VTEUPLLANF-125.000000 数据手册
VT Type
7.0 x 5.0 mm SMD LVPECL/LVDS Voltage
Controlled Crystal Oscillator
Actual Size
FEATURE
- Typical 7.0 x 5.0 x 1.75 mm 6 pads ceramic SMD package.
- Very low jitter performance: typical 0.3 pS RMS from 12k-20MHz.
- Wide frequency control range.
- Complementary Output.
- Tri-state enable/disable
TYPICAL APPLICATION
- Set-top Box, HDTV
- xDSL/ VoIP, Cable modem
- WiMAX/WLAN
VTADC
Type PECL
- Jitter Attenuator,
DIMENSION
[ TOP VIEW ] (mm)
[ BOTTOM VIEW ]
Pin#
1.40±0.20
0.650.65
1.75±0.15
1.75±0.15
[ SIDE VIEW ]
[ SIDE VIEW ]
Pin#1
1 2
2 3
3 4
4 5
5 6
6
#1
#1
0.1µF
4.00
#2
0.1µF
Function
Vcon
Function
Tri-State
Vcon
GND
Tri-State
Output
GND
Comp.Output
Output
Comp.Output
VDD
VDD
4.00
#3
1.40±0.20
#3
#2
2.00
#3
#3
2.00
#2
#2
5.08
5.08
1.27±0.20
#1
#1
SOLDER PAD L AYOUT (mm)
1.27±0.20
#5
#4
7.00±0.20
#5
#4
3.81±0.20
3.81±0.20
5.00±0.20
5.00±0.20
#6
VT Type PECL
5.08±0.20
[ BOTTOM VIEW ]
#4
#5
#6
5.08±0.20
#4
#5
#6
[ TOP VIEW ] 7.00±0.20
#6
RoHS Compliant
1.80
1.80
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close
to the
part as performance,
possible between
and GND
pads.of 0.1μF
To ensure
optimal
oscillator
place Vdd
a by-pass
capacitor
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
LVDS
LVPECL
Parameter
Supply Voltage Variation (VDD)
Frequency Range
Standard Frequency
Absolute Pulling Range (APR)
Control Voltage Range
Supply Current 1.5 MHz Fo < 65 MHz
65 MHz Fo 200 MHz
Output Level
Output High
Output Low
Transition Time: Rise/Fall Time+
Start Time
Tri-State (input to Pin 2, Enable High )
Enable (High voltage or floating)
Disable (Low voltage or GND)
Linearity
Modulation Bandwidth (BW)
Input Impedance
RMS Phase Jitter (Integrated 12kHz~20MHz)
Fo <100 MHz
100 MHz
Fo < 125 MHz
125 MHz
Fo < 150 MHz
150 MHz
Fo
Phase Noise@153.6 MHz 100 Hz
1 kHz
10 kHz
2.5V
2.5V
Min.
Max.
Max.
Min.
Max.
Min.
Max.
Min.
VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5%
1.5
200
65
200
1.5
200
65
200
77.76, 106.25, 122.88, 125, 155.52, 156.25, 200
_
_
_
_
±50
±50
±50
±50
0.3
3.0
0.3
3.0
_
_
_
_
75
75
45
45
_
_
_
_
100
100
80
80
_
_
_
_
2.275
1.475
1.6
1.6
_
_
_
_
1.68
1.095
0.9
0.9
_
_
_
_
1.0
1.0
1.0
1.0
_
_
_
_
3
3
3
3
3.3 V
_
2.31
_
_
0.99
10
_
_
15
10000
_
_
_
_
_
Aging (@ 25°C 1st year)
Storage Temp. Range
1
0.7
0.5
0.3
-85
-115
-130
±3
125
-55
_
1.75
_
_
0.75
10
15
10000
_
_
_
_
_
-55
3.3 V
_
_
1
0.7
0.5
0.3
-85
-115
-130
±3
125
_
2.31
_
_
0.99
10
_
_
15
10000
_
_
_
_
_
-55
1
0.7
0.5
0.3
-85
-115
-130
±3
125
_
1.75
_
_
0.75
10
15
10000
_
_
_
_
_
-55
Unit
V
MHz
ppm
V
mA
V
nSec
mSec
V
_
_
kHz
kΩ
1
0.7
0.5
0.3
pSec
-85
-115
-130
dBc/Hz
±3
125
ppm
°C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
+ Transition times are measured between 20% and 80% of VDD.
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
-10 ~ +60
-20 ~ +70
-40 ~ +85
±25
±50
○: Available △:Conditional X: Not available
* Inclusive of calibration @ 25 °C, operating temperature range, input
voltage variation, load variation, aging (1st year), shock, and vibration
Note: not all combination of options are available. Other specifications may be available upon request.
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(20)09/2019
73
VTEUPLLANF-125.000000 价格&库存
很抱歉,暂时无法提供与“VTEUPLLANF-125.000000”相匹配的价格&库存,您可以联系我们找货
