TTETTCJANF-25.000000 数据手册
TT Type < for Stratum 3 >
7.0 x 5.0 mm SMD Voltage Controlled Temperature
Compensated Crystal Oscillator
Actual Size
FEATURE
- Typical 7.0 x 5.0 x 1.9 mm ceramic SMD package.
- Stratum 3 (Overall ±4.6ppm including 20 years aging.)
- CMOS and Clipped Sine wave (without DC-cut capacitor) output optional.
TYPICAL APPLICATION
- Stratum 3
- Femtocell, Base Stations
RoHS Compliant
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[TOP VIEW]
[BOTTOM VIEW]
7.00±0.20
5.08±0.15
#3
4.00±0.15
#2
#2
#1
1.40±0.15
Pin#
0.7±0.12
1.90±0.20
1
2
3
4
4.20
0.1µF
0.80±0.15
#1
[SIDE VIEW]
5.08
#4
1.20
#3
5.00±0.20
#4
Function
1.50
Vcon:VC-TCXO
GND/NC:TCXO
GND
OUTPUT
VDD
To ensure optimal oscillator performance, place a
by-pass capacitor of 0.1μF as close to the part as
possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
Parameter
2.5V
Min.
VDD-5%
5
Supply Voltage Variation (VDD)
Frequency Range
Standard Frequency
3.3V
Max.
Min.
VDD+5%
VDD-5%
52
5
10, 12.8, 16.384, 19.2, 20, 25, 26
-20 ~ 70
-40 ~ 85
Operating Temp. Range
Frequency Stability (Overall, 20 Years)*
Frequency Stability Vs Temp. Range
(Ref. to (FMAX+Fmin)/2)
_
_
±0.14 (-20~+70°C)
±0.28 (-40~+85°C)
Holdover Stability +
_
±0.32
_
_
8
Supply Current (CMOS output)
Supply Current (Clipped Sine Wave)
Output Level (CMOS) Output High (Logic “1”)
Output Low (Logic “0”)
Duty
Output Level (Clipped Sine Wave)
Load (CMOS)
Load (Clipped Sine Wave)
Control Voltage Range (VCTCXO)
Pulling Range (VCTCXO)
Vc Input Impedance (VCTCXO)
Phase Noise @ 10 MHz
Start time
Storage Temp. Range
5
90%VDD
_
ppm
_
±0.14 (-20~+70°C)
±0.28 (-40~+85°C)
ppm
_
_
_
±0.32
ppm
_
45
0.8
_
15pF
10 KΩ // 10pF
0.5
±5.0
100
100 Hz
1 kHz
10 kHz
_
-55
MHz
±4.6
8
5
_
90%VDD
10%VDD
55
45
0.8
V
°C
_
±4.6
_
Unit
Max.
VDD+5%
52
10%VDD
55
_
mA
V
Vp-p
15pF
10 KΩ // 10pF
0.5
±5.0
100
2.5
_
_
-130
-145
-154
5
125
2.5
_
_
V
ppm
kΩ
dBc/Hz
_
-55
5
mSec
125
°C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
* Including calibration @ 25°C, supply voltage VDD±5% , load ±10%, reflow soldering, 20 years aging and frequency stability over temperature.
+ Including 24hours aging , supply voltage VDD±5% and frequency stability over temperature.
Note: not all combination of options are available. Other specifications may be available upon request.
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(12) 07/2022
101
TTETTCJANF-25.000000 价格&库存
很抱歉,暂时无法提供与“TTETTCJANF-25.000000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+272.417631+35.28761
- 10+236.7898510+30.67257
- 25+223.9755525+29.01267
- 50+214.7577550+27.81864
- 100+205.93097100+26.67527
- 300+200.09780300+25.91967
