TSEAALJANF-12.800000 数据手册
TS Type High Precision
7.0 x 5.0 mm SMD Voltage Controlled
Temperature Compensated Crystal Oscillator
Actual Size
FEATURE
- Typical 7.0 x 5.0 x 1.9 mm ceramic SMD package.
- High Precision for -40ºC~+85ºC, ±0.28ppm
- CMOS and Clipped Sine wave (without DC-cut capacitor) output optional.
TYPICAL APPLICATION
- Femtocell, Base Stations
- WLAN / WiMAX / WiFi, Wireless Communications
- Mobile Phone
RoHS Compliant
SOLDER PAD L AYOUT (mm)
#2 #3
#10
#4
#3
[ SIDE VIEW ]
#2 #1
10
0.7±0.12
1.90±0.20
0.90±0.15 0.60±0.15
6.00
4.30
Function
NC
NC
NC
GND
Output
NC
NC
Tri-State/NC
VDD
Vcon:VC-TCXO
GND/NC:TCXO
1.00
0.1µF
1.40
0.06
0.80±0.15
#4
#1
#9
1
2
3
4
5
6
7
8
9
0.80±0.15
#10
#5
0.80±0.15
#5
4.00±0.15
2.54±0.15
5.00±0.20
#9
Pin#
0.80±0.15
5.90±0.15
2.54±0.15
#6
#7
#8
7.00±0.20
#8 #7 #6
1.20
[ B O T T O M V IE W ]
[ TO P VIEW ]
2.54
DIMENSION (mm)
1.40
To ensure optimal oscillator performance, place a
by-pass capacitor of 0.1μF as close to the part as
possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
2.5V
3.3V
Min.
Max.
Min.
Max.
VDD+5%
VDD+5%
VDD-5%
VDD-5%
5
52
5
52
5, 6.4, 8, 8.192, 10, 12.5, 12.8, 16, 16.384, 19.44, 25
±2.0
±2.0
Parameter
Supply Voltage Variation (VDD)
Frequency Range
Standard Frequency (for CMOS)
Standard Frequency (for Clipped Sine Wave)
Frequency Tolerance*
Frequency Stability
Vs Supply Voltage (±5%) change
±0.5
±0.5
Vs Load (±10%) change
±0.2
±0.2
Vs Aging
±1.0
±1.0
Supply Current (CMOS output)
8
8
Supply Current (Clipped Sine Wave)
5
5
Output Level (CMOS)
Output Low (Logic“1”)
90%VDD
90%VDD
Output Low (Logic“0”)
10%VDD
10%VDD
Duty
45
55
45
55
Output Level (Clipped Sine Wave)
0.8
0.8
Load (CMOS)
15pF
15pF
Load (Clipped Sine Wave)
10 KΩ // 10pF
10 KΩ // 10pF
Control Voltage Range (VCTCXO)
0.5
2.5
0.5
2.5
Pulling Range (VCTCXO)
±5.0
±12.0
±5.0
±12.0
Vc Input Impedance (VCTCXO)
100
100
Phase Noise @ 19.2MHz
100 Hz
-120
-120
1 KHz
-140
-140
10 KHz
-148
-148
Start Time
5
5
Tri-State
Disable
1.5
0.99
Enable
3.5
2.31
Storage Temp. Range
-55
125
-55
125
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position
o
*Frequency at 25 C, 1 hour after reflow
Unit
V
MHz
ppm
ppm
ppm
ppm
mA
V
Vp-p
V
ppm
KΩ
dBc / Hz
mSec
V
o
C
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
±0.05
±0.1
±0.14
±0.2
±0.28
±0.5
±2
-10 ~ +70
-20 ~ +70
-40 ~ +85
-40 ~ +95
-40 ~ +105
○: Available △:Conditional X: Not available
Note: not all combination of options are available. Other specifications may be available upon request.
104
Rev(16) 07/2022
TSEAALJANF-12.800000 价格&库存
很抱歉,暂时无法提供与“TSEAALJANF-12.800000”相匹配的价格&库存,您可以联系我们找货
