0.80±0.15 #10 #5 0.80±0.15 #5 4.00±0.15 2.54±0.15 5.00±0.20 #9 Pin# 0.80±0.15 5.90±0.15 2.54±0.15 #6 #7 #8 7.00±0.20 #8 #7 #6 1.20 [ B O T T O M V IE W ] [ TO P VIEW ] 2.54 DIMENSION (mm) 1.40 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 2.5V 3.3V Min. Max. Min. Max. VDD+5% VDD+5% VDD-5% VDD-5% 5 52 5 52 5, 6.4, 8, 8.192, 10, 12.5, 12.8, 16, 16.384, 19.44, 25 8.192, 10, 12.5, 12.8, 16, 16.384, 19.44, 25 ±2.0 ±2.0 Parameter Supply Voltage Variation (VDD) Frequency Range Standard Frequency (for CMOS) Standard Frequency (for Clipped Sine Wave) Frequency Tolerance* Frequency Stability Vs Supply Voltage (±5%) change ±0.5 ±0.5 Vs Load (±10%) change ±0.2 ±0.2 Vs Aging ±1.0 ±1.0 Supply Current (CMOS output) 8 8 Supply Current (Clipped Sine Wave) 5 5 Output Level (CMOS) Output Low (Logic“1”) 90%VDD 90%VDD Output Low (Logic“0”) 10%VDD 10%VDD Duty 45 55 45 55 Output Level (Clipped Sine Wave) 0.8 0.8 Load (CMOS) 15pF 15pF Load (Clipped Sine Wave) 10 KΩ // 10pF 10 KΩ // 10pF Control Voltage Range (VCTCXO) 0.5 2.5 0.5 2.5 Pulling Range (VCTCXO) ±5.0 ±12.0 ±5.0 ±12.0 Vc Input Impedance (VCTCXO) 100 100 Phase Noise @ 19.2MHz 100 Hz -120 -120 1 KHz -140 -140 10 KHz -148 -148 Start Time 5 5 Tri-State Disable 1.5 0.99 Enable 3.5 2.31 Storage Temp. Range -55 125 -55 125 Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position o *Frequency at 25 C, 1 hour after reflow Unit V MHz ppm ppm ppm ppm mA V % Vp-p V ppm KΩ dBc / Hz mSec V o C FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm ±0.05 ±0.1 ±0.14 ±0.2 ±0.28 ±0.5 ±2 -10 ~ +70 -20 ~ +70 -40 ~ +85 -40 ~ +95 -40 ~ +105 * ○: Available △:Conditional X: Not available Note: not all combination of options are available. Other specifications may be available upon request. 104 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(16) 07/2022
TSEABCSANF-25.000000 价格&库存
很抱歉,暂时无法提供与“TSEABCSANF-25.000000”相匹配的价格&库存,您可以联系我们找货
