VTEUPCLANF-155.520000
    TAITIEN(泰艺)
    SMD-6
    有源晶振 3.3V 155.52MHz SMD-6
VTEUPCLANF-155.520000 数据手册
VT Type 7.0 x 5.0 mm SMD LVPECL/LVDS Voltage Controlled Crystal Oscillator Actual Size FEATURE - Typical 7.0 x 5.0 x 1.75 mm 6 pads ceramic SMD package. - Very low jitter performance: typical 0.3 pS RMS from 12k-20MHz. - Wide frequency control range. - Complementary Output. - Tri-state enable/disable TYPICAL APPLICATION - Set-top Box, HDTV - xDSL/ VoIP, Cable modem - WiMAX/WLAN VTADC Type PECL - Jitter Attenuator, DIMENSION [ TOP VIEW ] (mm) [ BOTTOM VIEW ] Pin# 1.40±0.20 0.650.65 1.75±0.15 1.75±0.15 [ SIDE VIEW ] [ SIDE VIEW ] Pin#1 1 2 2 3 3 4 4 5 5 6 6 #1 #1 0.1µF 4.00 #2 0.1µF Function Vcon Function Tri-State Vcon GND Tri-State Output GND Comp.Output Output Comp.Output VDD VDD 4.00 #3 1.40±0.20 #3 #2 2.00 #3 #3 2.00 #2 #2 5.08 5.08 1.27±0.20 #1 #1 SOLDER PAD L AYOUT (mm) 1.27±0.20 #5 #4 7.00±0.20 #5 #4 3.81±0.20 3.81±0.20 5.00±0.20 5.00±0.20 #6 VT Type PECL 5.08±0.20 [ BOTTOM VIEW ] #4 #5 #6 5.08±0.20 #4 #5 #6 [ TOP VIEW ] 7.00±0.20 #6 RoHS Compliant 1.80 1.80 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as performance, possible between and GND pads.of 0.1μF To ensure optimal oscillator place Vdd a by-pass capacitor as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION LVDS LVPECL Parameter Supply Voltage Variation (VDD) Frequency Range Standard Frequency Absolute Pulling Range (APR) Control Voltage Range Supply Current 1.5 MHz Fo < 65 MHz 65 MHz Fo 200 MHz Output Level Output High Output Low Transition Time: Rise/Fall Time+ Start Time Tri-State (input to Pin 2, Enable High ) Enable (High voltage or floating) Disable (Low voltage or GND) Linearity Modulation Bandwidth (BW) Input Impedance RMS Phase Jitter (Integrated 12kHz~20MHz) Fo <100 MHz 100 MHz Fo < 125 MHz 125 MHz Fo < 150 MHz 150 MHz Fo Phase Noise@153.6 MHz 100 Hz 1 kHz 10 kHz 2.5V 2.5V Min. Max. Max. Min. Max. Min. Max. Min. VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5% 1.5 200 65 200 1.5 200 65 200 77.76, 106.25, 122.88, 125, 155.52, 156.25, 200 _ _ _ _ ±50 ±50 ±50 ±50 0.3 3.0 0 2.5 0.3 3.0 0 2.5 _ _ _ _ 75 75 45 45 _ _ _ _ 100 100 80 80 _ _ _ _ 2.275 1.475 1.6 1.6 _ _ _ _ 1.68 1.095 0.9 0.9 _ _ _ _ 1.0 1.0 1.0 1.0 _ _ _ _ 3 3 3 3 3.3 V _ 2.31 _ _ 0.99 10 _ _ 15 10000 _ _ _ _ _ Aging (@ 25°C 1st year) Storage Temp. Range 1 0.7 0.5 0.3 -85 -115 -130 ±3 125 -55 _ 1.75 _ _ 0.75 10 15 10000 _ _ _ _ _ -55 3.3 V _ _ 1 0.7 0.5 0.3 -85 -115 -130 ±3 125 _ 2.31 _ _ 0.99 10 _ _ 15 10000 _ _ _ _ _ -55 1 0.7 0.5 0.3 -85 -115 -130 ±3 125 _ 1.75 _ _ 0.75 10 15 10000 _ _ _ _ _ -55 Unit V MHz ppm V mA V nSec mSec V _ _ % kHz kΩ 1 0.7 0.5 0.3 pSec -85 -115 -130 dBc/Hz ±3 125 ppm °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. + Transition times are measured between 20% and 80% of VDD. FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm -10 ~ +60 -20 ~ +70 -40 ~ +85 ±25 ±50 * ○: Available △:Conditional X: Not available * Inclusive of calibration @ 25 °C, operating temperature range, input voltage variation, load variation, aging (1st year), shock, and vibration Note: not all combination of options are available. Other specifications may be available upon request. Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(20)09/2019 73
VTEUPCLANF-155.520000 价格&库存
很抱歉,暂时无法提供与“VTEUPCLANF-155.520000”相匹配的价格&库存,您可以联系我们找货
