TTETKLSANF-10.000000
    TAITIEN(泰艺)
    SMD7050_4P_EP
    有源晶振 10MHz SMD7050_4P_EP 2.8V~3.3V
TTETKLSANF-10.000000 数据手册
TT Type High Precision 7.0 x 5.0 mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator Actual Size FEATURE - Typical 7.0 x 5.0 x 1.9 mm ceramic SMD package. - High Precision for -40ºC ~ +85ºC, ±0.28ppm , -40ºC ~ +105ºC ,±2ppm. - CMOS and Clipped Sine wave (without DC-cut capacitor) output optional. TYPICAL APPLICATION - Femtocell , Base Stations - WLAN/WiMAX/WIFI, Wireless Communications RoHS Compliant DIMENSION (mm) SOLDER PAD L AYOUT (mm) [TOP VIEW] [BOTTOM VIEW] 7.00±0.20 5.08±0.15 #3 4.00±0.15 #2 #2 #1 1.40±0.15 [SIDE VIEW] Pin# 0.7±0.12 1.90±0.20 1 2 3 4 4.20 0.1µF 0.80±0.15 #1 5.08 #4 1.20 #3 5.00±0.20 #4 Function 1.50 Vcon:VC-TCXO GND/NC:TCXO GND OUTPUT VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 2.5V Parameter Min. VDD-5% 5 Supply Voltage Variation (VDD) Frequency Range Standard Frequency _ Frequency Tolerance* Frequency Stability Vs Supply Voltage (±5%) change Vs Load (±10%) change Vs Aging (@1st year) Output Level (CMOS) Output High (Logic “1”) Output Low (Logic “0”) Duty ±0.1 ±0.05 ±1.0 8 5 _ 90%VDD _ _ _ _ _ _ ±0.05 ±0.05 ±1.0 8 90%VDD _ 15pF 10 KΩ // 10pF 100 Hz 1 kHz 10 kHz _ 0.5 ±5.0 100 _ _ -130 -145 -154 5 -55 10%VDD 55 Unit V MHz ppm ppm ppm / year mA V % Vp-p 15pF 10 KΩ // 10pF 2.5 _ Start time Storage Temp. Range 5 45 0.8 _ 0.5 ±5.0 100 ±2.0 _ 10%VDD 55 45 0.8 Output Level (Clipped Sine Wave) Max. VDD+5% 52 _ ±2.0 _ _ _ _ _ Supply Current (CMOS output) Supply Current (Clipped Sine Wave) Load (CMOS) Load (Clipped Sine Wave) Control Voltage Range (VCTCXO) Pulling Range (VCTCXO) Vc Input Impedance (VCTCXO) Phase Noise @ 10 MHz 3.3V Max. Min. VDD+5% VDD-5% 52 5 10, 12.8, 16.384, 19.2, 19.44, 20, 25, 26 125 2.5 _ _ V ppm kΩ dBc/Hz _ -55 5 mSec 125 °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. * Frequency at 25°C, 1 hour after reflow. FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm ±0.05 ±0.1 ±0.14 ±0.2 ±0.28 ±0.5 ±2 -10 ~ +70 -20 ~ +70 -40 ~ +85 -40 ~ +95 -40 ~ +105 * ○: Available △:Conditional X: Not available Note: not all combination of options are available. Other specifications may be available upon request. 100 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(15) 07/2022
PDF文档中包含的物料型号为TT型高精度7.0 x 5.0 mm SMD电压控制温度补偿晶体振荡器。
器件简介指出其具有高精准度,适用于-40°C至+85°C的温度范围,精度为±0.28ppm,以及-40°C至+105°C的温度范围,精度为±2ppm。
引脚分配包括Vcon:VC-TCXO、GND/NC:TCXO GND和OUTPUT。
参数特性包括供电电压变化、频率范围、标准频率、频率容差、频率稳定性、供电电流、输出电平、负载、控制电压范围、拉取范围、Vc输入阻抗和相位噪声。
功能详解强调了其高精度和温度补偿功能,以及CMOS和裁剪正弦波(无直流阻断电容)输出的可选性。
应用信息涉及飞蜂窝、基站、WLAN/WiMAX/WIFI和无线通信。
封装信息为7.0 x 5.0 x 1.9 mm的典型尺寸,且符合RoHS标准。
TTETKLSANF-10.000000 价格&库存
很抱歉,暂时无法提供与“TTETKLSANF-10.000000”相匹配的价格&库存,您可以联系我们找货
  • 1+266.291971+34.37304
